Plagued by "inaudible sound"
Reply #29 – 2007-03-26 13:52:10
Use one that runs natively at 96kHz sampling frequency, and is known to do so cleanly and without adding distortion to high frequency signals under whatever operating system you're using This will be the problem you had with the cutoff of 22kHz: since the majority of sound equipment is designed for the standard of 44100 Hz, it can only accurately produce sounds of below half that. I can honestly say that I occasionally have the same problem with my CRT monitor: leaving it on overnight causes endless irritation. I'm 17, and neither a friend of the same age nor my sister can hear that. Having just experimented in Foobar, I can hear up to about 20.5kHz, though this is in a slightly noisy environment with a poor sound card. As far as I know hearing is usually determined by using simple tones, and what is normally accepted (20Hz - 20kHz with possible high frequency drop-off) is very accurate and there is no point debating it. This is obviously a problem that varies from person to person, and I agree that it isn't exactly true to say that 22kHz is an absolute threshold, as we're all individuals. Another possibility is that, while we are talking on a very small scale, it could be that the (apparently) very high 40kHz sound emmited by the bulb etc could be causing something else very nearby to oscillate at a different rate, and this would be what you are hearing. I give an example. In our music department, we have an extremely high quality recording pc, with two speakers of fairly good quality. However, in the same room, we have two snare drums, which always resonate with the speakers, no matter what frequency. While this is obviously on a larger scale, it is a possiblity that this could be happening. Hope I've been of some use, and feel free to contradict me on anything I've said Pingue
