Topic: Default UI Gallery (Read 622897 times) previous topic - next topic
Default UI Gallery
Reply #201
I'm loving Tabs =)
Default UI Gallery
Reply #202
Hi
This is my first week with the Foo, and this is just a quick & dirty setup with minor tweaks until I become more proficient with it.
[a href="http://img42.imageshack.us/i/fb2kb.jpg/" target="_blank"]
This thing is a blast!
Dave
Default UI Gallery
Reply #203
hi, this is how fb2k looks on my laptop
[a href="http://img88.imageshack.us/i/fb2k.png/" target="_blank"]
ive been using foobar more than and year since version 0.9.3 (or 0.9.6) and i dont feel like changing it for anything, what i like about it most is that by default it has no skin
Default UI Gallery
Reply #204
Well, after some hard drive failure I've made the jump to linux... and I find that my CUI foobar setup features a rather ugly bit of memory leakage under wine.  So here's my go at a quick shift to default UI.
Liked your color setup
Here it is, simple, only changed the colors and made some little adjustments
Default UI Gallery
Reply #205
Well I figured out the 2 color seekbar effect thing. After changing thru the DirectX Frontend choices, when I switched to the Direct2D setting just to see what might change, the seekbar did...to a 2 color one. After going back to Direct3D and playing with color & highlight, I finally got it.
, then I have to try scripting things with ColumnsUI. Good thing my back is all jacked up lately as it gives me some time to play around, well in a relative sense it's a good thing....
Default UI Gallery
Reply #206
Trying out EsPlaylist!
Default UI Gallery
Reply #207
Default UI Gallery
Reply #208
I think I love ESPlaylist :)
Default UI Gallery
Reply #209
Default UI Gallery
Reply #210
Default UI Gallery
Reply #211
Here's mine, thanks to everyone for posting theirs, helping inspire me.
Haven't really changed much things except created a "by codec", "by last modified" (quicky find newly added songs) sort for Album List View and modified the default "by album" sort so that I like it more.
Basically the facet views replicate the album list view in a sometimes more user-friendly way.
Since I don't know if those changes are present in the .fth file, here are the lines you need to add in the "Album List" preferences.
By CODEC : %codec%|%samplerate% Hz|%album%|[[%discnumber%.]%tracknumber%. ]['['%album artist%']'] - %title% '('%filename_ext%')'
By Last Modified: $date(%last_modified%)|[%album% - $meta_branch_remap(tracknumber) - %artist% - %title% '('%filename_ext%')']
By Album : %album%|[[%discnumber%.]%tracknumber%. ]['['%album artist%']'] - %title%
In the Facet preferences, I added the following (inspired by the Album List).
CODEC : [%CODEC%]
Sample rate : [%samplerate%] Hz
Last Modified : $date(%last_modified%)
Track - Artist - Title (Filename) : [$meta_branch_remap(tracknumber) - %artist% - %title% '('%filename_ext%')']
Screenshots:
FTH file:
foobar2000.fth - 14 Kb
You might the following components added:
foo_facets
foo_uie_esplaylist
foo_uie_biography
foo_uie_lyrics2
foo_wave_seekbar
Default UI Gallery
Reply #212
Here's mine. It's pretty average and boring.
Default UI Gallery
Reply #213
Default UI Gallery
Reply #214
I just wish I could color the the columns in different colors and randomize the library viewer artist order somehow...
Uploaded with ImageShack.us
Default UI Gallery
Reply #215
My current layout with buttons changed...
Default UI Gallery
Reply #216
I like it simple.
Default UI Gallery
Reply #217
I changed fonts and you can see what the other tab looks like..
Default UI Gallery
Reply #218
Synthesized library in separate portable install, basically the same simple setup as other portable foobar install with common music
[a href="http://i54.tinypic.com/218l92.png" target="_blank"]
Default UI Gallery
Reply #219
Default UI Gallery
Reply #221
My foobar at the moment...
Default UI Gallery
Reply #222
Default UI Gallery
Reply #223
Okay, it's simple, but I like it.
The real strength of Foobar to me is in the KB shortcuts.
Default UI Gallery
Reply #224
using audioscrobbler, biography view, lyrics grabber 2, text display, playback statistics, last fm sync, run services, soft playlists, and lastfm radio.  thanks to all the developers.
if you have a comment or suggestion please pm me
