Topic: Discussion of "Default UI Gallery" (Read 283602 times) previous topic - next topic
Reply #575
Hey there! I like the looks of this UI: http://customize.org/foobar/skins/65153. But am new to this foobar "skinning". Can you guys/girls please advise whether or not downloading that skin is safe or perhaps not. Because I haven't got the slightest clue what is mainstream to fb2k skinning and what is considered balancing on edge. I do understand foo is customizable because of it's core modular setup. But he only piece of software I can write and understand is a DOS batch-file.
(oh and english not my native, sorry for sounding stupid - I do try my best)
Reply #577
Not a very fancy design, but well suited for my needs. I just love the flexibility of foobar2000! In the toolbar i have buttons for Open CD (rarely used, i rip with Cueripper), Convert to m4a (qaac), replaygain buttons, buttons for syncing my Sony walkman, and a button for fb2k preferences.
How can the buttons be edited/added?
Reply #578
Right click on the toolbar (buttons), Customize Buttons...
Choose from Available Commands on the right, and Add. Choose layout and icons on the left.
Reply #579
Here's mine, Have been discovering solarized & love it's muted Palette. This is my first try well other than using defaults.
A question is there a way to change the colour of the  font  for  highlighted text
https://i.imgur.com/Kp5iuIg.jpg
Reply #580
I think you want prefs>DUI>Colors + Fonts>Top text color item
DJAtrac - http://www.hydrogenaudio.org/forums/index....mp;#entry851721
Is this large display WSH?
can anyone share?
Reply #581
My current layout, simple, nothing complicated
But i came with a question and don't know where to post it so here it is:
Reply #582
Nobody knows how the set the added music folder as first folder in Library View???
Reply #584
you can add your own buttons (right click>customise buttons). then use the change icon button to browse for your own .ico files. IIRC, they must contain a 16x16 image.
Reply #585
Oh wow, you're right, I use it so plain that I completely forgot you can do that  Thanks.
Reply #586
Hotsoup, can you share this one http://www.hydrogenaud.io/forums/index.php...st&p=873324 ?
Also, how did you put these icons there?
Hi eahm, I think this is the last export of that theme: https://googledrive.com/host/0B0v92OYo7i-6Y...E/new_home5.fth
I recently made a playlist view that is tailored for classical music tags but that would be the only thing missing..
Like marc2003 said, all my custom icons range from 16px to 32px. I found them mainly through softicons and iconfinder.
Besides the very top buttons, the rest are "bottom-docked" which you have to checkmark in layout editing mode. HTH
Reply #587
Hotsoup, thanks, got most of it done, can you please list your components?
I don't even know if I can switch from my setup but I want to try to make it fully working and see how it works for few days before I can keep it. All I can say is that your setup is the best I've seen in a while.
Also, I have a ton of classical (like 400GB) and I am copying your renaming (Last name, First name (Nationality) (Year)).
Reply #588
Thanks, and you're welcome! I'll post my plugins/components when I get home from work today.
