Topic: A Great Idea ! (Read 2440 times) previous topic - next topic
A Great Idea !
Hi all !
I just had a nice idea, which would make life just 10 times easier for all the people who use Musepack, Vorbis, AAC etc !
Problem:
A lot of software (RealJukebox, RealOne, Sony "Open"MG, etc..) that are used for NetMD/MP3/SDMI/Other portable devices and other purposes, ONLY accept *MP3* and *WAV* as input..
The current, simple, but CUMBERSOME !! solution:
So you either have to use/create high-bitrates mp3's for temporary use, or decode the files to WAV :-(
The improved solution:
Create a software that creates a virtual drives, on which EVERY mpc/ogg/aac/mp4 you have on your sub-directories, becomes WAV !
How to do this ?
Well, this is about the same principle as encryption software such as BestCrypt/Scramdisk/E4M/PGPDisk/Safeguard easy and others...  Creating a virtual drive is not too difficult under windows, and we'd (generally speaking) perform "on-the-fly DECODING" instead of "on-the-fly DECRYPTION". Also, there would be no writing support to worry about.
We'd just have to simulate a drive that contains WAV. When a software accesses a data sector on the virtual drive, the corresponding compressed file is decompressed (from the encoded files on hard disk) and kept in a cache..  and the decoded, WAV data is returned to the bloatware, offending program :-)
Of course, each of the WAV file would be calculated (ie. decoded) on the 1st access.
This would have some REAL use, wouldn't it ?
Just imagine.. burning MPC files using NERO, without ANY temporary work !!!  :-) :-) :-)
Of course, there would be a setting in the software, to choose the kind of WAV decoding (ie: album/file/no gain;  noise shaping/none;  etc).
What do you guys think about all this ?
A Great Idea !
cool idea, but who realizes it?
A Great Idea !
I don't know..
That could be the next audio-related open source project :-)
It should not be too difficult to create a virtual FAT32, non-fragmented file system. Isn't E4M (the transparent encryption program) open-source ? That would help one to create a virtual drive. Then comes a very simplified version of FAT32 filesystem, and last - audio decoding.
The audio decoding should be very simple, by taking all code from mppdec.exe and VorbisLib...
Tag support would be nonexistent, at start.
EDIT: btw, linkin, have you seen ? I joined HA precisely one day after you
A Great Idea !
Cool...  Strange, this idea could be as well mine... Hope, that somebody will realize that! That would be really great!
