Topic: Peakmeter for Columns UI (Read 209490 times) previous topic - next topic
Reply #50
Mmm can't seem to get this working at all here...
Using latest Foobar 9.4.2 and Columns_UI version 0.2.0 alpha 2 under Windows Vista.
Help please?
Edit: It also doesn't work with the previous version of Columns_ui
What exactly doesn't work?
Reply #51
And some requests:
1. Make peaks to fall down, not always staying at their max level.
2. Possibility to change peaks colour.
One more kind of peak's behaviour - disappearing after 1-2 seconds.
So it should be a separated option (switch) for the peaks:
1. Stay freezed (just like now)
2. Fall down
3. Disappear
Thanks! That'a good idea! I will implement this in association with the time setting for the fall down option.
Reply #52
Help please?
The columns_ui appearance is there, but I don't see the configuration panel for the Peakmeter and I dont see any option anywhere to enable/disable it both in the columns_ui config area or the foobar preferences.
Am I just being completely stupid or is there something genuinely wrong here?
p.s. I can see the columns_ui spectrum analyser and I can also load and use the Egoh one.
Reply #53
Did you already tried Right-click on the panel?
Reply #54
Amazing work! Keep updating!
No Foobar? No music
Reply #55
I love this plug-in - thank you!
I have a question, though, about it's accuracy:
When I play a WAV file in Audition that shows peaks at -1dB, the same file (when played in foobar, without ReplayGain) shows peaks at -6dB in foo_uie_peakmeter.
Why does it report a different level?  Am I missing a setting?
~esa
Reply #56
This is the thing...
There is no panel no nothing, the dll is installed in the components directory, it appears in the list under preferences in Foobar, but it just doesnt exist anyplace else application wise.
Fustrating to say the least.
Reply #57
It's not under Visualizations, it's under Panels.
Reply #58
Where is the Panels option?
I dont have any Panel options anywhere here under Foobar, or when I try the customize options on Columns_ui.
I have the feeling that someone is going to make me look pretty stupid when they explain to me where it is...
Edit: Do I need to install Panels_ui for it to work?
Reply #60
@Sysagent
Maybe this helps: http://farm2.static.flickr.com/1063/538435...288a97591_o.jpg
YES!
As the saying goes "A picture speaks a thousand words..."
Many thanks for that, it's been driving me mad for ages!
Much appreciated Roentgen
Just need to work out now how to get it positioned where the Spectrum Analyzer usually goes now...
:E
Reply #61
Ahh getting a "grasp" on this now a bit...
Got the Panel in the same position where the Spectrum Analyser usually sit (thanks again to the jpg) but when I change the size of Foobar horizontally the Peakmeter does not change its appearance dynamically.
In other words the peakmeter just seems to have a "fixed" size horizontally which can't change in sympathy with the Foobar application changes.
Is the how it is meant to work or is there a tickbox or some other change that enables dynamically resizing?
Sorry for being a pain!
Reply #62
@Sysagent
Right click on the Peakmeter panel > Lock panel is checked?
Reply #64
Hi there, i've noticed a weird issue with peakmeter, i could'nt printscreen this behaviour so i reproduced exactly the same effect with Photoshop
you can see it in image, i have those annoying "brush" threads when the foobar windows is focused drawn outside the player window from side to side of the screen
anyone has the same issue?
No Foobar? No music
Reply #65
~esa
Thank You! I created a wav file with a "peak-" level from -9 dB up to 0 dB in 3 steps. I'm using audicity 1.2.6 to create the file. Both applications (foobar with peakmeter and audicity) display the same peak level. You can download the file here: http://download.yousendit.com/7B551E1B71A2289B
Reply #67
~esa
Thank you for the file; it helped me find the problem - which is not with the foo_uie_peakmeter.
(I had my pre-amp in foobar set to -3dB for files that have no ReplayGain info - d'oh!)
Reply #68
foo_pm
One more suggestion about peaks.  Now they are drawn as lines, no matter what bar's brush I've chosen. I want peaks depending on the brush. E.g. default brush is dots. And peaks should be drawn as dots.
Added:
Another wanted feature. Display current peak level to the right of the bars.
The past  was yesterday...
Reply #69
This has been a long time coming. I was about to experiment around with making one myself, but you've saved me the hassle!!! Thanks!
If at first you don't succeed, so much for hang-gliding
Reply #71
don't work with mono .mp3 file ... why don't rendering the L and R channels like 'front center' at the same when mono ?
