Topic: Default UI Gallery (Read 748681 times) previous topic - next topic
Re: Default UI Gallery
Reply #575
foobar2000 v2.0 64bit Default User Interface with JScript Panel 3 (thanks Marc)
Light mode
Dark mode
Dark mode with dynamic colours on (Smooth Browser, JS Playlist and Custom Track)
Reply #578
I probably should distribute a bottom panel like that with JSP3 itself. I've been too lazy to incorporate a volume slider in the current track info/seekbar/buttons scripts.
Yes, that would be an interesting addition. Of course, you can complete anything as basic as this in no time.
But if you don't have the time, here is the script I use. As you know, I'm a newbie, and there must have been a joke line code in the script.
eurekagliese, looks good!
Thank you, and thank you for your Flags script, which I could learn from along with the JSP samples.
Reply #579
I just upgraded to ver 2.0 and am loving it. Thanks for all the effort!
I've noticed the arrowhead in my album list panel is not highlighted like the text.  Is this a known issue, or is there a setting I'm missing.  See the attached image.
Foobar2000 2.0 [x64]
Reply #580
I just realized this is a gallery topic, so plz ignore my post.  Replying here since I couldn't fine a way to edit or delete it.
Reply #581
In the post right bottom "more" button, you can report your own post  ;D and ask an admin to delete or move it
Reply #582
#eurekagliese
i have an error in your custom_track :
JScript Panel 3.2.14 (Track Info + Seekbar + Buttons by marc2003)
JavaScript runtime error
Unable to get property 'Width' of undefined or null reference
File: <main>
Line: 571, Col: 3
i copy the 2 files in sample/images
Reply #584
My foobar2000 v2 layout
Reply #585
My Foobar2000 64bits:
Thanks for the Bottom Seekbar that i customize a bit .
The scripts of the bottom panel , the spinning Albumart and the Lastfm panel are below.
MOD Edited text
Reply #589
Correction from the last UI .
- Add radio Stream + thumbs + small biography
- Add two biography : composer and performer
- Correct the Spinning Vinyl panel
- Small correction on the biography panel
- Add LastFM Scrobbles panel
- Add Country Flags
Would like the switch the Biography ( composer / performer ) , not with a tab stack , but with a left click button maybe or by a right click menu popup ? it's beyond my skill ? ANY HELP ? THANKS THANKS
Reply #590
- Add Country Flags
You can apply JSplitter instead of JScript3 or SMP, it provides similiar features like Panel Stack Splitter.
This is my theme, hople this can help.
Reply #591
- Add Country Flags
thanks
MOD: edited
Reply #592
@eurekagliese
JScript Panel 3 3.3.0 (foo_jscript_panel3) (2023-07-04)
https://github.com/jscript-panel/release/releases
Reply #578: https://hydrogenaud.io/index.php/topic,58574.msg1026530.html#msg1026530
track_custom.js
Reply #2372: https://hydrogenaud.io/index.php/topic,63984.msg1027506.html#msg1027506
track_custom_v2.1.js
It can not be used. Crash on start.
SHURE SRH1840, SENNHEISER HD660S2, SENNHEISER HD 490 PRO, DT 1990 PRO, HiFiMAN Edition XS, Bowers & Wilkins P7, FiiO FT5, 水月雨 (MOONDROP) 空鳴 - VOID, Nakamichi Elite FIVE ANC, SONY WH-ULT900N (ULT WEAR) (made a Upgrade/Balanced Cable by myself)
Reply #594
@eurekagliese
track_custom.js
Updated for latest JSP3 3.3.0
Reply #595
This is my DUI layout it will have to make do until Refacets gets updated to finally allow showing album art /fingerscrossed its gonna happen soon
PC - Teac UD-505 - Adam Audio A4V - DCA ÆON Open X
Samsung S23 Ultra 512GB - Fiio UTWS5 - TinHifi P1 Max.
Reply #596
@eurekagliese
Thank you for your precious time.
again...
Custom Track Buttons (Compact) v2.js
Playback > Order > Repeat (playlist)
The repeat (playlist) and repeat (track) icons have been swapped.
(Repeat (track) is 1 track repeat.)
Reply #597
@eurekagliese
again...
Updated
Reply #598
Perfect.
Many Thanks.  :)
Reply #599
Updated
This is very cool, thanks for making it available.
One question how or what would need to be deleted in the script to remove the seekbar but keep everything else?
