Topic: Peakmeter for Columns UI (Read 209530 times) previous topic - next topic
Very nice, but could it have an option to make it vertical ?
I second this.
also could it be possible for the range of the meter to be customised from -60dB to +10dB to say -30dB to +3dB or what ever the person wants. So the meter will be a smaller dB range but the physical onscreen length is still the same (basically makes the meter move more).
- In one of the next versions it will be possible to show the bars also vertically. The code is already prepared for that.
- I will think about a free configuration of the range. It's really a good idea.
This is awesome!
I second the request to make this vertical, and the request for customizable dB levels. Inputting our own (like an "Add New" button to add entries, and a "Remove" to remove entries) would be nice .
EDIT: Also, if we could export our settings (like all the colors and settings) to a file and then import them into a second or whatever peakmeter that would be great too. I want to put the left channel on the left side of my playlist, and the right on the right side, but thats a lot of manual color typing and I am lazy lol.
I can see potential for this component. Keep up the good work!
Thank you! "Add New" + Remove": When i implement the idea of PedroElGringo (customizable dB levels) this will be implemented too.
EDIT: it will be implemented in one of the next versions.
Wow. Best vis ever for Foobar. Good job.
A few suggestions though.
* Center everything in available space (vertically I mean).
* Ability to remove the L, R in the beginning of a meter.
* Padding, left and right.
* Peak falloff feature, with time setting.
* Currently there doesn't seem to be an option available to flip the meters to go from bottom up instead of left right.
Keep up the good work.
Thank you for the helpful suggestions!
Also it would be nice to change the color of the small channelboxes (or am I blind?), and the possebility of removing them. I didn't see the possebility of changing the falloff indicator color.
And another vote the for vertical meters
It would be nice if you could add some channel configuration condition, so only the channels in use would be displayed.
Bug(/Annoyance): It seems that the falloff indicator are based on the current track, since I've never seen it actually fall off. Could you add a (configurable) timeout to it, as they would normally act?
But this is a really cool plugin!
Thank you! Yes, you are right. The possebility to change the color or hide the channelboxes is not implemented -> Next version. Changing the falloff indicator color: -> Next version. Configurable timeout for the falloff indicator -> I will think about it.
Another suggestion... Ability to have multiple peakmeter panels, with different settings. Then one could create a mirror effect like the one in WMP11.
EDIT: Oh, then you would also need the ability to reverse peaks.  Well, it's up to you how much coolness you wanna add.
supercool. keep it up!
Reply #30
I can add more than one of these panels to my columns UI config and have different settings for each  .
Hummm...  I cannot seem to get it to work with Panels UI.
I have all the latest components installed, and have libmmd.dll , libpng13.dll ,  and zlib1.dll  in the install directory.
I used this code to make a panel appear:
/////////////Equalizer Panel///////////////
$panel(Equalizer,Peakmeter,24,470,200,70,)
The box showed up, and then I right-clicked and got into preferences, and set them exactly as shown in the example photo that was posted, just to get me going.
The background changed from black to grey after I applied the preferences, but when I play a song, nothing happens.  I only see a grey rectangle.
Would someone suggest to me what I'm not doing correctly here?    Thanks!
I tried to simulate this on my W2K-PC (with GDI+): no failure, it works fine. But under XP the component don't get it's initial values automatically. I think it' a bug in Panels UI. Before the next release I'll try to find the cause of defect.
Reply #33
Crash location: "foo_uie_peakmeter" -- I have the component inside a Panels UI window if that helps any.
