Topic: Converting Lossless To Lossy... (Read 4322 times) previous topic - next topic
I made backups of my Cd's in lossless [APE] with one file for CD with cue-sheets. I wanna know, there is any software what can  read the cue-sheets and "re-create" the tracks separately and after compress them to another format [lossy in this case] keeping all the info [artist, name of track] of cue-sheet?
Sorry for my bad english.
foobar
I'm installed foobar but when I added the file foobar doesn't 'find" the cue-sheet what is in the same folder of the file. This cue-sheet was made by EAC.
Here it is:
REM GENRE "Heavy Metal"
REM DATE 1981
REM DISCID A40E6D0C
REM COMMENT "ExactAudioCopy v0.95b4"
PERFORMER "Iron Maiden"
TITLE "Killers"
FILE "Iron Maiden - Killers.wav" WAVE
  TRACK 01 AUDIO
    TITLE "Ides Of March"
    INDEX 01 00:00:00
  TRACK 02 AUDIO
    TITLE "Wratchild"
    INDEX 01 01:46:10
  TRACK 03 AUDIO
    TITLE "Murders In Rue Morgue"
    INDEX 01 04:41:25
  TRACK 04 AUDIO
    TITLE "Another Life"
    INDEX 01 09:00:40
  TRACK 05 AUDIO
    TITLE "Genghis Khan"
    INDEX 01 12:23:70
  TRACK 06 AUDIO
    TITLE "Innocent Exile"
    INDEX 01 15:33:17
  TRACK 07 AUDIO
    TITLE "Killers"
    INDEX 00 19:24:30
    INDEX 01 19:27:40
  TRACK 08 AUDIO
    TITLE "Prodigal Son"
    INDEX 00 24:29:26
    INDEX 01 24:29:32
  TRACK 09 AUDIO
    TITLE "Purgatory"
    INDEX 01 30:42:05
  TRACK 10 AUDIO
    TITLE "Twinlight Zone"
    INDEX 00 34:02:44
    INDEX 01 34:02:47
  TRACK 11 AUDIO
    TITLE "Drifter"
    INDEX 00 36:35:44
    INDEX 01 36:35:72
Someone can tell me what's wrong with it? I tried to replace *.wav from *.ape but don't work.
you should add the cue sheet to foobar, not the actual file. the cue sheet should be pointing to the audio file, which should be in the same folder.
Change this line in the cuesheet :
To instead :
FILE "Iron Maiden - Killers.ape" WAVE
Then download the Monkey's Audio decoding plugin for fb2k here :
http://www.foobar2000.org/components/foo_input_monkey.zip
Unpack the .zip archive and move the file "foo_input_monkey.dll" into "C:\Program Files\foobar2000\Components" and restart fb2k.
Thanks  again, I just missed the "add the cue-sheet and not the actual file"
