Topic: Lyrics Show Panel (Modified version) (Read 490123 times) previous topic - next topic
0 Members and 5 Guests are viewing this topic.
Reply #76
Can you make the lyric box scrollable with the arrow keys? I'm aware that the lyrics are scrollable via a mouse scroll wheel, but not all of us use mice! I am a Lenovo laptop user who uses the trackpoint exclusively.
Reply #77
  • Optimized version for SSE2 ( build against /arch:SSE2)
When i update 0.3.1.1b5 , crash again
why~~~~~~~~
Code C000001Dh is EXCEPTION_ILLEGAL_INSTRUCTION. Probably your CPU does not support SSE2. That's not your fault though..
but i download the normal version  ,not the sse2 version ><"
Reply #78
why~~~~~~~~
It's my fault. I'll reupload the normal version soon.
EDIT I've Uploaded, try and see if it works.
Thanks, I'll try to solve this problem
Reply #79
  ....yeah~~
it works...
but when i try scrolling the lyrics, i click the panel ..
foobar will disappear(just like crash)..
but not  any crash logs.
Reply #80
  ....yeah~~
it works...
I don't know how it'll happen, sorry.
However I'll release a new version with titleformatting function $lpsetscroll(value) and $lpsetpos({top, middle, bottom}) and some others for scrolling
I'll add this feature: scroll by mouse dragging. However, now I don't have much time because I'm reviewing my courses for the terminal examination
Reply #81
When i click on the lyrics show panel i too get that wierd shutdown...dunno what causes it, but i use it with columns ui
Reply #82
  ....yeah~~
it works...
I changed some code(without Clicking the panel), may solve this problem.
here: http://www.hydrogenaudio.org/forums/index....t=0#entry499817
Reply #83
Hi, I've uploaded DEV version of Lyrics show panel
http://fb2k.theophile.googlepages.com/foo_uie_lyrics_DEV.7z
with this build, you can scroll lyrics with arrow keys.
Reply #84
I have found a minor issue with linebreaking: Sometimes the last word on a line is partially hidden because it does not break to a new line...
Reply #85
I really appreciate your hard work with this, but it is rather inferior to "Lyric Panel". Especially the newer version that can't really be found anywhere. Here is a link to it if anyone is interested:
Lyrics Panel
A few things this can do that Lyric Show can't:
- has a timestamp maker built in
- more flexible with colors (6 instead of 4)
- decrease font size if the lyric line is to long (prevents word wrapping)
- has gradual (per line I think... can be user defined), and auto scroll
- line spacing
- can backup settings
- looking for lyrics is a lot more simple
- right click on the panel, and if you have lyricDB installed, you can search it (technically the playlist right click menu is just added to the panel right click menu)
- can execute commands when no lyrics are found/or when they are found
- more lyrics align options (left, center-left, center, center-right, right)
And more that I haven't mentioned, or just don't use myself. Would it be possible to make this component have a transparent background also? Thats the only thing missing I think... everything else is really great .
Song List: keikoniumboards.ke.funpic.org/files/songlist.html
Reply #86
Thanks, but I can't get it to work!
I've tried a bunch of combinations in preferences, but with no results. I've tried using both Up/Down and Left/Right, but with no success. What do I have to do to scroll?
Also, the lyric text has ClearType disabled. How do I enable it?
I'm using Columns UI and the Lyrics Panel is in a "Tabbed panel stack mod".
Reply #87
wow this new database is just right !
it finds lyrics for almost every song now !
thank you alot for this !
a new small request tho:
could you change the panel so that if it only found .txt-lyrics for a song so far that he will look for .lrc-files everytime and preferably download them?
and if you then also include the autoscroll for txt lyrics the panel will be perfect!
youre doin a  great job man! best regards!
- creative x-fi extreme music
- sennheiser 650hd
- F U B A R++
Reply #88
Thanks, I'll fix this in next version.
Lyrics Panel
- line spacing
Thank you for your advice.
I'll add some of them in the future.
If I had the source, I would add "transparent background"
So It seems that I should add some keybrd shortcuts mapping, the panel won't handle the key events well if it doesn't have focus, I'll try to fix that in the next version.
ClearType setting is depend on the configuration in your Display properties" -> "Appearance" -> "Effecrt".
I'll consider to add an opnion in the panel.
thank you!
But I'm now busying with the final exam, so it will take me to have these done.
Reply #89
I have ClearType enabled. I tried changing the font in the lyrics panel, and much to my surprise, ClearType is enabled in every font except for the one I prefer, Calibri. Why would that be? I have Calibri as my default sans serif font for everything, including FB2K and it works fine with ClearType. Bizarre.
As for the scrolling. I managed to get it to scroll when it was it's own panel, but not when it was a tab in a foo_uie_tabs tab aka "Tabbed panel stack mod". Would you please make it so it's scrollable in a foo_uie_tabs tab?
