Discussion of "Default UI Gallery" Reply #100 – 2008-02-08 04:35:38 Quote from: riderforever on 2008-02-05 14:14:54Quote from: picmixer on 2008-02-05 13:44:07This is what I use as a replaygain indicator. Just make a custom column with:Code: [Select]$if(%replaygain_album_gain%,A,$if(%replaygain_track_gain%,T,X))And modify to your hearts delight of course.Thanks that's exactly what I meant! Do you know how to color the 'X' in red? I've tried with $rgb function without any success$rgb function doesn't work in DUI
Discussion of "Default UI Gallery" Reply #101 – 2008-02-13 20:53:47 Which color scheme do you guys use for the spectrum visualization?There are lots of options, like making gradients of different colors.Playing with the color choices, I came with this one:What I did was setting the first color to 150 hue, 150 sat, 0 lum. Then I added a color with 150 hue, 150 sat, but increasing the lum 10 by 10 (step 10), until I got to lum=210. That way the colors were really vivid in a shade of blue.It would be great to see other combinations of colors, there's a lot of creativity in the color scheme of this element.
Discussion of "Default UI Gallery" Reply #102 – 2008-02-20 23:19:07 how can i move around elements when i'm in layout edit mode?i'm trying to do:
Discussion of "Default UI Gallery" Reply #103 – 2008-02-20 23:33:49 Quote from: snively on 2008-02-20 23:19:07how can i move around elements when i'm in layout edit mode?you can't "move them" per say, but you have to copy and paste to move them around. Last Edit: 2008-02-20 23:34:16 by shakey_snake
Discussion of "Default UI Gallery" Reply #104 – 2008-02-21 07:28:47 right klick on the elements and then cut out or change the UI Element.For this construct you need a (left/right) splitter, and then on the left field of the splitter you also need a (top/bottom) splitter.Just rightclick on the fields and insert the new ui element.I hope this will help you a little bit!
Discussion of "Default UI Gallery" Reply #105 – 2008-02-22 20:24:40 I've seen a few defaul_uis now with custom buttons... How can this be done, or are these just dockable panels?
Discussion of "Default UI Gallery" Reply #106 – 2008-02-22 20:26:20 Quote from: Fractal_Mortality on 2008-02-22 20:24:40I've seen a few defaul_uis now with custom buttons... How can this be done, or are these just dockable panels?it is a new feature of 9.5.1 betas.http://www.foobar2000.org/beta/index.html
Discussion of "Default UI Gallery" Reply #108 – 2008-02-23 03:58:08 Here's mine:I still think it's rather ugly, but I'm using a darker colour to reduce strain on my eyes. I wish there was some way to remove the very obvious splitter bars, or at least, reduce them to being a few pixels thick.What would be really cool is if you could specify which columns the playlist would show depending on the playlist tab that's selected. The reason I wonder is that my classical/opera music contains extra tags that my pop/rock collection does not, such as performer, conductor, etc...If foobar could remember which columns to show per playlist that would rock....Unless this exists?Doubt it.
Discussion of "Default UI Gallery" Reply #109 – 2008-02-23 05:52:13 Quote from: Takaji on 2008-02-23 03:58:08What would be really cool is if you could specify which columns the playlist would show depending on the playlist tab that's selected. The reason I wonder is that my classical/opera music contains extra tags that my pop/rock collection does not, such as performer, conductor, etc...If foobar could remember which columns to show per playlist that would rock....Unless this exists?Doubt it.I agree, this feature would be quite cool.
Discussion of "Default UI Gallery" Reply #110 – 2008-02-23 17:37:18 I agree too. In fact the best would be if, for each playlist, one could specify which columns to show / hide.Some examples :- For classical music : more columns (conductor, performer, etc.)- For singles : the album column might be not necessary- For VA albums : the artist column might be necessary (it isn't in most albums, except when album artist is not null)- For soundtracks : the genre column might be not necessary if the genre has been already set to "soundtrack"- Etc.So the best would be to be able to create SEVERAL PLAYLIST VIEW LAYOUTS (layout 1, layout 2, layout 3...), and then for each playlist, be able to assign one precise layout (classical -> layout 1, singles -> layout 2, etc.)The advantage of layouts over columns is simple : in a layout, one could specify each column's width and order. Imagine the possibilities !And now the big question : what do devs think ?... Last Edit: 2008-02-23 17:39:09 by Jose Hidalgo
Discussion of "Default UI Gallery" Reply #111 – 2008-02-23 19:27:47 You could already do something like this with one column and title formatting.Code: [Select]$if($equal($lower(%genre%),classical),%performer% - %conductor%,%artist%)...or something to that effect.Obviously maybe not exactly what you guys are looking for, but if you need something more complicated, there's always other UIs. Last Edit: 2008-02-23 19:37:31 by shakey_snake
Discussion of "Default UI Gallery" Reply #112 – 2008-02-23 19:56:55 i need to get a widescreen lcd...would be sooo much nice with a wider screen
Discussion of "Default UI Gallery" Reply #113 – 2008-02-23 20:09:15 Thanks shakey snake. You know, that's what I like about this forum : whatever your request, there's always someone coming in and saying : "but you can ALREADY do that, don't you know ?" As for the rest of your post :Quote from: shakey_snake on 2008-02-23 19:27:47if you need something more complicated, there's always other UIs.That's the kind of answer I was hoping NOT to get. IMHO this function is not, or should not be, UI-dependent. In every UI there are playlists and a playlist view, so I'd rather see this as improving the way foobar handles playlists ("playlist preferences" if you like).
