Topic: foo_input_tak (Read 213399 times) previous topic - next topic
foo_input_tak
There is a beta now of 0.9.4.3
from the change list
*      Fixed multiple bugs in ReplayGain Scanner
Let's try if it help for this.
foo_input_tak
A few weird things I've noticed myself... when I initially added TAK files to a playlist, there is no bitrate known/displayed.  It was there for all other files I added after my initial use of the plugin, however.  Might have been something I did...
I'm not sure, if or how static bitrate display is implemented. I'll have to look at that first.
The only other thing that I could hope for, at this point, would be support for embedded cue files.  I've not been able to reproduce a crash yet, and I've been trying.
I'll add support for embedded cue sheets for the next release.
Also, it seems that tagging was much faster when the plugin used foobar's own mechanism. Anyone else notice this?
It still uses the APEv2 routines provided by foobar2000. Tag updating might be slower compared to the stub decoder that did only tagging, because now a TAK decoder instance is created and initialized whenever tags are read or updated.
Next release should be out some time before the weekend.
foo_input_tak
hi foosion,
integrating some more encoder-information in the next release would be great! (something like %tool%=v1.0.1)
and if it is possible a more specific %codec_profile%. (not only High but HighMax...)
greatz
..::l0ve is needed::..
foo_input_tak
That was not possible with the first versions of the TAK SDK. I will add it in the next release.
foo_input_tak
Possibly i can speed this up a bit. I could wait with most of the decoder object's initializations until audio data is beeing read. If the decoder object is only beeing used to request some info about the file, most of it's internal initializations are not needed.
But this will have to wait a bit.
Great!
  Thomas
foo_input_tak
foo_input_tak 0.3
Bundled tak_deco_lib.dll 1.0.2. Added support for embedded cue sheets. Fixed static bitrate display when dynamic bitrate display is disabled in foobar2000 preferences. Added encoder version ("tool" tech info field) and preset display ("codec_profile" tech info field).
foo_input_tak
foo_input_tak 0.3
Thank you
EDIT: I've had two crashes so far: one while tagging and another while replaygaining.
Crash while replaygaining:
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 01581E9Eh
Access violation, operation: write, address: 0000BCAEh
Call path:
ReplayGain thread=>input_entry::g_open_for_decoding
Code bytes (01581E9Eh):
01581E5Eh:  90 F4 89 5B 04 89 1B EB 3A 8B 10 89 43 04 89 13
01581E6Eh:  89 18 89 5A 04 EB 2C 81 FE 00 3C 00 00 7C 0D 8B
01581E7Eh:  D6 8B C7 E8 EA FE FF FF 84 C0 75 17 A1 0C 86 5A
01581E8Eh:  01 89 1D 0C 86 5A 01 8B 10 89 43 04 89 13 89 18
01581E9Eh:  89 5A 04 5F 5E 5B C3 8D 40 00 83 3D 10 86 5A 01
01581EAEh:  00 7E 40 83 3D 10 86 5A 01 0C 7D 0C C7 05 BC 85
01581EBEh:  5A 01 07 00 00 00 EB 2B A1 10 86 5A 01 83 C8 02
01581ECEh:  8B 15 14 86 5A 01 89 02 A1 14 86 5A 01 83 C0 04
Stack (0516F918h):
0516F8F8h:  77404D01 04AF4580 00000101 04AC2298
0516F908h:  00000000 01D00178 77404D01 00000000
0516F918h:  00012694 058D596C 058D7FFC 01581C67
0516F928h:  00181B54 01581DE9 8D800000 01000005
0516F938h:  058E6C00 0516F97C 058D596C 00012690
0516F948h:  058D596C 01581E86 058E6314 058D596C
0516F958h:  00012690 015823F9 0516F9C4 01582422
0516F968h:  0516F97C 016D4A78 058E6214 058E6214
0516F978h:  00000001 0516F9A8 015826F3 058E6214
0516F988h:  0158330D 44FA0001 015836CD 015A4DB0
0516F998h:  016D5328 0516F9F4 01583353 015A5687
0516F9A8h:  02336530 01539164 058E6214 BA90532B
0516F9B8h:  0230A590 00000000 016D7988 0516FC0C
0516F9C8h:  0154BEB8 FFFFFFFF 01538DC4 0516F9F4
0516F9D8h:  BA90534F 00000000 00000000 04A87804
0516F9E8h:  00000000 04A877F4 0516F9C8 016D5328
0516F9F8h:  FFFFFFFF 00000002 7C9106AB 7C9106EB
0516FA08h:  00000004 00000000 7C9105D4 0516FAE0
0516FA18h:  7C910551 00000000 00000000 00000000
0516FA28h:  016D6BC8 0516FA3C 00000000 0230A590
Registers:
EAX: 058A23A8, EBX: 058D596C, ECX: 00002690, EDX: 0000BCAA
ESI: 00002690, EDI: 058D596C, EBP: 058D8000, ESP: 0516F918
Crash location: "tak_deco_lib", loaded at 01580000h - 015B1000h
Loaded modules:
foobar2000                      loaded at 00400000h - 004F3000h
ntdll                            loaded at 7C900000h - 7C9B0000h
kernel32                        loaded at 7C800000h - 7C8F4000h
COMCTL32                        loaded at 773D0000h - 774D3000h
msvcrt                          loaded at 77C10000h - 77C68000h
ADVAPI32                        loaded at 77DD0000h - 77E6B000h
RPCRT4                          loaded at 77E70000h - 77F01000h
GDI32                            loaded at 77F10000h - 77F57000h
USER32                          loaded at 7E410000h - 7E4A0000h
SHLWAPI                          loaded at 77F60000h - 77FD6000h
SHELL32                          loaded at 7C9C0000h - 7D1D5000h
ole32                            loaded at 774E0000h - 7761D000h
shared                          loaded at 10000000h - 10029000h
comdlg32                        loaded at 763B0000h - 763F9000h
LVPrcInj                        loaded at 003D0000h - 003E7000h
uxtheme                          loaded at 5AD70000h - 5ADA8000h
RocketDock                      loaded at 00A30000h - 00A42000h
PSAPI                            loaded at 76BF0000h - 76BFB000h
foo_audioscrobbler              loaded at 00A60000h - 00A97000h
WS2_32                          loaded at 71AB0000h - 71AC7000h
WS2HELP                          loaded at 71AA0000h - 71AA8000h
foo_autoplaylist                loaded at 00B30000h - 00B60000h
foo_benchmark                    loaded at 00B60000h - 00B88000h
foo_bitcompare                  loaded at 00BB0000h - 00BD7000h
foo_cdda                        loaded at 00C00000h - 00C35000h
foo_converter                    loaded at 00C60000h - 00CC9000h
foo_cwb_hooks                    loaded at 00CF0000h - 00D25000h
foo_dbsearch                    loaded at 00D50000h - 00DC0000h
OLEAUT32                        loaded at 77120000h - 771AC000h
foo_dsp_dolbyhp                  loaded at 00DE0000h - 00E01000h
VERSION                          loaded at 77C00000h - 77C08000h
foo_dsp_headphones              loaded at 00E20000h - 00E88000h
NTMARTA                          loaded at 77690000h - 776B1000h
WLDAP32                          loaded at 76F60000h - 76F8C000h
SAMLIB                          loaded at 71BF0000h - 71C03000h
Apphelp                          loaded at 77B40000h - 77B62000h
foo_dsp_std                      loaded at 010D0000h - 01111000h
foo_freedb2                      loaded at 01140000h - 01180000h
foo_input_alac                  loaded at 011A0000h - 011BD000h
foo_input_dts                    loaded at 011E0000h - 01245000h
foo_input_matroska              loaded at 01270000h - 012F8000h
foo_input_monkey                loaded at 01320000h - 0136A000h
foo_input_shorten                loaded at 01390000h - 013BD000h
foo_input_std                    loaded at 013E0000h - 014F3000h
foo_input_tak                    loaded at 01520000h - 01566000h
tak_deco_lib                    loaded at 01580000h - 015B1000h
foo_lnk                          loaded at 016E0000h - 016F9000h
foo_lyricsdb                    loaded at 01720000h - 0174F000h
WININET                          loaded at 771B0000h - 77256000h
CRYPT32                          loaded at 77A80000h - 77B14000h
MSASN1                          loaded at 77B20000h - 77B32000h
foo_masstag                      loaded at 01770000h - 017BF000h
foo_menu_addons                  loaded at 01820000h - 0186D000h
libmmd                          loaded at 01870000h - 01B21000h
MSVCR80                          loaded at 78130000h - 781CB000h
foo_navigator                    loaded at 01B30000h - 01B61000h
foo_packet_decoder_ac3          loaded at 01B90000h - 01BB7000h
foo_playcount                    loaded at 01BE0000h - 01C08000h
foo_playlist_manager            loaded at 01C30000h - 01C74000h
foo_rgscan                      loaded at 01CA0000h - 01CE8000h
foo_run                          loaded at 01D10000h - 01D3B000h
foo_uie_albumart                loaded at 01D60000h - 01D9C000h
gdiplus                          loaded at 4EC50000h - 4EDF3000h
foo_uie_albumlist                loaded at 01DD0000h - 01E0F000h
foo_uie_console                  loaded at 01E30000h - 01E4C000h
foo_uie_tabs                    loaded at 01E70000h - 01E96000h
foo_uie_trackinfo_mod            loaded at 01EC0000h - 01F16000h
MSVCP80                          loaded at 7C420000h - 7C4A7000h
foo_ui_columns                  loaded at 01F30000h - 01FC7000h
foo_ui_std                      loaded at 01FF0000h - 02047000h
foo_unpack                      loaded at 02070000h - 0209E000h
foo_utils                        loaded at 020C0000h - 020F8000h
foo_utils_matroska              loaded at 02120000h - 0213A000h
foo_verifier                    loaded at 02160000h - 02190000h
foo_version                      loaded at 021B0000h - 021D6000h
dbghelp                          loaded at 59A60000h - 59B01000h
dciman32                        loaded at 73BC0000h - 73BC6000h
mswsock                          loaded at 71A50000h - 71A8F000h
DNSAPI                          loaded at 76F20000h - 76F47000h
iphlpapi                        loaded at 76D60000h - 76D79000h
hnetcfg                          loaded at 662B0000h - 66308000h