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 03334F96h
Access violation, operation: read, address: E553D1F8h
Call path:
entry=>app_mainloop=>titleformat_object::run
Code bytes (03334F96h):
03334F56h:  8D 4C 24 18 51 89 44 24 34 C7 44 24 38 00 00 00
03334F66h:  00 C7 44 24 40 B0 A1 34 03 FF 15 70 81 34 03 66
03334F76h:  A3 D0 F8 34 03 8B 15 D8 F8 34 03 D9 7C 24 0E 8B
03334F86h:  4D 08 56 52 0F B7 D0 8B 86 B4 00 00 00 6A 00 51
03334F96h:  DD 04 C5 80 9E 34 03 0F B7 44 24 1E 6A 00 6A 00
03334FA6h:  0D 00 0C 00 00 89 44 24 28 68 00 00 00 80 68 00
03334FB6h:  00 00 80 D9 6C 24 30 68 00 00 00 40 68 F8 A1 34
03334FC6h:  03 52 DF 7C 24 3C 8B 4C 24 3C 51 D9 6C 24 3E FF
Stack (0017A630h):
0017A610h:  00000000 00000000 00000000 00000000
0017A620h:  00000000 00000000 00000000 00000000
0017A630h:  007A03AC 00000000 03330000 08FEEFC8
0017A640h:  03CF13C8 03EBA980 03BF83EF 027F0000
0017A650h:  03BFA700 CA88862F 03CF13C8 03EBA980
0017A660h:  03BFC54A 03CF15D4 CA8886FB 03CF13C8
0017A670h:  03EBA980 00000000 0000000F 0017A668
0017A680h:  03EBA994 03C0CBBD 007A03AC 0017A6C0
0017A690h:  03CCC26C CA8886EF 03EBA980 03CF0BF8
0017A6A0h:  08FEEFC8 0017A701 03CF13C8 0017A730
0017A6B0h:  03CA314E 00000004 03C0D160 03EBA980
0017A6C0h:  03CF13C8 007A03AC 08FEEFC8 CA8886A7
0017A6D0h:  00000046 061F0910 0017A918 0000000A
0017A6E0h:  08FEEFC8 0017A6C8 03EBA980 00000010
0017A6F0h:  0020A540 03CF0BE0 03CAE57C 03CF23C8
0017A700h:  0000001A 0000001A 00000009 0000000F
0017A710h:  03CF2490 2D207363 03EB0020 0017A744
0017A720h:  00000012 0000001F CA888697 03EB6B18
0017A730h:  0017A90C 03CA36DC 00000007 03C23852
0017A740h:  03CF0BE0 03BF5F44 6972794C 00007363
Registers:
EAX: 3C43E66F, EBX: 00000000, ECX: 007A03AC, EDX: 0000C3AC
ESI: 08FEEFC8, EDI: 03CF13C8, EBP: 0017A680, ESP: 0017A630
Crash location: "foo_uie_peakmeter", loaded at 03330000h - 03356000h
Loaded modules:
foobar2000                      loaded at 00400000h - 004F3000h
ntdll                            loaded at 77500000h - 77650000h
kernel32                        loaded at 75760000h - 75870000h
COMCTL32                        loaded at 75340000h - 754D4000h
msvcrt                          loaded at 76FC0000h - 7706A000h
ADVAPI32                        loaded at 75A10000h - 75ACF000h
RPCRT4                          loaded at 75910000h - 75A00000h
Secur32                          loaded at 75700000h - 75760000h
GDI32                            loaded at 75EB0000h - 75F40000h
USER32                          loaded at 76A90000h - 76B60000h
SHLWAPI                          loaded at 76CE0000h - 76D35000h
SHELL32                          loaded at 75F40000h - 76A0E000h
ole32                            loaded at 75D60000h - 75EA4000h
shared                          loaded at 10000000h - 10029000h
comdlg32                        loaded at 76B60000h - 76BD4000h
IMM32                            loaded at 76ED0000h - 76F30000h
MSCTF                            loaded at 75C00000h - 75CC7000h
LPK                              loaded at 774E0000h - 774E9000h
USP10                            loaded at 76BE0000h - 76C5D000h
uxtheme                          loaded at 74B90000h - 74C10000h
foo_albumlist                    loaded at 00300000h - 00347000h
OLEAUT32                        loaded at 75880000h - 7590C000h
foo_audioscrobbler              loaded at 00690000h - 006C7000h
WS2_32                          loaded at 76A10000h - 76A3D000h
NSI                              loaded at 75A00000h - 75A06000h
foo_autoplaylist                loaded at 02460000h - 02492000h
foo_browser                      loaded at 024A0000h - 024D9000h
foo_cdda                        loaded at 024E0000h - 02515000h
foo_converter                    loaded at 02630000h - 02699000h
foo_cwb_hooks                    loaded at 02750000h - 0279A000h
foo_dbsearch                    loaded at 028F0000h - 02960000h
foo_dsp_std                      loaded at 02AB0000h - 02AF1000h
foo_input_std                    loaded at 02C30000h - 02D43000h
foo_masstag                      loaded at 02D50000h - 02D9F000h
foo_playcount                    loaded at 02DA0000h - 02DC8000h
foo_playlist_tree                loaded at 02E30000h - 02EA2000h
libmzsch360_000                  loaded at 10400000h - 105D0000h
WSOCK32                          loaded at 75270000h - 75277000h
libmzgc360_000                  loaded at 02F30000h - 02FD4000h
foo_removeplayed                loaded at 02DE0000h - 02DF8000h
foo_rgscan                      loaded at 02EB0000h - 02EF8000h
foo_run                          loaded at 02FE0000h - 0300B000h
foo_scrobblecharts              loaded at 03170000h - 031A3000h
WININET                          loaded at 77070000h - 7713F000h
Normaliz                        loaded at 75870000h - 75873000h
iertutil                        loaded at 76C60000h - 76CA5000h
foo_trackpos                    loaded at 031B0000h - 031CF000h
foo_uie_albumart                loaded at 03200000h - 0323C000h
gdiplus                          loaded at 73DC0000h - 73F6A000h
foo_uie_albumlist                loaded at 03250000h - 0328D000h
foo_uie_explorer                loaded at 032D0000h - 0330C000h
foo_uie_lyrics                  loaded at 03370000h - 033CF000h
WINMM                            loaded at 74B20000h - 74B53000h
OLEACC                          loaded at 74560000h - 74598000h
foo_uie_peakmeter                loaded at 03330000h - 03356000h
foo_uie_quicksearch              loaded at 03400000h - 03446000h
foo_uie_vis_egoh                loaded at 03580000h - 0359D000h
foo_uie_wsh_panel                loaded at 035A0000h - 035D6000h
foo_ui_columns                  loaded at 037A0000h - 03842000h
foo_ui_panels                    loaded at 03BF0000h - 03CDD000h
foo_ui_std                      loaded at 03870000h - 038C7000h
ctagent                          loaded at 03770000h - 03777000h
Msimg32                          loaded at 74A40000h - 74A45000h
mswsock                          loaded at 742A0000h - 742DB000h
DNSAPI                          loaded at 75130000h - 7515B000h
winrnr                          loaded at 74900000h - 74908000h
WLDAP32                          loaded at 76A40000h - 76A89000h
PSAPI                            loaded at 774D0000h - 774D7000h
NLAapi                          loaded at 748F0000h - 748FF000h
IPHLPAPI                        loaded at 74460000h - 74479000h
dhcpcsvc                        loaded at 74330000h - 74365000h
WINNSI                          loaded at 74AA0000h - 74AA7000h
dhcpcsvc6                        loaded at 74420000h - 74440000h
napinsp                          loaded at 748E0000h - 748EF000h
pnrpnsp                          loaded at 73DA0000h - 73DB2000h
mdnsNSP                          loaded at 16080000h - 16099000h
rasadhlp                        loaded at 74910000h - 74916000h
imon                            loaded at 20B00000h - 20B4B000h
wship6                          loaded at 74290000h - 74296000h
wshtcpip                        loaded at 74280000h - 74286000h
tskh                            loaded at 03E90000h - 03E9D000h
idle                            loaded at 60300000h - 60307000h
MSVCR71                          loaded at 7C340000h - 7C396000h
dwmapi                          loaded at 74410000h - 7441C000h
DSOUND                          loaded at 744E0000h - 74551000h
POWRPROF                        loaded at 74A50000h - 74A6A000h
CLBCatQ                          loaded at 76F30000h - 76FB4000h
