Topic: EAC CRCs using Daemon Tools (Read 2635 times) previous topic - next topic
I ripped some albums with EAC and Accuraterip. Generally I was getting good results from Accuraterip.
For some reason I then decided to check the cue/wav image by loading it into Daemon Tools and running a test and copy image. I have checked a few albums and the results are not consistent.
Here is the log from one album
Exact Audio Copy V0.99 prebeta 1 from 25. May 2007
EAC extraction logfile from 9. November 2007, 6:13
Genesis / Foxtrot (Remastered)
Used drive  : MF3770R ALT842P   Adapter: 2  ID: 0
Read mode               : Secure
Utilize accurate stream : Yes
Defeat audio cache      : Yes
Make use of C2 pointers : No
Read offset correction                      : 0
Overread into Lead-In and Lead-Out          : Yes
Fill up missing offset samples with silence : No
Delete leading and trailing silent blocks   : No
Used interface                              : Installed external ASPI interface
Used output format : Internal WAV Routines
Sample format      : 44.100 Hz; 16 Bit; Stereo
TOC of the extracted CD
     Track |   Start  |  Length  | Start sector | End sector
        1  |  0:00.00 |  7:24.05 |         0    |    33304
        2  |  7:24.05 |  4:48.15 |     33305    |    54919
        3  | 12:12.20 |  8:38.10 |     54920    |    93779
        4  | 20:50.30 |  5:47.45 |     93780    |   119849
        5  | 26:38.00 |  1:43.62 |    119850    |   127636
        6  | 28:21.62 | 22:58.13 |    127637    |   230999
Range status and errors
Selected range
     Filename C:\Documents and Settings\Gordon Avon\My Documents\My Music\Genesis - Foxtrot (Remastered).wav
     Peak level 0.0 %
     Range quality 97.0 %
     Test CRC 76F34DE3
     Copy CRC C6951FD4
     Copy OK
AccurateRip summary
Track  1  not ripped accurately (confidence 10)  [484D2849], but should be [E2D0B14F]
Track  2  not ripped accurately (confidence 10)  [757D0A08], but should be [75007B7C]
Track  3  not ripped accurately (confidence 10)  [02CEEC8E], but should be [BAD5335E]
Track  4  not ripped accurately (confidence 10)  [D3EC4678], but should be [974F7D44]
Track  5  not ripped accurately (confidence 11)  [DFE8278B], but should be [B8D79297]
Track  6  not ripped accurately (confidence 10)  [6A288CC4], but should be [4448B846]
Not all tracks ripped accurately
End of status report
From the original rip the CRC of 76F34DE3 is correct.
Why does the test result give me this correct result and then the actual copy gives me something else and then tells me the tracks are not ripped with confidence. All was fine with the original rip.
You're still using 0.99pb1 and probably suffering from one of the documented bugs, though I am reasonably certain that the AccurateRip results are really coming from the test rip and not the copy rip.  If the CRCs generated by AR are the same for the disc you ripped then perhaps there's another not-yet-identified issue at stake.
PS: It's kinda pointless using secure mode while ripping from a virtual drive.
That would not be a problem with a virtual drive, since they do not suffer from a unreliable optical media.
I've seen virtual drives give different results, but that is beside the point [the copy rip literally failed for some reason (peak level of 0%); in fact, you were the dude that discovered the specific bug that may have caused this ].
Still, there are a few reasons why he may still be comparing apples to oranges even though he gets a match for the CRC 76F34DE3.  Regardless, he should not be using V0.99pb1.
Goodness me. I had no idea there was a more recent EAC beta. Will install it tonight and see what happens.
BTW other than not using Secure ripping on a virtual drive are there any other drive settings I should change (I did change the offset to 0).
