Issue with Tagging (Mac)
Reply #1 – 2007-05-08 23:57:07
As far as I know there is no real tagging standard for Wav. That is probably the reason only MM can read the 'tagging' in your files. It may use some 'self-invented' way that is not compatible with other apps. The chances you'll find anything that can read them on the Mac are very slim. I'd suggest to try to use MM to convert you files to FLAC files. FLAC files are a good choice for use on the Mac and their tags are standardised and read by various OS X programs. You talk about AIF (AIFF?) as being a lossless (compression?) format. Actually AIIF is not really a compression format. You might call it the Wav of OS X. It stores the same info but doesn't compress so the files will be just as big as Wav's. I'd suggest choosing FLAC instead. It is lossless and well supported on the Mac. Rumour has it it will even be a standard format on the next version of OS X. If you are looking for players on OS X, I can recommend Cog and Play . For conversion of various formats I recommend Max , it won't help with your Wav files, though. At least, I seriously doubt it. First thing for you to try now is fire up MM and convert one of these files to FLAC (or any other lossless format that Max can read) and see whether Cog or Play can play these files and see the tagging. Edit: Hhmm, only now do I see you actually meant MusicMatch and not MediaMonkey. I know nothing about MusicMatch but someone else might.
