foo_vis_shpeck
Reply #47 –
I installed Winamp 5.5 copied the directory. The I uninstalled Winamp.
I now have the problem that the winamp directory doesn't seem to be recognized. I clicked refresh list but no result.
Some one whch has similar problems?
Can somebody help me?
Which directory are you trying to select? It only (related to this) appends "\Plugins\" to the selected directory name and searches for all *.dll files there - no other files nor settings are needed. If you are sure the vis_whatever.dll are there, they might not show up because of other error - possibly other DLL dependencies or something like this.
[quote author=cartman(2vd) link=msg=534899 date=1197314230]ive found maybe a component collision? i use winamp_spam component to send !amp_power command to close foobar through global hotkey in my gui (nvm it just work no need to explain why i need it ;)) and ive installed spcheck just tu check how it work... now when i hit the hotkey i sometime recive this msg in console:
[Shpeck] Unsupported WM_COMMAND 40001.
which is command that should turn winamp off. Now it looks like spheck take control of winamp sends over foo_winamp_spam... strange think is that sometime command is send to winamp_spam blank window and sometime to spheck blank window (i think its just decided by height of hwnd od which ever window with same classid is found first)...
is there any way to somehow resolve this? for now i easily solved it by removing spheck from my components but if youve ever reach panels/uie state id like to test it again.[/quote]
It is not possible to run two "winamp emulators" at once, because they both need to register a window class named "Winamp v1.x". I had to implement a large part of Winamp API to work with the vis plugins anyway, but didn't included the quit command, just because I didn't like it, but it will be there in upcoming version.
[quote author=cartman(2vd) link=msg=534899 date=1197314230]ps:
ive recieved this msg also:
[Shpeck] Unsupported WM_WA_IPC 3033 (param = 0)
which isnt correct ipc call accordin to winamp sdk but it apears only with this component[/quote]
Welcome to the world of undocumented functions! It's not the first one, but it will be supported in the next release.
When I open the configuration window of Milkdrop 2 in Winamp, my graphical card is recognised and the visualisation works normal.
When I open the configuration window of Milkdrop 2 in Foobar2000, my graphical card is missing! When I start the visualisation the screen remains black.
Any idea what could be the problem?
EDIT: On my XP-system with a Geforce 7650GS everything works correct, this problem occurs on my Vista-laptop with a ATI X1150
This might be related to the undocumented call #3033 above, but I would be surprised if it was. Are there any Shpeck messages in the fb2k console?
Anyway, the big changes are coming soon, stay tuned.
