Topic: [0.9.5 Beta 5] Problem with hot key for Random (Read 2070 times) previous topic - next topic
Although i quite like the new beta, i have a problem with the hot key for the random function. Not that it doesn't work, it works. It's just that if you do ctrl+f and type in for instance rawhide, it changes song to a random song and doesn't put in the letter r in the box.
BTW i'm on xp, and global option is off
From release notes:
Keyboard shortcuts
In order to minimize potential interference with typing in the new Default User Interface, existing single-letter shortcuts without Alt or Control modifier keys are removed on the first run after installing 0.9.5. Manually re-adding these shortcuts, while possible, is not recommended due to the issues stated above.
http://foobar2000.org/releasenotes-095/releasenotes.html
From release notes:
Keyboard shortcuts
Then that is the problem, it wasn't removed at first run. It was there before installation of this beta (i was running 0.9.4.5) and didn't add it...
So the problem is solved. Thanks.
