Topic: Album Art Downloader XUI (Read 1498082 times) previous topic - next topic
Re: Album Art Downloader XUI
Reply #2975
Why 4.7.2 and not 4.8? Installing 4.7.2 requires 4.0 -> 4.7 -> 4.7.2, while 4.8 requires 4.0 -> 4.8.
Reply #2976
Yes, that message is out of date. It is Framework 4.7 that should be installed, not 3.5.
4.8 might work just fine, but given that running things in wine can be quite finicky, I figured I would have the best chance using the version specified. My closest options within winetricks were 4.7.1 or 4.7.2. I tried the latter.
Reply #2977
Installing 4.8 in Wine is a lot less troublesome at this point than 4.7.2. And if you have esync or fsync enabled, it goes pretty quickly, too. Or maybe my current system is just that much faster than my previous one.
Reply #2978
Hello,
I really love your program you made Alex, but right now I have a problem that happened just out of nowhere.
When I try to download a cover, it just gives me an error message that the file cannot be saved because the "file cannot be found"
The error only occurs at v1.04 and above. v1.03 works perfectly fine but It's outdated.
Do you know why it's causing this error message? Will be much appreciated!
Edit: Never mind, fixed it. It was just Windows Security that prevented it.
Reply #2979
I'm taking some seconds to post an acknowledgement message. I've used this wonderful tool for years, it was about time to do so :)
THANKS !
Reply #2980
Hey, is there any prospect of fixing the Google Play Music connector? It's been broken for a while. :)
Reply #2981
The sources scripts database isn't updating. I can see the .boo files in the Scripts folder in AAD but the newer sources don't show up in the actual program. Any help?
Reply #2982
Seems to be working for me. Maybe it's just blacklisted your IP? Or if you give me the album you are searching for, I can try that.
Sorry, I don't understand the question. Are you getting an error message at startup, when it tries to compile the scripts? Is it a specific script that can't be loaded? Or you've added a script .boo file and AAD isn't trying to compile it at startup at all?
Reply #2985
Is the GoogleImage script just completely dead now or what?
Pretty much, unless they change again to make something less scraper unfriendly. Sorry.
https://sourceforge.net/p/album-art/support-requests/35/
I figured that was the case. I was trying to use google for another scraper and all calls were rejected too.
Reply #2986
It's the Allmusic.boo and Yandex.boo . When i start up Album Art Downloader there is a link at the bottom of the right-side panel that "new scripts downloaded". These are the two mentioned: allmusic.boo and yandex.boo. I click OK & restart the app and in my directory [C:\Program Files\AlbumArtDownloader\Scripts] both the .boo files are there but, they are not there in the side panel of the AAD app itself and i again have a message at the very bottom of the right-side panel that says New Scripts Downloaded... There is no error message. I hope  this post makes more sense to you.  I don't know the difference between "compiling" and "loading" them but, i just know that the two files are in the directory i mentioned above but not in the side panel of the app itself where you have the option to choose the Sources AAD uses and change the settings of them. Yandex and Allmusic are just not in that panel at all. And i always have that link to click on and it always has a pop-up window that shows the 2 .boo files it downloaded and when i click Restart they are still not in the Sources right-side panel.
Thanks. Love the app. I had been looking for something exactly like this for years now!
Reply #2987
It's the Allmusic.boo and Yandex.boo.
Sorry, it looks like those scripts are no longer available, the links are 404. They should not have been listed as New Scripts Downloaded, but for some reason the update check file wasn't properly updated - I think I've fixed that now.
