Topic: Lyrics Show Panel (Modified version) (Read 487775 times) previous topic - next topic
T.P Wang,
thank you, that is great, autoscroll work's nice when using timestamped lyric
T.P Wang i also thanks you very much. it works for me too. even wheel scroll.
But which is difference between the two zip in download section... what is SSE2 (with this one wheel scroll doesn't work).
i m very grateful too you for the development of this component i use everyday.
Cheers
Cheers
SSE2 means Intel Streaming "Single Instruction, Multiple Data" Extensions 2
http://en.wikipedia.org/wiki/SSE2
so if you haven't got CPU supports SSE2, there will be problems.
Besides, the SSE2 build with some options may be "unstable", so if you meet any problem, switch to the build without "SSE2"
Thanks for support.
Thanks you very much for adding the nice fading effect, I didn't expect it that quickly...
But I noticed a little problem with it, don't know how to explain it... I'll try. The fading efftect is nice when the line appears from the bottom. But at a certain point, it suddently becomes unfaded, while it should still be faded, because still in the fade zone...
Same thing happens at the top, the line suudently becomes faded.
Did anybody else noticed it ?
Maybe you did that on purpose ?
Just a small request as well, could you make an option to enable/disable the fading effect ?
Thanks a lot
Thanks a lot
EDIT: Yes I make the fadding effect on that purpose
However, ,I'll try to fix it ASAP.
Could anybody post their CPU usage while the text is scrolling, please?
I would like to have a panel with big letters on a black full screen but I'm afraid it could keep the usage at 40/60%.
You better test it yourself,since the CPU usage is quite different from machine to machine.As for me the CPU
is pretty high when i use this panel,even with plain text,so i returned to my own lyrics panel.
Favourite artist:CD-R
Favourite album:700MB
Reply #32
Found a small "bug" I think.
When you start a new song it seems like the Lyrics window gets focused. So you can't scroll in the playlist etc without clicking in it again. It doesn't matter if the lyric is a timestamped or not, the window always gets focused.
Ok, I'll fix it.
Reply #34
YAS ! you have just completed my foobar ! thank you alot flippin lot !
only one small request:
could add an option to auto-scroll non-timestamped lyrics ?
THANK YOU !
- creative x-fi extreme music
- sennheiser 650hd
- F U B A R++
Reply #35
Thanks a lot
I've uploaded new Lyrics show panel ver 0.3.1.1b3
Just have a try
Reply #36
I just have a little test(not very strict), using Microsoft's perfmon.msc to monitor foobar2000's CPU time(%)
after played same song(APE 980kps), and under same playing condition(mostly)
I've got these result (average)
1. using Lyrics Panel
6.613%
2. no Lyrics Panel
4.820%
I'm using Althlon64 3000+, WinXP Pro Sp2. with 0.3.1.1b3 quick fix(SSE2).
Reply #37
thanks for the modification. I have one big request, but I don't know if it is possible at all. I would like to see this panel merged with the functionality of this version. Also it would be nice to include LyricsDB search. It uses a really big lyrics database. I think it should be possible at least to call this plugin to search for lyrics if they're not found.
Reply #38
Ok, there is a problem for me with the fading effect. The fadinfg effect is not at the very top and very botom, seems that it is 10 px from each border, at least for me... (using panels_ui)
Reply #39
I'd like to add LyricDb searching support.
But I'm wondering what kinds of foo_uie_lyrics_panel's functions do you want?
strange, I'm trying to find out.
EDIT: can you post snippet of your code which $panel the Lyrics Panel? And which font do you use?
EDIT2: I think i've found the problem, you can change your Vertical Padding and Horizontal Padding to "0", I'll fix it.
Reply #40
Yep, that solved my problem, now the component is perfect for me !
thanks a lot !
