Topic: foo_vis_shpeck (Read 620344 times) previous topic - next topic
foo_vis_shpeck
Reply #50
When I open the configuration window of Milkdrop 2 in Winamp, my graphical card is recognised and the visualisation works normal.
When I open the configuration window of Milkdrop 2 in Foobar2000, my graphical card is missing! When I start the visualisation the screen remains black.
Any idea what could be the problem?
EDIT: On my XP-system with a Geforce 7650GS everything works correct, this problem occurs on my Vista-laptop with a ATI X1150
After restarting the computer, the configuration window in foobar2000 remains unchanged (not recognising graphical card) but the visualisation itself works perfect!
foo_vis_shpeck
Reply #51
wow thanks for this! i was waiting for something like this for my home theater pc
foo_vis_shpeck
Reply #52
Thanks for this plugin, i have it and milkdrop2 running on a 40inch TV and i just lost 1 hour because i couldn't look away .
foo_vis_shpeck
Reply #53
All right, the almighty new version 0.1.0 is finally here. Although many parts have been rewritten, it wouldn't have taken me so long weren't there so many little incompatibilities and minor glitches I tried to fix before this release. Anyway, the changes:
  * A ZIPPED VERSION OF TEH DLL IS NOW AVAILABLE FOR TEH DOWNLOAD!!!!!!11oneoneelevencos(0)
  * Each plugin has now its own menu item, so there is no need to choose the "active one" in the preferences anymore. (A side effect: clicking "Refresh list" is needed after updates, it is no more done automatically.)
  * Plugins can now be simply changed, without manual stop-start cycle.
  * Plugins running in an embedded window now have a toolbar with next/prev/random/fullscreen/menu buttons to send them commands. It can be hidden in preferences or using popup menu.
  * Plugins running in embedded window get keyboard focus correctly and can be controlled.
  * Title is correctly reset when playback is stopped.
  * And yes, btw, it works in a Columns UI panel now too.
A few acompanying notes:
  The standard ("old") plugins work as they did, i.e. creating their own window or running in fullscreen.
  The embedded window ("new") plugins run in a CUI panel, or in an external window if panel is not available.
  Only one instance of the panel is allowed. Current version of CUI allows you to create more instances during the "Live editing mode", but it's only a temporary bug.
  Plugins embeddable in a panel which I am aware of (and which I have tested) are Milkdrop (both 1 & 2) and AVS. Actually, the later is supposed to be run only that way. For MilkDrops, you have to check the "Integrate with Winamp (skin)" in their configuration.
  The embedded window toolbar buttons don't work for MilkDrop 1.
  One plugin can be selected to be run in the panel after start automatically - click on the caption/title and use the popup menu.
  If you like the old Milkdrop 1.04 like me (I do because it doesn't hang the whole system for a second, as the new version does during D3D de/init and screen mode switching, and also eats just a few percent CPU on my PC), you are tired of the "This plugin needs some music." and feel like a 1337 h4x0r, change the byte at vis_milk.dll:0002A12B from 74h to EBh.
Downloads for Shpeck version 0.1.0:
<obsolete links removed, see the first post in this thread for information about the latest version>
Your feedback is appreciated.
foo_vis_shpeck
Reply #54
That's great news -thanks for your efforts on this awesome component - that was just what my foobar-config was missing -looks great!
In ordner not to forget it, I have a feature proposal: Is it possible to make the toolbar-functions (next preset, fullscreen etc) accessible via foobar actions (if this is the right term) so they could be assigned to shortcuts, buttons etc? That would be extremely helpful!
Back to the actual version:
-I encountered 2 problems:
Right now I don't seem to get milkdrop2 to run in a panel. (AVS and milkdrop 1 work fine) The panel only displays the toolbar and "[SPHECK]". When I select a plugin for autostart it always starts in a seperate window an the panel stays black. Is it supposed to be that way?
When exiting with AVS active in a panel or trying to change the visuals spheck keeps crashing:
(hope its ok to post that much code?)