[a href="http://img526.imageshack.us/my.php?image=peakmeternotworkbr4.png" target="_blank"]
Reply #72
Bug...
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 01DE4F96h
Access violation, operation: read, address: EBF8FA20h
Call path:
entry=>app_mainloop=>context
Code bytes (01DE4F96h):
01DE4F56h:  8D 4C 24 18 51 89 44 24 34 C7 44 24 38 00 00 00
01DE4F66h:  00 C7 44 24 40 B0 A1 DF 01 FF 15 70 81 DF 01 66
01DE4F76h:  A3 D0 F8 DF 01 8B 15 D8 F8 DF 01 D9 7C 24 0E 8B
01DE4F86h:  4D 08 56 52 0F B7 D0 8B 86 B4 00 00 00 6A 00 51
01DE4F96h:  DD 04 C5 80 9E DF 01 0F B7 44 24 1E 6A 00 6A 00
01DE4FA6h:  0D 00 0C 00 00 89 44 24 28 68 00 00 00 80 68 00
01DE4FB6h:  00 00 80 D9 6C 24 30 68 00 00 00 40 68 F8 A1 DF
01DE4FC6h:  01 52 DF 7C 24 3C 8B 4C 24 3C 51 D9 6C 24 3E FF
Stack (0012F130h):
0012F110h:  00000000 B6BEE8D8 B6BEE534 BBE88A00
0012F120h:  B6BEE5F4 804E2490 804E5760 FFFFFFFF
0012F130h:  000203EE 00000000 01DE0000 01E24C48
0012F140h:  00000001 06033DF8 22C0E645 027FFFFE
0012F150h:  0378D997 0378BB25 037D5328 21A88D1D
0012F160h:  0012F1BC 01E24C48 06035868 00000000
0012F170h:  0012F15C 0012F194 01DE55AA 01E24E84
0012F180h:  00000000 06001CDA 000203EE 0012F1A8
0012F190h:  06012F80 201185BE 00000001 06033DF8
0012F1A0h:  77D3B8CA 06035868 06033DF8 20118596
0012F1B0h:  00000001 06033DF8 0000014A 01E24C48
0012F1C0h:  0000000A 003B99D8 0271016B 0012F1EC
0012F1D0h:  0012F1EC 060056A9 00000001 060028E4
0012F1E0h:  00000000 201185CE 01E24C48 0012F2A8
0012F1F0h:  060057DB 00000000 06003B3C 06033DF8
0012F200h:  00000000 2011862E 06033DF8 77D3B8CA
0012F210h:  0012F3DC 00000001 77D3B52C 00000000
0012F220h:  00000010 036F4290 00000029 00000000
0012F230h:  060092FC 06035728 00000013 00000020
0012F240h:  06033DF8 060091A4 06034D98 00000017
Registers:
EAX: 3D432B74, EBX: 0012F1E8, ECX: 000203EE, EDX: 0000C258
ESI: 01E24C48, EDI: 00000001, EBP: 0012F180, ESP: 0012F130
Crash location: "foo_uie_peakmeter", loaded at 01DE0000h - 01E06000h
Loaded modules:
foobar2000                      loaded at 00400000h - 004F3000h
ntdll                            loaded at 7C900000h - 7C9B1000h
kernel32                        loaded at 7C800000h - 7C8F7000h
COMCTL32                        loaded at 773C0000h - 774C3000h
msvcrt                          loaded at 77C00000h - 77C58000h
ADVAPI32                        loaded at 77DC0000h - 77E6C000h
RPCRT4                          loaded at 77E70000h - 77F01000h
GDI32                            loaded at 77F10000h - 77F57000h
USER32                          loaded at 77D30000h - 77DC0000h
SHLWAPI                          loaded at 77F60000h - 77FD6000h
SHELL32                          loaded at 7C9C0000h - 7D1DA000h
ole32                            loaded at 774D0000h - 7760D000h
shared                          loaded at 10000000h - 10029000h
comdlg32                        loaded at 76380000h - 763C9000h
uxtheme                          loaded at 5B260000h - 5B298000h
UnlockerHook                    loaded at 003C0000h - 003C4000h
foo_channel_mixer                loaded at 00A30000h - 00A6B000h
foo_convolve                    loaded at 00A70000h - 00AC1000h
foo_dsp_atsurround              loaded at 00AD0000h - 00C68000h
foo_dsp_bs2b                    loaded at 014B0000h - 014CC000h
foo_dsp_centercut                loaded at 014F0000h - 01515000h
foo_dsp_crossfader              loaded at 01540000h - 01596000h
libmmd                          loaded at 015B0000h - 01861000h
MSVCR80                          loaded at 78130000h - 781CB000h
foo_dsp_crossfeed                loaded at 01890000h - 018B4000h
foo_dsp_delta                    loaded at 018E0000h - 018FE000h
foo_dsp_soundtouch              loaded at 01920000h - 01943000h
