Topic: Errors (Read 2329 times) previous topic - next topic
Errors
Ok so I was getting the following errors with several of my files, not all of which I have ripped myself.
$ flac -d 01\ -\ \'New.\'.flac
flac 1.2.0, Copyright (C) 2000,2001,2002,2003,2004,2005,2006,2007  Josh Coalson
flac comes with ABSOLUTELY NO WARRANTY.  This is free software, and you are
welcome to redistribute it under certain conditions.  Type `flac' for details.
01 - 'New.'.flac: *** Got error code 0:FLAC__STREAM_DECODER_ERROR_STATUS_LOST_SYNC
01 - 'New.'.flac: ERROR while decoding data
                  state = FLAC__STREAM_DECODER_READ_FRAME
That's what they had in the first place. So I thought, maybe they have an ID3 tag in the beginning of them. So I removed this with id3v2 (I'm running Ubuntu), with the delete all command which is supposed to delete v1 and v2 tags.
$ id3v2 -D file.flac
Stripping id3 tag in "file.flac"...id3v1 and v2 stripped.
So then I try again and get the same and think maybe the Vorbis tag needs rewriting. So I go into EasyTag and resave the file. Apparently EasyTag is messed up cus now it gives this:
$ flac -t 04\ -\ Sacrificed\ Sons.flac
04 - Sacrificed Sons.flac: *** Got error code 0:FLAC__STREAM_DECODER_ERROR_STATUS_LOST_SYNC
04 - Sacrificed Sons.flac: *** Got error code 1:FLAC__STREAM_DECODER_ERROR_STATUS_BAD_HEADER
04 - Sacrificed Sons.flac: ERROR while decoding data
Yes the filenames are different because I am using a different file to show what this file originally did. Unfortunately, I didn't back up this one file the latter happened on because I was stupid. But I can re-rip it.
So now I do the -F feature and it gives me those errors plus an MD5 mismatch.
3467cafc8bfb82fe352e51c7b9824f84        04 - Sacrificed Sons.wav
d6cef12e7184181937c06e0f89342e3e        04 - Sacrificed Sons.flac
I reencode and I get this:
test.wav: 100% complete, ratio=0.711test.wav: WARNING: unexpected EOF; expected 28142268 samples, got 28135424 samples
I test it with -t and it tests and plays ok.
So am I ok or did I lose data?
Errors
Ok so I posted this a long time ago and this is the worst bump ever but I've been keeping two copies of these songs and I would like to get rid of the old ones or rerip them if they're bad so will someone please comment on this?
Errors
you lost data, probably only off the the beginning of the stream, and maybe not enough to notice (looks like only ~150msec worth.)
Josh
Errors
Josh
Thanks a lot. I'll probably re-rip them.