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 01C44270h
Access violation, operation: read, address: 02547D69h
Call path:
entry=>user_interface::shutdown=>destroy panel=>destroy child panel
Code bytes (01C44270h):
01C44230h:  52 C6 01 E9 BD 00 00 00 6A 05 57 FF 15 20 52 C6
01C44240h:  01 85 C0 74 0D 6A 00 6A 00 6A 10 50 FF 15 08 52
01C44250h:  C6 01 6A EB 57 FF 15 D0 51 C6 01 8B D8 85 DB 0F
01C44260h:  84 90 00 00 00 6A 00 6A EB 57 FF 15 E8 51 C6 01
01C44270h:  80 7B 51 00 74 0A 8B F3 E8 A3 FE FF FF 8B 75 0C
01C44280h:  83 7B 1C 01 75 6F 53 E8 C6 EC 00 00 83 C4 04 EB
01C44290h:  64 83 7D 10 04 74 5E 83 7D 10 03 74 58 83 7D 10
01C442A0h:  01 74 52 85 DB 74 4E 8D 53 08 52 57 FF 15 B4 51
Stack (0012F0C8h):
0012F0A8h:  00000000 00000000 B1728258 804E6207
0012F0B8h:  B1728284 7FFDF700 00000000 00000000
0012F0C8h:  0012F194 01C441E0 00000000 77D188DA
0012F0D8h:  00220B3C FDDE05A0 00180B6A 0012F1B0
0012F0E8h:  019960FC FFFFFFFF 77D40467 00000210
0012F0F8h:  019743A7 00220B3C 00000210 00000002
0012F108h:  00180B6A 01C441E0 01974230 0012F158
0012F118h:  00000000 0012F124 00000018 00050004
0012F128h:  00180B6A 0012F158 77D18734 00180B6A
0012F138h:  00000002 00000000 00000000 01C441E0
0012F148h:  DCBAABCD 00000000 0012F194 01C441E0
0012F158h:  0012F1C0 77D18816 01C441E0 00180B6A
0012F168h:  00000002 00000000 00000000 00000000
0012F178h:  00180B6A 00000000 00000014 00000001
0012F188h:  00000000 00000000 00000010 00000000
0012F198h:  0012F204 00000000 00000000 00000000
0012F1A8h:  0012F174 0012ECEC 0012F204 77D40467
0012F1B8h:  77D18830 00000000 0012F214 77D1B4C0
0012F1C8h:  00000000 01C441E0 00180B6A 00000002
0012F1D8h:  00000000 00000000 007F0D1C 00000001
Registers:
EAX: 02547D18, EBX: 02547D18, ECX: 0012F078, EDX: 7C91EB94
ESI: 00000002, EDI: 00180B6A, EBP: 0012F12C, ESP: 0012F0C8
Crash location: "foo_vis_shpeck", loaded at 01C40000h - 01C80000h
Loaded modules:
foobar2000   loaded at 00400000h - 00506000h
ntdll loaded at 7C910000h - 7C9C7000h
kernel32 loaded at 7C800000h - 7C907000h
COMCTL32 loaded at 773A0000h - 774A3000h
msvcrt   loaded at 77BE0000h - 77C38000h
ADVAPI32 loaded at 77DA0000h - 77E4A000h
RPCRT4   loaded at 77E50000h - 77EE1000h
GDI32 loaded at 77EF0000h - 77F37000h
USER32   loaded at 77D10000h - 77DA0000h
SHLWAPI   loaded at 77F40000h - 77FB6000h
SHELL32   loaded at 7C9D0000h - 7D1EF000h
ole32 loaded at 774B0000h - 775EC000h
shared   loaded at 10000000h - 1002D000h
COMDLG32 loaded at 76350000h - 7639A000h
MSCTF loaded at 746A0000h - 746EC000h
UnlockerHook loaded at 003E0000h - 003E4000h
nview loaded at 00A30000h - 00BA0000h
PSAPI loaded at 76BB0000h - 76BBB000h
OLEAUT32 loaded at 770F0000h - 7717C000h
WINMM loaded at 76AF0000h - 76B1E000h
VERSION   loaded at 77BD0000h - 77BD8000h
NTMARTA   loaded at 77660000h - 77681000h
WLDAP32   loaded at 76F20000h - 76F4D000h
SAMLIB   loaded at 71B70000h - 71B83000h
foo_albumlist loaded at 00CD0000h - 00D25000h
foo_cdda loaded at 00D50000h - 00D86000h
foo_channel_mixer loaded at 00DB0000h - 00DEB000h
foo_converter loaded at 00E00000h - 00E73000h
foo_custominfo   loaded at 00EA0000h - 00F25000h
foo_cwb_hooks loaded at 00F50000h - 00F9D000h