Reply #41
feel like Not compatible with foo_dockable_panels.dll
Illegal operation:
Code: C000001Dh, flags: 00000000h, address: 00F3707Ch
Call path:
entry=>app_mainloop
Code bytes (00F3707Ch):
00F3703Ch:  00 00 39 5C 24 34 89 6C 24 30 73 04 8D 44 24 20
00F3704Ch:  BE 09 00 00 00 66 89 28 39 74 24 34 73 10 8B 44
00F3705Ch:  24 30 50 56 8D 4C 24 24 51 E8 86 CF FE FF 39 5C
00F3706Ch:  24 34 8B 44 24 20 73 04 8D 44 24 20 66 0F EF C0
00F3707Ch:  66 0F D6 00 66 0F D6 40 08 66 89 68 10 39 5C 24
00F3708Ch:  34 8B 44 24 20 89 74 24 30 73 04 8D 44 24 20 66
00F3709Ch:  89 68 12 39 5C 24 34 8B 44 24 20 73 04 8D 44 24
00F370ACh:  20 B9 FA 00 00 00 C7 00 00 00 00 44 C7 40 04 00
Stack (0012E998h):
0012E978h:  00000000 0012ED2C 0012ED04 00000000
0012E988h:  F15BBF98 F15BBCA0 00460049 F15BBD60
0012E998h:  D10C7014 00F63C40 00F63BFC 0012EA0C
0012E9A8h:  00F63BF0 000905DA 00F63BF0 00F20761
0012E9B8h:  01234BB0 0012EA04 00F63BFC 01234B98
0012E9C8h:  00000000 000000A7 D10C7024 0012EA84
0012E9D8h:  00F4E338 00000000 00F130AD 00F63BF0
0012E9E8h:  0012EB60 0012EA74 00F63BEC 004576E3
0012E9F8h:  00000000 00F63BFC 00000000 00F63C40
0012EA08h:  FFFFFFFF 0012EA90 0045670D 000905DA
0012EA18h:  0012EB60 00456932 00000000 000A0000
0012EA28h:  005DA330 77F16E56 77F16E77 510A0A33
0012EA38h:  6FBD7000 6FBD71C8 6FB8A1E2 6FBDB0D0
0012EA48h:  0012EA60 77D4F8A6 006F5928 00000000
0012EA58h:  000C0000 0012EAF8 0012EAE0 00B02647
0012EA68h:  00000000 00000000 00000000 00F63BEC
0012EA78h:  0012EAE0 0012EAF8 0012EA18 0012EAEC
0012EA88h:  004A9A16 00000001 0012EAF8 00456B60
0012EA98h:  000905DA 015024D8 0012EB60 00456932
0012EAA8h:  00000000 77D54F1C 77D618FC 00000000
Registers:
EAX: 01234BB0, EBX: 00000008, ECX: D10C700C, EDX: 01230608
ESI: 00000009, EDI: 00F63C40, EBP: 00000000, ESP: 0012E998
Crash location: "foo_uie_lyrics", loaded at 00F10000h - 00F6F000h
Loaded modules:
foobar2000                      loaded at 00400000h - 004F3000h
ntdll                            loaded at 7C900000h - 7C9B0000h
kernel32                        loaded at 7C800000h - 7C8F5000h
COMCTL32                        loaded at 773D0000h - 774D3000h
msvcrt                          loaded at 77C10000h - 77C68000h
ADVAPI32                        loaded at 77DD0000h - 77E6B000h
RPCRT4                          loaded at 77E70000h - 77F01000h
GDI32                            loaded at 77F10000h - 77F57000h
USER32                          loaded at 77D40000h - 77DD0000h
SHLWAPI                          loaded at 77F60000h - 77FD6000h
SHELL32                          loaded at 7C9C0000h - 7E37F000h
ole32                            loaded at 774E0000h - 7761D000h
shared                          loaded at 10000000h - 10029000h
comdlg32                        loaded at 763B0000h - 76405000h
IMM32                            loaded at 76390000h - 763AD000h
LPK                              loaded at 629C0000h - 629C9000h
USP10                            loaded at 6FB80000h - 6FBFD000h
prio                            loaded at 003F0000h - 003F5000h
uxtheme                          loaded at 5AD70000h - 5ADA8000h
MSCTF                            loaded at 74720000h - 7476C000h
YzShadow                        loaded at 00AE0000h - 00AEE000h
DM2                              loaded at 00B00000h - 00B06000h
msctfime                        loaded at 755C0000h - 755EE000h
foo_converter                    loaded at 00B30000h - 00B99000h
foo_cwb_hooks                    loaded at 00BC0000h - 00C0D000h
foo_dockable_panels              loaded at 00C30000h - 00C63000h
foo_infobox                      loaded at 00C90000h - 00CD0000h
foo_input_monkey                loaded at 00CF0000h - 00D3A000h
foo_input_std                    loaded at 00D60000h - 00E73000h
foo_masstag                      loaded at 00EA0000h - 00EEF000h
