Topic: Album Art Downloader XUI (Read 1555895 times) previous topic - next topic
Re: Album Art Downloader XUI
Reply #3025
I confirm that fanart.tv script is broken again. I can't figure out why though, I tried to update the script myself, I removed the "search" prefix from musicbrainz because that one seems not to work, but even that didn't fix it.
Either there's a problem with the script while searching for the musicbrainz ID or I just don't know what I'm doing. Even tried the update in this thread from last July but still no dice. Changing the settings all over doesn't help either.
Testing the API itself it seems to work so I don't know why the results aren't showing up in AAD. Hoping someone here could help. Thanks!
Reply #3026
I've updated discogs (v0.21) and Mordred's fanarttv (0.7), they should work again now. @jod773 the problem with fanarttv wasn't just the removal of search (although that was the correct first step), it was also that Musicbrainz was forbidding access without providing a meaningful identifying useragent.
Reply #3027
Hey! Thanks for clearing that up :) I really thought I did everything but I couldn't think of a way to test the script and see where the error happens.
Thank you for the fix!
Reply #3028
Thanks, Alex!
Reply #3029
Hey Alex, I just discovered today that discogs actually stores images greater than 600x600. For example, this is what discogs returns:
https://img.discogs.com/cTvdhiSkSuFI2Xq_oMJjzwTFLp4=/fit-in/600x609/filters:strip_icc():format(jpeg):mode_rgb():quality(90)/discogs-images/R-629210-1495380053-6160.jpeg.jpg
And this is the full size image:
https://www.discogs.com/image/R-629210-1495380053-6160.jpeg
You'll notice all you need to do from the original image string is:
for image in images:
fullImageMatch = Regex("discogs-images/(?<filename>.*jpeg).jpg", RegexOptions.IgnoreCase).Match(image.full)
if fullImageMatch.Success:
imageName = "https://discogs.com/image/" + fullImageMatch.Groups["filename"].Value
However, when I updated discogs.boo to actually implement this, when attempting to retrieve the fullsize image, everything it returns is max 300x300. I can't figure out what's actually going wrong here and was hoping maybe you had some ideas. Being able to get images larger than 600x600 from discogs would be huge.
