Topic: Discussion of "Default UI Gallery" (Read 386589 times) previous topic - next topic
Reply #250
And I'd like to know how it's possible to center the title of the main window. Even if it's not a foobar workaround I'd like to know how to do that, since I've already searched without success. Thanks.
Reply #251
I think that's down to the visual style you're using. deviantart is a good source for visual styles. You need a patched uxtheme.dll as well. (Or you can use Windowblinds but I found that to be pretty slow and bloated.)
Reply #252
I don't use the DUI on my home PC as it won't support my cover art naming scheme and there is no plugin to view time-stamped lyrics. I'm really pleased with the setup and would switch to the DUI instead of the plugin that shall-not-be-named if I could use my albumart and lyrics.
Using foo_uie_lyrics with foo_dockable_panels might get you 50% of your way there. The implementation results in a floating lyric panel which is problematic only if you regularly drag your foobar window about the desktop. Worth a try.
terry
Reply #254
After choosing your main columns (e.g. artist), right click the column header and go to Statistics, then choose what you like.
Reply #255
thank you, i thought that was something related to playback statistics (foo_playcount) so i didn't even look at it
Reply #256
This is how my foobar2000 looks like :
hi, i need help to let my foobar looks like this. i can do everything, except for the right columns (artist, album, tracks). what i should do?
Reply #259
Just something simple and easy.
Could you tell me for what you use the Audioscrobbler button and how you could get the artist info in the upper right corner?
I would like to know this as well.
Terribly sorry I didn't even notice anyone took interest. It's simply just a button that is linked to the last.fm radio plugin (I forgot where I got the button, I think it was actually from last.fm)
As for the artist information it's just simply me going to last.fm copying and pasting the artist information to my comment tags. I use foosions plugin to display it just as if someone would do with lyrics.
It's a lot of work but I was very bored one day. :x
Reply #260
Edit:
Download theme file here.
Hi , just posting to say how much I appreciate your theme file.  It is perfect for how I use foobar.  I am pretty new to foobar so the Default UI seems more my speed, and this was easy to install.  Thanks again.
Reply #261
All artist images and bio is manually done (there is no plugin or anything to do it, as far as I know)
How did you convince the album art viewer to display your artist art? Anything more elegant than rename them to back.jpg or disc.jpg and copying them in the album folder?
Edit: And where have you found your button icons?
Reply #262
All images are named Back in the album folders, and I made the buttons.
Reply #263
Sad.. I hoped you had found some undocumented feature.
Well done; I just asked because I long struggled to find decent buttons in ico format (too lazy to convert from png).
Thanks for the quick reply!
Reply #264
buttons.zip
There is the buttons if you want them.
Reply #266
Never mind, I found what I was looking for
Reply #269
Here is my new config for DUI:
If anyone would like a copy of the fth-file, please send me an PM
can you (or anyone else) please explain how you got those dividers in the status bar on the far right?
thanks!
Reply #270
thanks!
Right click on the status bar and select 'show total time of selection' and 'show volume'.
Reply #271
thanks!
thanks for the answer. i'm disappointed though, i was hoping you could add those separators anywhere in the status bar. that would be a nice feature, to be able to incorporate them into your custom status bar code
Reply #273
You can add multiple album viewers to your configuration.
Right click on one and you will see the acceptable names for the image files.
terry
Reply #274
thanks chongy5! and thanks tpijag for providing the answer
i just have artist images called back.jpg for all albums. each is cropped to 300x500 to fit my config. it took a couple days of google searching to find interesting pics for all my music, but it was worth it!
