Topic: Cue error with ape file (Read 2128 times) previous topic - next topic
Hi, I'm a little new to using cue files but I have a bunch of ape files with cue files that go with them and I want to burn them to a cd.  Now I've tried using both EAC and Burrn to make a cd but there seems to be an error with the cue file I am using.  I get the error: INDEX position is behind end of FILE in line 36.  I'm not sure how I can fix the cue file in order to get this cd to burn properly.  Can anyone help me?  I'll post the cue text here:
REM GENRE Classical
REM DATE 2006
REM DISCID 5710C706
REM COMMENT "ExactAudioCopy v0.95b4"
CATALOG 0028947762393
PERFORMER "Herbert von Karajan"
TITLE "Herbert von Karajan - The Mono Recordings CD 2"
FILE "CD2Image.ape" WAVE
  TRACK 01 AUDIO
    TITLE "Symphony No. 1 in Cm op.68 - Un poco sostenuto, Allegro"
    PERFORMER "Johannes Brahms"
    ISRC DEF054302021
    INDEX 00 00:00:00
    INDEX 01 00:00:33
  TRACK 02 AUDIO
    TITLE "Symphony No. 1 in Cm op.68 - Andante sostenuto"
    ISRC DEF054302022
    INDEX 00 14:25:08
    INDEX 01 14:29:58
  TRACK 03 AUDIO
    TITLE "Symphony No. 1 in Cm op.68 - Un poco allegretto e grazioso"
    ISRC DEF054302023
    INDEX 00 23:22:07
    INDEX 01 23:23:65
  TRACK 04 AUDIO
    TITLE "Symphony No. 1 in Cm op.68 - Adagio, Allegro non troppo ma con brio"
    ISRC DEF054302024
    INDEX 01 27:54:08
  TRACK 05 AUDIO
    TITLE "Don Juan op.20"
    PERFORMER "Richard Strauss"
    ISRC DEF054302030
    INDEX 00 45:26:33
    INDEX 01 45:31:33
  TRACK 06 AUDIO
    TITLE "Salome - Tanz der sieben Schleier"
    ISRC DEF054302040
    INDEX 00 62:49:33
    INDEX 01 62:55:33
Line 36 is the one that says: INDEX 00 45:26:33
I'm just not sure what this error means or how to go about fixing it.  Thanks.
Install FooBar2000 with the Monkey's Audio decoding support. Try playing the APE image in FB2K and see what error it gives you. I have not had any trouble with EAC's non-standard CUE sheets and playback in FB2K.
My suggestion: remove all the INDEX 01's and change the INDEX 00 to INDEX 01. Also, removing all the ISRCs won't affect the burn, in my experience. That usually fixes any problems I have with CUEs.
OP can't edit initial post when a solution is determined  :'-(