wshtcpip                        loaded at 71A90000h - 71A98000h
DolbyHph                        loaded at 04B70000h - 04C6C000h
rasadhlp                        loaded at 76FC0000h - 76FC6000h
netapi32                        loaded at 5B860000h - 5B8B4000h
CLBCATQ                          loaded at 76FD0000h - 7704F000h
COMRes                          loaded at 77050000h - 77115000h
shdocvw                          loaded at 7E290000h - 7E3FF000h
CRYPTUI                          loaded at 754D0000h - 75550000h
WINTRUST                        loaded at 76C30000h - 76C5E000h
IMAGEHLP                        loaded at 76C90000h - 76CB8000h
urlmon                          loaded at 7E1E0000h - 7E280000h
Secur32                          loaded at 77FE0000h - 77FF1000h
SETUPAPI                        loaded at 77920000h - 77A13000h
DSOUND                          loaded at 73F10000h - 73F6C000h
WINMM                            loaded at 76B40000h - 76B6D000h
wdmaud                          loaded at 72D20000h - 72D29000h
msacm32                          loaded at 72D10000h - 72D18000h
MSACM32                          loaded at 77BE0000h - 77BF5000h
midimap                          loaded at 77BD0000h - 77BD7000h
KsUser                          loaded at 73EE0000h - 73EE4000h
Stack dump analysis:
Address: 01581C67h, location: "tak_deco_lib", loaded at 01580000h - 015B1000h
Address: 01581DE9h, location: "tak_deco_lib", loaded at 01580000h - 015B1000h
Address: 01581E86h, location: "tak_deco_lib", loaded at 01580000h - 015B1000h
Address: 015823F9h, location: "tak_deco_lib", loaded at 01580000h - 015B1000h
Address: 01582422h, location: "tak_deco_lib", loaded at 01580000h - 015B1000h
Address: 015826F3h, location: "tak_deco_lib", loaded at 01580000h - 015B1000h
Address: 0158330Dh, location: "tak_deco_lib", loaded at 01580000h - 015B1000h
Address: 015836CDh, location: "tak_deco_lib", loaded at 01580000h - 015B1000h
Address: 015A4DB0h, location: "tak_deco_lib", loaded at 01580000h - 015B1000h
Address: 01583353h, location: "tak_deco_lib", loaded at 01580000h - 015B1000h
Address: 015A5687h, location: "tak_deco_lib", loaded at 01580000h - 015B1000h
Symbol: "tak_SSD_Destroy" (+0000000Fh)
Address: 01539164h, location: "foo_input_tak", loaded at 01520000h - 01566000h
Address: 0154BEB8h, location: "foo_input_tak", loaded at 01520000h - 01566000h
Address: 01538DC4h, location: "foo_input_tak", loaded at 01520000h - 01566000h
Address: 7C9106ABh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+000000D7h)
Address: 7C9106EBh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+00000117h)
Address: 7C9105D4h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+00000000h)
Address: 7C910551h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlFreeHeap" (+00000114h)
Address: 01550948h, location: "foo_input_tak", loaded at 01520000h - 01566000h
Address: 0154DB40h, location: "foo_input_tak", loaded at 01520000h - 01566000h
Address: 015395EFh, location: "foo_input_tak", loaded at 01520000h - 01566000h
Address: 0154DC88h, location: "foo_input_tak", loaded at 01520000h - 01566000h
Address: 015392DFh, location: "foo_input_tak", loaded at 01520000h - 01566000h
Address: 0154DCC0h, location: "foo_input_tak", loaded at 01520000h - 01566000h
Address: 0153827Fh, location: "foo_input_tak", loaded at 01520000h - 01566000h
Address: 0155D584h, location: "foo_input_tak", loaded at 01520000h - 01566000h
Address: 01CB5F51h, location: "foo_rgscan", loaded at 01CA0000h - 01CE8000h
Address: 01CCE378h, location: "foo_rgscan", loaded at 01CA0000h - 01CE8000h
Address: 01CB4EBBh, location: "foo_rgscan", loaded at 01CA0000h - 01CE8000h
Address: 01CB4F37h, location: "foo_rgscan", loaded at 01CA0000h - 01CE8000h
Address: 01CB4F53h, location: "foo_rgscan", loaded at 01CA0000h - 01CE8000h
Address: 014E11B0h, location: "foo_input_std", loaded at 013E0000h - 014F3000h
Address: 01CD4698h, location: "foo_rgscan", loaded at 01CA0000h - 01CE8000h
Address: 01CCF238h, location: "foo_rgscan", loaded at 01CA0000h - 01CE8000h
Address: 01CB5301h, location: "foo_rgscan", loaded at 01CA0000h - 01CE8000h
Address: 004DE5F8h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0153BA70h, location: "foo_input_tak", loaded at 01520000h - 01566000h
Address: 0153BA8Fh, location: "foo_input_tak", loaded at 01520000h - 01566000h
Address: 01CD46A0h, location: "foo_rgscan", loaded at 01CA0000h - 01CE8000h
Address: 0153D1D0h, location: "foo_input_tak", loaded at 01520000h - 01566000h
Address: 01CCF288h, location: "foo_rgscan", loaded at 01CA0000h - 01CE8000h
Address: 01CB4FA2h, location: "foo_rgscan", loaded at 01CA0000h - 01CE8000h
Address: 01CCF2B8h, location: "foo_rgscan", loaded at 01CA0000h - 01CE8000h
Address: 01CBC30Fh, location: "foo_rgscan", loaded at 01CA0000h - 01CE8000h
Address: 01CCF67Bh, location: "foo_rgscan", loaded at 01CA0000h - 01CE8000h
Address: 01CBC06Eh, location: "foo_rgscan", loaded at 01CA0000h - 01CE8000h
Address: 01CCF6B0h, location: "foo_rgscan", loaded at 01CA0000h - 01CE8000h
Address: 01CAE6BFh, location: "foo_rgscan", loaded at 01CA0000h - 01CE8000h
Address: 01CC2964h, location: "foo_rgscan", loaded at 01CA0000h - 01CE8000h
Address: 01CC0A80h, location: "foo_rgscan", loaded at 01CA0000h - 01CE8000h
Address: 01CBF861h, location: "foo_rgscan", loaded at 01CA0000h - 01CE8000h
Address: 01CCF883h, location: "foo_rgscan", loaded at 01CA0000h - 01CE8000h
Address: 01CAEC8Fh, location: "foo_rgscan", loaded at 01CA0000h - 01CE8000h
Address: 77404D01h, location: "COMCTL32", loaded at 773D0000h - 774D3000h
Symbol: "Ordinal384" (+00018E61h)
Address: 01CCFA50h, location: "foo_rgscan", loaded at 01CA0000h - 01CE8000h
Address: 01CAE4C8h, location: "foo_rgscan", loaded at 01CA0000h - 01CE8000h
Address: 01CCFA79h, location: "foo_rgscan", loaded at 01CA0000h - 01CE8000h
Address: 7C90E2DCh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "NtRegisterThreadTerminatePort" (+0000000Ch)
Address: 7C80B683h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "GetModuleFileNameA" (+000001B4h)
Address: 7C839AA8h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "ValidateLocale" (+000002B0h)
Address: 7C80B690h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "GetModuleFileNameA" (+000001C1h)
Address: 01CAE440h, location: "foo_rgscan", loaded at 01CA0000h - 01CE8000h
Address: 010E01F7h, location: "foo_dsp_std", loaded at 010D0000h - 01111000h
Address: 012A2E74h, location: "foo_input_matroska", loaded at 01270000h - 012F8000h
Address: 77000000h, location: "CLBCATQ", loaded at 76FD0000h - 7704F000h
Symbol: "ActivatorUpdateForIsRouterChanges" (+000000DDh)
Address: 02000000h, location: "foo_ui_std", loaded at 01FF0000h - 02047000h
Address: 770013DAh, location: "CLBCATQ", loaded at 76FD0000h - 7704F000h
Symbol: "DowngradeAPL" (+00000C1Fh)
Address: 00E79511h, location: "foo_dsp_headphones", loaded at 00E20000h - 00E88000h
Address: 00D20000h, location: "foo_cwb_hooks", loaded at 00CF0000h - 00D25000h
Address: 00440000h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 010E0121h, location: "foo_dsp_std", loaded at 010D0000h - 01111000h
Address: 00426400h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 01FF10FFh, location: "foo_ui_std", loaded at 01FF0000h - 02047000h
Version info:
foobar2000 v0.9.4.2
UNICODE
Additional info:
Playlist Tools 0.5.9  (foo_utils)
ATSC A/52 (AC3) Packet Decoder 0.9  (foo_packet_decoder_ac3)
Monkey's Audio decoder 2.1.2  (foo_input_monkey)
cwbowron's title format hooks 1.1.0beta [Dec  1 2006 - 13:47:34]  (foo_cwb_hooks)
File Integrity Verifier 1.0.1  (foo_verifier)
4Front Headphones 1.0c  (foo_dsp_headphones)
ReplayGain Scanner 2.0.2  (foo_rgscan)
Run services 0.3.2  (foo_run)
Matroska Utility Plugin 1.0.2  (foo_utils_matroska)
Masstagger 1.6  (foo_masstag)
Binary Comparator 1.1  (foo_bitcompare)
Menu Addons 0.3.9.1 (Intel SSE)  (foo_menu_addons)
FLAC Decoder 1.1.0  (foo_input_std)
Album Art Panel 0.2.6  (foo_uie_albumart)
Shell Link Resolver 1.2  (foo_lnk)
Converter 1.0.1  (foo_converter)
foo_lyricsdb 0.0.7 beta 5  (foo_lyricsdb)
Default User Interface 0.9acc  (foo_ui_std)
TAK Decoder 0.3  (foo_input_tak)
Standard DSP array 1.0  (foo_dsp_std)
Shorten decoder 0.4.2a  (foo_input_shorten)
Playlist Manager 1.0.2  (foo_playlist_manager)
RAR reader 1.1  (foo_unpack)
Track info panel mod 0.8.0 beta [Jan  5 2007 - 13:36:12]  (foo_uie_trackinfo_mod)
Playback Statistics 1.3.2  (foo_playcount)
Database Search 1.4  (foo_dbsearch)
Decoding Speed Test 1.0  (foo_benchmark)
Audioscrobbler 1.3.5  (foo_audioscrobbler)
Console panel 0.2  (foo_uie_console)
CD Audio Decoder 2.1.1  (foo_cdda)
foobar2000 core 0.9.4.2  (Core)
Components versions viewer 0.3  (foo_version)
freedb Tagger 0.5.2a  (foo_freedb2)
WMA Decoder 1.1  (foo_input_std)
Tabbed panel modifyed 0.2.1  (foo_uie_tabs)
Autoplaylist Manager 1.0  (foo_autoplaylist)
DTS decoder 0.1.7  (foo_input_dts)
Album list panel 0.2.1 beta 4  (foo_uie_albumlist)
Dolby Headphone Wrapper 1.1  (foo_dsp_dolbyhp)
ALAC Decoder 1.0  (foo_input_alac)
Navigator 0.6  (foo_navigator)
Columns UI 0.1.3 beta 1v7  (foo_ui_columns)
ZIP/GZIP reader 1.0  (foo_unpack)
Matroska Plugin 0.9.2.0  (foo_input_matroska)
Crash while tagging (using the latest version):
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 01581E95h
Access violation, operation: read, address: 058E4000h
Call path:
threaded_process thread
This is your 2-nd crash. When reporting the problem to a developer, please try to post info about the first crash instead.