foo_uie_lyrics                  loaded at 00F10000h - 00F6F000h
WININET                          loaded at 771B0000h - 7727E000h
Normaliz                        loaded at 00F80000h - 00F89000h
iertutil                        loaded at 6E850000h - 6E895000h
gdiplus                          loaded at 4EC50000h - 4EDF3000h
WINMM                            loaded at 76B40000h - 76B6D000h
foo_uie_playlists_dropdown      loaded at 01240000h - 01279000h
foo_uie_single_column_playlist  loaded at 012A0000h - 012EC000h
MSVCP80                          loaded at 7C420000h - 7C4A7000h
MSVCR80                          loaded at 78130000h - 781CB000h
foo_uie_tabs                    loaded at 01310000h - 0133A000h
foo_uie_trackinfo_mod            loaded at 01360000h - 013B7000h
foo_ui_columns                  loaded at 013D0000h - 01473000h
foo_utils                        loaded at 014A0000h - 014D8000h
imagehlp                        loaded at 76C90000h - 76CB8000h
DBGHELP                          loaded at 59A60000h - 59B01000h
VERSION                          loaded at 77C00000h - 77C08000h
Stack dump analysis:
Address: 00F63C40h, location: "foo_uie_lyrics", loaded at 00F10000h - 00F6F000h
Address: 00F63BF0h, location: "foo_uie_lyrics", loaded at 00F10000h - 00F6F000h
Address: 00F20761h, location: "foo_uie_lyrics", loaded at 00F10000h - 00F6F000h
Address: 00F4E338h, location: "foo_uie_lyrics", loaded at 00F10000h - 00F6F000h
Address: 00F130ADh, location: "foo_uie_lyrics", loaded at 00F10000h - 00F6F000h
Address: 00F63BECh, location: "foo_uie_lyrics", loaded at 00F10000h - 00F6F000h
Address: 004576E3h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0045670Dh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00456932h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 77F16E56h, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "DeleteObject" (+00000229h)
Address: 77F16E77h, location: "GDI32", loaded at 77F10000h - 77F57000h
Symbol: "DeleteObject" (+0000024Ah)
Address: 6FBD7000h, location: "USP10", loaded at 6FB80000h - 6FBFD000h
Address: 6FBD71C8h, location: "USP10", loaded at 6FB80000h - 6FBFD000h
Address: 6FB8A1E2h, location: "USP10", loaded at 6FB80000h - 6FBFD000h
Symbol: "ScriptPlace" (+000000E9h)
Address: 6FBDB0D0h, location: "USP10", loaded at 6FB80000h - 6FBFD000h
Address: 77D4F8A6h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "CallNextHookEx" (+0000003Bh)
Address: 00B02647h, location: "DM2", loaded at 00B00000h - 00B06000h
Symbol: "CreateMenuFromString" (+00000D27h)
Address: 004A9A16h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00456B60h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 77D54F1Ch, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "PostQuitMessage" (+000002CBh)
Address: 77D618FCh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "UnhookWinEvent" (+00000077h)
Address: 77D9ABF4h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetRawInputDeviceInfoA" (+0000011Fh)
Address: 004AD1EEh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 77D48744h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetDC" (+0000006Dh)
Address: 77D54ECBh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "PostQuitMessage" (+0000027Ah)
Address: 77D7046Fh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DeregisterShellHookWindow" (+000001CFh)
Address: 77D54EF0h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "PostQuitMessage" (+0000029Fh)
Address: 77D54D17h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "PostQuitMessage" (+000000C6h)
Address: 77D54F22h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefDlgProcW" (+00000000h)
Address: 77D54F44h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefDlgProcW" (+00000022h)
Address: 77D48826h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetDC" (+0000014Fh)