MMDevApi                        loaded at 74480000h - 744A7000h
SETUPAPI                        loaded at 76D40000h - 76EC8000h
WINTRUST                        loaded at 74B60000h - 74B8D000h
CRYPT32                          loaded at 745A0000h - 74691000h
MSASN1                          loaded at 750F0000h - 75102000h
USERENV                          loaded at 75110000h - 7512E000h
imagehlp                        loaded at 76CB0000h - 76CD9000h
WindowsCodecs                    loaded at 73CE0000h - 73D92000h
audioses                        loaded at 743E0000h - 74401000h
audioeng                        loaded at 74370000h - 743D6000h
AVRT                            loaded at 750E0000h - 750E7000h
SXS                              loaded at 73C80000h - 73CDF000h
jscript                          loaded at 73B80000h - 73BF8000h
rsaenh                          loaded at 752F0000h - 75328000h
dciman32                        loaded at 73580000h - 73586000h
dbghelp                          loaded at 71B70000h - 71C4C000h
Stack dump analysis:
Address: 03330000h, location: "foo_uie_peakmeter", loaded at 03330000h - 03356000h
Address: 03BF83EFh, location: "foo_ui_panels", loaded at 03BF0000h - 03CDD000h
Address: 03BFA700h, location: "foo_ui_panels", loaded at 03BF0000h - 03CDD000h
Address: 03BFC54Ah, location: "foo_ui_panels", loaded at 03BF0000h - 03CDD000h
Address: 03C0CBBDh, location: "foo_ui_panels", loaded at 03BF0000h - 03CDD000h
Address: 03CA314Eh, location: "foo_ui_panels", loaded at 03BF0000h - 03CDD000h
Symbol: "Scintilla_DirectFunction" (+0003A098h)
Address: 03C0D160h, location: "foo_ui_panels", loaded at 03BF0000h - 03CDD000h
Address: 03CAE57Ch, location: "foo_ui_panels", loaded at 03BF0000h - 03CDD000h
Symbol: "Scintilla_DirectFunction" (+000454C6h)
Address: 03CA36DCh, location: "foo_ui_panels", loaded at 03BF0000h - 03CDD000h
Symbol: "Scintilla_DirectFunction" (+0003A626h)
Address: 03C23852h, location: "foo_ui_panels", loaded at 03BF0000h - 03CDD000h
Address: 03BF5F44h, location: "foo_ui_panels", loaded at 03BF0000h - 03CDD000h
Address: 77527860h, location: "ntdll", loaded at 77500000h - 77650000h
Symbol: "RtlDeactivateActivationContextUnsafeFast" (+00008834h)
Address: 7752BB41h, location: "ntdll", loaded at 77500000h - 77650000h
Symbol: "RtlTryEnterCriticalSection" (+000004DFh)
Address: 03C06171h, location: "foo_ui_panels", loaded at 03BF0000h - 03CDD000h
Address: 02753BE4h, location: "foo_cwb_hooks", loaded at 02750000h - 0279A000h
Address: 0277F420h, location: "foo_cwb_hooks", loaded at 02750000h - 0279A000h
Symbol: "foobar2000_get_interface" (+0001A860h)
Address: 02754673h, location: "foo_cwb_hooks", loaded at 02750000h - 0279A000h
Address: 0043D4DDh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 10004D50h, location: "shared", loaded at 10000000h - 10029000h
Symbol: "stricmp_utf8_ex" (+00000000h)
Address: 02E63C04h, location: "foo_playlist_tree", loaded at 02E30000h - 02EA2000h
Symbol: "foobar2000_get_interface" (+00021AD4h)
Address: 02E7BC80h, location: "foo_playlist_tree", loaded at 02E30000h - 02EA2000h
Symbol: "foobar2000_get_interface" (+00039B50h)
Address: 02E640FBh, location: "foo_playlist_tree", loaded at 02E30000h - 02EA2000h
Symbol: "foobar2000_get_interface" (+00021FCBh)
Address: 7752B2DFh, location: "ntdll", loaded at 77500000h - 77650000h
Symbol: "RtlDeactivateActivationContextUnsafeFast" (+0000C2B3h)
Address: 757E1D27h, location: "kernel32", loaded at 75760000h - 75870000h
Symbol: "HeapFree" (+00000014h)
Address: 004935B9h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 03CA45B0h, location: "foo_ui_panels", loaded at 03BF0000h - 03CDD000h
Symbol: "Scintilla_DirectFunction" (+0003B4FAh)
Address: 03C327CFh, location: "foo_ui_panels", loaded at 03BF0000h - 03CDD000h
