Topic: Using xACT to rip and encode to FLAC. (Read 1989 times) previous topic - next topic
Okay, I just downloaded the newest version of xACT (1.59) with the intent of ripping a cd and then encoding to FLAC.  Problem is, whenever I attempt this, by going to the "util" menu of xACT, selecting CD Extraction and then wav, adding the files from the cd and then executing, I get the following message:
There is no sound support configured!
cdda2wav: Input/output error. inquiry: scsi sendcmd: no error
CDB:  12 00 00 00 24 00
status: 0x2 (CHECK CONDITION)
Sense Bytes: 55 53 42 53 00 00 00 93 00 00 00 00 00 61 72 79 2F 45
Sense Key: 0xFFFFFFFF [], Segment 0
Sense Code: 0x55 Qual 0x00 (system resource failure) Fru 0x0
Sense flags: Blk 5456467 (not valid)
resid: 36
cmd finished after 0.002s timeout 60s
Inquiry command failed. Aborting...
Has anyone else encountered this?  If you have, is there a solution?
The guide that I was following can be found at this page:
Ripping FLAC with a log on Mac OSX
