Topic: foo_ui_panels (Read 1319233 times) previous topic - next topic
foo_ui_panels
Reply #125
Sorry if this has been asked made a quick search but couldn't find anything on the topic.
Will components such as Playlists Dropdown have the proper context menu in a future version?
foo_ui_panels
Reply #126
Ok I think I understand them now and all is going as planned. I look forward to being able to trigger events in track display and SCPL using PVARS, at the moment all triggers need to be in the per-second section.
Can I also make a suggest for the $button2 function, for the text inside, I need to use '$font(tahoma,8,,255-255-255)button text' for example. I like to define all my colours and fonts in variables, ideally I would have something like this: '$font($get(font),$get(fontsize),,$get(fontcolor))$get(buttontext)' but I can't run $get within single quotes. I am finding this to be a big restriction to my plans, is there any fix or way around this?
foo_ui_panels
Reply #127
Thanks for this amazing plugin, terrestrial!
I have just one problem: I'm using the latest version of panelsUI, and configured the Track Display. But the track display doesn't update every second. I've set the mode of the Track Display to 'Now Playing' and the playback times are shown (so no questionmarks anywhere), but not updated...
Is there some very basic checkbox I'm overlooking, or do I need to enter some command somewhere?
Thanks in advance!
foo_ui_panels
Reply #128
Re: Syntax highlighting
If you tab indent a commented line it is no longer highlighted green. It turns black.
foo_ui_panels
Reply #130
I have to apologize a little.  It seems the weird double icon issue was somehow related to WindowBlinds.  I updated from 5.01 to 5.1 tonight and the problem went away.  It seemed to affect programs that always show a tray icon and then also minimize to the tray, hiding the taskbar.  I noticed it with Peerguardian tonight, so I checked into it further.  Sorry for the trouble!
foo_ui_panels
Reply #131
Thanks in advance!
I'll field this. Put
// PerSecond
at the beginning of the Track Display code.
naaa na na naaaaaa na na NAAAAAAA na na naaaaaaaaa
foo_ui_panels
Reply #132
Sorry to ask but it is not possible for me to make background of SPC black.
Can anyone tell how?
foo_ui_panels
Reply #134
I already use a image for the tracks, it handy to make black lines if i can make the background black.
In the normal SPCL it was possible but now i can't find it anymore.
Thanks for your reply    Ulquiorra
foo_ui_panels
Reply #135
very nice plugin I see a new revolution coming for foobar.
Haha as for the rest stupid mistake of me
foo_ui_panels
Reply #136
Crashlog :
llegal operation:
Code: C0000005h, flags: 00000000h, address: 05276460h
Access violation, operation: write, address: 00000009h
Call path:
entry=>app_mainloop
Code bytes (05276460h):
05276420h:  FF D2 8B F0 85 F6 74 6B 6A 10 E8 9A 15 07 00 8B
05276430h:  5C 24 1C 83 C4 04 85 C0 74 21 8B 8B 08 01 00 00
05276440h:  C7 00 14 D7 30 05 C7 40 04 01 00 00 00 C7 40 08
05276450h:  02 00 00 00 89 48 0C 8B F8 EB 02 33 FF 8B 43 0C
05276460h:  C6 40 09 01 8D 44 24 38 50 6A 01 57 56 FF 15 B4
05276470h:  54 30 05 8B 5B 0C 57 C6 43 09 00 E8 0E 16 07 00
05276480h:  8B 0E 8B 51 08 83 C4 04 56 FF D2 8B 5C 24 20 8B
05276490h:  7C 24 10 C6 84 24 F0 0B 00 00 08 8B 07 8B 10 8B
Stack (0012EDF4h):
0012EDD4h:  00FEDCDC 7C9D93C0 77F443DD 7C9D93C0
0012EDE4h:  00000004 00000000 00FED1E8 00000000
0012EDF4h:  02ACAC57 003F00E7 000401DE 05344270
0012EE04h:  004DF100 000401DE 05344270 056A8250
0012EE14h:  003F00E7 0530C814 0A4EA990 00000001
