Topic: Album Art Downloader XUI (Read 1607033 times) previous topic - next topic
Re: Album Art Downloader XUI
Reply #3050
Well, no joy here.
I did confirm again that KB5000841 DOES cause the issue [jpg will not display, tho png will],
but  KB5001639 DOES NOT fix it.
wating on MS to get it together....
Reply #3051
Discogs seems to have stopped working with AAD
Is there a new script available?
TiA
Reply #3052
Seems they are blocking by user agent. I've uploaded a v0.23 which identifies itself appending your machine name to the UA string, so hopefully Discogs will treat each user as an individual and block or allow them based on their own usage rather than as the application in general.
If it fails again, try changing the line starting request.UserAgent to, well, anything else. Your guess is as good as mine!
Reply #3053
Just tested it and it works. Really appreciated!
Reply #3054
awesome, thanks Alex!
Reply #3055
Hi everyone, I have been using older versions of all my audio tools for years now and have reached a point where I need to upgrade everything.
How does the current version of AAD integrate with fb2k?  (I've been using the COM automation server, and I seem to recall this was deprecated even way long ago but "it worked for me".)
Reply #3056
Hi, "coveralia" plugin is not longer working
Reply #3059
just want to mention, that the bandcamp.boo fails to do its work finding matching covers from the site.
check the screenshots. happens to almost all runs I do.
no covers, present on the webpages are shown.
can this be fixed? or is it just me?
and a big thank you for this very useful piece of code! helped us all the years! easy to use, speedy and no useless clutter!
Reply #3061
Unfortunately it looks like Bandcamp's search is just not very good. Album Art Downloader XUI will do a search on the site like: https://bandcamp.com/search?q=%22Night+Driver%22+%22Spectravision%22 and the results that I see there match your screenshot fairly well. As to why a search for "Night Driver" "Spectravision" doesn't return the album Spectravision by Night Driver as the first result, that's something you will have to take up with Bandcamp! I do note that it is better at searching album titles than artist names, so you might try just omitting the artist when you search?
Reply #3062
U're right, I could have checked the bandcamp search myself before, which I did not, because I assumed it will work. How wrong I was! Sorry! The bandcamp search is underwhelming.
 I try my luck and write a mail to them....
That worked much better, thanks for the hint!
Reply #3063
This is just a problem caused by a regression in wine, but I'll share here just in case it's useful.
Album Art Downloader has encountered a fatal error, and has had to close.
If you wish to report this error, please include this information, which
has been written to the file: C:\Program Files\AlbumArtDownloader\errorlog.txt
App version: 1.0.5.0, running on Microsoft Windows NT 6.1.7601 Service Pack 1 (64 bit)
System.DivideByZeroException: Attempted to divide by zero.
   at MS.Internal.AppModel.IFileDialog.Show(IntPtr parent)
   at Microsoft.Win32.FileDialog.RunVistaDialog(IntPtr hwndOwner)
   at Microsoft.Win32.CommonDialog.ShowDialog(Window owner)
   at AlbumArtDownloader.AlbumArt.SaveAs(Window dialogOwner)
   at AlbumArtDownloader.ArtSearchWindow.SaveAsExec(Object sender, ExecutedRoutedEventArgs e)
   at System.Windows.Input.CommandBinding.OnExecuted(Object sender, ExecutedRoutedEventArgs e)
   at System.Windows.Input.CommandManager.ExecuteCommandBinding(Object sender, ExecutedRoutedEventArgs e, CommandBinding commandBinding)
   at System.Windows.Input.CommandManager.FindCommandBinding(CommandBindingCollection commandBindings, Object sender, RoutedEventArgs e, ICommand command, Boolean execute)
   at System.Windows.Input.CommandManager.FindCommandBinding(Object sender, RoutedEventArgs e, ICommand command, Boolean execute)
   at System.Windows.Input.CommandManager.OnExecuted(Object sender, ExecutedRoutedEventArgs e)
   at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
   at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
   at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
   at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
   at System.Windows.Input.RoutedCommand.ExecuteImpl(Object parameter, IInputElement target, Boolean userInitiated)
   at MS.Internal.Commands.CommandHelpers.CriticalExecuteCommandSource(ICommandSource commandSource, Boolean userInitiated)
   at System.Windows.Controls.MenuItem.InvokeClickAfterRender(Object arg)
   at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
   at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
   at System.Windows.Threading.DispatcherOperation.InvokeImpl()
   at MS.Internal.CulturePreservingExecutionContext.CallbackWrapper(Object obj)
   at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
   at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
   at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
   at MS.Internal.CulturePreservingExecutionContext.Run(CulturePreservingExecutionContext executionContext, ContextCallback callback, Object state)
   at System.Windows.Threading.DispatcherOperation.Invoke()
   at System.Windows.Threading.Dispatcher.ProcessQueue()
   at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
   at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
   at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
   at MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg)
   at System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame)
   at System.Windows.Application.RunDispatcher(Object ignore)
   at System.Windows.Application.RunInternal(Window window)
   at AlbumArtDownloader.App.AlbumArtDownloader.IPriorInstance.Run()
   at AlbumArtDownloader.InstanceMutex.RunAppAsServiceHost(IPriorInstance instance, String channelUri)
   at AlbumArtDownloader.App.Main(String[] args)
Reply #3064
Thanks, but it looks like it's coming from inside the Windows common file "Save" window, not something under my control. You can probably work around it by setting the path to save as (just click on it to edit) without using Save As, and then just clicking Save.
Reply #3065
Perfect!  Thank you!