Code bytes (01581E95h):
01581E55h:  75 10 A1 18 86 5A 01 89 5C 90 F4 89 5B 04 89 1B
01581E65h:  EB 3A 8B 10 89 43 04 89 13 89 18 89 5A 04 EB 2C
01581E75h:  81 FE 00 3C 00 00 7C 0D 8B D6 8B C7 E8 EA FE FF
01581E85h:  FF 84 C0 75 17 A1 0C 86 5A 01 89 1D 0C 86 5A 01
01581E95h:  8B 10 89 43 04 89 13 89 18 89 5A 04 5F 5E 5B C3
01581EA5h:  8D 40 00 83 3D 10 86 5A 01 00 7E 40 83 3D 10 86
01581EB5h:  5A 01 0C 7D 0C C7 05 BC 85 5A 01 07 00 00 00 EB
01581EC5h:  2B A1 10 86 5A 01 83 C8 02 8B 15 14 86 5A 01 89
Stack (055BF78Ch):
055BF76Ch:  0013EF00 7E4237BC 00000000 0000000C
055BF77Ch:  00000000 003C4838 00000000 0013EF2C
055BF78Ch:  0000DC58 058A23A8 058A3FFC 01581C67
055BF79Ch:  00181A84 01581DE9 8A400000 00C00005
055BF7ACh:  00000000 055BF7F0 058A23A8 0000DC54
055BF7BCh:  058A23A8 01581E86 058AE050 058A23A8
055BF7CCh:  0000DC54 015823F9 055BF86C 01582422
055BF7DCh:  055BF7F0 05636DF8 058A238C 058A238C
055BF7ECh:  0159B618 055BF850 015826F3 058A238C
055BF7FCh:  0159B7EA 055BF801 0159B8D7 058A1B08
055BF80Ch:  055BF801 01583353 0159D676 05890088
055BF81Ch:  44FB0001 01583353 0159DF11 05841B6C
055BF82Ch:  05841B6C 01583353 015A461A 44FB0001
055BF83Ch:  015A4D92 05677E98 055BF89C 01583353
055BF84Ch:  015A5687 02621330 01539164 05841B6C
055BF85Ch:  BADD52F3 02309D50 00000000 05677E80
055BF86Ch:  055BFAB4 0154BEB8 FFFFFFFF 01538DC4
055BF87Ch:  055BF89C BADD5217 00000000 00000000
055BF88Ch:  055BFF30 00000000 0013F3E0 055BF870
055BF89Ch:  05677E98 7C9106EB 00000004 00000000
Registers:
EAX: 058E4000, EBX: 058A23A8, ECX: 00001C54, EDX: 00001C54
ESI: 00001C54, EDI: 058A23A8, EBP: 058A4000, ESP: 055BF78C
Loaded modules:
Address: 00C00005h, location: "foo_cdda", loaded at 00C00000h - 00C35000h
Address: 0159B618h, location: "tak_deco_lib", loaded at 01580000h - 015B1000h
Address: 0159B7EAh, location: "tak_deco_lib", loaded at 01580000h - 015B1000h
Address: 0159B8D7h, location: "tak_deco_lib", loaded at 01580000h - 015B1000h
Address: 0159D676h, location: "tak_deco_lib", loaded at 01580000h - 015B1000h
Address: 0159DF11h, location: "tak_deco_lib", loaded at 01580000h - 015B1000h
Address: 015A461Ah, location: "tak_deco_lib", loaded at 01580000h - 015B1000h
Address: 015A4D92h, location: "tak_deco_lib", loaded at 01580000h - 015B1000h
Address: 7C9105C8h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlFreeHeap" (+0000018Bh)
Address: 015394DFh, location: "foo_input_tak", loaded at 01520000h - 01566000h
Address: 0153839Fh, location: "foo_input_tak", loaded at 01520000h - 01566000h
Address: 0047F831h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0047E206h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0047E223h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C6FC8h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0047413Dh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004A9118h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0047EC7Ch, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00442290h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E2C6Ch, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C6FD0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E2C84h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004A91E8h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0047E351h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004A9218h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0047E3FCh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004AAA48h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0043ACC3h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C7008h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004BE970h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004AF987h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0045D460h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C42A8h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 10002D87h, location: "shared", loaded at 10000000h - 10029000h
Symbol: "uPrintCrashInfo_SetDumpPath" (+000000A7h)
Address: 004A86ACh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0045D414h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004A6459h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0045D3EFh, location: "foobar2000", loaded at 00400000h - 004F3000h
Version info:
foobar2000 v0.9.4.2
UNICODE
Additional info:
foo_input_tak
Reply #32
foo_input_tak 0.3
Thank you very much foosion.
Been waiting for the embedded cuesheet option. I'm using the component right now and everything works very well! No crashes or anything so far!
foo_input_tak
foo_input_tak 0.3
you are unbelievable!!
Everything works great. Thank you!
foo_input_tak
Reply #34
TAK v3 and Foobar v9.4.3b crashed when i was replaygaining cue+single tak and also playing it at the same time.
Illegal operation:
Code: 0EEDFADEh, flags: 00000001h, address: 7C812A5Bh
Call path:
ReplayGain thread=>input_decoder::initialize=>input_entry::g_open_for_decoding
Code bytes (7C812A5Bh):
7C812A1Bh:  8B 45 0C 56 8B 75 14 83 E0 01 85 F6 89 45 B4 C7
7C812A2Bh:  45 BC 09 2A 81 7C 0F 84 99 00 00 00 8B 4D 10 83
7C812A3Bh:  F9 0F 0F 87 65 1D 03 00 85 C9 89 4D C0 74 07 57
7C812A4Bh:  8D 7D C4 F3 A5 5F 8D 45 B0 50 FF 15 08 15 80 7C
7C812A5Bh:  5E C9 C2 10 00 85 FF 0F 8E 36 93 FF FF 8B 55 FC
7C812A6Bh:  89 55 0C 0F B7 16 8B 7D F8 8A 14 3A 88 11 8B 78
7C812A7Bh:  0C 0F B6 D2 66 8B 14 57 66 3B 16 0F 85 DB 8A 03
7C812A8Bh:  00 8B 50 08 66 8B 5A 04 38 19 0F 84 D9 8A 03 00
Stack (03C2F564h):
03C2F544h:  00788298 00000000 7E4188CA 00000000
03C2F554h:  0012F2DC 77404899 01C5FEA0 00000000
03C2F564h:  00F22700 0EEDFADE 00000001 00000000
03C2F574h:  7C812A5B 00000007 00F22700 00F60470
03C2F584h:  00F22700 00F22700 010744A8 03C2F63C
03C2F594h:  03C2F5EC 00000000 03D5C000 00014000
03C2F5A4h:  03D5C000 0015DC4C 00F21E0E D5C00001
03C2F5B4h:  01400003 03C2F63C 00F22700 0EEDFADE
03C2F5C4h:  00000001 00000007 03C2F5D0 00F22700
03C2F5D4h:  00F60470 00F22700 00F22700 010744A8
03C2F5E4h:  03C2F63C 03C2F5EC 00000002 00F227A0
03C2F5F4h:  03D48084 0000000B 00F22700 03D48084
03C2F604h:  00F2330D 03C2F601 00F236CD 00F3B8E2
03C2F614h:  01020088 01020088 00F23353 00F4462A
03C2F624h:  000A0001 00F44D92 02966F78 03C2F688
03C2F634h:  00F23353 00F45687 00EB7B50 00ED9164
03C2F644h:  01020088 EEF3B025 01A288D8 00000000
03C2F654h:  02966F08 03C2F8A0 00EEBEB8 FFFFFFFF
03C2F664h:  00ED8DC4 03C2F688 EEF3B019 00000000
03C2F674h:  00000000 00EB7D10 00000000 039477F4
Registers:
EAX: 03C2F568, EBX: 00F22700, ECX: 00000000, EDX: 00F22700
ESI: 03C2F5EC, EDI: 010744A8, EBP: 03C2F5B8, ESP: 03C2F564
Crash location: "kernel32", loaded at 7C800000h - 7C8F5000h
Symbol: "RaiseException" (+00000052h)
Loaded modules:
kernel32                        loaded at 7C800000h - 7C8F5000h
USER32                          loaded at 7E410000h - 7E4A1000h
SHELL32                          loaded at 7C9C0000h - 7D1D6000h
IMM32                            loaded at 76390000h - 763AD000h
MSCTF                            loaded at 74720000h - 7476B000h
msctfime                        loaded at 755C0000h - 755EE000h
foo_abx                          loaded at 00A70000h - 00AA3000h
foo_ac3                          loaded at 00AB0000h - 00ADC000h
foo_albumlist                    loaded at 00B00000h - 00B47000h
foo_benchmark                    loaded at 00B70000h - 00B98000h
foo_cdda                        loaded at 00BC0000h - 00BF5000h
foo_converter                    loaded at 00C20000h - 00C89000h
foo_dsp_std                      loaded at 00CB0000h - 00CF1000h
foo_freedb2                      loaded at 00D20000h - 00D60000h
foo_input_std                    loaded at 00D80000h - 00E93000h
foo_input_tak                    loaded at 00EC0000h - 00F06000h
tak_deco_lib                    loaded at 00F20000h - 00F51000h
foo_masstag                      loaded at 01080000h - 010CF000h
foo_msnalt                      loaded at 010F0000h - 01109000h
foo_rgscan                      loaded at 01130000h - 01178000h
foo_uie_albumart                loaded at 011A0000h - 011D7000h
foo_uie_albumlist                loaded at 01210000h - 0124D000h
foo_ui_columns                  loaded at 01270000h - 01307000h
foo_ui_std                      loaded at 01330000h - 01387000h
foo_unpack                      loaded at 013B0000h - 013DE000h
DBGHELP                          loaded at 59A60000h - 59B01000h
netapi32                        loaded at 5B860000h - 5B8B5000h
Address: 00F22700h, location: "tak_deco_lib", loaded at 00F20000h - 00F51000h
Address: 7C812A5Bh, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Address: 00F21E0Eh, location: "tak_deco_lib", loaded at 00F20000h - 00F51000h
Address: 00F227A0h, location: "tak_deco_lib", loaded at 00F20000h - 00F51000h
Address: 00F2330Dh, location: "tak_deco_lib", loaded at 00F20000h - 00F51000h
Address: 00F236CDh, location: "tak_deco_lib", loaded at 00F20000h - 00F51000h
Address: 00F3B8E2h, location: "tak_deco_lib", loaded at 00F20000h - 00F51000h
Address: 00F23353h, location: "tak_deco_lib", loaded at 00F20000h - 00F51000h
Address: 00F4462Ah, location: "tak_deco_lib", loaded at 00F20000h - 00F51000h
