Topic: best audio editor (Read 20756 times) previous topic - next topic
best audio editor
Hi
i have a question
it's my inquisitiveness, curiosity
which is the best audio editor ? for a pro job
i knew wavelab was the best
could somebody give some opinions, ideas
thanks , kind regards
best audio editor
I know some record studios use ProTools: http://www.digidesign.com/
portable: 128 kbps cbr AAC
local: -7 FLAC
best audio editor
What type of audio editor?
If a wave editor (with potentially some multitracking), I think Cool Edit/Audition/that newer Adobe thing and SoundForge are also popular options.
best audio editor
SONAR 6 Producer Edition.
ProTools doesn't come close. To bad it's becomed the "industry standard".
myspace.com/borgei - last.fm/user/borgei
best audio editor
most recording studios i've seen/worked in used logic (mac) for recording and wavelab (windows) for editing/mastering.
protools actually was some kind of a standard 10 years back, but today? i don't think so.
best audio editor
Adobe Audition looks like it is something that professional type people would use.
And if you believe theres not a chance to die...
best audio editor
Well, I make my living doing recording/editing so here's my 2 cents:
I prefer Adobe Audition 1.5 (which began life as CoolEdit) for the majority of destructive 2 track wav editing.  There is Audition 2.0 but it's a lot more bloated and slow.  I use it when I absolutely need a few of its really useful features.
I prefer Sonar 6.2.1 for my multitrack work, eg. song production, video soundtracks, that sort of thing.
ProTools is excellent, and it is an industry standard.  It probably has the best multitrack recording and editing capabilities of any program out there.  I don't use it because it is overpriced (IMO, of course) and because it will only export audio in real-time.  That's a deal-breaker when working on tight deadlines.
I tried Wavelab and SoundForge, but I just couldn't get used to them.  CoolEdit (and thus Audition) just worked the way I wanted to.
Audacity seems to work for some people, but it always crashed on me.  I tried its stable versions under both OSX and WinXP but it was never stable.
Take that however you will.
best audio editor
Hi
i have a question
if all you wanna do is edit then go with soundforge. i've tried the bulk of professional editors out there and the interface and simplicity of it is just a dream and it never compromises on quality. wavelab is very good but more geared towards mastering, likewise for samplitude. audition's the cheapo editor's choice, professional editing on a budget. don't get shit like protools or cubase or vegas (basically sequencers/dmws) for editing. these things are meant for tracking (though you can obviously do some editing with them), they're huge in size and memory and ahem cost. not for standalone editing for sure.
Be healthy, be kind, grow rich and prosper
best audio editor
I was under the impression Magix Samplitude pro/Sequoia played a big role amongst the wave editors/multi trackers; was I wrong?
best audio editor
Audition has the best feel, as most of what you will need is intuitive.
It is able to handle DSP comparably to Steinberg's CuBase [note: I only have SX, which came with the Firewire mixer], and much faster and more accurately than Sonar [short term comparison, plugged the Alesis into Cakewalk just for testing.]
However, I had some trouble getting it to accept the plug-ins I needed (Waves mono) so I switched to the much clunkier feeling and slower Sound Forge.
Have never used Pro Logic, as it only runs on Mac.  (EAC does not run on Mac, so my hands are tied; otherwise I would be fawning over Linux.)  Rumor (generated by Apple users) has it that Pro is still the best, and I recall that at the end of last year Google claimed that there were some 20% more searches for pro-logic, than there were for Audition or Sound Forge.
Just my own two bits.  Have you tried Googling for threads on other forums?
best audio editor
I believe Sound Forge is the best for Audio editing / detailed work, whereas Wavelab sufficies for simple cropping / resampling operations as it is slightly quicker and better at saving files. For Multi-Tracking, I use Cubase SX, which admittedly can be sluggish on a poor PC, but can do amazing things once you've learnt how to use it.
If at first you don't succeed, so much for hang-gliding
best audio editor
1. Adobe Audition
2. DC Six (Diamond Cut)
best audio editor
Probably the one the "pro" you're dealing with already uses; failing that, the one you're most proficient with.
Pro Tools is pretty common, sort of a de facto standard -- excellent multi-track mixer, not quite so great as a waveform editor. Free version out there for Macs and Win 98.
Adobe Audition has lots of followers in the radio production world, though it's not the obvious low-cost choice that Cool Edit once was since Adobe bought it added major $$ to the price.... A great waveform editor: the noise reduction function can do incredible things. (Disclosure: it's what I use, mainly because it's already paid for and I have lots of presets and project templates built up...)
Audacity isn't too shabby for free; supports VST plugins so it can be expanded.
best audio editor
Sequoia.
best audio editor
here wavelab is not very popular
best audio editor
i second tarsier... Audition v1.5 is the fastest that I've seen.  Speed counts the most for me, and of course that there are no quality problems with it.