Address: 77D48840h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetDC" (+00000169h)
Address: 77D4B4D0h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcW" (+00000184h)
Address: 77D4B4E0h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcW" (+00000194h)
Address: 77D4B51Ch, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcW" (+000001D0h)
Address: 7C90EAE3h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "KiUserCallbackDispatcher" (+00000013h)
Address: 77D4B483h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcW" (+00000137h)
Address: 77D494CEh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetWindowLongA" (+00000061h)
Address: 77D4D4F4h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "SetPropW" (+000000BBh)
Address: 77D4B913h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "SendMessageW" (+00000049h)
Address: 773EAFF1h, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "Ordinal414" (+00000FB4h)
Address: 77407392h, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "Ordinal384" (+0001B4F2h)
Address: 77407720h, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "Ordinal384" (+0001B880h)
Address: 77D4BF88h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "RedrawWindow" (+0000000Ch)
Address: 7740885Ch, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "Ordinal384" (+0001C9BCh)
Address: 774096BDh, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "Ordinal384" (+0001D81Dh)
Address: 7740AF3Fh, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "Ordinal384" (+0001F09Fh)
Address: 7740A549h, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "Ordinal384" (+0001E6A9h)
Address: 77D4883Ah, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetDC" (+00000163h)
Address: 77D4B8CAh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "SendMessageW" (+00000000h)
Address: 77D4D8A0h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetDlgCtrlID" (+00000027h)
Address: 00F54738h, location: "foo_uie_lyrics", loaded at 00F10000h - 00F6F000h
Address: 77D56950h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "SendDlgItemMessageW" (+00000032h)
Address: 00456D0Ah, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00F54728h, location: "foo_uie_lyrics", loaded at 00F10000h - 00F6F000h
Address: 004C07D0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 77D55324h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefDlgProcW" (+00000402h)
Address: 004EE568h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 77D55B68h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetWindowTextLengthW" (+00000547h)
Address: 004EE3F8h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00400000h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004EE450h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004EE558h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004EE564h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E0213h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 77D55E8Ch, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "CreateDialogIndirectParamAorW" (+00000033h)
Address: 77D5A1AFh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "CreateDialogParamW" (+00000049h)
Address: 00456E73h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00466549h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00F1852Ah, location: "foo_uie_lyrics", loaded at 00F10000h - 00F6F000h
Address: 004DF5FCh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 77D4F818h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "EnableMenuItem" (+00000081h)
Address: 77D4F815h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "EnableMenuItem" (+0000007Eh)
Address: 77D4F95Bh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "CallNextHookEx" (+000000F0h)
Address: 77D4F96Bh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "CallNextHookEx" (+00000100h)