0012EE24h:  00000001 00000002 757E0474 00000005
0012EE34h:  00000000 0012EE64 757AB762 00000017
0012EE44h:  000001BA 00000089 0012EEB4 00000000
0012EE54h:  757E0260 00000000 757E0470 00000001
0012EE64h:  0012EE90 757AB91E 00000000 757E037C
0012EE74h:  00000005 0012EE94 757A3E48 757E0384
0012EE84h:  FFFFFFFF AF010927 757E0260 757E0320
0012EE94h:  0012EEC0 757AC7A4 AF010927 757E0384
0012EEA4h:  757E037C AF010927 00000000 00000200
0012EEB4h:  00000000 00000010 00000000 0012EED8
0012EEC4h:  757A428A 00000001 AF010927 00000000
0012EED4h:  000020A0 0012EF24 62E148F2 AF010927
0012EEE4h:  07957080 00000001 003C9718 FFFFFFFF
0012EEF4h:  000030A0 00000000 0012EF20 0012EF4E
0012EF04h:  00000000 757E0260 00000000 0012EFB0
Registers:
EAX: 00000000, EBX: 05344270, ECX: 000401DE, EDX: 8C3B001B
ESI: 05CE8C10, EDI: 0A4EB750, EBP: 0012F9E8, ESP: 0012EDF4
Crash location: "foo_ui_panels", loaded at 05270000h - 0532D000h
Loaded modules:
foobar2000                      loaded at 00400000h - 004F3000h
ntdll                            loaded at 7C910000h - 7C9C7000h
kernel32                        loaded at 7C800000h - 7C906000h
COMCTL32                        loaded at 773A0000h - 774A3000h
msvcrt                          loaded at 77BE0000h - 77C38000h
ADVAPI32                        loaded at 77DA0000h - 77E4A000h
RPCRT4                          loaded at 77E50000h - 77EE1000h
GDI32                            loaded at 77EF0000h - 77F37000h
USER32                          loaded at 77D10000h - 77DA0000h
SHLWAPI                          loaded at 77F40000h - 77FB6000h
SHELL32                          loaded at 7C9D0000h - 7D1EF000h
ole32                            loaded at 774B0000h - 775ED000h
shared                          loaded at 10000000h - 10029000h
comdlg32                        loaded at 76350000h - 7639A000h
IMM32                            loaded at 76330000h - 7634D000h
LPK                              loaded at 62E10000h - 62E19000h
USP10                            loaded at 75790000h - 757FB000h
uxtheme                          loaded at 5AD70000h - 5ADA2000h
RocketDock                      loaded at 003D0000h - 003DE000h
msctfime                        loaded at 75250000h - 7527E000h
foo_runcmd                      loaded at 00A30000h - 00A5F000h
OLEAUT32                        loaded at 770F0000h - 7717C000h
foo_abx                          loaded at 00A80000h - 00AB3000h
foo_ac3                          loaded at 00AE0000h - 00B0C000h
foo_albumlist                    loaded at 00B30000h - 00B77000h
foo_albumlist_autoupdate        loaded at 00BA0000h - 00BB7000h
foo_audioscrobbler              loaded at 00BE0000h - 00C17000h
WS2_32                          loaded at 71A10000h - 71A27000h
WS2HELP                          loaded at 71A00000h - 71A08000h
foo_autoplaylist                loaded at 00C40000h - 00C70000h
foo_browser                      loaded at 00C90000h - 00CCB000h
foo_burninate                    loaded at 00CF0000h - 00D27000h
VERSION                          loaded at 77BD0000h - 77BD8000h
foo_cdda                        loaded at 00D50000h - 00D86000h
foo_comserver2                  loaded at 00DB0000h - 00E06000h
foo_converter                    loaded at 00E30000h - 00E99000h
foo_custominfo                  loaded at 00EC0000h - 00F45000h
foo_cwb_hooks                    loaded at 00F70000h - 00F9E000h
foo_dbsearch                    loaded at 00FC0000h - 01035000h
foo_dbsearch_api_demo            loaded at 01060000h - 01082000h
foo_default_videoplayer          loaded at 010B0000h - 010BA000h
MSVCR80                          loaded at 78130000h - 781CB000h