Address: 0047D8CFh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00461ED3h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C4808h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C47E8h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004DF58Ch, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004AEA63h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0046359Fh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0045E1ADh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004A6D71h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00460F7Bh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0046201Bh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00462C10h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004AAFACh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0047D7A2h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C6FBCh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E2AE0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C1EFCh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00438CA5h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004DEDF8h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E2A8Ch, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C1EE4h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00497080h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 03CCC124h, location: "foo_ui_panels", loaded at 03BF0000h - 03CDD000h
Symbol: "Scintilla_DirectFunction" (+0006306Eh)
Address: 0278EC50h, location: "foo_cwb_hooks", loaded at 02750000h - 0279A000h
Symbol: "foobar2000_get_interface" (+0002A090h)
Address: 02E8FF80h, location: "foo_playlist_tree", loaded at 02E30000h - 02EA2000h
Symbol: "foobar2000_get_interface" (+0004DE50h)
Address: 02E8FFB4h, location: "foo_playlist_tree", loaded at 02E30000h - 02EA2000h
Symbol: "foobar2000_get_interface" (+0004DE84h)
Address: 004A7F20h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00440ADDh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C2784h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 03BFE781h, location: "foo_ui_panels", loaded at 03BF0000h - 03CDD000h
Address: 03C9F920h, location: "foo_ui_panels", loaded at 03BF0000h - 03CDD000h
Symbol: "Scintilla_DirectFunction" (+0003686Ah)
Address: 03C06C4Eh, location: "foo_ui_panels", loaded at 03BF0000h - 03CDD000h
Address: 03CAFE10h, location: "foo_ui_panels", loaded at 03BF0000h - 03CDD000h
Symbol: "Scintilla_DirectFunction" (+00046D5Ah)
Address: 03CAFCE0h, location: "foo_ui_panels", loaded at 03BF0000h - 03CDD000h
Symbol: "Scintilla_DirectFunction" (+00046C2Ah)
Address: 03CAFE28h, location: "foo_ui_panels", loaded at 03BF0000h - 03CDD000h
Symbol: "Scintilla_DirectFunction" (+00046D72h)
Address: 03CAE664h, location: "foo_ui_panels", loaded at 03BF0000h - 03CDD000h
Symbol: "Scintilla_DirectFunction" (+000455AEh)
Address: 004D0000h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004F004Eh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 03CCC184h, location: "foo_ui_panels", loaded at 03BF0000h - 03CDD000h
Symbol: "Scintilla_DirectFunction" (+000630CEh)
Address: 03C865A9h, location: "foo_ui_panels", loaded at 03BF0000h - 03CDD000h
Symbol: "Scintilla_DirectFunction" (+0001D4F3h)
Address: 75EC5B04h, location: "GDI32", loaded at 75EB0000h - 75F40000h
Symbol: "BitBlt" (+00000098h)
Address: 75EC5AE3h, location: "GDI32", loaded at 75EB0000h - 75F40000h
Symbol: "BitBlt" (+00000077h)
Address: 03C024F8h, location: "foo_ui_panels", loaded at 03BF0000h - 03CDD000h
Address: 03CA40F2h, location: "foo_ui_panels", loaded at 03BF0000h - 03CDD000h
Symbol: "Scintilla_DirectFunction" (+0003B03Ch)
Address: 03C0253Dh, location: "foo_ui_panels", loaded at 03BF0000h - 03CDD000h
Address: 74656724h, location: "CRYPT32", loaded at 745A0000h - 74691000h
