Topic: Default UI Gallery (Read 623177 times) previous topic - next topic
Default UI Gallery
Reply #175
My simple DUI layout.
Default UI Gallery
Reply #176
An update from me, i converted my buttons and pbo to wsh scripts and got rid of the ugly toolbal, and replaced the default playlist view with the esplaylist 0.0.3
Default UI Gallery
Reply #177
Been sleeping on upgrading to 1.0, just discovered WSH panel, seriously looking forward to having some time to work with it.  JavaScript in foobar is, in my opinion, brilliant.
Default UI Gallery
Reply #178
First time using Foobar. Like it a lot. Here's the theme I currently playing with:
Default UI Gallery
Reply #180
Long time lurker here. Since I have learned a lot from the forums, I decided to join.
Here's my default config with a slightly changed WSH-Panel Mod in the layout (fixed width of 400 pixels) and the latest esplaylist.
(Thank you T.P Wang for this great plug-in and marc2003 for the locked size option!)
[a href="http://img88.imageshack.us/i/myfoobar.jpg/" target="_blank"]
Default UI Gallery
Reply #182
Well, after some hard drive failure I've made the jump to linux... and I find that my CUI foobar setup features a rather ugly bit of memory leakage under wine.  So here's my go at a quick shift to default UI.
Default UI Gallery
Reply #183
Well, I made this one some weeks ago when I was just getting to know F2K, so it´s a work in progress.... I took a lot of inspiration from this thread  and a little from my MMD3 Winamp theme. There are still a lot of things I´m looking forward to change, like how to override the current VS, use images as background colors, but that goes to the discussion thread...
OK, here it is:
Default UI Gallery
Reply #184
I wound up writing my own Seekbar effect, using a 30dB (instead of linear) scale, and normalizing with track peaks.
Most of the tagging is by hand. Bleh.
Playlist columns/groups are in a pretty constant state of flux depending on my needs.
Default UI Gallery
Reply #187
Mine  quite simple:
Default UI Gallery
Reply #188
My current layout:
Changed some things like colors, added rating and playcount column...
Default UI Gallery
Reply #189
EDIT: I realize now that I have the spectrum visualization mislabeled.
Also, the two meters on the left are VU and peak.
Default UI Gallery
Reply #190
mine for a long time...
Default UI Gallery
Reply #191
My latest skin, fooEKo_v2 in two versions (see them in fullscreen as they get distorted in the preview thumbnail):
  Suggestions are welcomed!
Default UI Gallery
Reply #192
This is my current DUI-config I'm using.
(Click for big)
Default UI Gallery
Reply #193
I needed a more basic, straight-forward layout which would consume little resources and wouldn't fill half my screen:
Download here
Default UI Gallery
Reply #194
Default UI Gallery
Reply #195
Default UI Gallery
Reply #197
Components used:
WSH Panels mod for the playback control buttons
EsPlaylist for the Album list tab and playlist viewer
Waveform seekbar (thanks Zao!)
UPnP server/browser (thanks bubblegumm)
Default UI Gallery
Reply #198
I have always used mainly the same look for my set up-