foo_discogs                      loaded at 010E0000h - 01152000h
gdiplus                          loaded at 4EBA0000h - 4ED43000h
WINMM                            loaded at 76AF0000h - 76B1E000h
foo_dockable_panels              loaded at 01200000h - 01232000h
foo_dsp_delta                    loaded at 01260000h - 0127E000h
foo_dsp_dolbyhp                  loaded at 012A0000h - 012C1000h
foo_dsp_std                      loaded at 012E0000h - 01321000h
foo_dsp_winamp                  loaded at 01350000h - 01373000h
foo_explorer                    loaded at 013A0000h - 013B8000h
foo_freedb2                      loaded at 013E0000h - 01420000h
foo_guidlookup                  loaded at 01440000h - 01458000h
foo_infobox                      loaded at 01480000h - 014C0000h
foo_info_samurize                loaded at 014E0000h - 01502000h
foo_input_avs                    loaded at 01640000h - 0165F000h
foo_input_awma                  loaded at 01680000h - 01699000h
WMVCore                          loaded at 086D0000h - 08917000h
WMASF                            loaded at 070D0000h - 0710A000h
foo_input_mslive                loaded at 016B0000h - 016D8000h
foo_input_std                    loaded at 016F0000h - 01804000h
foo_lyricsdb                    loaded at 01830000h - 0184E000h
MSVCP80                          loaded at 7C420000h - 7C4A7000h
WININET                          loaded at 77180000h - 77227000h
CRYPT32                          loaded at 77A50000h - 77AE5000h
MSASN1                          loaded at 77AF0000h - 77B02000h
foo_managedWrapper              loaded at 01860000h - 01902000h
mscoree                          loaded at 79000000h - 79045000h
msvcm80                          loaded at 7C4C0000h - 7C53D000h
mscorwks                        loaded at 79E70000h - 7A3D1000h
mscorlib.ni                      loaded at 790C0000h - 79BA6000h
mscorjit                        loaded at 79060000h - 790B3000h
rsaenh                          loaded at 0FFD0000h - 0FFF8000h
System.ni                        loaded at 7A440000h - 7ABFE000h
System.Drawing.ni                loaded at 7ADE0000h - 7AF74000h
System.Windows.Forms.ni          loaded at 7AFD0000h - 7BC56000h
xpsp2res                        loaded at 20000000h - 202D9000h
dotnet_title                    loaded at 11000000h - 11014000h
foo_masstag                      loaded at 043C0000h - 04410000h
foo_oddcastv3                    loaded at 04420000h - 044EF000h
BASS                            loaded at 04500000h - 04540000h
MSACM32                          loaded at 77BB0000h - 77BC5000h
WINSPOOL                        loaded at 72F70000h - 72F96000h
vorbis                          loaded at 04540000h - 0464F000h
ogg                              loaded at 04650000h - 04658000h
libOggFLAC                      loaded at 04660000h - 04671000h
libFLAC                          loaded at 04680000h - 046A2000h
pthreadVSE                      loaded at 046B0000h - 046BD000h
WSOCK32                          loaded at 71A30000h - 71A3A000h
foo_playcount                    loaded at 046F0000h - 04718000h
foo_playlist_tree                loaded at 04740000h - 047AB000h
foo_rgscan                      loaded at 047D0000h - 04818000h
foo_run                          loaded at 04840000h - 0486B000h
foo_scheduler                    loaded at 04890000h - 048FF000h
POWRPROF                        loaded at 74A50000h - 74A58000h
foo_seek_remote                  loaded at 04920000h - 0493B000h
foo_sendtodevice                loaded at 04950000h - 0497F000h