foo_discogs   loaded at 00FC0000h - 01061000h
gdiplus   loaded at 4EBA0000h - 4ED43000h
WS2_32   loaded at 71A10000h - 71A27000h
WS2HELP   loaded at 71A00000h - 71A08000h
foo_dsp_std   loaded at 010D0000h - 01117000h
foo_fileops   loaded at 01140000h - 01187000h
foo_freedb2   loaded at 011B0000h - 011F1000h
foo_input_std loaded at 01220000h - 01342000h
foo_navigator loaded at 01370000h - 013A1000h
foo_playback_custom   loaded at 013D0000h - 01415000h
WINSPOOL loaded at 72F70000h - 72F96000h
foo_rgscan   loaded at 01460000h - 014A7000h
foo_run   loaded at 014D0000h - 014FB000h
foo_uie_albumart loaded at 01520000h - 0155D000h
foo_uie_albumlist loaded at 01580000h - 015C3000h
foo_uie_console   loaded at 015F0000h - 0160B000h
foo_uie_explorer loaded at 01630000h - 0166C000h
UxTheme   loaded at 5B0F0000h - 5B128000h
foo_uie_peakmeter loaded at 01690000h - 016C3000h
foo_uie_quicksearch   loaded at 016F0000h - 01736000h
foo_uie_tabs loaded at 01760000h - 0178A000h
foo_uie_typefind loaded at 017B0000h - 017E0000h
foo_uie_vis_channel_spectrum loaded at 01800000h - 0182B000h
MSIMG32   loaded at 76320000h - 76325000h
foo_uie_vis_egoh loaded at 01850000h - 0186D000h
foo_uie_vis_projectm loaded at 01880000h - 018CC000h
OPENGL32 loaded at 5F0D0000h - 5F19C000h
GLU32 loaded at 68FC0000h - 68FE0000h
DDRAW loaded at 736D0000h - 73719000h
DCIMAN32 loaded at 73B30000h - 73B36000h
MSVCR80   loaded at 78130000h - 781CB000h
foo_ui_columns   loaded at 018F0000h - 019DB000h
foo_ui_panels loaded at 01A00000h - 01AE9000h
IMM32 loaded at 76330000h - 7634D000h
foo_ui_std   loaded at 01B10000h - 01BC4000h
foo_unpack   loaded at 01BF0000h - 01C1E000h
foo_vis_shpeck   loaded at 01C40000h - 01C80000h
MSACM32   loaded at 77BB0000h - 77BC5000h
CLBCATQ   loaded at 76F90000h - 7700F000h
COMRes   loaded at 77010000h - 770E3000h
SSSensor loaded at 06810000h - 06825000h
DSOUND   loaded at 73E70000h - 73ECC000h
wdmaud   loaded at 72C90000h - 72C99000h
WINTRUST loaded at 76BF0000h - 76C1E000h
CRYPT32   loaded at 77A50000h - 77AE5000h
MSASN1   loaded at 77AF0000h - 77B02000h
IMAGEHLP loaded at 76C50000h - 76C78000h
msacm32   loaded at 72C80000h - 72C88000h
midimap   loaded at 77BA0000h - 77BA7000h
KsUser   loaded at 73E40000h - 73E44000h
Amhooker loaded at 097D0000h - 097D9000h
nvwddi   loaded at 0D1D0000h - 0D1E5000h
DBGHELP   loaded at 59DD0000h - 59E71000h
Stack dump analysis:
Address: 01C441E0h, location: "foo_vis_shpeck", loaded at 01C40000h - 01C80000h
Address: 77D188DAh, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "GetWindowLongW" (+00000034h)
Address: 019960FCh, location: "foo_ui_columns", loaded at 018F0000h - 019DB000h
Address: 77D40467h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DeregisterShellHookWindow" (+000001CFh)
Address: 019743A7h, location: "foo_ui_columns", loaded at 018F0000h - 019DB000h
Address: 01974230h, location: "foo_ui_columns", loaded at 018F0000h - 019DB000h
Address: 77D18734h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "GetDC" (+0000006Dh)
Address: 77D18816h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "GetDC" (+0000014Fh)
