Post your DAE Quality results 2007-12-29 20:10:14 Reading the forums I've seen people refer to their own private results with DAE quality tool but I haven't seen a single place where someone actually published their results in detail (C2 graphs etc.).So I'd like to know if there actually have been published results for various drives somewhere.If not I encourage people that have results lying around to publish them.I myself have plans to get my hands on some old plextor drives and test those and of course also test the other drives from various manufacturers I have.Edit:Numerous tests have now been published. Be aware that you can't directly compare tests made by different people since different test cds were used.HP DVD Writer 300cLiteOn LTD 163LiteOn Ltr-40125sMSI CR52-A2Plextor PX-40TSiPlextor Px-40tsPlextor Premium (1.03) (don't know exactly what drive this is)Plextor PX-755APlextor PX-708APlextor PX-716APlextor PX-W4824APlextor PX-W5224APlextor 40TS@12XPlextor 40TS@4XSamsung SH-S203NSamsung SH-182DSamsung SH-203P@12XSamsung SH-203P@8XSony DDU-1621Toshiba SD-R5372Yamaha CRW4416S-NB - Does not have accurate stream. Not tested further.Discussion about LiteOn LTD 163, Plextor Px-40ts and LiteOn Ltr-40125s.Discussion on reliability DAEquality testMore discussionDAE quality, What about a thread for drive comparisonDAE Quality, views? - suggestion to make master test cd Last Edit: 2009-02-09 17:29:27 by Jan S.
Post your DAE Quality results Reply #5 – 2008-03-01 16:19:33 Samsung SH-182D Last Edit: 2008-03-01 16:19:52 by exec
Post your DAE Quality results Reply #6 – 2008-03-05 16:31:40 PLEXTOR 40TS - 4 days old from out of box - test at 12XCode: [Select]Errors total Num : 1080777Errors (Loudness) Num : 32449 - Avg : -70.4 dB(A) - Max : -8.3 dB(A)Error Muting Num : 10156 - Avg : 15.8 Samples - Max : 3583 SamplesSkips Num : 49 - Avg : 24.7 Samples - Max : 406 SamplesTotal Test Result : 59.2 points (of 100.0 maximum)SAMSUNG SH-203P - test at 12XCode: [Select]Errors total Num : 689410Errors (Loudness) Num : 21612 - Avg : -69.8 dB(A) - Max : -17.8 dB(A)Error Muting Num : 2880 - Avg : 1.1 Samples - Max : 3 SamplesSkips Num : 0 - Avg : 0.0 Samples - Max : 0 SamplesTotal Test Result : 77.7 points (of 100.0 maximum)Why are these Plextors regarded as one of the best drives?? Last Edit: 2008-03-05 16:40:21 by ell-ess-dee
Post your DAE Quality results Reply #7 – 2008-03-05 21:04:42 Interesting..PLEXTOR 40TS @ 4X Last Edit: 2008-03-05 21:05:52 by ell-ess-dee
Post your DAE Quality results Reply #8 – 2008-03-05 21:11:36 [quote author=ell-ess-dee link=msg=551209 date=1204751082]So the Plextor gets better and the Sammy gets worse [/quote]This is not unusual. Plextor drives are known to do better at lower speeds, but this isn't true for all drives.I know that DAE Quality can't report on the C2 accuracy of some drives, but it would still be nice to see results when it can.
Post your DAE Quality results Reply #9 – 2008-03-06 11:44:26 [quote author=ell-ess-dee link=msg=551148 date=1204734700]Why are these Plextors regarded as one of the best drives??[/quote]Maybe because the "real" ones can overread? Dunno...Well, I finally got the c2extract program working now (needed the Nero ASPI driver) and it is a bit strange: No problems with the Toshiba drive (results are essentially the same as when ripping in EAC/burst). Ripping with c2extract and my Plextor drives also makes no problems. But when analysing the results with analyse.exe, it takes nearly 10 hours (!!) (in comparison: analysing the Toshiba's results took aprox. 5 minutes). The generated graphs then show something you could call the worst case. I don't think that they are really representative.OK, c2extract seems to always rip with max. speed and Plextor drives usually perform better when slowing down. Anyway, the results should be comparable to EAC rips with max. speed, shouldn't they?
Post your DAE Quality results Reply #10 – 2008-04-06 16:30:46 Finally I got my hands on a 716A. So here's the test:Plextor PX-716A
Post your DAE Quality results Reply #11 – 2008-04-06 20:41:50 Very cool idea - but unfortunately flawed as we're all using different (albeit slight), evaluation CDs.Might someone take it upon themselves to create a 'Master CD' that we can all share back and forth? Snail-mail is slow, but gets the job done, and sending one CD around is dirt-cheap.At least this would give us a true reference.Andrew D.www.cdnav.com
Post your DAE Quality results Reply #12 – 2008-04-07 17:17:54 Quote from: digital on 2008-04-06 20:41:50Very cool idea - but unfortunately flawed as we're all using different (albeit slight), evaluation CDs.Might someone take it upon themselves to create a 'Master CD' that we can all share back and forth? Snail-mail is slow, but gets the job done, and sending one CD around is dirt-cheap.At least this would give us a true reference.Yes, your're right. Only the results done by the same person/with the same test disc can be compared. I've tried to test some of the "praised" Plextor drives just for personal interest, but thought that it would be interesting to share the results.However, a while ago the idea of creating a master CD and sharing it came up, but unfortunately this idea was dropped (maybe because only a few pepole agreed to participate?). You can find the corresponding thread here.
Post your DAE Quality results Reply #15 – 2008-08-29 21:43:43 Updated with the tests I currently know.
Post your DAE Quality results Reply #17 – 2009-01-30 18:52:04 And here is a graph of all the DAE results of my Plextor drives (only the test results of the EAC rips included):http://www.hydrogenaudio.org/forums/index....ost&id=4861 Last Edit: 2009-01-30 18:53:21 by exec