foo_tutorial1_step1              loaded at 049A0000h - 049BB000h
foo_uie_albumart                loaded at 049E0000h - 04A12000h
foo_uie_albumlist                loaded at 04A40000h - 04A7F000h
foo_uie_lyrics                  loaded at 04AA0000h - 04AFE000h
foo_uie_playlists_dropdown      loaded at 04B20000h - 04B5A000h
foo_uie_queuemanager            loaded at 04B80000h - 04BB9000h
foo_uie_quicksearch              loaded at 04C50000h - 04C96000h
foo_uie_single_column_playlist  loaded at 04CA0000h - 04CEA000h
foo_uie_tabs                    loaded at 04D00000h - 04D26000h
foo_uie_trackinfo                loaded at 04D50000h - 04D7E000h
foo_uie_trackinfo_mod            loaded at 04DA0000h - 04DF5000h
foo_uie_vis_projectm            loaded at 04E10000h - 04E84000h
OPENGL32                        loaded at 5F0D0000h - 5F19C000h
GLU32                            loaded at 68FC0000h - 68FE0000h
DDRAW                            loaded at 736D0000h - 73719000h
DCIMAN32                        loaded at 73B30000h - 73B36000h
foo_ui_columns                  loaded at 051B0000h - 05247000h
foo_ui_panels                    loaded at 05270000h - 0532D000h
foo_ui_std                      loaded at 05350000h - 053A7000h
foo_unpack                      loaded at 053D0000h - 053FE000h
foo_utils                        loaded at 05420000h - 05459000h
foo_vis_samurize2                loaded at 05480000h - 054B0000h
foo_winamp_spam                  loaded at 054D0000h - 054EF000h
foo_tutorial1_step2              loaded at 05500000h - 05521000h
foo_tutorial1_step3              loaded at 05550000h - 05574000h
foo_tutorial1_step4              loaded at 055A0000h - 055C4000h
NEWDOT~1                        loaded at 05EF0000h - 05F2C000h
urlmon                          loaded at 7DF20000h - 7DFC0000h
SETUPAPI                        loaded at 778F0000h - 779E4000h
MPR                              loaded at 71A80000h - 71A92000h
WINTRUST                        loaded at 76BF0000h - 76C1E000h
IMAGEHLP                        loaded at 76C50000h - 76C78000h
nvoglnt                          loaded at 69500000h - 69A76000h
dsp_iZVinyl                      loaded at 08010000h - 08407000h
dsound                          loaded at 73E70000h - 73ECC000h
wdmaud                          loaded at 72C90000h - 72C99000h
msacm32                          loaded at 72C80000h - 72C88000h
midimap                          loaded at 77BA0000h - 77BA7000h
CLBCATQ                          loaded at 76F90000h - 7700F000h
COMRes                          loaded at 77010000h - 770E3000h
mscorlib.resources              loaded at 08680000h - 086D0000h
diasymreader                    loaded at 5E380000h - 5E409000h
SXS                              loaded at 76970000h - 76A21000h
msi                              loaded at 745E0000h - 748A6000h
DolbyHph                        loaded at 093B0000h - 094AC000h
KsUser                          loaded at 73E40000h - 73E44000h
Msimg32                          loaded at 76320000h - 76325000h
DBGHELP                          loaded at 59DD0000h - 59E71000h
Stack dump analysis:
Address: 004DF100h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0530C814h, location: "foo_ui_panels", loaded at 05270000h - 0532D000h
Address: 757E0474h, location: "USP10", loaded at 75790000h - 757FB000h
Address: 757AB762h, location: "USP10", loaded at 75790000h - 757FB000h
Symbol: "ScriptApplyDigitSubstitution" (+00006AE0h)
Address: 757E0260h, location: "USP10", loaded at 75790000h - 757FB000h
Address: 757E0470h, location: "USP10", loaded at 75790000h - 757FB000h