MSVCP80                          loaded at 7C420000h - 7C4A7000h
foo_dsp_src9                    loaded at 01960000h - 0199B000h
foo_dsp_tube                    loaded at 019B0000h - 019D6000h
foo_common                      loaded at 019F0000h - 01A23000h
foo_dbsearch                    loaded at 01A50000h - 01AC0000h
OLEAUT32                        loaded at 77110000h - 7719C000h
foo_input_shorten                loaded at 01AE0000h - 01B0D000h
foo_lnk                          loaded at 01B30000h - 01B49000h
foo_playlist_manager            loaded at 01B70000h - 01BB4000h
foo_pqview                      loaded at 01BE0000h - 01BFB000h
foo_random                      loaded at 01C20000h - 01C5F000h
foo_tradersfriend                loaded at 01C80000h - 01CBA000h
foo_utils                        loaded at 01CE0000h - 01D18000h
foo_whatsnew                    loaded at 01D40000h - 01D70000h
foo_AdvancedControls            loaded at 01D90000h - 01DC9000h
foo_uie_peakmeter                loaded at 01DE0000h - 01E06000h
foo_version                      loaded at 01E30000h - 01E56000h
dbghelp                          loaded at 59C60000h - 59D01000h
VERSION                          loaded at 77BF0000h - 77BF8000h
foo_ac3                          loaded at 01F80000h - 01FAF000h
foo_dts                          loaded at 01FD0000h - 02026000h
foo_dumb                        loaded at 02040000h - 020C9000h
foo_input_alac                  loaded at 020F0000h - 0210D000h
foo_input_monkey                loaded at 02130000h - 0217A000h
foo_input_ofr                    loaded at 021A0000h - 021DC000h
OptimFROG                        loaded at 021F0000h - 02222000h
foo_input_reverse                loaded at 02250000h - 0227E000h
foo_input_tta                    loaded at 02290000h - 022BD000h
foo_midi                        loaded at 022E0000h - 0238A000h
foo_autoplaylist                loaded at 023B0000h - 023E0000h
foo_benchmark                    loaded at 02400000h - 02428000h
foo_bitcompare                  loaded at 02450000h - 02477000h
foo_cuesheet_creator            loaded at 024A0000h - 024CC000h
foo_discogs                      loaded at 024F0000h - 0256D000h
gdiplus                          loaded at 4EBE0000h - 4ED83000h
WS2_32                          loaded at 71A90000h - 71AA7000h
WS2HELP                          loaded at 71A80000h - 71A88000h
WINMM                            loaded at 76B20000h - 76B4E000h
serwvdrv                        loaded at 5D270000h - 5D277000h
umdmxfrm                        loaded at 5B590000h - 5B597000h
foo_freedb2_fix                  loaded at 02610000h - 02625000h
foo_fullscreen                  loaded at 02650000h - 0266B000h
foo_history                      loaded at 02690000h - 026AC000h
foo_infobox                      loaded at 026D0000h - 02710000h
foo_masstag_addons              loaded at 02730000h - 0274D000h
foo_menu_addons                  loaded at 02760000h - 027B1000h
foo_osd                          loaded at 027D0000h - 02802000h
foo_playcount                    loaded at 02830000h - 02858000h
foo_playlist_bind                loaded at 02880000h - 028A5000h
foo_run                          loaded at 028C0000h - 028EB000h
foo_scheduler                    loaded at 02910000h - 0297F000h
POWRPROF                        loaded at 74A90000h - 74A98000h
foo_skip                        loaded at 029A0000h - 029BB000h
foo_verifier                    loaded at 029E0000h - 02A10000h
foo_vis_channelusage            loaded at 02A30000h - 02A53000h
foo_vis_projectM                loaded at 02A80000h - 02AF2000h
OPENGL32                        loaded at 5F220000h - 5F2EC000h
GLU32                            loaded at 5FF90000h - 5FFB1000h