Or maybe I'm not giving it focus. I've tried clicking and double clicking on it? Is there anything else I should try?
PS: Here's a screenshot to give you a visualization of my problem:
Reply #90
Now I add a new feature, so you can scroll nontimestamped lyrics with drag.
It seems that gdiplus didn't accept ClearType setting with DrawString(), so I changed it into AA.
check the new DEV version, I've uploaded the new one.
Reply #91
Perhaps my previous post was a bit unclear.
I've tried the latest version of the lyrics panel (0.3.1.b6), but had a few problems with it:
-ClearType/AA doesn't work with my preferred font, Calibri. It's works with every other font I've tried, but not Calibri.
-The lyrics panel is scrollable with the arrow keys except when it's tabbed using foo_uie_tabs (v. 0.2.5).
This screenshot: shows the problems quite clearly. Is it possible to correct them?
Thanks, and sorry for the unclear previous post.
Reply #92
Now I have no idea  to scroll with arrow keys using foo_uie_tabs
Have you tried the newest DEV version?
Reply #93
I'm using the newest DEV version of your lyrics panel and the latest version of foo_uie_tabs. I can't get the panel to scroll even when it is by itself outside of foo_uie_tabs. It also won't allow ClearType on a very common font called Calibri.
Reply #94
Hello,
I have 2 (or maybe 3) problems with this plugin.
1) Sometimes (not each time),  when theres no lyrics available for a song, the plugin displays the lyrics of another song of the same artist. My LRC files are all in one folder, and named in the format %artist% - %title%. In the settings, thz only scheme for filenames is : $if(%artist%,%artist%' - ')$if2(%title%,%_filename%). So I don't understand why it  act like this...
2) When I activate transparent Background, first the background is not transparent (it keep the color it has when trasparency is off, black in my case), second (but it's probably the same thing) the panel is not refreshed, so the line stay displyed at there first position when srolling (I don't know if I explain well, see screenshot), or when a window have been over the panel, the image remains.
(the sreenshot displays the 2 things, lyrics from 1979 when Siva is played, and panel not refreshed)
Is there something I've forgotten to do?
Reply #95
1. Now I've no idea to get arrow keys scrolled in foo_uie_tabs, however, these a alternate way to scroll: Hold left mouse button and move the mouse up and down. I'm now looking into the foo_uie_tabs' source and maybe I can solve the problem.
2. It seems that I should do some more work to enable ClearType on these new fonts.
Hello,
1) It seem that your "Match error level" is too high.
2) Can you post the code where you place the panel?
Reply #96
1) Oh, yes, my mistake, I hadn't seen this slider
2)The code is like that :
$ifequal($getpvar(display.mode),3,
     $panel(TIM-Lyrics,Track Display,0,$eval($get(offset-top)+$get(playlist-lgy)+2),$eval(%_width%-$get(playlist-lgx)),$eval(%_height%-$get(offset-top)-$get(offset-bot)-$get(lgy-botswapper)-$get(playlist-lgy)-2),)
     $panel(Lyrics,Lyric Show,$eval(0+15+17),$eval($get(offset-top)+$get(playlist-lgy)+84+25+1-80-{$getpvar(fulls)*2}),$eval(%_width%-$get(playlist-lgx)-30-29-5),$eval(%_height%-$get(offset-top)-$get(offset-bot)-$get(lgy-botswapper)-$get(playlist-lgy)-87-35-1+81+{$getpvar(fulls)*2}),)
TIM-Lyrics contains the code to draw the frame, but it seems that's this line that makes problems (all works good when I comment it)
Reply #97
It's fixed in the latest DEV version
Now there's no problem with fading effect with latest DEV version
Add you can see if you can set focus to lyrcs show panel with double click.
Alternate way to scroll lyrics you can see my previous post.
It's not recommended to use one panel to overlay another panel.
PS: you can use "codebox" instead of "code"
Reply #98
for a few days now the panel doesnt seem to find anything anymore. and when i manually use the online search function it doesnt even say "nothing found" anymore. ive tried both the regular and the dev version.
has anyone else got this problem too ?
ps: i just saw that you have included the txt-scroll in the dev version ! works really well. but could you disable the manual scrolling then ? thank you already !
and btw: my lyrics db search has "network problems" too so maybe thats why my lyrics panel doesnt find anything anymore.
another edit: i take back that id like the manual scroll disabled for txt-lyrics. i really like that now cause you can correct them if they are ahead or behind the song.
so good job ! i only hope its goona find some lyrics again soon
- sennheiser 650hd
- F U B A R++
Reply #99
First, i just love that new version, everything works perfectly. The new server for lyrics is great, i find almost everything.
I have a feature request : the possibility to have more than one instance of the panel. I know it s quite a lot of work but it would be awesome. I would allow me to create a popup for lyrics on my second display(video projector) with bigger font for easy reading.