Reply #589
Current components (not all are necessarily needed for this theme)
Core (2013-12-27 11:08:12 UTC)	    foobar2000 core 1.3
foo_abx.dll (2012-02-26 22:32:36 UTC)     ABX Comparator 1.3.4
foo_albumlist.dll (2013-12-27 10:57:38 UTC)     Album List 4.5
foo_bitcompare.dll (2012-10-14 20:23:15 UTC)     Binary Comparator 1.2
foo_bpm.dll (2014-06-25 00:42:53 UTC)     BPM Analyser 0.2.4.6
foo_burninate.dll (2013-08-06 00:31:15 UTC)     Audio CD Writer 3.0.3
foo_cdda.dll (2013-12-27 10:57:10 UTC)     CD Audio Decoder 3.0
foo_converter.dll (2013-12-27 10:56:52 UTC)     Converter 1.5
foo_DeleteCurrent.dll (2012-06-13 03:55:43 UTC)     FooBar2000 Delete Current Track 1.0.0.0
foo_dsp_bs2b.dll (2011-04-27 02:04:58 UTC)     bs2b 3.1.0
foo_dsp_deemph.dll (2014-06-25 00:43:03 UTC)     De-emphasis DSP filter 0.1.0
foo_dsp_effect.dll (2014-02-12 05:09:28 UTC)     Effect DSP 0.12
foo_dsp_eq.dll (2013-12-27 10:58:06 UTC)     Equalizer 1.0
foo_dsp_resampler.dll (2011-10-19 03:39:55 UTC)     SoX Resampler 0.7.0
foo_dsp_std.dll (2013-12-27 10:57:46 UTC)     Standard DSP Array 1.3
foo_dynamic_range.dll (2012-02-29 03:30:18 UTC)     Dynamic Range Meter 1.1.1
foo_fileops.dll (2013-12-27 10:53:04 UTC)     File Operations 2.2
foo_freedb2.dll (2013-12-27 10:52:32 UTC)     Online Tagger 0.7
foo_input_dvda.dll (2013-02-10 18:49:33 UTC)     DVD-Audio Decoder and Watermark Detector 0.4.11
foo_input_monkey.dll (2014-06-25 00:42:53 UTC)     Monkey's Audio Decoder 2.1.7
foo_input_std.dll (2013-12-27 11:08:14 UTC)     Standard Input Array 1.0
foo_masstag.dll (2009-09-18 18:01:36 UTC)     Masstagger 1.8.4
foo_musical_spectrum.dll (2013-08-21 00:23:43 UTC)     Musical Spectrum 0.9.1
foo_out_wasapi.dll (2014-06-25 00:42:53 UTC)     WASAPI output support 3.2.3
foo_rgscan.dll (2013-12-27 10:55:34 UTC)     ReplayGain Scanner 2.2
foo_simplaylist.dll (2014-04-19 21:52:25 UTC)     SimPlaylist 1.0
foo_texttools.dll (2012-12-31 16:42:24 UTC)     Text Tools 1.0.5
foo_ui_std.dll (2013-12-27 11:08:12 UTC)     Default User Interface 0.9.5
foo_unpack.dll (2013-12-27 10:54:24 UTC)     ZIP/GZIP/RAR Reader 1.6
foo_upnp.dll (2014-06-25 00:42:53 UTC)     UPnP/DLNA Renderer, Server, Control Point 0.99.48
foo_verifier.dll (2014-06-25 00:42:53 UTC)     File Integrity Verifier 1.1.1
foo_vst.dll (2014-07-13 19:13:28 UTC)     VST 2.4 adapter 0.9.0.3
foo_wave_seekbar.dll (2014-04-30 23:22:15 UTC)     Waveform seekbar 0.2.45
foo_youtube.dll (2014-08-13 13:00:43 UTC)     Youtube Source 1.1
Reply #590
Thanks Hotsoup, I'll start modifying again Monday evening when I come back from a quick vacation.
Reply #591
I saw your screenshots eahm, lookin' good! I like how your default theme features the lyrics. I'm inspired now to find a way to squeeze that in..
Reply #592
Yes for the Lyrics but I like it even more how it's setup with your theme modified, in a different tab so I check it only when I care to
Reply #593
my final layout
Left side library, center for playlists, right for now playing.
I would like to neaten the now playing metadata display with Artist, Title, Album only, but I don't know how so that'll suffice.
More stars in the universe than grains of beach sand
Reply #594
Weird question, why is my theme.fth 3.83 KB and the one I modified from Hotsoup 642 KB?
...ohh, the icons maybe?
Reply #595
Once the layout editing "clicks" it's surprisingly flexible and fun to goof around with. At first it was only a variation of the quick setup album list + properties (tabbed), which was my standard for a long time. Then I totally fell down the rabbit hole....
Reply #596
Trying to switch to DUI maintaining functionality of my UI. Still WIP, but I like the result so far.
can you share?I like it very much, please ^^^^^^……………………
Reply #598
It's still work in progress, I still have to fix couple of issues here and there, but I'll put it up somewhere for download once I'm happy with it