DDRAW                            loaded at 73720000h - 73769000h
DCIMAN32                        loaded at 73B80000h - 73B86000h
foo_out_ks                      loaded at 03020000h - 0304A000h
SETUPAPI                        loaded at 77910000h - 77A04000h
foo_abx                          loaded at 03070000h - 030A3000h
foo_albumlist                    loaded at 030D0000h - 03117000h
foo_cdda                        loaded at 03140000h - 03175000h
foo_converter                    loaded at 031A0000h - 03209000h
foo_dsp_std                      loaded at 03230000h - 03271000h
foo_freedb2                      loaded at 032A0000h - 032E0000h
foo_input_std                    loaded at 03300000h - 03413000h
foo_masstag                      loaded at 03440000h - 0348F000h
foo_rgscan                      loaded at 034B0000h - 034F8000h
foo_unpack                      loaded at 03520000h - 0354E000h
foo_uie_albumart                loaded at 03570000h - 035AC000h
foo_uie_albumlist                loaded at 035D0000h - 0360D000h
foo_uie_bookmarks                loaded at 03630000h - 03685000h
foo_uie_explorer                loaded at 036A0000h - 036DC000h
foo_uie_lyrics                  loaded at 03700000h - 0375F000h
WININET                          loaded at 771A0000h - 77249000h
CRYPT32                          loaded at 77A70000h - 77B05000h
MSASN1                          loaded at 77B10000h - 77B22000h
foo_uie_playlists_dropdown      loaded at 03780000h - 037BA000h
foo_uie_queuemanager            loaded at 037E0000h - 03816000h
mscoree                          loaded at 79000000h - 79045000h
msvcm80                          loaded at 7C4C0000h - 7C53D000h
mscorwks                        loaded at 79E70000h - 7A3D1000h
mscorlib.ni                      loaded at 790C0000h - 79BA6000h
mscorjit                        loaded at 79060000h - 790B3000h
rsaenh                          loaded at 0FFD0000h - 0FFF8000h
System.ni                        loaded at 7A440000h - 7ABFE000h
System.Drawing.ni                loaded at 7ADE0000h - 7AF74000h
foo_uie_quicksearch              loaded at 05F90000h - 05FD6000h
foo_uie_tabs                    loaded at 05FF0000h - 0601A000h
foo_uie_trackinfo                loaded at 06040000h - 0606E000h
foo_ui_columns                  loaded at 06090000h - 06127000h
correct                          loaded at 06550000h - 06556000h
CLBCATQ                          loaded at 76FC0000h - 7703F000h
COMRes                          loaded at 77040000h - 77107000h
appHelp                          loaded at 77B30000h - 77B52000h
cscui                            loaded at 77A10000h - 77A65000h
CSCDLL                          loaded at 765D0000h - 765ED000h
USERENV                          loaded at 769A0000h - 76A54000h
System.Windows.Forms.ni          loaded at 7AFD0000h - 7BC56000h
WINTRUST                        loaded at 76C20000h - 76C4E000h
IMAGEHLP                        loaded at 76C80000h - 76CA8000h
ksuser                          loaded at 73EA0000h - 73EA4000h
Secur32                          loaded at 77FE0000h - 77FF1000h
wsock32                          loaded at 71AB0000h - 71ABA000h
RASAPI32                        loaded at 76ED0000h - 76F0C000h
rasman                          loaded at 76E80000h - 76E92000h
NETAPI32                        loaded at 5BD50000h - 5BDA5000h
TAPI32                          loaded at 76EA0000h - 76ECF000h
rtutils                          loaded at 76E70000h - 76E7E000h
adialhk                          loaded at 07150000h - 07167000h
msv1_0                          loaded at 77C60000h - 77C83000h
iphlpapi                        loaded at 76D50000h - 76D69000h