Address: 757AB91Eh, location: "USP10", loaded at 75790000h - 757FB000h
Symbol: "ScriptApplyDigitSubstitution" (+00006C9Ch)
Address: 757E037Ch, location: "USP10", loaded at 75790000h - 757FB000h
Address: 757A3E48h, location: "USP10", loaded at 75790000h - 757FB000h
Symbol: "ScriptCacheGetHeight" (+00000023h)
Address: 757E0384h, location: "USP10", loaded at 75790000h - 757FB000h
Address: 757AC7A4h, location: "USP10", loaded at 75790000h - 757FB000h
Symbol: "ScriptApplyDigitSubstitution" (+00007B22h)
Address: 757A428Ah, location: "USP10", loaded at 75790000h - 757FB000h
Symbol: "ScriptStringAnalyse" (+00000237h)
Address: 62E148F2h, location: "LPK", loaded at 62E10000h - 62E19000h
Symbol: "LpkTabbedTextOut" (+00000A9Fh)
Address: 62E1464Bh, location: "LPK", loaded at 62E10000h - 62E19000h
Symbol: "LpkTabbedTextOut" (+000007F8h)
Address: 757AE501h, location: "USP10", loaded at 75790000h - 757FB000h
Address: 757D5030h, location: "USP10", loaded at 75790000h - 757FB000h
Address: 757A42F8h, location: "USP10", loaded at 75790000h - 757FB000h
Symbol: "ScriptStringFree" (+00000035h)
Address: 62E14680h, location: "LPK", loaded at 62E10000h - 62E19000h
Symbol: "LpkTabbedTextOut" (+0000082Dh)
Address: 62E14741h, location: "LPK", loaded at 62E10000h - 62E19000h
Symbol: "LpkTabbedTextOut" (+000008EEh)
Address: 5AD7E43Bh, location: "uxtheme", loaded at 5AD70000h - 5ADA2000h
Address: 62E11269h, location: "LPK", loaded at 62E10000h - 62E19000h
Symbol: "LpkDrawTextEx" (+00000034h)
Address: 77D4E363h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DeregisterShellHookWindow" (+0000E0CBh)
Address: 77D1F076h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DrawTextExW" (+00000426h)
Address: 77D1DDDCh, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "TrackMouseEvent" (+000000F6h)
Address: 77D1DDF7h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "TrackMouseEvent" (+00000111h)
Address: 5AD7E3DFh, location: "uxtheme", loaded at 5AD70000h - 5ADA2000h
Address: 77F33020h, location: "GDI32", loaded at 77EF0000h - 77F37000h
Address: 77EF7E5Ah, location: "GDI32", loaded at 77EF0000h - 77F37000h
Symbol: "GetTextMetricsW" (+00000068h)
Address: 77EF7E6Ah, location: "GDI32", loaded at 77EF0000h - 77F37000h
Symbol: "GetTextMetricsW" (+00000078h)
Address: 77EF7E81h, location: "GDI32", loaded at 77EF0000h - 77F37000h
Symbol: "GetTextMetricsW" (+0000008Fh)
Address: 77EF8469h, location: "GDI32", loaded at 77EF0000h - 77F37000h
Symbol: "GetTextCharsetInfo" (+00000000h)
Address: 77D1EEE5h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DrawTextExW" (+00000295h)
Address: 77EF60BBh, location: "GDI32", loaded at 77EF0000h - 77F37000h
Symbol: "CreateCompatibleDC" (+000000BBh)
Address: 77EF7AB2h, location: "GDI32", loaded at 77EF0000h - 77F37000h
Symbol: "ExtSelectClipRgn" (+00000205h)
Address: 77EF7AC1h, location: "GDI32", loaded at 77EF0000h - 77F37000h
Symbol: "ExtSelectClipRgn" (+00000214h)
Address: 77D1F00Bh, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DrawTextExW" (+000003BBh)
Address: 77D1EC50h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DrawTextExW" (+00000000h)
Address: 5AD8F35Ah, location: "uxtheme", loaded at 5AD70000h - 5ADA2000h
Symbol: "Ordinal46" (+000016F0h)
Address: 5AD793BFh, location: "uxtheme", loaded at 5AD70000h - 5ADA2000h
Address: 77D1EC6Eh, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DrawTextExW" (+0000001Eh)
Address: 00FFFFFFh, location: "foo_dbsearch", loaded at 00FC0000h - 01035000h
Address: 5AD8F1AFh, location: "uxtheme", loaded at 5AD70000h - 5ADA2000h
Symbol: "Ordinal46" (+00001545h)
Address: 7C809E01h, location: "kernel32", loaded at 7C800000h - 7C906000h
