Topic: foobar2000 0.9.5 beta 9 (Read 275455 times) previous topic - next topic
Reply #225
I'm really impressed with new UI and components. Finally changed from old-customized Navigator theme to something new. Organizing music is so much nicer now.
Besides of what is mentioned in feature proposals thread (colors, tabs, alignment, spectrum options are the most important for me) I dare to suggest a few other things:
- $caps2 feature in properties window
- Selected files count in statusbar (if playlist is long, there is no easier way to tell if what we see as selected, is all that its really selected)
- Would be nice if double clicking on row generated by grouping scheme (in playlist) could call properties window (or possibly be configured to anything else), now it plays first track from this selection (pointless IMO as the same can be achieved by double clicking one line below)
- In selection properties element - could there be added option to disable display of caption? In my case, this component is set up that each information (Metadata, Location etc) is displayed in its own tab - so the same information as in caption is already in tab name.
- Now its hard to include all information in grouping scheme, for me perfect would be: album artist, year, album, genre, AG, totaltracks for full information. I wish that there could be added second line to grouping scheme, preferably with smaller font.
- Borders for collumns
Reply #226
a (not small) feature request :
can see the album art in the playlist, like in Windows Media Player or in foo_ui_panels.
Reply #227
It would be very nice (and i think its also very easy to implement) if we could add a resizable space in the toolbar (like the one in the Firefox toolbar - only more precise). This would help to position the other ellements (like buttons or volume control) anywhere in the toolbar. Right now i had to use the "layout editing mode" button so i can keep the volume control on a normal size.
click for full size:
Reply #228
+1
I doubt it will happen but its the only reason im sticking to panels. Gotta say the new default UI is a big improvement and step in the right direction
Reply #229
I love the new foobar beta. I appreciate that the authors are trying to make this incredible program more friendly for beginners (like me) whith the new default UI.
I was wondering if custom capitalization schemes will be possible in the future. Maybe a option in "Preferences" - ... - "Properties dialog" could be added for the "Capitalize" command.
Not all languages use the English capitalization scheme, and I prefer "feat." instead of "Feat." etc.
Reply #230
so wait... are most of the components i currently have installed going to be compatible with the new beta?
Reply #231
Yes. But maybe not the new default UI. But you can always use a different UI than the default.
elevatorladylevitateme
Reply #232
first of all: you did a wonderful job! chapeau!
one tiny feature request: is it possible make the ui element over which the mouse pointer is hovering react to the scroll wheel instead of the currently active ui element? that would add a lot of usability to the interface!
thx,
frncle
--edit:
the volume slider already works like that, if you could extend this function to the other elements, it would be perfect!
request has already been posted by another user:
http://www.hydrogenaudio.org/forums/index....showtopic=58673
Reply #233
It allows too many nonsensical combinations. How would you sort %artist% by %tracknumber%, for example?
On one hand I'd say if the user really wants to do that nonsense, let him do, on the other hand I understand that this breaks the principle of easy configuration, because the user can unintenional do something he don't want to.
In Facets, you can already add both Artist and Artist Sort columns, sort by the Artist Sort column, and finally hide the column by resizing it to a width of 0px.
This is total sufficient. I didn't play too much with facets until now, so I didn't see this solution. But it can't be used for album list.
Reply #234
Another small feature request besides the 'use scrollwheel on mouse-over ui element instead of active ui element' one (foosion, could you add it to the request list so it won't be forgotten?):
Create a new playlist on double click in the playlist manager.
Having uninstalled CUI,
frncle
Reply #235
questions:
a. can i see the song that is curently playing in albumlist somehow? (i mean by clicking something)
b. is playback queue visualized someplace? (like playlist?)
c. is it possible to remember status, size, position of undocked components like eq or console? (they should survive the player restart)
Reply #237
In the library/album list, I wish there was a "Clear" button to reset the search field
Reply #238
Sorry if this was already discussed, couldn't the Playlist Search being implented as an UI Element?
Reply #240
This has been added with beta 3, check the new option at Preferences, General to activate it.
Reply #241
almost perfect
Reply #242
Works like a charm! Great!
frncle
Reply #243
I installed beta 3 under Vista (32, UAC enabled) with the setting "Install for all users" enabled and  "Enable per user settings" disabled.
When starting Foobar I need to select a theme, but when I do this I get the error "Theme could not be written Access Denied".
Procmon says access is denied writing the file theme.fth.tmp in the foobar map itself.
Reply #244
The users profile switch should never be disabled under Vista. UAC does not allow unlimited access to folders such as "program files". Therefore programs themselves also can not write files to said folder without running into various issues.
Reply #245
Maybe the installer can be changed to warn users running Vista not to use this option? (Maybe it wasn't clear from my post but I'm well aware about the Vista rights in the program files folder)
Reply #246
The installer will either be changed so that this option will be greyed out where it really shouldn't be used or some other other option along those lines to warn users of this behaviour.
Reply #248
In 0.9.4 the current volume (in dB) was displayed in the lower righthand corner, is there any way of getting that back? As much as I like 0.9.5 I hate not seeing what volume foobar is set to, and I don't want to use the volumeslider.
Reply #249
Hint: Right-click on the status bar.
