Topic: Public, Multiformat Listening Test @ 64 kbps - OPEN (Read 120993 times) previous topic - next topic
Reply #175
Test is not closed, yet!  But in case anyone is still testing, please hurry up - only a few hours left (can't say for sure - having some private work to do here before I can start evaluating the results).
Reply #178
my friends do the test! please 30 minutes!!!
OK Sebastian! He does the test and send to you to mail listening-tests dot info.
We wait the results!!!
Reply #179
Woah, somebody's excited!
Though I don't blame you; I am too!
Copy Restriction, Annulment, & Protection = C.R.A.P. -Supacon
Reply #180
Huh? So, your friends are still doing the test or what?
OK, the test is over! No results will be accepted any longer. A total of 43 people submitted results.
Reply #181
OK, no problem decrypting the results. I know that one user who also received a mail from me a few days ago had a problem with three results actually pointing to the same test session (= set of samples). This is something I encountered in all test so far (OK, I only conducted two others ) and have no idea why it happens. The encrypted results file differ, but once decrypted, you find out that several files correspond to the test for sample 15 for example.
Anyways, was wondering what to do when people submitted results in two or more "waves", but only the first wave of results contains a nickname. Should I add the nick to the other anonymous results, or mark them as anonymous? Two people are affected by this problem. Also sending out a mail...
Reply #182
Bleh, it's almost midnight and I've only finished sorting the results. Since I am very tired, I hope you don't mind if I just hunt the results through chunky and friedman and assemble a nice overall graph only. The graphs for each sample along with a full results webpage will be up tomorrow.
Edit: What was wrong with Sample 7 folks? So far, it has the most invalid results (ranked reference) - something like 7 IIRC!
Second Edit: Wow, a total of 40 results were invalid.  However, 470 results were valid!
Third Edit: In case anyone is interested, here's the number of valid results per sample:
Sample 01: 33
Sample 02: 33
Sample 03: 29
Sample 04: 29
Sample 05: 28
Sample 06: 27
Sample 07: 20
Sample 08: 21
Sample 09: 25
Sample 10: 21
Sample 11: 25
Sample 12: 27
Sample 13: 27
Sample 14: 24
Sample 15: 25
Sample 16: 26
Sample 17: 29
Sample 18: 21
Total: 470
Fourth Edit: Ah, missed an invalid result!
Reply #183
We want re-sults! We want results!
Reply #184
I'll start the count-down!
10
9
8
Reply #185
Third Edit: In case anyone is interested, here's the number of valid results per sample:(...)
These results can be compared with the previous ones (from August, 9th):
Aug 9 2007,   | Aug 15 2007
Sample 01: 18 |  33  (+15)
Sample 02: 18 |  33  (+15)
Sample 03: 16 |  29  (+13)
Sample 04: 17 |  29  (+12)
Sample 05: 15 |  28  (+13)
Sample 06: 14 |  27  (+13)
Sample 07: 11 |  20  (+9)
Sample 08:  9 |  21  (+12)
Sample 09: 12 |  25  (+13)
Sample 10: 10 |  21  (+11)
Sample 11: 11 |  25  (+14)
Sample 12: 11 |  27  (+18)
Sample 13: 13 |  27  (+14)
Sample 14: 11 |  24  (+13)
Sample 15: 10 |  25  (+15)
Sample 16: 10 |  26  (+16)
Sample 17: 12 |  29  (+17)
Sample 18: 11 |  21  (+10)
People were very active during the "bonus" period. It's a good point!