Symbol: "IsBadReadPtr" (+00000000h)
Address: 5AD88724h, location: "uxtheme", loaded at 5AD70000h - 5ADA2000h
Symbol: "Ordinal13" (+000012B7h)
Address: 5AD88738h, location: "uxtheme", loaded at 5AD70000h - 5ADA2000h
Symbol: "Ordinal13" (+000012CBh)
Address: 5AD90130h, location: "uxtheme", loaded at 5AD70000h - 5ADA2000h
Symbol: "Ordinal63" (+00000B1Bh)
Address: 5AD90B4Bh, location: "uxtheme", loaded at 5AD70000h - 5ADA2000h
Symbol: "DrawThemeText" (+000000BEh)
Address: 7740E359h, location: "COMCTL32", loaded at 773A0000h - 774A3000h
Symbol: "Ordinal384" (+000524B9h)
Address: 7740E5A9h, location: "COMCTL32", loaded at 773A0000h - 774A3000h
Symbol: "Ordinal384" (+00052709h)
Address: 7740E5CAh, location: "COMCTL32", loaded at 773A0000h - 774A3000h
Symbol: "Ordinal384" (+0005272Ah)
Address: 77412B26h, location: "COMCTL32", loaded at 773A0000h - 774A3000h
Symbol: "Ordinal384" (+00056C86h)
Address: 7C809E60h, location: "kernel32", loaded at 7C800000h - 7C906000h
Symbol: "IsBadReadPtr" (+0000005Fh)
Address: 7741318Ch, location: "COMCTL32", loaded at 773A0000h - 774A3000h
Symbol: "Ordinal384" (+000572ECh)
Address: 774134FAh, location: "COMCTL32", loaded at 773A0000h - 774A3000h
Symbol: "Ordinal384" (+0005765Ah)
Address: 77413588h, location: "COMCTL32", loaded at 773A0000h - 774A3000h
Symbol: "Ordinal384" (+000576E8h)
Address: 051B65D0h, location: "foo_ui_columns", loaded at 051B0000h - 05247000h
Address: 01900011h, location: "foo_managedWrapper", loaded at 01860000h - 01902000h
Address: 00473124h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 77D18830h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "GetDC" (+00000169h)
Address: 77D1882Ah, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "GetDC" (+00000163h)
Address: 77D1B89Bh, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "GetParent" (+0000016Ch)
Address: 773BAFF1h, location: "COMCTL32", loaded at 773A0000h - 774A3000h
Symbol: "Ordinal414" (+00000FB4h)
Address: 773BABE2h, location: "COMCTL32", loaded at 773A0000h - 774A3000h
Symbol: "Ordinal414" (+00000BA5h)
Address: 77D1BEFDh, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "InflateRect" (+00000000h)
Address: 77EF703Bh, location: "GDI32", loaded at 77EF0000h - 77F37000h
Symbol: "BitBlt" (+00000089h)
Address: 77EF7023h, location: "GDI32", loaded at 77EF0000h - 77F37000h
Symbol: "BitBlt" (+00000071h)
Address: 04434CA3h, location: "foo_oddcastv3", loaded at 04420000h - 044EF000h
Address: 77EF6E56h, location: "GDI32", loaded at 77EF0000h - 77F37000h
Symbol: "DeleteObject" (+00000229h)
Address: 77EF6F43h, location: "GDI32", loaded at 77EF0000h - 77F37000h
Symbol: "DeleteDC" (+000000ABh)
Address: 77D184FCh, location: "USER32", loaded at 77D10000h - 77DA0000h
Address: 77D185A4h, location: "USER32", loaded at 77D10000h - 77DA0000h
Address: 77D1D598h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DefWindowProcA" (+000000AAh)
Address: 77D18BD9h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "GetWindowThreadProcessId" (+00000159h)
Address: 77D70088h, location: "USER32", loaded at 77D10000h - 77DA0000h
Address: 77D1D5ACh, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DefWindowProcA" (+000000BEh)
Address: 77D1D559h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DefWindowProcA" (+0000006Bh)
Address: 77D40467h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DeregisterShellHookWindow" (+000001CFh)
Address: 77D1D560h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DefWindowProcA" (+00000072h)
Address: 77D3E545h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "EnumClipboardFormats" (+00000030h)