Address: 00F44D92h, location: "tak_deco_lib", loaded at 00F20000h - 00F51000h
Address: 00F45687h, location: "tak_deco_lib", loaded at 00F20000h - 00F51000h
Address: 00ED9164h, location: "foo_input_tak", loaded at 00EC0000h - 00F06000h
Address: 00EEBEB8h, location: "foo_input_tak", loaded at 00EC0000h - 00F06000h
Address: 00ED8DC4h, location: "foo_input_tak", loaded at 00EC0000h - 00F06000h
Address: 7C90EE18h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "strchr" (+00000117h)
Address: 7C910732h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+0000015Eh)
Address: 00EF0948h, location: "foo_input_tak", loaded at 00EC0000h - 00F06000h
Address: 7C910738h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+00000164h)
Address: 7C911B09h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlLogStackBackTrace" (+00000025h)
Address: 7C9119E6h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlDeleteCriticalSection" (+0000015Ch)
Address: 7C911A24h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlDeleteCriticalSection" (+0000019Ah)
Address: 7C97C080h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 7C911B10h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlLogStackBackTrace" (+0000002Ch)
Address: 7C911AD6h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlInitializeCriticalSectionAndSpinCount" (+000000ACh)
Address: 7C97C0A0h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 7C911B3Ch, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlInitializeCriticalSection" (+0000000Fh)
Address: 00EEDB40h, location: "foo_input_tak", loaded at 00EC0000h - 00F06000h
Address: 00ED95EFh, location: "foo_input_tak", loaded at 00EC0000h - 00F06000h
Address: 00EEDC88h, location: "foo_input_tak", loaded at 00EC0000h - 00F06000h
Address: 00ED92DFh, location: "foo_input_tak", loaded at 00EC0000h - 00F06000h
Address: 00EEDCC0h, location: "foo_input_tak", loaded at 00EC0000h - 00F06000h
Address: 00ED827Fh, location: "foo_input_tak", loaded at 00EC0000h - 00F06000h
Address: 00EFD584h, location: "foo_input_tak", loaded at 00EC0000h - 00F06000h
Address: 00DD0421h, location: "foo_input_std", loaded at 00D80000h - 00E93000h
Address: 00DCF338h, location: "foo_input_std", loaded at 00D80000h - 00E93000h
Address: 00DCF3B6h, location: "foo_input_std", loaded at 00D80000h - 00E93000h
Address: 00DCF3D3h, location: "foo_input_std", loaded at 00D80000h - 00E93000h
Address: 00E80B80h, location: "foo_input_std", loaded at 00D80000h - 00E93000h
Address: 00E599D4h, location: "foo_input_std", loaded at 00D80000h - 00E93000h
Address: 00E446D8h, location: "foo_input_std", loaded at 00D80000h - 00E93000h
Address: 00DCF7FBh, location: "foo_input_std", loaded at 00D80000h - 00E93000h
Address: 7C917E77h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlReAllocateHeap" (+0000047Ah)
Address: 00E599DCh, location: "foo_input_std", loaded at 00D80000h - 00E93000h
Address: 00E44728h, location: "foo_input_std", loaded at 00D80000h - 00E93000h
Address: 00DCF422h, location: "foo_input_std", loaded at 00D80000h - 00E93000h
Address: 00E44788h, location: "foo_input_std", loaded at 00D80000h - 00E93000h
Address: 00DE6EDDh, location: "foo_input_std", loaded at 00D80000h - 00E93000h
Address: 00E453EBh, location: "foo_input_std", loaded at 00D80000h - 00E93000h
Address: 00DE767Dh, location: "foo_input_std", loaded at 00D80000h - 00E93000h
Address: 7C91056Dh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlFreeHeap" (+00000130h)
Address: 7C9106F0h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+0000011Ch)
Address: 00491E58h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00447AE7h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C910570h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlFreeHeap" (+00000133h)
Address: 7C917BB8h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlReAllocateHeap" (+000001BBh)
Address: 7C917BB0h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlReAllocateHeap" (+000001B3h)
Address: 00E2E7D2h, location: "foo_input_std", loaded at 00D80000h - 00E93000h
Address: 00E32FC0h, location: "foo_input_std", loaded at 00D80000h - 00E93000h
Address: 004935B9h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004935D8h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00D8707Fh, location: "foo_input_std", loaded at 00D80000h - 00E93000h
Address: 00D8728Ch, location: "foo_input_std", loaded at 00D80000h - 00E93000h
Address: 00497110h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0043D4CAh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00407E27h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00417247h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C03D0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00E2EAF5h, location: "foo_input_std", loaded at 00D80000h - 00E93000h
Address: 00E2EB14h, location: "foo_input_std", loaded at 00D80000h - 00E93000h
Address: 00DCD892h, location: "foo_input_std", loaded at 00D80000h - 00E93000h
Address: 00DCC40Dh, location: "foo_input_std", loaded at 00D80000h - 00E93000h
Address: 00D870CEh, location: "foo_input_std", loaded at 00D80000h - 00E93000h
Address: 00E426E1h, location: "foo_input_std", loaded at 00D80000h - 00E93000h
Address: 00E476D3h, location: "foo_input_std", loaded at 00D80000h - 00E93000h
Address: 00DB60D6h, location: "foo_input_std", loaded at 00D80000h - 00E93000h
Address: 004DEB6Ch, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00E4B62Ch, location: "foo_input_std", loaded at 00D80000h - 00E93000h
Address: 00E5A2ACh, location: "foo_input_std", loaded at 00D80000h - 00E93000h
Address: 011352B5h, location: "foo_rgscan", loaded at 01130000h - 01178000h
Address: 01135128h, location: "foo_rgscan", loaded at 01130000h - 01178000h
Address: 01135628h, location: "foo_rgscan", loaded at 01130000h - 01178000h
Address: 00E478C3h, location: "foo_input_std", loaded at 00D80000h - 00E93000h
Address: 011648BCh, location: "foo_rgscan", loaded at 01130000h - 01178000h
Address: 00DB6DC8h, location: "foo_input_std", loaded at 00D80000h - 00E93000h
Address: 0114C46Bh, location: "foo_rgscan", loaded at 01130000h - 01178000h
Address: 0115F67Bh, location: "foo_rgscan", loaded at 01130000h - 01178000h
Address: 0114C06Eh, location: "foo_rgscan", loaded at 01130000h - 01178000h
Address: 0115F6B0h, location: "foo_rgscan", loaded at 01130000h - 01178000h
Address: 0113E6BFh, location: "foo_rgscan", loaded at 01130000h - 01178000h
Address: 011AF000h, location: "foo_uie_albumart", loaded at 011A0000h - 011D7000h
Address: 01152964h, location: "foo_rgscan", loaded at 01130000h - 01178000h
Address: 01150A80h, location: "foo_rgscan", loaded at 01130000h - 01178000h
Address: 0114F861h, location: "foo_rgscan", loaded at 01130000h - 01178000h
Address: 0115F883h, location: "foo_rgscan", loaded at 01130000h - 01178000h
Address: 0113EC8Fh, location: "foo_rgscan", loaded at 01130000h - 01178000h
Address: 0115FA50h, location: "foo_rgscan", loaded at 01130000h - 01178000h
Address: 0113E4C8h, location: "foo_rgscan", loaded at 01130000h - 01178000h
Address: 0109001Fh, location: "foo_masstag", loaded at 01080000h - 010CF000h
Address: 0115FA79h, location: "foo_rgscan", loaded at 01130000h - 01178000h
Address: 7C80B683h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Address: 7C839A00h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Address: 7C80B690h, location: "kernel32", loaded at 7C800000h - 7C8F5000h
Address: 0113E440h, location: "foo_rgscan", loaded at 01130000h - 01178000h
Address: 0108014Dh, location: "foo_masstag", loaded at 01080000h - 010CF000h
Address: 01080134h, location: "foo_masstag", loaded at 01080000h - 010CF000h
Version info:
foobar2000 v0.9.4.3 beta
UNICODE
Additional info:
Album list panel 0.2.1  (foo_uie_albumlist)
ABX Comparator 1.3.1  (foo_abx)
AC3 decoder 0.7  (foo_ac3)
foobar2000 core 0.9.4.3 beta  (Core)
Album List 3.2.0  (foo_albumlist)
Album Art Panel 0.2.5  (foo_uie_albumart)
MSN Now Playing (alt) 2.4  (foo_msnalt)
foo_input_tak
Reply #35
To anyone experiencing crashes: Can you reproduce these crashes? Do they occur with specific files?
foo_input_tak
Reply #36
I have thought about possible sources for the errors in my SDK. One Idea:
On creation, the decoder once checks the file size, stores it into an internal variable and expects it to be constant. Usually it should not matter, if the file is getting bigger afterwards, but an error could occur, if it is getting smaller, for instance because of an update of the APEv2 tag!
If this is related to the error, the crashes should occur if the file has become smaller because of an tag update and when the decoder is decoding (for playback or maybe a replaygain scan) the last couple of seconds of the file.
foo_input_tak
Reply #37
In my case, the crashes are not due to individual files but rather occur when i try to do something to a large number of files (e.g. Replaygain a large number of files or tag a large number of files).
For clarification:
Let's say i select 2000 tak files and try to replaygain them. Suppose Foobar crashes while scanning File X. next time when i select file x and try to replaygain a smaller group of files, there is no problem.