sensapi                          loaded at 72290000h - 72295000h
urlmon                          loaded at 7DF10000h - 7DFB2000h
mswsock                          loaded at 71A30000h - 71A70000h
rasadhlp                        loaded at 76FB0000h - 76FB6000h
DNSAPI                          loaded at 072F0000h - 07317000h
winrnr                          loaded at 76FA0000h - 76FA8000h
WLDAP32                          loaded at 76F50000h - 76F7D000h
shdocvw                          loaded at 77750000h - 778C0000h
CRYPTUI                          loaded at 76650000h - 766D1000h
scrchpg                          loaded at 081A0000h - 081C5000h
DVDShell                        loaded at 51980000h - 5198D000h
Stack dump analysis:
Address: 01DE0000h, location: "foo_uie_peakmeter", loaded at 01DE0000h - 01E06000h
Address: 0378D997h, location: "foo_uie_playlists_dropdown", loaded at 03780000h - 037BA000h
Address: 0378BB25h, location: "foo_uie_playlists_dropdown", loaded at 03780000h - 037BA000h
Address: 01DE55AAh, location: "foo_uie_peakmeter", loaded at 01DE0000h - 01E06000h
Address: 06001CDAh, location: "foo_uie_tabs", loaded at 05FF0000h - 0601A000h
Address: 77D3B8CAh, location: "USER32", loaded at 77D30000h - 77DC0000h
Symbol: "SendMessageW" (+00000000h)
Address: 060056A9h, location: "foo_uie_tabs", loaded at 05FF0000h - 0601A000h
Address: 060028E4h, location: "foo_uie_tabs", loaded at 05FF0000h - 0601A000h
Address: 060057DBh, location: "foo_uie_tabs", loaded at 05FF0000h - 0601A000h
Address: 06003B3Ch, location: "foo_uie_tabs", loaded at 05FF0000h - 0601A000h
Address: 77D3B52Ch, location: "USER32", loaded at 77D30000h - 77DC0000h
Symbol: "DefWindowProcW" (+000001E0h)
Address: 060092FCh, location: "foo_uie_tabs", loaded at 05FF0000h - 0601A000h
Address: 060091A4h, location: "foo_uie_tabs", loaded at 05FF0000h - 0601A000h
Address: 060092A8h, location: "foo_uie_tabs", loaded at 05FF0000h - 0601A000h
Address: 060092B0h, location: "foo_uie_tabs", loaded at 05FF0000h - 0601A000h
Address: 060092D0h, location: "foo_uie_tabs", loaded at 05FF0000h - 0601A000h
Address: 06009630h, location: "foo_uie_tabs", loaded at 05FF0000h - 0601A000h
Address: 05FF1AE0h, location: "foo_uie_tabs", loaded at 05FF0000h - 0601A000h
Address: 060059DAh, location: "foo_uie_tabs", loaded at 05FF0000h - 0601A000h
Address: 06003F9Fh, location: "foo_uie_tabs", loaded at 05FF0000h - 0601A000h
Address: 77D3B4E0h, location: "USER32", loaded at 77D30000h - 77DC0000h
Symbol: "DefWindowProcW" (+00000194h)
Address: 77D3B4DBh, location: "USER32", loaded at 77D30000h - 77DC0000h
Symbol: "DefWindowProcW" (+0000018Fh)
Address: 77D3B51Ch, location: "USER32", loaded at 77D30000h - 77DC0000h
Symbol: "DefWindowProcW" (+000001D0h)
Address: 7C90EAE3h, location: "ntdll", loaded at 7C900000h - 7C9B1000h
Symbol: "KiUserCallbackDispatcher" (+00000013h)
Address: 02050001h, location: "foo_dumb", loaded at 02040000h - 020C9000h
Address: 060965D0h, location: "foo_ui_columns", loaded at 06090000h - 06127000h
Address: 77D3B483h, location: "USER32", loaded at 77D30000h - 77DC0000h
Symbol: "DefWindowProcW" (+00000137h)
Address: 77D394CEh, location: "USER32", loaded at 77D30000h - 77DC0000h
Symbol: "GetWindowLongA" (+00000061h)
Address: 77D3B43Dh, location: "USER32", loaded at 77D30000h - 77DC0000h
Symbol: "DefWindowProcW" (+000000F1h)
Address: 77D38B36h, location: "USER32", loaded at 77D30000h - 77DC0000h
Symbol: "GetWindowThreadProcessId" (+000000A6h)
Address: 77D388E1h, location: "USER32", loaded at 77D30000h - 77DC0000h
Symbol: "GetWindowLongW" (+0000002Bh)
Address: 77D388EAh, location: "USER32", loaded at 77D30000h - 77DC0000h
Symbol: "GetWindowLongW" (+00000034h)
Address: 06005A12h, location: "foo_uie_tabs", loaded at 05FF0000h - 0601A000h
