Topic: Burrrn question (Read 5087 times) previous topic - next topic
Burrrn question
i created a cue sheet in foobar, the cue sheet does not have any gaps between the songs. Should burrrn be able to burn the cue sheet without any problems or will it not work because i dont have the gaps? it gave me an error when i tried to burn (the error came after burrrn had processed all the songs).
Burrrn question
As far as I know, it should not be a problem. Some of my first CDs were just WAVs without beginning or end silence, and I forgot to add gaps in the CUE, and it Burrrned fine... just sucked playing in the car since the car starts playing a song slightly after the track starts.
OP can't edit initial post when a solution is determined  :'-(
Burrrn question
oh ok...i'll try once more and see...if it doesnt work i'll try to paste the cue sheet and someone could see if there's something wrong with it
Burrrn question
The only instance where a cue sheet adds audio data is when there's a pregap or postgap statement in which case the added data will only be silence.  Other than this, index statements do nothing more than mark off time; they do not remove audio data and they do not add audio data.
EDIT: All I'm really trying to say here (in a contorted, roundabout and even nonsensical way) is that a lack of non-01 indices in a cue sheet will never cause an error when burning, provided the sheet is still properly formatted.
Burrrn question
the error i get in burrrn is:
ERROR: Start position 119514528 exceeds available data of file "C:/DOCUME~1/user/LOCALS~1/Temp/burrrn_temp/07_Moonblood - Under The Cold Fullmoon - 07 - Sin Is Here.wav".
ERROR: C:\Program Files\Burrrn\burrrn.toc:30: Cannot determine length of track data specification.
here's cue sheet
REM GENRE Black Metal
PERFORMER "Moonblood"
TITLE "Under The Cold Fullmoon"
FILE "Moonblood - Under The Cold Fullmoon - 01 - Under The Cold Fullmoon.mp3" WAVE
  TRACK 01 AUDIO
    TITLE "Under The Cold Fullmoon "
    INDEX 01 00:00:00
FILE "Moonblood - Under The Cold Fullmoon - 02 - A Hiker In The Darkness.mp3" WAVE
  TRACK 02 AUDIO
    TITLE "A Hiker In The Darkness"
    INDEX 01 07:09:21
FILE "Moonblood - Under The Cold Fullmoon - 03 - Blood On The Moon.mp3" WAVE
  TRACK 03 AUDIO
    TITLE "Blood On The Moon"
    INDEX 01 15:59:28
FILE "Moonblood - Under The Cold Fullmoon - 04 - A Good Day To Die.mp3" WAVE
  TRACK 04 AUDIO
    TITLE "A Good Day To Die"
    INDEX 01 22:29:30
FILE "Moonblood - Under The Cold Fullmoon - 05 - On Cold Wings.mp3" WAVE
  TRACK 05 AUDIO
    TITLE "On Cold Wings"
    INDEX 01 28:55:18
FILE "Moonblood - Under The Cold Fullmoon - 06 - Raise The Dead (Bathory Cover).mp3" WAVE
  TRACK 06 AUDIO
    TITLE "Raise The Dead (Bathory Cover)"
    INDEX 01 36:55:45
FILE "Moonblood - Under The Cold Fullmoon - 07 - Sin Is Here.mp3" WAVE
  TRACK 07 AUDIO
    TITLE "Sin Is Here"
    INDEX 01 45:10:06
Burrrn question
This CUE sheet is not valid. How exactly did it get created?
The times assume a single file image, though you're telling it to use a new file for every track.  Every INDEX 01 should have 00:00:00 for the specified time.
Burrrn question
i created the cue sheet in foobar with the cue sheet plugin..is there another way to creater a proper cue sheet in foobar?
Burrrn question
You need to update your Foobar2000 or cuesheet plugin as I just tested this with Foobar2000 0.9.5 beta 6 and cuesheet 0.4.6 and the Index's are created correctly.
PERFORMER "Led Zeppelin"
TITLE "Led Zeppelin I"
REM REPLAYGAIN_ALBUM_GAIN -6.15 dB
REM REPLAYGAIN_ALBUM_PEAK 1.000000
FILE "01. Good Times, Bad Times.wv" WAVE
  TRACK 01 AUDIO
    TITLE "Good Times, Bad Times"
    REM REPLAYGAIN_TRACK_GAIN -6.52 dB
    REM REPLAYGAIN_TRACK_PEAK 0.999511
    INDEX 01 00:00:00
FILE "02. Babe, I'm Gonna Leave You.wv" WAVE
  TRACK 02 AUDIO
    TITLE "Babe, I'm Gonna Leave You"
    REM REPLAYGAIN_TRACK_GAIN -5.12 dB
    REM REPLAYGAIN_TRACK_PEAK 0.999267
    INDEX 01 00:00:00
FILE "03. You Shook Me.wv" WAVE
  TRACK 03 AUDIO
    TITLE "You Shook Me"
    REM REPLAYGAIN_TRACK_GAIN -4.78 dB
    REM REPLAYGAIN_TRACK_PEAK 0.983886
    INDEX 01 00:00:00
FILE "04. Dazed And Confused.wv" WAVE
  TRACK 04 AUDIO
    TITLE "Dazed And Confused"
    REM REPLAYGAIN_TRACK_GAIN -6.79 dB
    REM REPLAYGAIN_TRACK_PEAK 0.999450
    INDEX 01 00:00:00
FILE "05. Your Time Is Gonna Come.wv" WAVE
  TRACK 05 AUDIO
    TITLE "Your Time Is Gonna Come"
    REM REPLAYGAIN_TRACK_GAIN -4.18 dB
    REM REPLAYGAIN_TRACK_PEAK 0.818634
    INDEX 01 00:00:00
FILE "06. Black Mountain Side.wv" WAVE
  TRACK 06 AUDIO
    TITLE "Black Mountain Side"
    REM REPLAYGAIN_TRACK_GAIN +0.39 dB
    REM REPLAYGAIN_TRACK_PEAK 0.531433
    INDEX 01 00:00:00
FILE "07. Communication Breakdown.wv" WAVE
  TRACK 07 AUDIO
    TITLE "Communication Breakdown"
    REM REPLAYGAIN_TRACK_GAIN -7.78 dB
    REM REPLAYGAIN_TRACK_PEAK 0.999969
    INDEX 01 00:00:00
FILE "08. I Can't Quit You Baby.wv" WAVE
  TRACK 08 AUDIO
    TITLE "I Can't Quit You Baby"
    REM REPLAYGAIN_TRACK_GAIN -5.15 dB
    REM REPLAYGAIN_TRACK_PEAK 1.000000
    INDEX 01 00:00:00
FILE "09. How Many More Times.wv" WAVE
  TRACK 09 AUDIO
    TITLE "How Many More Times"
    REM REPLAYGAIN_TRACK_GAIN -6.50 dB
    REM REPLAYGAIN_TRACK_PEAK 0.996734
    INDEX 01 00:00:00
daefeatures.co.uk
Burrrn question
@ ArtmustHurt:
Yeah that is the wrong Cue sheet creator, however one of them I had to pick through to find the one I used before. I still don't know where the one I had went to...
@ Evereaux:
Thanks for finding that one.