Symbol: "CryptUpdateProtectedState" (+000150D6h)
Address: 76707465h, location: "SHELL32", loaded at 75F40000h - 76A0E000h
Symbol: "StrStrW" (+004C41D6h)
Address: 74686769h, location: "CRYPT32", loaded at 745A0000h - 74691000h
Symbol: "CryptUpdateProtectedState" (+0004511Bh)
Address: 75F100C0h, location: "GDI32", loaded at 75EB0000h - 75F40000h
Symbol: "XLATEOBJ_iXlate" (+0000ACE6h)
Address: 75EC98FCh, location: "GDI32", loaded at 75EB0000h - 75F40000h
Symbol: "CreateFontIndirectExW" (+0000008Dh)
Address: 75EC98CEh, location: "GDI32", loaded at 75EB0000h - 75F40000h
Symbol: "CreateFontIndirectExW" (+0000005Fh)
Address: 75EC994Dh, location: "GDI32", loaded at 75EB0000h - 75F40000h
Symbol: "CreateFontIndirectW" (+00000049h)
Address: 75EC9957h, location: "GDI32", loaded at 75EB0000h - 75F40000h
Symbol: "CreateFontIndirectW" (+00000053h)
Address: 00410054h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004F0048h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0041004Dh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 754D0000h, location: "COMCTL32", loaded at 75340000h - 754D4000h
Symbol: "Ordinal234" (+00076B7Dh)
Address: 77617264h, location: "ntdll", loaded at 77500000h - 77650000h
Symbol: "NlsMbOemCodePageTag" (+0003725Dh)
Address: 74636572h, location: "CRYPT32", loaded at 745A0000h - 74691000h
Symbol: "I_CryptEnableLruOfEntries" (+00003046h)
Address: 76652428h, location: "SHELL32", loaded at 75F40000h - 76A0E000h
Symbol: "StrStrW" (+0040F199h)
Address: 7466656Ch, location: "CRYPT32", loaded at 745A0000h - 74691000h
Symbol: "CryptUpdateProtectedState" (+00024F1Eh)
Address: 74657366h, location: "CRYPT32", loaded at 745A0000h - 74691000h
Symbol: "CryptUpdateProtectedState" (+00015D18h)
Address: 03C378C7h, location: "foo_ui_panels", loaded at 03BF0000h - 03CDD000h
Address: 03CB1794h, location: "foo_ui_panels", loaded at 03BF0000h - 03CDD000h
Symbol: "Scintilla_DirectFunction" (+000486DEh)
Address: 03C37A6Bh, location: "foo_ui_panels", loaded at 03BF0000h - 03CDD000h
Address: 03C37A7Dh, location: "foo_ui_panels", loaded at 03BF0000h - 03CDD000h
Address: 00450048h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C004Ch, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00440020h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0047004Ch, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 77520000h, location: "ntdll", loaded at 77500000h - 77650000h
Symbol: "RtlDeactivateActivationContextUnsafeFast" (+00000FD4h)
Address: 03C929EEh, location: "foo_ui_panels", loaded at 03BF0000h - 03CDD000h
Symbol: "Scintilla_DirectFunction" (+00029938h)
Address: 03C92A7Eh, location: "foo_ui_panels", loaded at 03BF0000h - 03CDD000h
Symbol: "Scintilla_DirectFunction" (+000299C8h)
Address: 03C92B8Bh, location: "foo_ui_panels", loaded at 03BF0000h - 03CDD000h
Symbol: "Scintilla_DirectFunction" (+00029AD5h)
Address: 03CC5E80h, location: "foo_ui_panels", loaded at 03BF0000h - 03CDD000h
Symbol: "Scintilla_DirectFunction" (+0005CDCAh)
Address: 03C865C8h, location: "foo_ui_panels", loaded at 03BF0000h - 03CDD000h
Symbol: "Scintilla_DirectFunction" (+0001D512h)
Address: 03C8F920h, location: "foo_ui_panels", loaded at 03BF0000h - 03CDD000h
Symbol: "Scintilla_DirectFunction" (+0002686Ah)
Address: 03C39A9Ah, location: "foo_ui_panels", loaded at 03BF0000h - 03CDD000h
Address: 0048002Ch, location: "foobar2000", loaded at 00400000h - 004F3000h
Version info:
foobar2000 v0.9.4.3
UNICODE
Additional info:
WSH Panel (uie) 0.7.1  (foo_uie_wsh_panel)
Default User Interface 0.9acc  (foo_ui_std)
FLAC Decoder 1.1.0  (foo_input_std)
WMA Decoder 1.1  (foo_input_std)
Playlist Tree Panel 3.0.BETA_2 [Mar 23 2007 - 16:44:16]  (foo_playlist_tree)
Album list panel 0.2.1  (foo_uie_albumlist)