Address: 0600053Eh, location: "foo_uie_tabs", loaded at 05FF0000h - 0601A000h
Address: 06000500h, location: "foo_uie_tabs", loaded at 05FF0000h - 0601A000h
Address: 77D38744h, location: "USER32", loaded at 77D30000h - 77DC0000h
Symbol: "GetDC" (+0000006Dh)
Address: 77D44ECBh, location: "USER32", loaded at 77D30000h - 77DC0000h
Symbol: "PostQuitMessage" (+0000027Ah)
Address: 7C9106EBh, location: "ntdll", loaded at 7C900000h - 7C9B1000h
Symbol: "RtlAllocateHeap" (+00000117h)
Address: 77D6046Fh, location: "USER32", loaded at 77D30000h - 77DC0000h
Symbol: "DeregisterShellHookWindow" (+000001CFh)
Address: 77D44EF0h, location: "USER32", loaded at 77D30000h - 77DC0000h
Symbol: "PostQuitMessage" (+0000029Fh)
Address: 77D44D17h, location: "USER32", loaded at 77D30000h - 77DC0000h
Symbol: "PostQuitMessage" (+000000C6h)
Address: 77D44F22h, location: "USER32", loaded at 77D30000h - 77DC0000h
Symbol: "DefDlgProcW" (+00000000h)
Address: 77D44F44h, location: "USER32", loaded at 77D30000h - 77DC0000h
Symbol: "DefDlgProcW" (+00000022h)
Address: 77D38826h, location: "USER32", loaded at 77D30000h - 77DC0000h
Symbol: "GetDC" (+0000014Fh)
Address: 77D38840h, location: "USER32", loaded at 77D30000h - 77DC0000h
Symbol: "GetDC" (+00000169h)
Address: 77D3B4D0h, location: "USER32", loaded at 77D30000h - 77DC0000h
Symbol: "DefWindowProcW" (+00000184h)
Address: 77D3B943h, location: "USER32", loaded at 77D30000h - 77DC0000h
Symbol: "IsWindow" (+00000000h)
Address: 77D3B409h, location: "USER32", loaded at 77D30000h - 77DC0000h
Symbol: "DefWindowProcW" (+000000BDh)
Address: 5B261AF6h, location: "uxtheme", loaded at 5B260000h - 5B298000h
Address: 77D44DF1h, location: "USER32", loaded at 77D30000h - 77DC0000h
Symbol: "PostQuitMessage" (+000001A0h)
Address: 77D3B3E2h, location: "USER32", loaded at 77D30000h - 77DC0000h
Symbol: "DefWindowProcW" (+00000096h)
Address: 5B261B3Dh, location: "uxtheme", loaded at 5B260000h - 5B298000h
Address: 77D3BB25h, location: "USER32", loaded at 77D30000h - 77DC0000h
Symbol: "GetPropW" (+0000003Ah)
Address: 77D3B3C0h, location: "USER32", loaded at 77D30000h - 77DC0000h
Symbol: "DefWindowProcW" (+00000074h)
Address: 773FF254h, location: "COMCTL32", loaded at 773C0000h - 774C3000h
Symbol: "Ordinal384" (+000233B4h)
Address: 773FF02Fh, location: "COMCTL32", loaded at 773C0000h - 774C3000h
Symbol: "Ordinal384" (+0002318Fh)
Address: 77D4F5A6h, location: "USER32", loaded at 77D30000h - 77DC0000h
Symbol: "SetWindowTextA" (+0000005Bh)
Address: 77D385B4h, location: "USER32", loaded at 77D30000h - 77DC0000h
Address: 77D3850Ch, location: "USER32", loaded at 77D30000h - 77DC0000h
Address: 77D3B3A3h, location: "USER32", loaded at 77D30000h - 77DC0000h
Symbol: "DefWindowProcW" (+00000057h)
Address: 06551A02h, location: "correct", loaded at 06550000h - 06556000h
Symbol: "SwitchLayout" (+00000575h)
Address: 77D518AAh, location: "USER32", loaded at 77D30000h - 77DC0000h
Symbol: "UnhookWinEvent" (+00000025h)
Address: 77D389DDh, location: "USER32", loaded at 77D30000h - 77DC0000h
Symbol: "GetWindowLongW" (+00000127h)
Address: 77D3F96Bh, location: "USER32", loaded at 77D30000h - 77DC0000h
Symbol: "CallNextHookEx" (+00000100h)
Address: 77D51B55h, location: "USER32", loaded at 77D30000h - 77DC0000h
Symbol: "AppendMenuA" (+0000006Eh)
Address: 77D38A00h, location: "USER32", loaded at 77D30000h - 77DC0000h
Symbol: "GetWindowLongW" (+0000014Ah)
Address: 77D38A20h, location: "USER32", loaded at 77D30000h - 77DC0000h
Symbol: "DispatchMessageW" (+0000000Fh)
Address: 77D43635h, location: "USER32", loaded at 77D30000h - 77DC0000h
Symbol: "IsDialogMessageW" (+000000DBh)
Address: 0042FD96h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 77D3DAFAh, location: "USER32", loaded at 77D30000h - 77DC0000h
