Topic: Typical questions of a new potential miniDV cam owner (Read 1916 times) previous topic - next topic
Hi!
I'm planning to buy a miniDV camera at around 300$
I think it may be Sony DCR-HC23E
Basically, I'm looking for something which has less pixels and bigger matrix. What can it be?
And the second question is, where can I read what is the best way of downloading and converting the resulting data to some video format (processor consuming with the best compression)
Thanks a lot!
no idea, as for the 2nd part of the question:
the best way is to hook up the firewire cable and dump dv stream to disk, free utility is windv for example.
http://windv.mourek.cz/
After that (as a 2nd step) you can compress further.