Address: 77D18830h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "GetDC" (+00000169h)
Address: 77D1B4C0h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DefWindowProcW" (+00000184h)
Address: 01C75114h, location: "foo_vis_shpeck", loaded at 01C40000h - 01C80000h
Address: 77D1B4D0h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DefWindowProcW" (+00000194h)
Address: 77D1B50Ch, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DefWindowProcW" (+000001D0h)
Address: 7C91EAE3h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "KiUserCallbackDispatcher" (+00000013h)
Address: 77D1B473h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DefWindowProcW" (+00000137h)
Address: 77D1DAF6h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DestroyWindow" (+0000000Ch)
Address: 01C48857h, location: "foo_vis_shpeck", loaded at 01C40000h - 01C80000h
Address: 0190AE11h, location: "foo_ui_columns", loaded at 018F0000h - 019DB000h
Address: 0198F098h, location: "foo_ui_columns", loaded at 018F0000h - 019DB000h
Address: 0190C587h, location: "foo_ui_columns", loaded at 018F0000h - 019DB000h
Address: 77D18B26h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "GetWindowThreadProcessId" (+000000A6h)
Address: 77D188D1h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "GetWindowLongW" (+0000002Bh)
Address: 10002F40h, location: "shared", loaded at 10000000h - 1002D000h
Symbol: "uCallStackTracker::uCallStackTracker" (+00000000h)
Address: 01944D31h, location: "foo_ui_columns", loaded at 018F0000h - 019DB000h
Address: 01772235h, location: "foo_uie_tabs", loaded at 01760000h - 0178A000h
Address: 01775739h, location: "foo_uie_tabs", loaded at 01760000h - 0178A000h
Address: 01772A9Ah, location: "foo_uie_tabs", loaded at 01760000h - 0178A000h
Address: 01775830h, location: "foo_uie_tabs", loaded at 01760000h - 0178A000h
Address: 003E123Bh, location: "UnlockerHook", loaded at 003E0000h - 003E4000h
Address: 019BE0A0h, location: "foo_ui_columns", loaded at 018F0000h - 019DB000h
Address: 0192C2B2h, location: "foo_ui_columns", loaded at 018F0000h - 019DB000h
Address: 019A1908h, location: "foo_ui_columns", loaded at 018F0000h - 019DB000h
Address: 019BE0CCh, location: "foo_ui_columns", loaded at 018F0000h - 019DB000h
Address: 019A18F0h, location: "foo_ui_columns", loaded at 018F0000h - 019DB000h
Address: 01992F08h, location: "foo_ui_columns", loaded at 018F0000h - 019DB000h
Address: 0192CC5Bh, location: "foo_ui_columns", loaded at 018F0000h - 019DB000h
Address: 01997640h, location: "foo_ui_columns", loaded at 018F0000h - 019DB000h
Address: 0197421Dh, location: "foo_ui_columns", loaded at 018F0000h - 019DB000h
Address: 01924C34h, location: "foo_ui_columns", loaded at 018F0000h - 019DB000h
Address: 01924010h, location: "foo_ui_columns", loaded at 018F0000h - 019DB000h
Address: 77420340h, location: "COMCTL32", loaded at 773A0000h - 774A3000h
Symbol: "Ordinal389" (+00004B5Dh)
Address: 774211CEh, location: "COMCTL32", loaded at 773A0000h - 774A3000h
Symbol: "Ordinal389" (+000059EBh)
Address: 00AA1CD0h, location: "nview", loaded at 00A30000h - 00BA0000h
Symbol: "PMLoadPresentation" (+000292D0h)
