Topic: Lame 3.94a8 (Read 2012 times) previous topic - next topic
Lame 3.94a8
I used the song 99 red luft balloons, the german version off the compilation sounds of the eighties. Pop type music.
Lame version 3.94 mmx (alpha8 January 12, 2003 16:05:29) compile by john33
Note alpha versions should ONLY be used for testing
All mp3s have 8949 frames. All reccomended preset mp3s use nspsytune, safe joint,joint stereo and vbr-old /vbr-rh unless noted.
Encoded via commandline on a celeron 500 with 256 ram.
Actual song length is 3:53 seconds
Presets in order of quality (from list of reccomended lame settings and ha.org board discussions)
Notes Recommended presets        Enc.Time Bitrate Filesize
c     --preset insane                1:40   320   9,342,756
      --alt-preset extreme -Z 1      2:36   254   7,430,534
      --alt-preset extreme           5:30   254   7,426,366
1     --preset fast extreme          1:48   265   7,757,198
      --alt preset extreme -Y        6:44   230   6,733,692
1     --preset fast extreme -Y       1:36   208   6,078,302
      --alt-preset standard -Z 1     4:38   194   5,687,266
      --alt preset standard          3:17   199   5,820,920
1     --preset fast standard         1:28   207   6,063,536
      --alt-preset standard -Y       3:48   181   5,305,498
1     --preset fast standard -Y      1:26   189   5,521,392
1 2 o --r3mix                        1:48   184   5,391,440
      --preset dm-medium             3:53   181   5,305,498
      --preset portable              3:15   172   5,047,162
      --preset medium                3:27   164   4,795,544
      --preset dm-radio              3:18   159   4,662,666
*     --alt preset 128               2:15   124   3,623,187
c     --alt preset cbr 128           2:17   128   3,740,315
* 2   --preset radio                 1:51   107   3,130,453
Following command line order is arbitrary.
Use --verbose to determine the settings used by these command lines.
Lines designed by HA.org members
* %   --abr 128 -h --nspsytune --athtype 2 --lowpass 16 --ns-bass -8 --scale 0.93
                                      8:07   126   3,674,719
c %   -h --nspsytune --athtype 2 --lowpass 16 --ns-bass -8 --scale 0.93
                                      7:11   128   3,740,315
+     -V3 -b96 -h -mj                10:50   169   4,935,599
#     --alt-preset medium -b 128      3:44   164   4,801,209
Experimental settings intended for testing only.
^      --alt-preset standard -Y -V3 --substep 1
                                      3:55   159   4,667,361
#      -V4 --nspsytune --nssafejoint --nsmsfix 2.0 --ns-sfb21 6 --athaa-sensitivity -15 -X 1,3 -Z 1
                                      3:20   148   4,337,112
#      --preset standard -V3 --lowpass 17.5 --nsmsfix 2.5 --ns-sfb21 4 --athaa-sensitivity -10 --shortthreshold 4,15                   3:35   152   4,841,680
#      --preset 167 --lowpass 17.5 --nsmsfix 3 --shortthreshold 4,15 -X 1,3 -Z 1
                                      2:06   164   4,815,112
#      --alt-preset 167 --lowpass 17.5 --nsmsfix 3 -Z 1
                                      2:22   164   4,815,112
Notes
--alt-preset and --preset mean the same.
c is a cbr preset for 320 kbps
* is an abr preset for 112kbps
1 uses vbr mtrh
2 does not use safe joint
# designed by mithrander
^ designed by dibrom
% designed by ff123 and hans jurgen
+ read on several different places on ha.org
o although --r3mix comes reccomended by many users and websites it is an outdated preset.
Is dm-medium the same as aps -Y ?
I plan to run these commandlines on the same wav file with lame 3.90.2 and for comparison. I will note which command lines will not work then run them on 3.93.1 and note which ones will still not work.
Next time I attempt this I will use a less annoying song!!
Any suggestions on how I have conducted this will be wonderful. Any other command lines you would like me to test?
I would like to provide these statistics for comparision reasons only. Perhaps it will help in deciding future preset options.
Lossy
r3mix zealot.
