Topic: 4.1 encoding (Read 2472 times) previous topic - next topic
4.1 encoding
I am trying to encode a 4.1 96KHz 24bit WAV file (with WaveFormatExTensible LRLfeLsRs) to FLAC 1.2.0a using Foobar 0.9.4.4 (command line: -s -8 - -o %d --channel-map=none). However this fails giving the following error:
Error flushing file (Object not found) : file://C:\TEMP\track-01.flac
Other 5.1 24bit 96KHz/48Khz files work fine.
I have tried:
- Using flac 1.2.1b. This does result in a flac file. However this one is not playable. Playback (both with Foobar 0.9.4.4 and 0.9.5b8[) gives errors like reporting a way to long file length (25 minutes instead of 1), seek errors and
'Decoding failure at 1:11.765 (Unsupported format or corrupted file):
- Using Foobar 0.9.4.5b8 in stead of 0.9.4.4 to encode. Fails.
- Converting the 4.1 WAV files to 5.1 WAV files (WaveFormatExTensible LRCLfeLsRs) and then convert to FLAC 1.2.0a: Works!
- Using WavPack 4.41: Works!
So I have two questions:
  • Is there something wrong with 4.1 encoding with flac (all versions)?
  • Why is 5.1 encoding broken with flac 1.2.1b, even when decoding using libflac 1.2.x as found in foobar 0.9.5b8?
4.1 encoding
if "flac -t" works on your flac file, the problem is probably in the player.  with that channel order you should not need --channel-map=none, but if you do (i.e. channel mask is not 0x0037 or 0x0607), apps are not required to support non-standard channel orderings.  to know how to map channels they have to be able to parse the WAVEFORMATEXTENSIBLE_CHANNEL_MASK tag.