Address: 77D1EAC1h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "EnableMenuItem" (+00000092h)
Address: 77D1B3F9h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DefWindowProcW" (+000000BDh)
Address: 77D1B393h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DefWindowProcW" (+00000057h)
Address: 77D1B3A7h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DefWindowProcW" (+0000006Bh)
Address: 77D1B3B0h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DefWindowProcW" (+00000074h)
Address: 01C44305h, location: "foo_vis_shpeck", loaded at 01C40000h - 01C80000h
Address: 0043AB33h, location: "foobar2000", loaded at 00400000h - 00506000h
Address: 0043AC26h, location: "foobar2000", loaded at 00400000h - 00506000h
Address: 77D1DAEAh, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DestroyWindow" (+00000000h)
Address: 0192640Eh, location: "foo_ui_columns", loaded at 018F0000h - 019DB000h
Address: 00468050h, location: "foobar2000", loaded at 00400000h - 00506000h
Address: 004AAD6Fh, location: "foobar2000", loaded at 00400000h - 00506000h
Address: 0042CA33h, location: "foobar2000", loaded at 00400000h - 00506000h
Address: 004C1C84h, location: "foobar2000", loaded at 00400000h - 00506000h
Address: 004CFBBCh, location: "foobar2000", loaded at 00400000h - 00506000h
Address: 00400000h, location: "foobar2000", loaded at 00400000h - 00506000h
Address: 004CFBA0h, location: "foobar2000", loaded at 00400000h - 00506000h
Address: 0049FFE4h, location: "foobar2000", loaded at 00400000h - 00506000h
Address: 01000000h, location: "foo_discogs", loaded at 00FC0000h - 01061000h
Symbol: "foobar2000_get_interface" (+000140F0h)
Address: 0049A700h, location: "foobar2000", loaded at 00400000h - 00506000h
Address: 0049E36Bh, location: "foobar2000", loaded at 00400000h - 00506000h
Address: 004C7068h, location: "foobar2000", loaded at 00400000h - 00506000h
Address: 10002F27h, location: "shared", loaded at 10000000h - 1002D000h
Symbol: "uPrintCrashInfo_SetDumpPath" (+000000A7h)
Address: 004B4204h, location: "foobar2000", loaded at 00400000h - 00506000h
Address: 0042CBBFh, location: "foobar2000", loaded at 00400000h - 00506000h
Address: 0049B807h, location: "foobar2000", loaded at 00400000h - 00506000h
Address: 004EB5B8h, location: "foobar2000", loaded at 00400000h - 00506000h
Address: 0049C5E1h, location: "foobar2000", loaded at 00400000h - 00506000h
Address: 00497089h, location: "foobar2000", loaded at 00400000h - 00506000h
Address: 00497083h, location: "foobar2000", loaded at 00400000h - 00506000h
Address: 004B9FACh, location: "foobar2000", loaded at 00400000h - 00506000h
Address: 004B87D0h, location: "foobar2000", loaded at 00400000h - 00506000h
Address: 004CFC10h, location: "foobar2000", loaded at 00400000h - 00506000h
Address: 004B46A7h, location: "foobar2000", loaded at 00400000h - 00506000h
Address: 0049A4B6h, location: "foobar2000", loaded at 00400000h - 00506000h
Address: 00ECCF78h, location: "foo_custominfo", loaded at 00EA0000h - 00F25000h
Address: 7C816FD7h, location: "kernel32", loaded at 7C800000h - 7C907000h
Symbol: "RegisterWaitForInputIdle" (+00000049h)
Address: 7C839A10h, location: "kernel32", loaded at 7C800000h - 7C907000h