Same with tagging.
foo_input_tak
Reply #38
2000 TAK files? At that early stage? Courageous. Or at least not conservative.
foo_input_tak
Reply #39
I've actually converted all my lossless files to TAK. I saved anywhere from 5-20 mb per album (mostly flacs, some wavpacks) by doing so (it does add up when you have ~1000 albums). I also verified the files, so i know they're lossless. Should the tak spec change, i'll simply let my computer transcode over several nights.
foo_input_tak
Reply #40
foo_input_tak 0.3.1
TAK decoder is closed and reopened when updating tags which should prevent crashes there.
foo_input_tak
Reply #41
foo_input_tak 0.3.1
Thanks for the update.
Foobar crashed when replaygaining a group of 500 tak files
Illegal operation:
Call path:
ReplayGain thread
7C812A3Bh:  F9 0F 0F 87 4D 1D 03 00 85 C9 89 4D C0 74 07 57
7C812A7Bh:  0C 0F B6 D2 66 8B 14 57 66 3B 16 0F 85 A3 89 03
7C812A8Bh:  00 8B 50 08 66 8B 5A 04 38 19 0F 84 A1 89 03 00
Stack (04E7FC48h):
04E7FC28h:  01AE65D0 057B8C18 0181473C 0620F9C8
04E7FC38h:  37303A31 01840178 7E418BD9 7FFDE000
04E7FC48h:  014D2700 0EEDFADE 00000001 00000000
04E7FC58h:  7C812A5B 00000007 014D2700 01510470
04E7FC68h:  014D2700 014D2700 01625B48 04E7FD20
04E7FC78h:  04E7FCD0 00000000 01578000 00018000
04E7FC88h:  01578000 00181704 014D1E0E 57800001
04E7FC98h:  01800001 04E7FD20 014D2700 0EEDFADE
04E7FCA8h:  00000001 00000007 04E7FCB4 014D2700
04E7FCB8h:  01510470 014D2700 014D2700 01625B48
04E7FCC8h:  04E7FD20 04E7FCD0 00000002 014D27A0
04E7FCD8h:  01550088 0000000B 014D2700 01550088
04E7FCE8h:  014D330D 04E7FD01 014D36CD 014EB8E2
04E7FCF8h:  01510C34 01510C34 014D3353 014F462A
04E7FD08h:  BD990001 014F4D92 01627BB0 01627FA8
04E7FD18h:  014D3353 014F5687 01624288 014892B4
04E7FD28h:  01510C34 0CF35579 01627F98 01627FA0
04E7FD38h:  00000000 04E7FD60 0149C008 FFFFFFFF
04E7FD48h:  0148A034 01627FA8 0CF3551D 00000000
04E7FD58h:  01627F98 01627FA0 04E7FD94 0149CA30
Registers:
EAX: 04E7FC4C, EBX: 014D2700, ECX: 00000000, EDX: 014D2700
ESI: 04E7FCD0, EDI: 01625B48, EBP: 04E7FC9C, ESP: 04E7FC48
Crash location: "kernel32", loaded at 7C800000h - 7C8F4000h
Loaded modules:
LVPrcInj                        loaded at 003E0000h - 003F7000h
foo_input_monkey                loaded at 01270000h - 012BA000h
foo_input_shorten                loaded at 012E0000h - 0130D000h
foo_input_std                    loaded at 01330000h - 01443000h
foo_input_tak                    loaded at 01470000h - 014B7000h
tak_deco_lib                    loaded at 014D0000h - 01501000h
foo_lnk                          loaded at 01630000h - 01649000h
foo_lyricsdb                    loaded at 01670000h - 0169F000h
foo_masstag                      loaded at 016C0000h - 0170F000h
foo_packet_decoder_ac3          loaded at 01730000h - 01757000h
foo_playcount                    loaded at 01790000h - 017B8000h
foo_rgscan                      loaded at 017E0000h - 01828000h
foo_run                          loaded at 01850000h - 0187B000h
foo_scrobblecharts              loaded at 018A0000h - 018D3000h
foo_uie_albumart                loaded at 01900000h - 0193C000h
foo_uie_albumlist                loaded at 01970000h - 019AF000h
foo_uie_console                  loaded at 019D0000h - 019EC000h
foo_uie_tabs                    loaded at 01A10000h - 01A36000h
foo_uie_trackinfo_mod            loaded at 01A60000h - 01AB6000h
foo_ui_columns                  loaded at 01AE0000h - 01B77000h
foo_unpack                      loaded at 01BA0000h - 01BCE000h
foo_utils                        loaded at 01BF0000h - 01C28000h
foo_utils_matroska              loaded at 01C50000h - 01C6A000h
foo_verifier                    loaded at 01C90000h - 01CC0000h
DolbyHph                        loaded at 05D20000h - 05E1C000h
xpsp2res                        loaded at 20000000h - 202C5000h
Address: 014D2700h, location: "tak_deco_lib", loaded at 014D0000h - 01501000h
Address: 7C812A5Bh, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Address: 014D1E0Eh, location: "tak_deco_lib", loaded at 014D0000h - 01501000h
Address: 01800001h, location: "foo_rgscan", loaded at 017E0000h - 01828000h
Address: 014D27A0h, location: "tak_deco_lib", loaded at 014D0000h - 01501000h
Address: 014D330Dh, location: "tak_deco_lib", loaded at 014D0000h - 01501000h
Address: 014D36CDh, location: "tak_deco_lib", loaded at 014D0000h - 01501000h
Address: 014EB8E2h, location: "tak_deco_lib", loaded at 014D0000h - 01501000h
Address: 014D3353h, location: "tak_deco_lib", loaded at 014D0000h - 01501000h
Address: 014F462Ah, location: "tak_deco_lib", loaded at 014D0000h - 01501000h
Address: 014F4D92h, location: "tak_deco_lib", loaded at 014D0000h - 01501000h
Address: 014F5687h, location: "tak_deco_lib", loaded at 014D0000h - 01501000h
Address: 014892B4h, location: "foo_input_tak", loaded at 01470000h - 014B7000h
Address: 0149C008h, location: "foo_input_tak", loaded at 01470000h - 014B7000h
Address: 0148A034h, location: "foo_input_tak", loaded at 01470000h - 014B7000h
Address: 0149CA30h, location: "foo_input_tak", loaded at 01470000h - 014B7000h
Address: 01489FB9h, location: "foo_input_tak", loaded at 01470000h - 014B7000h
Address: 01488D9Ch, location: "foo_input_tak", loaded at 01470000h - 014B7000h
Address: 0149D94Dh, location: "foo_input_tak", loaded at 01470000h - 014B7000h
Address: 01489A56h, location: "foo_input_tak", loaded at 01470000h - 014B7000h
Address: 0149DAF8h, location: "foo_input_tak", loaded at 01470000h - 014B7000h
Address: 014896E0h, location: "foo_input_tak", loaded at 01470000h - 014B7000h
Address: 0149DB20h, location: "foo_input_tak", loaded at 01470000h - 014B7000h
Address: 017FC28Ch, location: "foo_rgscan", loaded at 017E0000h - 01828000h
Address: 0180F67Bh, location: "foo_rgscan", loaded at 017E0000h - 01828000h
Address: 017FC06Eh, location: "foo_rgscan", loaded at 017E0000h - 01828000h
Address: 0180F6B0h, location: "foo_rgscan", loaded at 017E0000h - 01828000h
Address: 017EE6BFh, location: "foo_rgscan", loaded at 017E0000h - 01828000h
Address: 01802964h, location: "foo_rgscan", loaded at 017E0000h - 01828000h
Address: 01800A80h, location: "foo_rgscan", loaded at 017E0000h - 01828000h
Address: 017FF861h, location: "foo_rgscan", loaded at 017E0000h - 01828000h
Address: 0180F883h, location: "foo_rgscan", loaded at 017E0000h - 01828000h
Address: 017EEC8Fh, location: "foo_rgscan", loaded at 017E0000h - 01828000h
Address: 0180FA50h, location: "foo_rgscan", loaded at 017E0000h - 01828000h
Address: 017EE4C8h, location: "foo_rgscan", loaded at 017E0000h - 01828000h
Address: 0180FA79h, location: "foo_rgscan", loaded at 017E0000h - 01828000h
Address: 017EE440h, location: "foo_rgscan", loaded at 017E0000h - 01828000h
Version info:
foobar2000 v0.9.4.2
UNICODE
Additional info:
Last.fm Chart Player 0.2.3  (foo_scrobblecharts)
TAK Decoder 0.3.1  (foo_input_tak)
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 014D1BCAh
Access violation, operation: read, address: 0157A79Ch
Call path:
ReplayGain thread=>input_entry::g_open_for_decoding=>tak_ssd::create_from_stream
Code bytes (014D1BCAh):
014D1B8Ah:  10 68 B5 1B 4D 01 80 3D 45 80 4F 01 00 74 0A 68
014D1B9Ah:  C0 85 4F 01 E8 D5 F7 FF FF 68 C0 85 4F 01 E8 D3
014D1BAAh:  F7 FF FF C3 E9 F5 1E 00 00 EB DB 5B 5D C3 53 3B
014D1BBAh:  05 0C 86 4F 01 75 09 8B 50 04 89 15 0C 86 4F 01
014D1BCAh:  8B 50 04 8B 48 08 81 F9 00 10 00 00 7F 38 3B C2
014D1BDAh:  75 17 85 C9 79 03 83 C1 03 C1 F9 02 A1 18 86 4F
014D1BEAh:  01 33 D2 89 54 88 F4 EB 24 85 C9 79 03 83 C1 03
014D1BFAh:  C1 F9 02 8B 1D 18 86 4F 01 89 54 8B F4 8B 00 89
Stack (04D7F840h):
04D7F820h:  057331A8 773F65E1 0181473C 00000007
04D7F830h:  38303A31 0033303A 7E41885A 000002E0
04D7F840h:  0157A798 014D20B6 04D7F87C 01624758
04D7F850h:  01627948 00000104 014D2258 04D7F988
04D7F860h:  014D227C 04D7F87C 01624758 01627948
04D7F870h:  014F4108 1000CA41 04D7F8F4 04D7F8C8
04D7F880h:  014D26D3 014F4108 014D32EF 02FD2C48
04D7F890h:  014D3682 02FD2C48 014AE50C 014AE501
04D7F8A0h:  014F4CB1 FFFFFFFF 7C91056D 00000010
04D7F8B0h:  00000000 01624758 01627948 02FD2C48
04D7F8C0h:  0000001B 03E76C10 04D7F8E0 014F5676
04D7F8D0h:  00000000 00000000 04D7F928 01624758
04D7F8E0h:  00000000 0148B570 014AE50C 01624758
04D7F8F0h:  04D7F928 00000000 00000000 02FD2C48
04D7F900h:  00000033 0148ADA7 014AE50C 01624758
04D7F910h:  04D7F928 0CC35151 04D7FA34 01627948
04D7F920h:  00000001 04D7F9F4 00000007 00000002
04D7F930h:  004F8E6D 04D7F96C 00000060 0000000C
04D7F940h:  01620000 04D7F73C 01CE8CC0 04D7F9B8
04D7F950h:  7C90EE18 7C9106F0 FFFFFFFF 7C9106EB
Registers:
EAX: 0157A798, EBX: 0157A798, ECX: 00000000, EDX: 0157A798
ESI: 00000104, EDI: 014F860C, EBP: 014F8610, ESP: 04D7F840
Crash location: "tak_deco_lib", loaded at 014D0000h - 01501000h
Loaded modules:
faultrep                        loaded at 69450000h - 69466000h
USERENV                          loaded at 769C0000h - 76A73000h
WINSTA                          loaded at 76360000h - 76370000h