Address: 77D240B3h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "PrivateExtractIconExW" (+000001D8h)
Address: 77D3E54Fh, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DefDlgProcA" (+00000000h)
Address: 77D3E571h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DefDlgProcA" (+00000022h)
Address: 77D18734h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "GetDC" (+0000006Dh)
Address: 77D1885Ah, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "GetDC" (+00000193h)
Address: 04427FD0h, location: "foo_oddcastv3", loaded at 04420000h - 044EF000h
Address: 7C920732h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlAllocateHeap" (+0000015Eh)
Address: 7C91EE18h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "strchr" (+00000117h)
Address: 7C920738h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlAllocateHeap" (+00000164h)
Address: 7C9206ABh, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlAllocateHeap" (+000000D7h)
Address: 7C9206EBh, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlAllocateHeap" (+00000117h)
Address: 7C9205D4h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlAllocateHeap" (+00000000h)
Address: 77D1E905h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "CallWindowProcA" (+0000001Bh)
Address: 04436166h, location: "foo_oddcastv3", loaded at 04420000h - 044EF000h
Address: 04437D83h, location: "foo_oddcastv3", loaded at 04420000h - 044EF000h
Address: 04428132h, location: "foo_oddcastv3", loaded at 04420000h - 044EF000h
Address: 04439C4Ah, location: "foo_oddcastv3", loaded at 04420000h - 044EF000h
Address: 77414BDBh, location: "COMCTL32", loaded at 773A0000h - 774A3000h
Symbol: "CreateToolbar" (+00000037h)
Address: 77D1C63Fh, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "IsWindowUnicode" (+000000A1h)
Address: 044AADDCh, location: "foo_oddcastv3", loaded at 04420000h - 044EF000h
Address: 0445DD20h, location: "foo_oddcastv3", loaded at 04420000h - 044EF000h
Address: 04436276h, location: "foo_oddcastv3", loaded at 04420000h - 044EF000h
Address: 04462110h, location: "foo_oddcastv3", loaded at 04420000h - 044EF000h
Address: 044384A6h, location: "foo_oddcastv3", loaded at 04420000h - 044EF000h
Address: 7C9205C8h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlFreeHeap" (+0000018Bh)
Address: 7C920551h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlFreeHeap" (+00000114h)
Address: 7C92056Dh, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "RtlFreeHeap" (+00000130h)
Address: 0444058Dh, location: "foo_oddcastv3", loaded at 04420000h - 044EF000h
Address: 0443BFF4h, location: "foo_oddcastv3", loaded at 04420000h - 044EF000h
Address: 0443BE0Eh, location: "foo_oddcastv3", loaded at 04420000h - 044EF000h
Address: 0443CBD6h, location: "foo_oddcastv3", loaded at 04420000h - 044EF000h
Address: 77D18B26h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "GetWindowThreadProcessId" (+000000A6h)
Address: 77D188D1h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "GetWindowLongW" (+0000002Bh)
Address: 77D188DAh, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "GetWindowLongW" (+00000034h)
Address: 7C91DCDFh, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "ZwOpenEvent" (+0000000Ch)
Address: 05303FE7h, location: "foo_ui_panels", loaded at 05270000h - 0532D000h
Address: 0527416Ah, location: "foo_ui_panels", loaded at 05270000h - 0532D000h
Address: 05274100h, location: "foo_ui_panels", loaded at 05270000h - 0532D000h
Address: 77D18816h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "GetDC" (+0000014Fh)
Address: 77D189CDh, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "GetWindowLongW" (+00000127h)