Symbol: "ValidateLocale" (+000002B0h)
Address: 7C816FE0h, location: "kernel32", loaded at 7C800000h - 7C907000h
Symbol: "RegisterWaitForInputIdle" (+00000052h)
Address: 0049A51Fh, location: "foobar2000", loaded at 00400000h - 00506000h
Version info:
foobar2000 v0.9.5 beta 4
UNICODE
Windows 5.1
Additional info:
Converter 1.0.2  (foo_converter)
Album Art Panel 0.2.7  (foo_uie_albumart)
Explorer Tree 1.04.6b  (foo_uie_explorer)
File Operations 2.0  (foo_fileops)
ZIP/GZIP reader 1.0  (foo_unpack)
Panels UI 0.13.8 beta [Jun 12 2007 - 12:28:00]  (foo_ui_panels)
Shpeck - Winamp vis plugins wrapper 0.1.0  (foo_vis_shpeck)
projectM visualization (Panel) 0.4 (SSE2)  (foo_uie_vis_projectm)
Album list panel 0.2.3 beta  (foo_uie_albumlist)
Typefind 0.2 beta 2  (foo_uie_typefind)
Run services 0.3.2  (foo_run)
Peakmeter Panel 0.0.4.2 beta  (foo_uie_peakmeter)
Album List 4.1  (foo_albumlist)
RAR reader 1.1  (foo_unpack)
Playback Statistics Custom 1.4.3  (foo_playback_custom)
Tabbed panel modified 0.2.5  (foo_uie_tabs)
Console panel 0.2.1  (foo_uie_console)
Discogs Tagger 1.12  (foo_discogs)
freedb Tagger 0.5.2.1  (foo_freedb2)
ReplayGain Scanner 2.0.2  (foo_rgscan)
cwbowron's title format hooks 1.2.5 [Jun  8 2007 - 08:49:42]  (foo_cwb_hooks)
Channel Mixer 0.9.6.1  (foo_channel_mixer)
Columns UI 0.2.1 alpha 6  (foo_ui_columns)
Quick Search Toolbar 2.8l  (foo_uie_quicksearch)
foobar2000 core 0.9.5 beta 4  (Core)
CD Audio Decoder 2.1.2  (foo_cdda)
foo_custominfo 0.1.2  (foo_custominfo)
Standard DSP Array 1.0  (foo_dsp_std)
Tagger Panel Window 1.0.5 [Jun 12 2007 - 15:14:00]  (foo_cwb_hooks)
Navigator 0.6  (foo_navigator)
Egoh Spectrum analyser (uie) 1.1.2  (foo_uie_vis_egoh)
Channel Spectrum panel 0.10.1  (foo_uie_vis_channel_spectrum)
Default User Interface 0.9.5  (foo_ui_std)
Thanks again for this great component and you hard work!
[!--sizeo:1--][span style=\"font-size:8pt;line-height:100%\"][!--/sizeo--]Moderation:Codeboxed.[/size]
foo_vis_shpeck
Reply #56
Works like a charm. Thanks.
upd: Ow, not so charm. Stopping or starting after other vis was stopped AVS in panel results in crash.
Sharing delusions since 1991.
foo_vis_shpeck
Reply #57
Are they not? Have you actually looked into "Keyboard shortcuts" preferences, "[main]/View/Visualisations" category?
What about "For MilkDrops, you have to check the "Integrate with Winamp (skin)" in their configuration.", have you enabled that?
Error. Fixed in 0.1.1.
(Sure, but you should rather use [?codebox] instead of [?code], which encloses it in a small scrollable window.)
dtto.
Downloads for Shpeck version 0.1.1:
foo_vis_shpeck
Reply #58
Works like a charm here.  Thanks for cranking out a panel version!!
foo_vis_shpeck
Reply #59
great stuff, working perfect for me
foo_vis_shpeck
Reply #60
This has turned out awesome. Best visualization component available for Foobar by far. Thank you. Now my config is almost perfect!(for me anyway)
Any chance of getting that "Autostart plugin" option available to be made as a button? It'd be great to be able to use that functionality without having to use a panel. Thanks for the consideration.
foo_vis_shpeck
Reply #61
Awesome!
