Topic: Discussion of "Default UI Gallery" (Read 283193 times) previous topic - next topic
Re: Discussion of "Default UI Gallery"
Reply #650
Amazing ! Thanks Coreda for the link.
Unfortunately I don't see any folder support for JS Smooth Playlist Manager ?
Reply #651
Can't recall which features it has off-hand, it's fairly basic. What do you mean by playlist folders btw?
Reply #652
Folders containing playlists ? A way to group playlists.
Reply #653
I was just really satisfied with the program and decided to share my theme  :)
Screenshot of 1080p wide display, the theme file (orangin.fth) is included.
You can simply load it as is, doesn't use any other dependency (only the tray icon is linked to different foobar2000 program files ico).
Screenshot is from v1.3.14 but works with v1.3.16 as well.
Cheers!
Reply #655
I'm using SimPlaylist
I can't remember anymore if this is one of the predefined Group setting, or a modified template - anyway here a screenshot of the Group settings:
.halverhahn
Reply #658
It's a second Biography Panel switch by Album Cover without last.fm infos...
Reply #660
Hi - what are the spectrum and VU meters that you are using here?
https://hydrogenaud.io/index.php/topic,58574.msg953285.html#msg953285
Oh, those? Peakmeter Spectrum Visualisation. I think it's on the list of unstable components, but for me it works just fine. Normally there are both peakmeter and spectrum in one window, but you can configure it to be only one of them.
Error 404; signature server not available.
