Funny how these things go ... an hour of typing stuff into emacs later, I've "tuned" that script a little.
Now it handles spaces correctly, and will canonicalise file paths.
You can find it here: http://jyujin.de/~creidiki/foobar2000.bash
my first try at bash scripting - i have modified this script slightly to include a recursive -adddir argument
i also tried to have the -add argument detect if it was given a directory and behave accordingly; but it's not necessary and it didn't work first try so i gave up
i have left my thoughts if the file (### commented out) so if anyone would to fix it, please let me know!
another thing....has anyone got foobars context:"open containing folder" to work? like open it up in thunar or xterm or whatever...
#!/bin/bash
# set this to what's needed to run foobar.
# for example, if you have binfmt_misc setup
# for wine, something like this will work.
# otherwise, "wine path-to-foobar" is what you want.
fb2k="/home/t/.foobar2000"
direc () {
cd canonicalise$1
pwd
canonicalise () {
filename="${1}"
# prefix replacement
case "${1}" in
# absolute, nothing to do.
# home-relative and for some odd reason calling shell
# didnt expand this already (for ex. it was quoted).
filename="${HOME}/${filename}"
# directory,
# relative path.
filename="$(pwd)/${filename}"
esac
# strip './' elements
filename=$(echo "${filename}" | sed -e 's:/\./:/:g')
# strip 'foo/../' elements
filename=$(echo "${filename}" | sed -e 's:/[^/]\+/\.\./:/:g')
# protect real backslashes
filename=$(echo "${filename}" | sed -e 's/\\/\\\\/g')
file="${filename}"
unset filename
case "${1}" in
-add)
### case "${1}" in
### echo "ADDING DIRECTORY"
### canonicalise "${2}"
### cd "$file"
### fb -addfiles *
### echo "Result: added $2 to foobar2000"
[[ -n ${2} ]] && canonicalise "${2}"
${fb2k}/foobar2000.exe /add "z:$file" & &>/dev/null
echo "Action: adding Directory or Files \"${file}\" to foobar2000"
### esac
-addfiles)
files=( "${@}" )
for (( i = 1 ; i < ${#} ; ++i )); do
canonicalise "${files[$i]}"
${fb2k}/foobar2000.exe /add "z:${file}" & &>/dev/null
echo "Action: adding $(echo ${file})"
done
echo "Result: added "$(( ${#}-1 ))" files to foobar2000"
-adddir)
canonicalise "${2}"
cd "$file"
fb -addfiles *
-play)
${fb2k}/foobar2000.exe /play & &>/dev/null
echo "Action: play Song in foobar2000"
-pause)
${fb2k}/foobar2000.exe /pause & &>/dev/null
echo "Action: pause Song in foobar2000"
-playpause)
${fb2k}/foobar2000.exe /playpause & &>/dev/null
echo "Action: play or pause Song in foobar2000"
-prev)
${fb2k}/foobar2000.exe /prev & &>/dev/null
echo "Action: play previous Song in foobar2000"
-next)
${fb2k}/foobar2000.exe /next & &>/dev/null
echo "Action: play next Song in foobar2000"
-rand)
${fb2k}/foobar2000.exe /rand & &>/dev/null
echo "Action: play random Song in foobar2000"
-stop)
${fb2k}/foobar2000.exe /stop & &>/dev/null
echo "Action: stop playing a Song in foobar2000"
-mute)
${fb2k}/foobar2000.exe /command:Volume\ mute & &>/dev/null
echo "Action: mute foobar2000"
-volup)
${fb2k}/foobar2000.exe /command:Volume\ up & &>/dev/null
echo "Action: raise Volume in foobar2000"
-voldown)
${fb2k}/foobar2000.exe /command:Volume\ down & &>/dev/null
echo "Action: decrease Volume in foobar2000"
-hide)
${fb2k}/foobar2000.exe /hide & &>/dev/null
echo "Action: hide foobar2000 window"
-show)
${fb2k}/foobar2000.exe /show & &>/dev/null
echo "Action: show foobar2000 window"
-exit)
${fb2k}/foobar2000.exe /exit & &>/dev/null
echo "Action: exit foobar2000"
-rescan)
${fb2k}/foobar2000.exe /command:"Rescan Media Library" & &>/dev/null
echo "Action: Rescan foobar2000 Media Library"
-command-*)
[[ -n ${1} ]] && command=${1##*command-}
${fb2k}/foobar2000.exe /command:"${command}" & &>/dev/null
echo "Action: call foobar2000 with command \"$command\""
-playlist_command-*)
${fb2k}/foobar2000.exe /playlist_command:"${command}" & &>/dev/null
echo "Action: call foobar2000 with playlist command \"$command\""
-playing_command-*)
${fb2k}/foobar2000.exe /playing_command:"${command}" & &>/dev/null
echo "Action: call foobar2000 with playing command \"$command\""
-help)
echo "Using: foobar2000 [Command]
Where Command can be on of these:
-add -adddir -addfiles -play -pause -playpause -stop -next -prev -rand -mute -volup -voldown -hide -show -rescan -command-[fb2k command] -playlist_command-[fb2k playlist command] -playing_command-[fb2k playing command] -help"
if [[ -n ${1} ]]; then
canonicalise "${1}"
${fb2k}/foobar2000.exe "z:${file}" & &>/dev/null
echo "Action: start foobar2000 with file ${file}"
else
${fb2k}/foobar2000.exe & &>/dev/null
echo "Action: start foobar2000"
fi
esac