Sequoia is also something I use for mixing tracks for a CD master from pre-mastered stuff (if i did them or not, but usually because i've done them).  The way it mixes is mathematically sound (two 16-bit sources into 17-bits, two 24-bit sources into 25-bits, etc), and the quantization of Pow-r dithering is of course fantastic.  I almost always use Apogee UV22 HR afterwards though, but still it's really hard to ABX the Pow-R dithering against UV22 HR (and that doesn't prove which, if either, are "better")
I used to have a SADiE PCM-4M for analog transfers and cd mastering, but got rid of it, but that's also a fantastic editing & mastering platform.  Especially for surround apps with the 8+ channel units, right up into the 64 channel units which could certainly be used for critical multitrack recording.  Not cheap.    (as much as i'm heading away from proprietary hardware, the LRX2 with 64-channel MADI interface looks amazingly sexy)
Mainly now I'm just using Audition v1.5 and Apogee hardware.  Winamp as a shell for my mastering components - before you laugh, test it with in_wave v2.06 (or earlier, which doesn't force bit depth or dither) and out_disk and you'll find it's a 1:1 copy.  Sequoia for cd mastering and burning (at 2x) or Burrrn for non-mixed cd masters (at 2x).
best audio editor
my fave wave editor is sound forge although i'm not 100% happy with it (anymore). i chose it back in the days when it was considerably faster than cool edit and stuck with it. i see lots of recommendations for audition v1.5, especially for its speed (i thought it was just cool edit in disguise, therefore haven't given it attention), saying v2.0 is slow and bloated, but from what i can see the last version is v3 - any thoughts on that one? even slower than v2 or is it optimized and leaner like v1.5 (small chance of that i presume, but still)? does it perhaps have some other substantial upgrades that would still make its usage worth while, despite the presumed bloat, or would i still be better off hunting for the old version?
best audio editor
erm "Pro Logic" is an analog matrix surround sound format invented by Dolby. I think you mean Logic Pro. Logic used to be developed by Emagic until Apple bought them in 2002, the last windows version was 5.
This entire thread seems to confuse multitrack music productions systems with audio editors and mastering tools. There are of course programs which try and do both.
If you want to record and edit audio rather than sequence it then the options in no particular order are:
Steinberg WaveLab (Stereo, Windows Only)
AudioFileEngineering Wave Editor (Stereo, Windows Only)
Bias Peak (Stereo, Mac Only)
Adobe Audition (Multichannel, Windows Only)
Apple Soundtrack Pro (Multichannel, Mac Only)
Sony Sound Forge (Multichannel, Windows Only)
Sonic Studio Sound Blade (Limited multi channel, Mac Only, ultra high end if you have to ask the price you can't afford it)
SADiE (Multichannel, Windows only, ultra high end if you have to ask the price you can't afford it)
If you want something that does sequencing  and  MIDI as well then again in no particular order
Cakewalk Sonar (Windows Only)
Magix Sequoia (Windows Only)
Apple Logic Pro (Mac Only)
Steinberg Nuendo  (Cross platform but happiest on Windows)
Digidesign ProTools (Cross platform)
Most studios will have multiple applications as no single product does everything required from multitrack sequencing through to mastering.
best audio editor
Nope. Still is very much the "industry standard" -- and it's "Pro Tools".
Yep. Some confusion here regarding digital audio workstations (DAWs) and audio editors. Pro Tools, Nuendo and Logic Pro are best defined as DAWs (digital audio workstations); WaveLab, Peak and Sound Forge are best defined as audio editors; and applications like Audition dip into both realms.
I personally use Pro Tools and BIAS's Peak Pro when I'm in Macland, and Pro Tools and WaveLab in the PC world. As it stands now, I prefer Peak.
best audio editor
I just wish there was something for the Mac that does what Audacity does and wasn't a buggy pile of crap with a dubious internal architecture.
Soundtrack Pro looks as though it does some of what I want but it doesn't look as though you can apply arbitrary envelopes to the duration of a clip which is the feature I really want that Audacity has.
best audio editor
Have you tried Amadeus?  I have a license for Amadeus II (haven't tried Amadeus Pro) and I find it to be intuitive, fast and powerful.
This should read, 'Mac Only'
best audio editor
Nobody has mentioned Reaper, so I will. Teeny tiny download, very fast and very flexible, good stock plugins.
This falls into the multitrack recording and mixing category btw.
Dan
best audio editor
I'll have to say, that once you're used to it, Reaper is absoloutely amazing: you can pay hundreds for stuff like Cubasis, or take a short time to navigate the maze of menus in Reaper, which is totally free! Good favourite (despite my earlier post, by which time I hadn't discovered this!)
best audio editor
I think Adobe Audition or the new one err is it soundbooth.
:Foobar 2000:
:MPC --standard:
:iRiver H320 Rockboxed:
