Topic: %bitrate% with different behavior in 0.9.5 (Read 2593 times) previous topic - next topic
Hi there, I just upgraded to v0.9.5 and switched from ColumnsUI to the new Default User Interface (Simple Playlist + Tabs from the Quick Appearance Setup) and the bitrate shown in the status bar for playing VBR files is working like its description (%bitrate% - Bitrate of the track in kilobits per second (kbps); includes dynamic VBR bitrate display for currently played track.) but the bitrate shown in the Bitrate column is always the static average one.
Is this an intended behavior or a glitch?
Here's my components list:
Core (2007-12-31 15:57:54)
    foobar2000 core 0.9.5
foo_abx.dll (2006-12-16 10:52:46)
    ABX Comparator 1.3.1
foo_ac3.dll (2007-01-24 05:51:40)
    AC3 decoder 0.8
foo_adpcm.dll (2007-01-24 05:51:40)
    ADX decoder 1.6
    BRR decoder and converter 0.7
    GCN DSP decoder 1.3
    Interplay ACM decoder 1.0
    kode's ADPCM decoders 1.2
    OKI-ADPCM decoder 0.14
    RAC decoder 1.0
    XA ADPCM decoder 1.2
foo_albumlist.dll (2007-12-29 12:47:54)
    Album List 4.1
foo_benchmark.dll (2006-08-04 20:56:56)
    Decoding Speed Test 1.0
foo_bitcompare.dll (2006-08-04 20:56:50)
    Binary Comparator 1.1
foo_cdda.dll (2007-12-13 20:38:24)
    CD Audio Decoder 2.1.2
foo_converter.dll (2007-12-29 12:47:36)
    Converter 1.0.2
foo_dsp_std.dll (2007-11-22 19:20:02)
    Standard DSP Array 1.0
foo_dumb.dll (2007-02-28 07:47:28)
    DUMB module decoder 0.9.8.4
foo_fileops.dll (2007-12-29 12:48:10)
    File Operations 2.0
foo_freedb2.dll (2007-08-16 13:27:44)
    freedb Tagger 0.5.2.1
foo_gep.dll (2007-06-26 19:14:00)
    Game Emu Player 1.5
foo_input_matroska.dll (2007-06-11 00:42:24)
    Matroska Plugin 0.9.2.1
foo_input_monkey.dll (2006-08-04 20:57:18)
    Monkey's Audio decoder 2.1.1
foo_input_std.dll (2007-12-29 12:50:00)
    Standard Input Array 1.0
foo_input_tak.dll (2007-11-09 01:29:24)
    TAK Decoder 0.3.4
foo_input_tta.dll (2006-05-01 12:53:16)
    TTA Audio Decoder (unofficial) 2.4.2
foo_lunar2.dll (2007-01-24 06:01:04)
    Lunar 2 PCM decoder 0.5
foo_masstag.dll (2007-10-13 12:17:26)
    Masstagger 1.6
foo_midi.dll (2007-01-24 05:51:40)
    MIDI synthesizer host 1.7
foo_psf.dll (2007-08-18 19:15:44)
    Highly Experimental 2.0.6
foo_rgscan.dll (2007-12-29 12:47:00)
    ReplayGain Scanner 2.0.2
foo_sic.dll (2007-01-08 10:52:52)
    foosic music database 1.0 beta 12
foo_ui_columns.dll (2006-04-29 17:48:00)
    Columns UI 0.1.3 beta 1v5
foo_ui_std.dll (2007-12-29 15:06:28)
    Default User Interface 0.9.5
foo_unpack.dll (2007-12-29 12:46:42)
    RAR reader 1.1
    ZIP/GZIP reader 1.0
foo_unpack_jma.dll (2007-01-24 05:51:40)
    JMA unpacker 1.0
foo_unpack_lha.dll (2007-01-24 05:51:40)
    LHA unpacker 1.2
foo_verifier.dll (2006-08-29 21:09:16)
    File Integrity Verifier 1.0.1
foo_vis_channelusage.dll (2006-03-13 00:24:18)
    Channel Usage Visualisation 1.0
Allegari nihil et allegatum non probare, paria sunt.
Yeah, it is. New default UI does not support dynamic field, or not yet.
Yeah...the new default UI doesn't seem to support dynamic values. I would really like to see the bitrate move .
Any idea if its coming?
Yes indeed, it doesn´t support dynamic fields. I hope, it will support it in a while, but atm there is no way to say if it will or not. Let´s see.