Discussion of "Default UI Gallery" Reply #114 – 2008-02-23 20:41:51 Quote from: Jose Hidalgo on 2008-02-23 17:37:18I agree too. In fact the best would be if, for each playlist, one could specify which columns to show / hide.Exactly what I'm talking about. I'd love to see that function.Quote from: shakey_snake on 2008-02-23 19:27:47You could already do something like this with one column and title formatting.Code: [Select]$if($equal($lower(%genre%),classical),%performer% - %conductor%,%artist%)...or something to that effect.Thanks for that info, I guess I'll have to use it for now. Hopefully an idea like what we're talking about will be implemented?
Discussion of "Default UI Gallery" Reply #115 – 2008-02-23 20:57:49 Small Note:Code: [Select]$if($equal($lower(%genre%),classical),%performer% - %conductor%,%artist%)can be written more elegantly as:Code: [Select]$if($stricmp(%genre%,classical),%performer%- %conductor%,%artist%)NOTE: stricmp is case insensitive.
Discussion of "Default UI Gallery" Reply #116 – 2008-02-24 06:55:21 Quote from: Jose Hidalgo on 2008-02-23 20:09:15Thanks shakey snake. You know, that's what I like about this forum : whatever your request, there's always someone coming in and saying : "but you can ALREADY do that, don't you know ?" It is a lovely forum in that regard!Except I'm at a loss as to where I should ask why "Use Custom Sort String" isn't an option on any Library displayers
Discussion of "Default UI Gallery" Reply #117 – 2008-02-24 19:51:53 Quote from: kanak on 2008-02-23 20:57:49Small Note:Code: [Select]$if($equal($lower(%genre%),classical),%performer% - %conductor%,%artist%)can be written more elegantly as:Code: [Select]$if($stricmp(%genre%,classical),%performer%- %conductor%,%artist%)NOTE: stricmp is case insensitive.Could you please provide a version that would test, not if %genre% is equal to "classical", but if %genre% CONTAINS the string "classical" ? Thank you.I have several genres where I could use your trick, and all of them share the substring "classical". So a new version would avoid having to play with $or, which would be less elegant... Last Edit: 2008-02-24 19:56:37 by Jose Hidalgo
Discussion of "Default UI Gallery" Reply #118 – 2008-02-24 21:03:53 For "contains", try this:Code: [Select]$strstr(%genre%,classical)
Discussion of "Default UI Gallery" Reply #119 – 2008-02-25 12:59:09 Thanks, it works. Not case-sentitive though, but that's not a problem for me.
Discussion of "Default UI Gallery" Reply #120 – 2008-02-25 13:51:00 Quote from: Jose Hidalgo on 2008-02-25 12:59:09Thanks, it works. Not case-sentitive though, but that's not a problem for me.using the $lower to force the tag to become lowercase would solve that problem: Quote$strstr($lower(%genre%),classical)
Discussion of "Default UI Gallery" Reply #121 – 2008-02-25 14:57:28 Yes, I know, like I said it's not a problem for me. I just wanted to emphasize for everybody the fact that $strstr is case sentitive, that's all.
Discussion of "Default UI Gallery" Reply #122 – 2008-02-25 19:06:47 What is the code to show the album info in playlist view like in these screenshot?
Discussion of "Default UI Gallery" Reply #123 – 2008-02-25 19:13:01 Right-click on a column header, choose Groups, By Artist/Date/Album/Codec.
Discussion of "Default UI Gallery" Reply #124 – 2008-02-28 00:16:13 I absolutley love the new foobar. However, I noticed that with album list you can longer just click on a folder or album and it be sent to the playlist, you now have to press ENTER. Is there any way of changing this?