Address: 013F7415h, location: "foo_ui_columns", loaded at 013D0000h - 01473000h
Address: 77D4F829h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "EnableMenuItem" (+00000092h)
Address: 00460088h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 77D9CB2Eh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "TrackPopupMenuEx" (+0000000Ch)
Address: 77D94EF9h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "TrackPopupMenu" (+0000001Bh)
Address: 00F1848Eh, location: "foo_uie_lyrics", loaded at 00F10000h - 00F6F000h
Address: 00F50065h, location: "foo_uie_lyrics", loaded at 00F10000h - 00F6F000h
Address: 00F184A4h, location: "foo_uie_lyrics", loaded at 00F10000h - 00F6F000h
Address: 00F17499h, location: "foo_uie_lyrics", loaded at 00F10000h - 00F6F000h
Address: 77D488EAh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetWindowLongW" (+00000034h)
Address: 00F501E1h, location: "foo_uie_lyrics", loaded at 00F10000h - 00F6F000h
Address: 77D4D63Bh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "SetWindowLongW" (+00000000h)
Address: 00F223BCh, location: "foo_uie_lyrics", loaded at 00F10000h - 00F6F000h
Address: 00F22370h, location: "foo_uie_lyrics", loaded at 00F10000h - 00F6F000h
Address: 77D488E1h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetWindowLongW" (+0000002Bh)
Address: 00C333ABh, location: "foo_dockable_panels", loaded at 00C30000h - 00C63000h
Address: 00C332F0h, location: "foo_dockable_panels", loaded at 00C30000h - 00C63000h
Address: 77D5F5A6h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "SetWindowTextA" (+0000005Bh)
Address: 77D4850Ch, location: "USER32", loaded at 77D40000h - 77DD0000h
Address: 77D485B4h, location: "USER32", loaded at 77D40000h - 77DD0000h
Address: 77D4B409h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcW" (+000000BDh)
Address: 77D4B3A3h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcW" (+00000057h)
Address: 77D4B3C0h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcW" (+00000074h)
Address: 77D4C341h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "SetRectEmpty" (+0000004Fh)
Address: 77D54DF1h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "PostQuitMessage" (+000001A0h)
Version info:
foobar2000 v0.9.4.3
UNICODE
Additional info:
Columns UI 0.2.0 alpha 2  (foo_ui_columns)
Playlists Dropdown 0.6 alpha 3  (foo_uie_playlists_dropdown)
Playlist Tools 0.5.9  (foo_utils)
Track info panel mod 0.8.0 beta [Dec  6 2006 - 14:21:24]  (foo_uie_trackinfo_mod)
Converter 1.0.1  (foo_converter)
WMA Decoder 1.1  (foo_input_std)
cwbowron's title format hooks 1.2.5 [Jun  8 2007 - 08:49:42]  (foo_cwb_hooks)
Dockable Panels 1.0.7b [Mar 28 2007 - 09:18:48]  (foo_dockable_panels)
Tabbed panel modified 0.2.5  (foo_uie_tabs)
Masstagger 1.6  (foo_masstag)
Monkey's Audio decoder 2.1.2  (foo_input_monkey)
Special file info box 2.0.4  (foo_infobox)
Single Column Playlist Display 0.5.4 beta [Jan  9 2007 - 15:42:59]  (foo_uie_single_column_playlist)
foobar2000 core 0.9.4.3  (Core)
Tagger Panel Window 1.0.5 [Jun 12 2007 - 15:14:00]  (foo_cwb_hooks)
Lyric Show Panels 0.3.1.1b3 [Jun 23 2007 - 16:14:36]  (foo_uie_lyrics)
FLAC Decoder 1.1.0  (foo_input_std)
Reply #42
Great work!
May i know what's the difference between ZN-CH and ZN-CH Special ? what's the special for?
.:: Evchenic.S+udio ::.
Reply #43
@ store88
Use "codebox" instead of "quote"!
Reply #44
Great work!
the differences are:
in ZH-CN Special you can specify english font and chinese font.
Since I work on the component, for some reasons, I haven't build ZhCN.Special
There's only ZhCN available:
http://bbs.pcpchina.com/index.php?showtopic=126534
Reply #45
@store88:
use codebox please!
There's no crash on my machine.
But it's not recommended that use lyric panel with PanelsUI and dockable panels.
