Topic: mpc2cue problem (Read 2405 times) previous topic - next topic
mpc2cue problem
hi all....its been a long time since I posted anything in this forum...but I finally came up with a question...primarily to ca5e:
I'm using mpc2cue in my path to make a cue sheet at will from a command prompt whenever need be...using mpc2cue -f burn.cue  ...However, load that cue up into EAC and you'll notice there are no PREGAPS in the CUE sheet....this is rather bothersome considering most standalone players refuse to play non redbook standard cds. And if I load the tracks automatically from within EAC, they are always out of order...I like mpc2cue, but would like PREGAPS to be added before each INDEX. Anyone know how I can do this simply?
Thanks,
Axion
mpc2cue problem
The cue sheet is perfectly valid and doesn't violate any specs. Pregap is only mandatory before first track and cue standard doesn't allow invalid CDs in this respect, 2 second gap is added there automatically.
I could add sometimes option to add pauses between tracks.
mpc2cue problem
How come when I make a cue sheet and burn it, some songs start 2 seconds late, but appear to play fine in the Write CD dialog of EAC?