Database Search 1.4  (foo_dbsearch)
Last.fm Chart Player 0.2.3  (foo_scrobblecharts)
Track Positioner 1.0  (foo_trackpos)
Columns UI 0.2.0 alpha 1  (foo_ui_columns)
Album Art Panel 0.2.6  (foo_uie_albumart)
Audioscrobbler 1.3.6  (foo_audioscrobbler)
Converter 1.0.1  (foo_converter)
Album List 3.2.0  (foo_albumlist)
Run services 0.3.2  (foo_run)
Peakmeter Panel 0.0.1  (foo_uie_peakmeter)
Egoh Spectrum analyser (uie) 1.1.2  (foo_uie_vis_egoh)
Tagger Panel Window 1.0.beta3 [Jun  5 2007 - 10:09:39]  (foo_cwb_hooks)
Masstagger 1.6  (foo_masstag)
Panels UI 0.13.6 beta [May 31 2007 - 18:48:41]  (foo_ui_panels)
CD Audio Decoder 2.1.1  (foo_cdda)
Quick Search Toolbar 2.8l  (foo_uie_quicksearch)
cwbowron's title format hooks 1.2.4 [Jun  5 2007 - 10:09:39]  (foo_cwb_hooks)
ReplayGain Scanner 2.0.2  (foo_rgscan)
Music Browser 1.2.3b [Mar 23 2007 - 16:52:56]  (foo_browser)
Explorer Tree 1.04.6b  (foo_uie_explorer)
Remove played Files 1.2.0 [Nov 19 2006 - 14:55:48]  (foo_removeplayed)
foobar2000 core 0.9.4.3  (Core)
Standard DSP array 1.0  (foo_dsp_std)
Lyric Show Panels 0.3.1.1  (foo_uie_lyrics)
Playback Statistics 1.3.2  (foo_playcount)
Reply #34
Illegal operation:
Call path:
Stack (0017A630h):
Registers:
Loaded modules:
Version info:
foobar2000 v0.9.4.3
UNICODE
Additional info:
When does it happen? After which action? Can you reproduce it?
Reply #35
Unfortunately I can't reproduce the crash. When it crashed I was sure another component caused it so I didn't look at the failure log until much later, therefore I cannot remember what action caused the crash. I'll keep fooling around with it to see if I can reproduce a crash.
Reply #36
This component looks like alot of fun. I think I will wait for the next version before I install it though. Theres some very promising changes you have said you will make for it.
A configurable timeout feature sounds like a good idea to me.
Reply #37
Thanks for this, it's really good.
I'm looking forward to the vertical version!
Reply #38
Very nice plugin! Looking forward for the next version
Reply #39
Thx for this plugin.  Enjoying playing with it.
Mr E
Reply #40
The problem was the different behaviour of Panels UI and Columns UI. Panels UI don't call the set_config- method when the component was initialized the first time.
Thanks!! The problem is fixed. The cause of defect is described above. You can get the fix here: http://pelit.koillismaa.fi/plugins/show.php?id=207
Reply #41
Just super!
My English is very good!
...in comparison with my Korean language...
Reply #42
foo_pm
Amazing plugin, exactly that I waited so long. Thank you for your great work!
And some requests:
1. Make peaks to fall down, not always staying at their max level.
2. Possibility to change peaks colour.
Of course, all this should be optionally.
The past  was yesterday...
Reply #43
very cool plugin ! thanks !
Reply #44
wow, been looking for a vis like this for ages! thanks.
Reply #45
Very nice - shows all 5.1 channels as well, if enabled.
Reply #46
Thank you so much, this is beautiful and well done. I agree on vertical layout and max peaks fall down.
Reply #47
Cool!
Just added in my  foobar. thanks a lot.
Hope the range bar can be more beautful. for exp, if it can use some pictures files to show the range bar, it 'll be great. Thx.
.:: Evchenic.S+udio ::.
Reply #48
And some requests:
One more kind of peak's behaviour - disappearing after 1-2 seconds.
So it should be a separated option (switch) for the peaks:
1. Stay freezed (just like now)
2. Fall down
3. Disappear
Reply #49
Mmm can't seem to get this working at all here...
Using latest Foobar 9.4.2 and Columns_UI version 0.2.0 alpha 2 under Windows Vista.
Help please?
Edit: It also doesn't work with the previous version of Columns_ui