WTSAPI32                        loaded at 76F50000h - 76F58000h
Address: 014D20B6h, location: "tak_deco_lib", loaded at 014D0000h - 01501000h
Address: 014D2258h, location: "tak_deco_lib", loaded at 014D0000h - 01501000h
Address: 014D227Ch, location: "tak_deco_lib", loaded at 014D0000h - 01501000h
Address: 014F4108h, location: "tak_deco_lib", loaded at 014D0000h - 01501000h
Address: 1000CA41h, location: "shared", loaded at 10000000h - 10029000h
Address: 014D26D3h, location: "tak_deco_lib", loaded at 014D0000h - 01501000h
Address: 014D32EFh, location: "tak_deco_lib", loaded at 014D0000h - 01501000h
Address: 014D3682h, location: "tak_deco_lib", loaded at 014D0000h - 01501000h
Address: 014AE50Ch, location: "foo_input_tak", loaded at 01470000h - 014B7000h
Address: 014F4CB1h, location: "tak_deco_lib", loaded at 014D0000h - 01501000h
Address: 014F5676h, location: "tak_deco_lib", loaded at 014D0000h - 01501000h
Symbol: "tak_SSD_Create_FromStream" (+00000022h)
Address: 0148B570h, location: "foo_input_tak", loaded at 01470000h - 014B7000h
Address: 0148ADA7h, location: "foo_input_tak", loaded at 01470000h - 014B7000h
Address: 0148B7B1h, location: "foo_input_tak", loaded at 01470000h - 014B7000h
Address: 0148BD03h, location: "foo_input_tak", loaded at 01470000h - 014B7000h
Address: 0149D5ABh, location: "foo_input_tak", loaded at 01470000h - 014B7000h
Address: 01487B1Fh, location: "foo_input_tak", loaded at 01470000h - 014B7000h
Address: 0149D833h, location: "foo_input_tak", loaded at 01470000h - 014B7000h
Address: 01488EBDh, location: "foo_input_tak", loaded at 01470000h - 014B7000h
Address: 014A1950h, location: "foo_input_tak", loaded at 01470000h - 014B7000h
Address: 0148BB90h, location: "foo_input_tak", loaded at 01470000h - 014B7000h
Address: 7C90DA54h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "NtFreeVirtualMemory" (+0000000Ch)
Address: 7C918331h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlReAllocateHeap" (+00000934h)
Address: 7C918632h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlReAllocateHeap" (+00000C35h)
Address: 7C911BFFh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlInitializeCriticalSection" (+000000D2h)
Address: 7C809B2Fh, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "VirtualFreeEx" (+0000002Dh)
Address: 0149DCA0h, location: "foo_input_tak", loaded at 01470000h - 014B7000h
Address: 0148991Fh, location: "foo_input_tak", loaded at 01470000h - 014B7000h
Address: 0149DE18h, location: "foo_input_tak", loaded at 01470000h - 014B7000h
Address: 0148942Fh, location: "foo_input_tak", loaded at 01470000h - 014B7000h
Address: 0149DDF0h, location: "foo_input_tak", loaded at 01470000h - 014B7000h
Address: 014883AFh, location: "foo_input_tak", loaded at 01470000h - 014B7000h
Address: 014AE584h, location: "foo_input_tak", loaded at 01470000h - 014B7000h
Address: 017F5F51h, location: "foo_rgscan", loaded at 017E0000h - 01828000h
Address: 0180E378h, location: "foo_rgscan", loaded at 017E0000h - 01828000h
Address: 017F4EBBh, location: "foo_rgscan", loaded at 017E0000h - 01828000h
Address: 017F4F37h, location: "foo_rgscan", loaded at 017E0000h - 01828000h
Address: 017F4F53h, location: "foo_rgscan", loaded at 017E0000h - 01828000h
Address: 01432AB0h, location: "foo_input_std", loaded at 01330000h - 01443000h
Address: 01814698h, location: "foo_rgscan", loaded at 017E0000h - 01828000h
Address: 0180F238h, location: "foo_rgscan", loaded at 017E0000h - 01828000h
Address: 017F5301h, location: "foo_rgscan", loaded at 017E0000h - 01828000h
Address: 0148BBAFh, location: "foo_input_tak", loaded at 01470000h - 014B7000h
Address: 018146A0h, location: "foo_rgscan", loaded at 017E0000h - 01828000h
Address: 0148D2F0h, location: "foo_input_tak", loaded at 01470000h - 014B7000h
Address: 0180F288h, location: "foo_rgscan", loaded at 017E0000h - 01828000h
Address: 017F4FA2h, location: "foo_rgscan", loaded at 017E0000h - 01828000h
Address: 0180F2B8h, location: "foo_rgscan", loaded at 017E0000h - 01828000h
Address: 017FC30Fh, location: "foo_rgscan", loaded at 017E0000h - 01828000h
Address: 01B3FF05h, location: "foo_ui_columns", loaded at 01AE0000h - 01B77000h
Address: 01B3FE00h, location: "foo_ui_columns", loaded at 01AE0000h - 01B77000h
Version info:
foobar2000 v0.9.4.2
UNICODE
Additional info:
both crash logs are from a single crash. Is it beacuse i have a dual core cpu or because two different things crashed?
foo_input_tak
Reply #42
Ok, I think I found a problem, but I'm not sure how to report it since it doesn't produce a crash.
It might be very specific to just one winamp DSP plugin: izotope Ozone.
It has a graphical interface. when using it (through foo_winamp_spam), it works fine with all formats I have tried. But when foobar plays a TAK file, there is a redrawing problem. The Ozone plugin fails to redraw properly (equalizer). The entire foobar goes crazy, with the 'on top' plugin leaving traces if moved around the screen. The equalizer moves slowly as well.
I have no idea how this might be happening. It is a CPU-demanding plugin.
foo_input_tak
Reply #43
That could be an important hint. What about the other people who experienced crashes: do you also have a dualcore CPU?
urlwolf: Does changing the bitrate update setting affect this (in Preferences > Display)?
foo_input_tak
Reply #44
Yes, although I haven't reported previously. Converting with Foobar went fine, trying to calculate replaygain-values crashed foobar instantly.
Currently I'm working with a dual-Xeon-workstation plus HT, that makes 4 CPUs and it gave me 5 crashlogs...
Hmm, I'm gonna disable the second CPU and HT and try again...
Be right back...
The logs:
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 00F122EEh
Access violation, operation: read, address: 02C28000h
Call path:
This is your 3-rd crash. When reporting the problem to a developer, please try to post info about the first crash instead.
Code bytes (00F122EEh):
00F122AEh:  84 C0 75 16 C7 05 BC 85 F3 00 08 00 00 00 C7 45
00F122BEh:  FC 08 00 00 00 E9 61 01 00 00 33 C9 55 68 22 24
00F122CEh:  F1 00 64 FF 31 64 89 21 80 3D 45 80 F3 00 00 74
00F122DEh:  0A 68 C0 85 F3 00 E8 87 F0 FF FF 8B F3 83 EE 04
00F122EEh:  8B 1E F6 C3 02 75 0F C7 05 BC 85 F3 00 09 00 00
00F122FEh:  00 E9 F5 00 00 00 FF 0D AC 85 F3 00 8B C3 25 FC
00F1230Eh:  FF FF 7F 83 E8 04 29 05 B0 85 F3 00 F6 C3 01 74
00F1231Eh:  45 8B C6 83 E8 0C 8B 50 08 83 FA 0C 7C 08 F7 C2
Stack (02BAF394h):
02BAF374h:  007614C0 00000000 7E3688DA 00000000
02BAF384h:  0012F2DC 773D4899 0019F268 00000000
02BAF394h:  02BAF8A4 00F12422 02BAF3B0 02BAF8A4
02BAF3A4h:  02BFCAD0 02BFCAD0 00F2B618 02BAF8C8
02BAF3B4h:  00F126F3 02BFCAD0 00F2B7EA 02BAF801
02BAF3C4h:  00F2B8D7 00FC051C 00FC051C 00F13353
02BAF3D4h:  00F34366 00000081 00F34D99 00000000
02BAF3E4h:  00F136A6 00F136B9 00FC051C 00000000
02BAF3F4h:  00F2B908 02CC06FC 02BAF4FC 02BAF428
02BAF404h:  02BAF434 00000000 00000000 00000000
02BAF414h:  7C9137BF 02BAF4FC 02BAF8A4 02BAF518
02BAF424h:  02BAF4D0 02BAF8A4 7C9137D8 02BAF8A4
02BAF434h:  02BAF4E4 7C91378B 02BAF4FC 02BAF8A4
02BAF444h:  02BAF518 02BAF4D0 00F136A1 00000001
02BAF454h:  02BAF4FC 02BAF8A4 7C947860 02BAF4FC
02BAF464h:  02BAF8A4 02BAF518 02BAF4D0 00F136A1
02BAF474h:  00010860 02BAF4FC 00FDC040 02BAF6AC
02BAF484h:  7C925A65 00000000 7C98C174 02BAF5F8
02BAF494h:  00000000 02BAF6FC 02BAF610 00000000
02BAF4A4h:  02BAF670 00000000 02BAF618 00800000
Registers:
EAX: 00000000, EBX: 02C28004, ECX: 00000000, EDX: 0001189F
ESI: 02C28000, EDI: 02BAF8A4, EBP: 02BAF3B0, ESP: 02BAF394
Crash location: "tak_deco_lib", loaded at 00F10000h - 00F41000h
Loaded modules:
ntdll                            loaded at 7C910000h - 7C9C7000h
kernel32                        loaded at 7C800000h - 7C906000h
COMCTL32                        loaded at 773A0000h - 774A3000h
msvcrt                          loaded at 77BE0000h - 77C38000h
ADVAPI32                        loaded at 77DA0000h - 77E4A000h
RPCRT4                          loaded at 77E50000h - 77EE1000h
GDI32                            loaded at 77EF0000h - 77F37000h
USER32                          loaded at 7E360000h - 7E3F0000h
SHLWAPI                          loaded at 77F40000h - 77FB6000h
SHELL32                          loaded at 7C9D0000h - 7D1EF000h
ole32                            loaded at 774B0000h - 775ED000h
shared                          loaded at 10000000h - 1002A000h
comdlg32                        loaded at 76350000h - 7639A000h
MSCTF                            loaded at 746A0000h - 746EB000h
foo_abx                          loaded at 00A20000h - 00A54000h
foo_albumlist                    loaded at 00A60000h - 00AA7000h
OLEAUT32                        loaded at 770F0000h - 7717C000h
foo_browser                      loaded at 00AD0000h - 00B09000h
foo_common                      loaded at 00B30000h - 00B6A000h
foo_converter                    loaded at 00B90000h - 00BF9000h
foo_dbsearch                    loaded at 00C20000h - 00C7C000h
