Default UI Gallery Reply #25 – 2007-11-02 22:59:26 Here's mine: http://agafonkin.com/files/images/foobar.gif
Default UI Gallery Reply #27 – 2007-11-05 04:56:15 This new beta is really quite nice. This is what I've got so far: Last Edit: 2007-11-05 04:56:51 by Emon
Default UI Gallery Reply #28 – 2007-11-05 06:24:14 Refined a bit after I decided that I didn't need the metadata and console tabs.
Default UI Gallery Reply #29 – 2007-11-09 18:38:36 Here's the 'shrinked' version of my two-window config posted above. I think Lyx asked for more compact configs, so here we go:-edit-and two more alternatives with only one window: 'bigOne' and 'compactOne' (animated GIFs)they can still be quite comfortable depending on your listening behaviour (i.e. if you mainly listen to albums or longer playlists).frncle Last Edit: 2007-11-09 22:11:01 by fooruncle
Default UI Gallery Reply #30 – 2007-11-10 03:48:01 Here's my final after much tweaking. Last Edit: 2007-12-07 23:57:09 by antiKk
Default UI Gallery Reply #31 – 2007-11-16 21:54:39 This is mine, pretty much a ripoff from some ideas I got from here. Oh, and tweaked for my needs of coarse:
Default UI Gallery Reply #32 – 2007-11-24 23:38:31 Bare-bones, Low-on-Resources, Thin, Compact theme.No AlbumArt or Lyrics. Uses Facets. Uses Font: "Photoshop Small" (Installed with Photoshop).Dimensions: Width=369pixels Height=996pixels.Visual Style: Windows Classic (with 'Jasmin 3D Colour Changer' mods). Last Edit: 2007-11-25 01:05:45 by Blur
Default UI Gallery Reply #33 – 2007-11-25 12:03:37 [a href="http://img256.imageshack.us/my.php?image=fb2krx2.png" target="_blank"]
Default UI Gallery Reply #34 – 2007-11-26 01:47:52 Uses Font: Frutiger Linotype. Dimensions: Width=427pixels Height=1024pixels. Visual Style: Windows Classic (with 'Jasmin 3D Colour Changer' mods).Thin, Compact theme. UPDATED!! with options for AlbumArt and Other Tabs and optimized Space Utilisation.I would have attached the theme file (if anyone wanted it!) but Unfortunately am not allowed Attachments as yet by Admin for being New to the forum!
Default UI Gallery Reply #35 – 2007-11-26 11:39:24 Here's Mine - With a few Dockable Panels on Display set to show/hide via function keys...
Default UI Gallery Reply #36 – 2007-12-07 19:57:07 Mine, really simple, that's why I like it : Last Edit: 2007-12-07 20:07:29 by kaki123
Default UI Gallery Reply #38 – 2007-12-19 00:30:30 When I first stumbled upon foobar2000 a couple weeks ago, I nearly gave up on it after a few minutes of tinkering around. It was version 9.4.5, and that night, the site that hosts the plug-ins was down. Then I saw the new beta version and decided to give it a try. Twenty minutes later, I had downloaded facets and had a pretty nice layout going on. Haven't looked back to iTunes yet. Last Edit: 2007-12-19 00:42:23 by badaboom
Default UI Gallery Reply #39 – 2007-12-22 13:30:30 Moderation: Your image (850 KB) was ten times larger than the maximum size. Replaced by a thumbnail. Last Edit: 2007-12-23 20:01:26 by Frank Bicking
Default UI Gallery Reply #40 – 2007-12-23 19:20:10 Made some small changes on my foobar 0.9.5 setup and cleaned up my custom status bar code and rearranging the replaygain info on the stat bar aswell. Last Edit: 2007-12-23 19:20:50 by /mnt
Default UI Gallery Reply #41 – 2007-12-26 10:38:26 Quote from: Maxim_289 on 2007-11-04 09:18:222joen: Nice config.That's mine (using Default UI, v0.9.5):[a href="http://img185.imageshack.us/my.php?image=newfoohq1.png" target="_blank"]
Default UI Gallery Reply #43 – 2007-12-28 02:11:35 Finally I also got to Foobar2ks new Default UI. It´s kinda cool =)Here is my little Fooby.greets, Raven.am0k
Default UI Gallery Reply #44 – 2008-01-03 20:34:46 Moderation: Please do not inline images larger than roughly 800x600 and 80KB. Please use thumbnails and/or links for large pictures instead. Last Edit: 2008-01-03 20:48:33 by foosion
Default UI Gallery Reply #45 – 2008-01-04 23:13:44 New one: Last Edit: 2008-01-04 23:14:32 by JohanDeBock
Default UI Gallery Reply #47 – 2008-01-05 13:24:32 Larger Pictures (1680 x 1050 + ClearType):View 1, View 2, View 3, View 4 & Theme. No Cover ? Last Edit: 2008-01-06 10:56:12 by DeepAnger
Default UI Gallery Reply #48 – 2008-01-16 02:12:32 Album art is in static position across all tabs Last Edit: 2008-01-16 02:13:47 by Paine-
Default UI Gallery Reply #49 – 2008-01-16 04:57:09 Finally started using facets and a fullscreen DUI.