Symbol: "DestroyWindow" (+00000000h)
Address: 004BEB98h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0042FE08h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 10002DD2h, location: "shared", loaded at 10000000h - 10029000h
Symbol: "uCallStackTracker::uCallStackTracker" (+00000032h)
Address: 004C0530h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00430967h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C07D0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004BC438h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C910732h, location: "ntdll", loaded at 7C900000h - 7C9B1000h
Symbol: "RtlAllocateHeap" (+0000015Eh)
Address: 00400000h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C70E0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C911538h, location: "ntdll", loaded at 7C900000h - 7C9B1000h
Symbol: "wcsncpy" (+00000AA9h)
Address: 7C90EE18h, location: "ntdll", loaded at 7C900000h - 7C9B1000h
Symbol: "strchr" (+00000117h)
Address: 7C910738h, location: "ntdll", loaded at 7C900000h - 7C9B1000h
Symbol: "RtlAllocateHeap" (+00000164h)
Address: 7C911596h, location: "ntdll", loaded at 7C900000h - 7C9B1000h
Symbol: "wcsncpy" (+00000B07h)
Address: 004E4198h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004B49CCh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C91056Dh, location: "ntdll", loaded at 7C900000h - 7C9B1000h
Symbol: "RtlFreeHeap" (+00000130h)
Address: 7C917BF5h, location: "ntdll", loaded at 7C900000h - 7C9B1000h
Symbol: "RtlReAllocateHeap" (+000001F8h)
Address: 1000E010h, location: "shared", loaded at 10000000h - 10029000h
Address: 1000C021h, location: "shared", loaded at 10000000h - 10029000h
Address: 004E3E68h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C9106F0h, location: "ntdll", loaded at 7C900000h - 7C9B1000h
Symbol: "RtlAllocateHeap" (+0000011Ch)
Address: 00491E58h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E4218h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00447AE7h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0043D4DDh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00407E27h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0049812Dh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C0540h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 10002D87h, location: "shared", loaded at 10000000h - 10029000h
Symbol: "uPrintCrashInfo_SetDumpPath" (+000000A7h)
Address: 004AF4F4h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00430B6Eh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E0928h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004973CAh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004936FCh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004936F6h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004B49E0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004B33D0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E4210h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00497110h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004AF8E8h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00496284h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0169D588h, location: "libmmd", loaded at 015B0000h - 01861000h
Symbol: "_csqrtq_f90" (+000EAC4Ch)
Address: 7C816FD7h, location: "kernel32", loaded at 7C800000h - 7C8F7000h
Symbol: "RegisterWaitForInputIdle" (+00000049h)
Address: 7C839A00h, location: "kernel32", loaded at 7C800000h - 7C8F7000h
Symbol: "ValidateLocale" (+000002B0h)
Address: 7C816FE0h, location: "kernel32", loaded at 7C800000h - 7C8F7000h
Symbol: "RegisterWaitForInputIdle" (+00000052h)
Address: 004962EDh, location: "foobar2000", loaded at 00400000h - 004F3000h