However, I think it's because foo_uie_tabs or foo_uie_single_column_playlist
Core (2007-04-21 03:36:34)
foo_albumlist.dll (2007-04-21 03:34:58)
    Album List 3.2.0
foo_audioscrobbler.dll (2007-05-13 14:23:40)
    Audioscrobbler 1.3.6
foo_cdda.dll (2007-04-21 03:34:44)
    CD Audio Decoder 2.1.1
foo_converter.dll (2007-04-21 03:34:28)
    Converter 1.0.1
foo_convolve.dll (2006-08-04 21:57:26)
    Convolver 0.3
foo_cwb_hooks.dll (2007-06-05 10:10:00)
    cwbowron's title format hooks 1.2.4 [Jun  5 2007 - 10:09:39]
    Tagger Panel Window 1.0.beta3 [Jun  5 2007 - 10:09:39]
foo_dockable_panels.dll (2007-03-28 09:19:02)
foo_dsp_bs2b.dll (2006-11-14 14:42:36)
    bs2b 2.1.0
foo_dsp_crossfader.dll (2007-06-13 00:02:08)
    Gapless Crossfader 0.3.2.2 (Intel SSE)
foo_dsp_delta.dll (2006-03-21 18:16:22)
    LPCM <--> delta-PCM converter 0.1.1
foo_dsp_std.dll (2007-01-20 07:36:56)
    Standard DSP array 1.0
foo_dsp_tube.dll (2007-02-07 07:17:55)
    Tube Sound 0.8
foo_freedb2.dll (2007-01-22 13:07:44)
    freedb Tagger 0.5.2a
foo_input_monkey.dll (2007-04-13 18:39:54)
foo_input_std.dll (2007-04-21 03:34:22)
    FLAC Decoder 1.1.0
    WMA Decoder 1.1
foo_masstag.dll (2007-04-21 03:33:44)
    Masstagger 1.6
foo_masstag_addons.dll (2007-05-20 08:00:08)
    Masstagger Addons 0.3.4 (Intel SSE)
foo_out_ks.dll (2006-08-04 21:54:58)
    Kernel Streaming Output 1.2.2
foo_playcount_mod.dll (2007-06-21 14:53:34)
    Play Count Mod 1.0.2
foo_playlist_manager.dll (2006-03-13 00:25:15)
    Playlist Manager 1.0
foo_rgscan.dll (2007-04-21 03:33:22)
    ReplayGain Scanner 2.0.2
foo_run.dll (2006-06-15 22:08:10)
    Run services 0.3.2
foo_ui_columns.dll (2007-06-08 00:22:56)
foo_ui_panels.dll (2007-06-12 12:28:20)
    Panels UI 0.13.8 beta [Jun 12 2007 - 12:28:00]
foo_ui_std.dll (2007-04-21 03:33:14)
    Default User Interface 0.9acc
foo_uie_albumart.dll (2007-01-15 17:04:44)
    Album Art Panel 0.2.6
foo_uie_albumlist.dll (2007-06-11 21:13:53)
    Album list panel 0.2.3 beta
foo_uie_lyrics.dll (2007-06-23 15:27:53)
    Lyric Show Panels 0.3.1.1b3 (SSE2) [Jun 23 2007 - 15:27:29]
foo_uie_playlists_dropdown.dll (2007-02-08 15:26:16)
foo_uie_quicksearch.dll (2007-05-18 13:31:10)
    Quick Search Toolbar 2.8l
foo_unpack.dll (2007-04-21 03:35:14)
    RAR reader 1.1
    ZIP/GZIP reader 1.0
Reply #46
Downloaded the new version, and it still steals focus for me.
I am using Panels UI, and I have a panel on the left where i can change between lyrics, art and some more things using pvars. It's just when the lyrics is "active" or how to say that it steals focus from the SCPL.
Hope you understand my bad english.
Reply #47
I got it.
But I think it's not bug. because i can't find a way to Handle Mouse wheel event without setting focus.
Reply #48
I got it.
Okok.. well it was just a small problem, I rather have it like this and being able to scroll the lyrics... Great work with this!
But I also have library filter in that panel I noticed, and in that you can scroll, but it doesn't automatically take focus when a new song is being played.... Maybe there is a way? In any way thanks for your work, this component really needed this.
Reply #49
I got it.
if you want to scroll with mouse wheel, just click the Library filter/SCPL and so on...
