Topic: Dedicating a playlist window to a particular playlist (Read 2845 times) previous topic - next topic
I have single column playlist and columns ui playlist both open at the same time in my foobar.  how do i make single column playlist window dedicated so it doesnt switch its view to the same as columns ui?
I want the single playlist to be open to my playback queue viewer playlist.
It's not possible.
You can always use foo_uie_queuemanager to view your queue.
elevatorladylevitateme
It's not possible.
thanks Ill check it out.
Another question, can I output the queue tracks so to a set of headphones so I can mix seperate from the room?  This would require two outputs, one for headphones that cue the track and one for the speakers (dj'ing).  I have a ac97 onboard and an audigy 2 zs in a pci slot.
Is there a way to do this in foobar?
edit:
thanks that queue manager is great btw.
