Topic: Dynamic Range (Read 8537 times) previous topic - next topic
Dynamic Range
Im encoding LPCM 5.1 tracks into FLAC.
Im using Graphedit and "Sonic Cinemaster Audio Decoder 4.2" directshow filter to decode the LPCM stream.
In the settings for Sonic Cinemaster I can control the number of channels the output should be and also the dynamic range. The setting is called "environment" and there are three options "Quiet", "Normal" and "Noisy".
I would like to have the same dynamic range as the original LPCM soundtrack. The question is if Quiet means "Normal full dynamic range" or if it artificially alters the stream to increase the dynamic range.
What option do you think I should use.. normal or quiet?
I have no other way to see the real LPCM soundtrack so I have a hard time deciding what the correct option is.
Dynamic Range
Encode the same material all three ways. Compare the result to understand the differences.
Dynamic Range
IIRC LPCM does not support DRC flags. So theoretically the outfile would be the same for all three options if the decoder itself does not do DRC.
Did you try the ffdshow audio decoder with graphedit? It can switch DRC on/off (AC3 and DTS), allows for downmixing, volume correction and much more.
Dynamic Range
I built a graph with a small DTS test file and made three wav files with the three different settings. All three files was bit identical. It should hopefully be the same with the LPCM ´transcodes I have done.
But for future reference if I were to transcode something that does support the DRC flags what should I pick?
Another DVD player, PowerDVD, has these explainations:
Quiet Environment: Experience the full dynamic range of Dolby Digital sound.
Normal Environment: Experience the compressed dynamic range of Dolby Digital sound.
Noisy Environment: Experience boosted sound. Strongly recommended for notebook users.
Dynamic Range
Quiet Environment in this case, it preserves the original dynamics.
Not to be confused with Late Nite listening (also Quiet ...) which reduces the loud parts.
Dynamic Range
yes, those settings are only for dolby digital, i dont know if DTS supports similar system (i think not) and it would be kinda weird if LPCM did.
