Topic: foo_listeningto (Read 12789 times) previous topic - next topic
foo_listeningto
foo_listeningto_v0.1.3_beta_src_bin.7z
Plugin sends NowPlaying information to Miranda IM.
Only works with ListeningTo Miranda IM plugin.
Works best with ListeningTo v0.1.1.8.
To receive information in Miranda, enable Options->Status->Listening info->Players->Other players.
Compiled against foobar2000 SDK v0.9.4.
Options page contains only Enable/Disable checkbox and custom title formatting field (not functional at the moment).
foo_listeningto
Impossible to load plugin: error detected by foobar2000 which prevents plugin to work.
foo_listeningto
Please, tell me exact error message. And foobar2000 version (if it is not 0.9.4.4).
foo_listeningto
Failed to load DLL: foo_listeningto.dll
Reason: Cette application n'a pas pu démarrer car la configuration de l'application est incorrecte. Réinstaller l'application pourrait résoudre ce problème.
Translation:
Reason: this app can't start because application configuration is incorrect. Reinstall application might solve this problem.
I'm using 0.9.4.4, winxp SP2 up to date.
foo_listeningto
Ah, this is, probably, because you don't have some fu***n MSVC dlls on your PC. Must be MSVCR80.dll. Try this
foo_listeningto
After installing what you said, it works.
Just for info,after installation, I had no MSVCR80.dll in system32 so it depends on another dll.
ps: what are the differences between your plugin and foo_msn_alt ?
foo_listeningto
foo_listeningto is for Miranda IM, while foo_msn_alt is, as i presume, for MSN Messenger. Other than that they are pretty similar, i think.
foo_listeningto
That's because the DLLs are nowadays in the WinSxS directory, in neatly named side-by-side folders.
This conveniently avoids the DLL hell.
Stay sane, exile.
foo_listeningto
It might be easier for users if you utilize static linking of the .dll at runtime, rather than dynamic linking when you compile your plugin.
foo_listeningto
Your plugin contains a serious bug in the part that extracts the filename from a track's path.
Offending code (DO NOT COPY THIS):
    char *filename = (char*)strrchr(p_track->get_path(),'\\');
    if (filename == NULL) filename = (char*)strrchr(p_track->get_path(),'/'); // ***UNSAFE*** removing const modifier
    if (filename == NULL) filename = "";
    else
      filename++;
      char *tmp2 = strrchr(filename,'.');
      if (tmp2 != NULL) tmp2[0] = 0; // ***BUG*** write access to constant string
Use pfc::string_filename to extract the filename instead:
pfc::string_filename filename(p_track->get_path());
Please fix your plugin as soon as possible, or we will have to ban it for corrupting the core's data structures.
foo_listeningto
But like Pescuma's plugin allows to make believe Miranda IM is WLM, foo_msn_alt works too.
But if I can, I prefer to use a plugin especially for Miranda IM, so I'll use yours.
You're a bit rude, foosion...
ps: thanks Zao for information.
foo_listeningto
Yeah, maybe they did it AT LAST!
I'll try.
----EDIT
Updated link in the first post to version 0.1.2.
Compiles with /MT (that is right, jarsonic?)
Extracts filename via pfc::string_filename class. I hope i did not messed up with object destruction. As you can see, i am not really fond of objects...
Oops. Looks like i forgot why i created a strdup from ptrack->get_path()  Well, i'll stick with pfc::string_filename now, since i used it already.
----EDIT
Updated link in the first post to version 0.1.3.
*sigh* Looks like i will never learn to write bug-free code. This time it is miscalculated estimated buffer length.