foo_dsp_std                      loaded at 00CA0000h - 00CE1000h
foo_freedb2                      loaded at 00D10000h - 00D50000h
foo_input_std                    loaded at 00D70000h - 00E84000h
foo_input_tak                    loaded at 00EB0000h - 00EF7000h
tak_deco_lib                    loaded at 00F10000h - 00F41000h
foo_masstag                      loaded at 01070000h - 010C0000h
foo_rgscan                      loaded at 010E0000h - 01128000h
foo_uie_albumlist                loaded at 01150000h - 0118F000h
foo_uie_trackinfo                loaded at 011B0000h - 011DF000h
foo_ui_columns                  loaded at 01200000h - 01297000h
foo_ui_std                      loaded at 012C0000h - 01317000h
foo_unpack                      loaded at 01340000h - 0136E000h
foo_verifier                    loaded at 01390000h - 013C0000h
uxtheme                          loaded at 5B0F0000h - 5B128000h
gdiplus                          loaded at 4EBA0000h - 4ED43000h
CLBCATQ                          loaded at 76F90000h - 7700F000h
COMRes                          loaded at 77010000h - 770E3000h
VERSION                          loaded at 77BD0000h - 77BD8000h
shdocvw                          loaded at 7E1E0000h - 7E34F000h
CRYPT32                          loaded at 77A50000h - 77AE5000h
MSASN1                          loaded at 77AF0000h - 77B02000h
CRYPTUI                          loaded at 76880000h - 76905000h
WINTRUST                        loaded at 76BF0000h - 76C1E000h
IMAGEHLP                        loaded at 76C50000h - 76C78000h
NETAPI32                        loaded at 597D0000h - 59824000h
WININET                          loaded at 77180000h - 77227000h
WLDAP32                          loaded at 76F20000h - 76F4D000h
Secur32                          loaded at 77FC0000h - 77FD1000h
appHelp                          loaded at 77B10000h - 77B32000h
cscui                            loaded at 779F0000h - 77A46000h
CSCDLL                          loaded at 765A0000h - 765BD000h
browseui                        loaded at 75F20000h - 7601D000h
SETUPAPI                        loaded at 778F0000h - 779E4000h
MPR                              loaded at 71A80000h - 71A92000h
LINKINFO                        loaded at 76930000h - 76938000h
ntshrui                          loaded at 76940000h - 76966000h
ATL                              loaded at 76AD0000h - 76AE1000h
USERENV                          loaded at 76620000h - 766D5000h
drprov                          loaded at 75F00000h - 75F07000h
ntlanman                        loaded at 71B90000h - 71B9E000h
NETUI0                          loaded at 71C50000h - 71C67000h
NETUI1                          loaded at 71C10000h - 71C50000h
NETRAP                          loaded at 71C00000h - 71C07000h
SAMLIB                          loaded at 71B70000h - 71B83000h
davclnt                          loaded at 75F10000h - 75F19000h
DBGHELP                          loaded at 59DD0000h - 59E71000h
Address: 00F12422h, location: "tak_deco_lib", loaded at 00F10000h - 00F41000h
Address: 00F2B618h, location: "tak_deco_lib", loaded at 00F10000h - 00F41000h
Address: 00F126F3h, location: "tak_deco_lib", loaded at 00F10000h - 00F41000h
Address: 00F2B7EAh, location: "tak_deco_lib", loaded at 00F10000h - 00F41000h
Address: 00F2B8D7h, location: "tak_deco_lib", loaded at 00F10000h - 00F41000h
Address: 00F13353h, location: "tak_deco_lib", loaded at 00F10000h - 00F41000h
Address: 00F34366h, location: "tak_deco_lib", loaded at 00F10000h - 00F41000h
Address: 00F34D99h, location: "tak_deco_lib", loaded at 00F10000h - 00F41000h
Address: 00F136A6h, location: "tak_deco_lib", loaded at 00F10000h - 00F41000h
Address: 00F136B9h, location: "tak_deco_lib", loaded at 00F10000h - 00F41000h
Address: 00F2B908h, location: "tak_deco_lib", loaded at 00F10000h - 00F41000h
Address: 7C9137BFh, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlConvertUlongToLargeInteger" (+0000007Ah)
Address: 7C9137D8h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlConvertUlongToLargeInteger" (+00000093h)
Address: 7C91378Bh, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlConvertUlongToLargeInteger" (+00000046h)
Address: 00F136A1h, location: "tak_deco_lib", loaded at 00F10000h - 00F41000h
Address: 7C947860h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "LdrAddRefDll" (+00000247h)
Address: 7C925A65h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlDosApplyFileIsolationRedirection_Ustr" (+000002C2h)
Address: 7C98C174h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Address: 7C91EAFAh, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "KiUserExceptionDispatcher" (+0000000Eh)
Address: 00F1287Bh, location: "tak_deco_lib", loaded at 00F10000h - 00F41000h
Address: 010E5326h, location: "foo_rgscan", loaded at 010E0000h - 01128000h
Address: 0045E080h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004BC5C8h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00462B70h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C920732h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Address: 7C9205D4h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Address: 7C91EE18h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Address: 7C921538h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "wcsncpy" (+00000AA9h)
Address: 7C921596h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "wcsncpy" (+00000B07h)
Address: 7C9206EBh, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Address: 7E368734h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetDC" (+0000006Dh)
Address: 7C92056Dh, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Address: 7E3688A6h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetWindowLongW" (+00000000h)
Address: 773D4D01h, location: "COMCTL32", loaded at 773A0000h - 774A3000h
Address: 7E3688D1h, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetWindowLongW" (+0000002Bh)
Address: 7E3688DAh, location: "USER32", loaded at 7E360000h - 7E3F0000h
Symbol: "GetWindowLongW" (+00000034h)
Address: 773D4899h, location: "COMCTL32", loaded at 773A0000h - 774A3000h
Symbol: "Ordinal384" (+000189F9h)
Address: 00F2B9F7h, location: "tak_deco_lib", loaded at 00F10000h - 00F41000h
Address: 00F2B83Fh, location: "tak_deco_lib", loaded at 00F10000h - 00F41000h
Address: 00F13B53h, location: "tak_deco_lib", loaded at 00F10000h - 00F41000h
Address: 00F2CF01h, location: "tak_deco_lib", loaded at 00F10000h - 00F41000h
Address: 00F2DC34h, location: "tak_deco_lib", loaded at 00F10000h - 00F41000h
Address: 00F2DEC8h, location: "tak_deco_lib", loaded at 00F10000h - 00F41000h
Address: 00F34602h, location: "tak_deco_lib", loaded at 00F10000h - 00F41000h
Address: 00F34BB9h, location: "tak_deco_lib", loaded at 00F10000h - 00F41000h
Address: 00EEE50Ch, location: "foo_input_tak", loaded at 00EB0000h - 00EF7000h
Address: 00F34D5Ch, location: "tak_deco_lib", loaded at 00F10000h - 00F41000h
Address: 00F138F8h, location: "tak_deco_lib", loaded at 00F10000h - 00F41000h
Address: 011D2418h, location: "foo_uie_trackinfo", loaded at 011B0000h - 011DF000h
Address: 00F35676h, location: "tak_deco_lib", loaded at 00F10000h - 00F41000h
Address: 00ECB570h, location: "foo_input_tak", loaded at 00EB0000h - 00EF7000h
Address: 00ECADA7h, location: "foo_input_tak", loaded at 00EB0000h - 00EF7000h
Address: 7C9206F0h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Address: 00ECB7B1h, location: "foo_input_tak", loaded at 00EB0000h - 00EF7000h
Address: 00ECBD03h, location: "foo_input_tak", loaded at 00EB0000h - 00EF7000h
Address: 00EDD5ABh, location: "foo_input_tak", loaded at 00EB0000h - 00EF7000h
Address: 00EC7B1Fh, location: "foo_input_tak", loaded at 00EB0000h - 00EF7000h
Address: 00EDD833h, location: "foo_input_tak", loaded at 00EB0000h - 00EF7000h
Address: 00EC8EBDh, location: "foo_input_tak", loaded at 00EB0000h - 00EF7000h
Address: 7C9206ABh, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Address: 7C910000h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Address: 00EE1950h, location: "foo_input_tak", loaded at 00EB0000h - 00EF7000h
Address: 7C8000E8h, location: "kernel32", loaded at 7C800000h - 7C906000h
Address: 7C808F8Eh, location: "kernel32", loaded at 7C800000h - 7C906000h
Symbol: "DecodePointer" (+00000006h)
Address: 7C929A9Ch, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "towlower" (+00000330h)
Address: 7C800000h, location: "kernel32", loaded at 7C800000h - 7C906000h
Address: 00BAFAC8h, location: "foo_converter", loaded at 00B90000h - 00BF9000h
Address: 7C98C0D8h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Address: 7C929AEBh, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "towlower" (+0000037Fh)
Address: 7C92393Dh, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlDecodePointer" (+00000000h)
Address: 7C929AF0h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "towlower" (+00000384h)
Address: 7C80ADDEh, location: "kernel32", loaded at 7C800000h - 7C906000h