Version info:
foobar2000 v0.9.4.3
UNICODE
Additional info:
Components versions viewer 0.3  (foo_version)
AC3 decoder 0.9  (foo_ac3)
Discogs Tagger 1.0  (foo_discogs)
TTA Audio Decoder (unofficial) 2.4.2  (foo_input_tta)
Album Art Panel 0.2.6  (foo_uie_albumart)
Feature Watcher 1.0.2  (foo_whatsnew)
Tabbed panel modified 0.2.5  (foo_uie_tabs)
Fullscreen 0.3.1  (foo_fullscreen)
Playback Statistics 1.3.2  (foo_playcount)
foobar2000 core 0.9.4.3  (Core)
FLAC Decoder 1.1.0  (foo_input_std)
Quick Search Toolbar 2.8l  (foo_uie_quicksearch)
Playlist Tools 0.5.9  (foo_utils)
Center Cut 1.0.1  (foo_dsp_centercut)
DUMB module decoder 0.9.8.4  (foo_dumb)
Special file info box 2.0.4  (foo_infobox)
File Integrity Verifier 1.0.1  (foo_verifier)
History 0.2  (foo_history)
Masstagger Addons 0.3.4 (Intel SSE)  (foo_masstag_addons)
Freedb2 characters fixer (masstagger addon) 0.02  (foo_freedb2_fix)
freedb Tagger 0.5.2a  (foo_freedb2)
Explorer Tree 1.04.6b  (foo_uie_explorer)
ReplayGain Scanner 2.0.2  (foo_rgscan)
Binary Comparator 1.1  (foo_bitcompare)
Autoplaylist Manager 1.0  (foo_autoplaylist)
Columns UI 0.1.3 beta 1v7  (foo_ui_columns)
Channel Usage Visualisation 1.0  (foo_vis_channelusage)
Queue manager panel 0.2.2  (foo_uie_queuemanager)
OptimFROG Lossless/DualStream Decoder 1.21b  (foo_input_ofr)
ALAC Decoder 1.0  (foo_input_alac)
Scheduler 3.53  (foo_scheduler)
CD Audio Decoder 2.1.1  (foo_cdda)
LPCM <--> delta-PCM converter 0.1.1  (foo_dsp_delta)
Shorten decoder 0.4.2a  (foo_input_shorten)
Peakmeter Panel 0.0.1  (foo_uie_peakmeter)
Bookmarks 0.2.5.2  (foo_uie_bookmarks)
Convolver 0.3  (foo_convolve)
ABX Comparator 1.3.1  (foo_abx)
Live Show Tagger 0.6.1  (foo_tradersfriend)
Run services 0.3.2  (foo_run)
Reverse Playback 0.1.3 (Intel SSE)  (foo_input_reverse)
projectM visualization 1.97.6.2  (foo_vis_projectM)
Album list panel 0.2.1  (foo_uie_albumlist)
ZIP/GZIP reader 1.0  (foo_unpack)
DTS decoder 0.1.1 (Intel SSE)  (foo_dts)
Converter 1.0.1  (foo_converter)
Crossfeed 0.92  (foo_dsp_crossfeed)
Kernel Streaming Output 1.2.2  (foo_out_ks)
Track info panel 0.8  (foo_uie_trackinfo)
Gapless Crossfader 0.3 (Intel SSE)  (foo_dsp_crossfader)
Decoding Speed Test 1.0  (foo_benchmark)
Menu Addons 0.3.9.5 (Intel SSE)  (foo_menu_addons)
ATSurround Processor 0.1.6a  (foo_dsp_atsurround)
Monkey's Audio decoder 2.1.2  (foo_input_monkey)
Playlist Manager 1.0.2  (foo_playlist_manager)
foo_skip 0.2  (foo_skip)
Resampler (Secret Rabbit Code) 1.03  (foo_dsp_src9)
Channel Mixer 0.9.6.2  (foo_channel_mixer)
Database Search 1.4  (foo_dbsearch)
Standard DSP array 1.0  (foo_dsp_std)
MIDI synthesizer host 1.7  (foo_midi)
Tube Sound 0.8  (foo_dsp_tube)
Playlists Dropdown 0.5.7.5  (foo_uie_playlists_dropdown)
Lyric Show Panels 0.3.1.1  (foo_uie_lyrics)
Playlist Bind 3.1  (foo_playlist_bind)
FooBar2000 Advanced Controls 0.5.9.4  (foo_AdvancedControls)
RAR reader 1.1  (foo_unpack)
Shell Link Resolver 1.2  (foo_lnk)
WMA Decoder 1.1  (foo_input_std)
Common services 0.1  (foo_common)
Cuesheet Creator 0.4.6  (foo_cuesheet_creator)
On-Screen Display 1.52  (foo_osd)
Album List 3.2.0  (foo_albumlist)
Randomized playlist entry 1.2.3  (foo_random)
SoundTouch DSP 0.1 (Intel SSE)  (foo_dsp_soundtouch)
Masstagger 1.6  (foo_masstag)
bs2b 2.1.0  (foo_dsp_bs2b)
Reply #73
Bug...
Illegal operation:
Call path:
The problem is fixed since  Jun 8 2007. Please install version 0.0.2 http://pelit.koillismaa.fi/plugins/show.php?id=207
Reply #74
Thank you! Peakmeter works also with mono files (front center channel). The component shows the channels like foobar used them. But it's a good idea for an optionally feature! So you don't need the front center channel visible to view the level of mono files.