Some request : can you somehow remove ( ' ) from your start command? like now it's like this
Shpeck - Start 'MilkDrop 2.0 / MilkDrop 2.0'
and when i tried creating this button to start this command in panel ui(using $button) i have no success. creating button to stop (Shpeck - Stop) work fine.
foo_vis_shpeck
Reply #62
Found it -thanks -I didnt go through the whole list (in the small window) und tried some filter-words like "preset" and others that didnt bring up any results (should have tried "spheck" i guess) -sorry for that
Works too, thanks
I can confirm that  Works great now. -Gonna do some more testing
foo_vis_shpeck
Reply #63
I thought you just put a Shpeck panel somewhere into the layout, set it up, hide the caption and don't touch it anymore. If you want to change temporarily the running one, you can use the View/Visualisations menu. What extra functionality would you get with such a button? Or, considering "without having to use a panel" - is the point to autostart a plugin in an external window?
From the official titleformat_help.html:
' (single quotation mark) -- Inserts specified text bypassing syntax processing; allows special characters such as %,$,[,] to be inserted. In order to insert a quotation mark character, use '' (two single quotation marks).
So, have you tried "Shpeck - Start ''MilkDrop 2.0 / MilkDrop 2.0''"?
foo_vis_shpeck
Reply #64
I have tried nearly every thing i can think of and none of them work. thanks anyway.
Can someone who use panel ui try creating this button Shpeck - Start 'MilkDrop 2.0 / MilkDrop 2.0' (using $button or $button2 command) for me or tell me if it can be done or not? thanks.
foo_vis_shpeck
Reply #65
Weird, seems like the Panels UI titleformating interpreter doesn't support it. I suppose you tried "Shpeck - Start $char(39)MilkDrop 2.0 / MilkDrop 2.0$char(39)" as well then, did you?
(Of course I will change the format if nothing proves useful, that's not a problem, I'm just curious.)
foo_vis_shpeck
Reply #66
Oops.. that work.  with out the (") of course.
For someone don't use panel ui or even column ui like yourself. you are one genius man I have to say..
foo_vis_shpeck
Reply #67
Yes, exactly. Unlike most people I don't care to use Shpeck as a panel. So if that 'Autostart plugin' option where also available to those of us who want to use Shpeck as an external window, it would allow us to quickly and easily launch any visualization of our choosing without having to access the menu toolbar(I personally don't even have one on my build), or have a bunch of seperate buttons or keyboard shortcuts.
foo_vis_shpeck
Reply #68
Great plug-in!!!  I cannot thank you enough, you implemented the one feature bacon was missing, panels support! Thank you!!
foo_vis_shpeck
Reply #69
This is awesome.  Thanks!!
foo_vis_shpeck
Reply #70
just had to say thanks for this.
foo_vis_shpeck
Reply #71
I just wanted to point out in response to a feature request on the first page for track-specific visualizations through a tag.  This should now be possible with PanelsUI as it appears the author has added arguments for selecting the preset. Re: question about the start/stop vis button.  Full disclosure:  I haven't tried it, just theorizing.
Edit:
Oh, kudos, by the way.  Thanks for some much-needed third-party innovation.  This is the only thing bringing me to the boards, currently.
foo_vis_shpeck
Reply #72
Milkdrop2 doenst show up.
i Tryd WINAmp veRSIon 5.12, 5.35 and 5.5
poitinG to COMPLETE INSTALED WINAMP ONLY THE AVs shOWs up in the shpeck list.
sorry for caps, little daughter standing next to me like to push some keys
foo_vis_shpeck
Reply #73
sry o dont understand completly but if youre trying to say that you have to have winamp installed for plugins to show than its not true. i dont have winamp installed at all (i had to install it once to extract milkdrop2 from it). i have milkdrops in my foobar dir and they are correctly shown in spcheck and functional as well.
Moderation:Removed unnecessary full quote of the preceding post.
foo_vis_shpeck
Reply #74
interesting.
i would like to uninstall winamp. what folders exactly are needed?