Symbol: "GetProcAddress" (+0000003Eh)
Address: 7C80ADF0h, location: "kernel32", loaded at 7C800000h - 7C906000h
Symbol: "GetProcAddress" (+00000050h)
Address: 013A228Ah, location: "foo_verifier", loaded at 01390000h - 013C0000h
Address: 0139D81Ah, location: "foo_verifier", loaded at 01390000h - 013C0000h
Address: 013B9590h, location: "foo_verifier", loaded at 01390000h - 013C0000h
Address: 0139ED78h, location: "foo_verifier", loaded at 01390000h - 013C0000h
Address: 0139ED70h, location: "foo_verifier", loaded at 01390000h - 013C0000h
Address: 7C91D4EAh, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "ZwAllocateVirtualMemory" (+0000000Ch)
Address: 7C921BFFh, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Address: 00EDDCA0h, location: "foo_input_tak", loaded at 00EB0000h - 00EF7000h
Address: 00EC991Fh, location: "foo_input_tak", loaded at 00EB0000h - 00EF7000h
Address: 00EDDE18h, location: "foo_input_tak", loaded at 00EB0000h - 00EF7000h
Address: 00EC942Fh, location: "foo_input_tak", loaded at 00EB0000h - 00EF7000h
Address: 00EDDDF0h, location: "foo_input_tak", loaded at 00EB0000h - 00EF7000h
Address: 00EC83AFh, location: "foo_input_tak", loaded at 00EB0000h - 00EF7000h
Address: 00EEE584h, location: "foo_input_tak", loaded at 00EB0000h - 00EF7000h
Address: 010F9241h, location: "foo_rgscan", loaded at 010E0000h - 01128000h
Address: 0110E608h, location: "foo_rgscan", loaded at 010E0000h - 01128000h
Address: 010F80BBh, location: "foo_rgscan", loaded at 010E0000h - 01128000h
Address: 010F8137h, location: "foo_rgscan", loaded at 010E0000h - 01128000h
Address: 010F8153h, location: "foo_rgscan", loaded at 010E0000h - 01128000h
Address: 00E71F90h, location: "foo_input_std", loaded at 00D70000h - 00E84000h
Address: 01114868h, location: "foo_rgscan", loaded at 010E0000h - 01128000h
Address: 0110F318h, location: "foo_rgscan", loaded at 010E0000h - 01128000h
Address: 010F8501h, location: "foo_rgscan", loaded at 010E0000h - 01128000h
Address: 00476C00h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 01114870h, location: "foo_rgscan", loaded at 010E0000h - 01128000h
Address: 0110F368h, location: "foo_rgscan", loaded at 010E0000h - 01128000h
Address: 010F81A2h, location: "foo_rgscan", loaded at 010E0000h - 01128000h
Address: 0110F398h, location: "foo_rgscan", loaded at 010E0000h - 01128000h
Address: 010F363Fh, location: "foo_rgscan", loaded at 010E0000h - 01128000h
Address: 0110F9CBh, location: "foo_rgscan", loaded at 010E0000h - 01128000h
Address: 010F339Eh, location: "foo_rgscan", loaded at 010E0000h - 01128000h
Address: 0110FA00h, location: "foo_rgscan", loaded at 010E0000h - 01128000h
Address: 010EE5AFh, location: "foo_rgscan", loaded at 010E0000h - 01128000h
Address: 00A83000h, location: "foo_albumlist", loaded at 00A60000h - 00AA7000h
Address: 01102964h, location: "foo_rgscan", loaded at 010E0000h - 01128000h
Address: 01100A80h, location: "foo_rgscan", loaded at 010E0000h - 01128000h
Address: 010FF871h, location: "foo_rgscan", loaded at 010E0000h - 01128000h
Address: 0110FAB3h, location: "foo_rgscan", loaded at 010E0000h - 01128000h
Address: 010EEB7Fh, location: "foo_rgscan", loaded at 010E0000h - 01128000h
Address: 0110FC80h, location: "foo_rgscan", loaded at 010E0000h - 01128000h
Address: 010EE3B8h, location: "foo_rgscan", loaded at 010E0000h - 01128000h
Address: 0108001Fh, location: "foo_masstag", loaded at 01070000h - 010C0000h
Address: 0109001Fh, location: "foo_masstag", loaded at 01070000h - 010C0000h
Address: 0110FCA9h, location: "foo_rgscan", loaded at 010E0000h - 01128000h
Address: 7C91E2DCh, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Address: 7C80B683h, location: "kernel32", loaded at 7C800000h - 7C906000h
Address: 7C839AA8h, location: "kernel32", loaded at 7C800000h - 7C906000h
Address: 7C80B690h, location: "kernel32", loaded at 7C800000h - 7C906000h
Address: 010EE330h, location: "foo_rgscan", loaded at 010E0000h - 01128000h
Version info:
foobar2000 v0.9.4.1
UNICODE
Additional info:
Music Browser 1.2.3b [Mar 23 2007 - 16:52:56]  (foo_browser)
Album list panel 0.2.1 beta 3  (foo_uie_albumlist)
Track info panel 0.5  (foo_uie_trackinfo)
Common services 0.1  (foo_common)
Columns UI 0.1.3 beta 1v6 TEST  (foo_ui_columns)
foobar2000 core v0.9.4.1  (Core)
Database search 1.3.1 beta 11  (foo_dbsearch)
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 00000800h
Access violation, operation: read, address: 00000800h
Call path:
ReplayGain thread=>input_decoder::run=>tak_ssd::read_audio
Stack (0288FD20h):
0288FD00h:  007614C0 00000000 7E3688DA 00000000
0288FD10h:  0012F2DC 773D4899 0019F268 00000000
0288FD20h:  00F33EFF 00FF00EC 00000005 00001588
0288FD30h:  0288FD60 00FD72CC 00F3455C 00002FB4
0288FD40h:  00FD72CC 00F347C3 00000008 00FD72CC
0288FD50h:  00001588 00000005 00FD72CC 00F34A7D
0288FD60h:  00001588 01068378 00FD72CC 00F352DD
0288FD70h:  00000006 01068378 02DB0048 02DB0048
0288FD80h:  0288FD8C 00F357B0 0288FDA8 0288FE34
0288FD90h:  00ECAFB4 00FD72CC 02DB0048 00001588
0288FDA0h:  0288FDA8 010673B0 00000000 00000025
0288FDB0h:  FFFFFFFF 01140178 00035D48 00000000
0288FDC0h:  01140000 0288FBBC 00000002 0288FF44
0288FDD0h:  7C91EE18 7C9206F0 FFFFFFFF 7C9206EB
0288FDE0h:  0000044C 022A7518 0000044C 022FE480
0288FDF0h:  010E29ED 0000044C 022B311C 00EC7E80
0288FE00h:  02DB0048 00001588 022833E4 00000000
0288FE10h:  00000012 00000000 00000000 00000000
0288FE20h:  001D2023 01114400 00000000 00000000
0288FE30h:  022833E4 0000AC44 00EC9E7E 0288FEB4
Registers:
EAX: 00FD73D0, EBX: 010137D4, ECX: 0288FD3C, EDX: 00FD73CC
ESI: 0288FD3C, EDI: 00FF2E0C, EBP: 0288FD80, ESP: 0288FD20
Unable to identify crash location
Loaded modules:
foobar2000                      loaded at 00400000h - 004F3000h
Address: 00F33EFFh, location: "tak_deco_lib", loaded at 00F10000h - 00F41000h
Address: 00F3455Ch, location: "tak_deco_lib", loaded at 00F10000h - 00F41000h
Address: 00F347C3h, location: "tak_deco_lib", loaded at 00F10000h - 00F41000h
Address: 00F34A7Dh, location: "tak_deco_lib", loaded at 00F10000h - 00F41000h
Address: 00F352DDh, location: "tak_deco_lib", loaded at 00F10000h - 00F41000h
Address: 00F357B0h, location: "tak_deco_lib", loaded at 00F10000h - 00F41000h
Symbol: "tak_SSD_ReadAudio" (+00000020h)
Address: 00ECAFB4h, location: "foo_input_tak", loaded at 00EB0000h - 00EF7000h
Address: 010E29EDh, location: "foo_rgscan", loaded at 010E0000h - 01128000h
Address: 00EC7E80h, location: "foo_input_tak", loaded at 00EB0000h - 00EF7000h
Address: 01114400h, location: "foo_rgscan", loaded at 010E0000h - 01128000h
Address: 00EC9E7Eh, location: "foo_input_tak", loaded at 00EB0000h - 00EF7000h
Address: 010F3823h, location: "foo_rgscan", loaded at 010E0000h - 01128000h
Address: 0110E839h, location: "foo_rgscan", loaded at 010E0000h - 01128000h
Address: 010EE652h, location: "foo_rgscan", loaded at 010E0000h - 01128000h
Address: 01113FCCh, location: "foo_rgscan", loaded at 010E0000h - 01128000h
Address: 01113FF8h, location: "foo_rgscan", loaded at 010E0000h - 01128000h
Address: 0111400Ch, location: "foo_rgscan", loaded at 010E0000h - 01128000h
Version info:
foobar2000 v0.9.4.1
UNICODE
Additional info:
Edit: obviously, my post was too long... If someone needs the other logs, please tell me...
foo_input_tak
Reply #45
OK, I'm back.
The crashes mentioned above hapened when I was trying to apply replaygain to 5 albums. Before RG, they were automatically tagged with album, title, artist, tracknumber, date and genre.
2 CPU, HT: no calculation of RG, instant crash
1 CPU, no HT: OK
RG values removed, then
2 CPU, no HT: OK
1 CPU, HT: OK
2 CPU, HT: OK
So, then I did a fresh start. 3 albums, converted like before, but this time I made a backup
1 CPU, no HT: OK
copy from backup, then
2 CPU, no HT: OK
1 CPU, HT: OK
2 CPU, HT: OK
For a crash, I guess you need: more than one CPU, more than about 50 tracks, they might contain tags but it's the first time trying to apply RG values. Strange...
I'll conduct further tests with a larger number of tracks on monday...
foo_input_tak
Reply #46
I made an album image with an embedded cue sheet using foobar2000 and it seems to work just fine.  I just started fooling around with it, but so far so good.
foo_input_tak
Reply #47
You are right! Thanks for this elaboration.
Unfortunately i had no time to examine my decoder library code for possible sources for the crashes before today.
Now i have to say sorry!
I found a bug in my dll which definitely can cause crashes if multithreading is beeing used (as the foobar plugin does) and those crashes are most likely to show up on multi core systems.
I will build a new test version of TAK's decoder dll and ask you to try it.
Again, sorry!
  Thomas
foo_input_tak
Reply #48
Hopefully this new decoding library will fix it: TAK Decoding library 1.0.3
foo_input_tak
Reply #49
As I said, I will happily test it on monday, as I have no multicore machine within reach until then.
