Topic: foo_run problem (Read 2341 times) previous topic - next topic
foo_run problem
Toolbar shortcuts don't work for foo_run commands. Is that some general bug? Do they work in someone's configuration?
User JB
foo_run problem
Am I only person in the world who uses foo_run plugin?
foo_run problem
I'm using it as well, it served me all necessary commands. I just don't figure out what a toolbar shortcut is. Never needed it. From columns ui?
foo_run problem
Problem solved. When linking a button to a runservice, the default "Item Group" is set to None. You need to set it to Now playing item in order for the button to work. You can also use Current playlist selection but that will only work if an item is selected in your playlist (no item selected, button doesnt work).
Thanks to Yotsuya. His advice has been copied from another thread.