Address: 77D1DAEAh, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DestroyWindow" (+00000000h)
Address: 77D2E04Ah, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "IsDialogMessageW" (+0000008Eh)
Address: 77D189F0h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "GetWindowLongW" (+0000014Ah)
Address: 77D18A10h, location: "USER32", loaded at 77D10000h - 77DA0000h
Symbol: "DispatchMessageW" (+0000000Fh)
Address: 0042FED3h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 10002DD2h, location: "shared", loaded at 10000000h - 10029000h
Symbol: "uCallStackTracker::uCallStackTracker" (+00000032h)
Address: 004C0510h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00430A19h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C07D0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C767Ch, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 014B9C28h, location: "foo_infobox", loaded at 01480000h - 014C0000h
Address: 00400000h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C7660h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C921596h, location: "ntdll", loaded at 7C910000h - 7C9C7000h
Symbol: "wcsncpy" (+00000B07h)
Address: 004E41C0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 010B1E6Fh, location: "foo_default_videoplayer", loaded at 010B0000h - 010BA000h
Address: 1000C391h, location: "shared", loaded at 10000000h - 10029000h
Version info:
foobar2000 v0.9.4
UNICODE
Additional info:
Default video player 0.1.2  (foo_default_videoplayer)
mslive 0.2  (foo_input_mslive)
Scheduler 3.52  (foo_scheduler)
Winamp API Emulator 0.90  (foo_winamp_spam)
Component Tutorial (Step 1) 0.3.1  (foo_tutorial1_step1)
Acro WMA decoder 0.1.5  (foo_input_awma)
Converter 1.0.1  (foo_converter)
Component Tutorial (Step 4) 0.3.1  (foo_tutorial1_step4)
Samurize Visualization Server (AMPI) 1.64  (foo_vis_samurize2)
Send to Device 1.0.5 [Nov 17 2006 - 14:16:40]  (foo_sendtodevice)
Audioscrobbler 1.3.4  (foo_audioscrobbler)
COM Automation server 0.7 alpha 6  (foo_comserver2)
Albumlist autoupdate 0.1  (foo_albumlist_autoupdate)
LPCM <--> delta-PCM converter 0.1.1  (foo_dsp_delta)
WMA Decoder 1.1  (foo_input_std)
AVS input 0.1  (foo_input_avs)
Component Tutorial (Step 2) 0.3.1  (foo_tutorial1_step2)
ReplayGain Scanner 2.0.2  (foo_rgscan)
Playback Statistics 1.3.2  (foo_playcount)
Track info panel 0.8  (foo_uie_trackinfo)
Special file info box 2.0.3  (foo_infobox)
RAR reader 1.1  (foo_unpack)
Component Tutorial (Step 3) 0.3.1  (foo_tutorial1_step3)
foo_managedWrapper 0.3  (foo_managedWrapper)
foo_lyricsdb 0.0.7 beta 4  (foo_lyricsdb)
Database Search Toolbar Demo 1.0  (foo_dbsearch_api_demo)
Lyric Show Panels 0.3.1.0  (foo_uie_lyrics)
Album Art Panel 0.2.1  (foo_uie_albumart)
PanelsUI 0.3.0 beta [Feb  9 2007 - 23:25:59]  (foo_ui_panels)
Playlist Tree Panel 2.2.4 [Nov 17 2006 - 16:34:17]  (foo_playlist_tree)
OddcastV3 3.x  (foo_oddcastv3)
FLAC decoder 1.1.0  (foo_input_std)
ZIP/GZIP reader 1.0  (foo_unpack)
foo_explorer 1.31  (foo_explorer)
Masstagger 1.6  (foo_masstag)
Default User Interface 0.9acc  (foo_ui_std)
Single Column Playlist Display 0.5.4 beta [Nov 24 2006 - 21:31:48]  (foo_uie_single_column_playlist)
Tabbed panel modifyed 0.2.1  (foo_uie_tabs)
projectM visualization (Panel) 0.4  (foo_uie_vis_projectm)
Queue manager panel 0.2.3  (foo_uie_queuemanager)
AC3 decoder 0.8  (foo_ac3)
foobar2000 core v0.9.4  (Core)
Album list panel 0.2.1 beta 4  (foo_uie_albumlist)
Album List 3.2.0  (foo_albumlist)
Samurize Info Server (AMPI) 1.64  (foo_info_samurize)
Autoplaylist Manager 1.0  (foo_autoplaylist)
Run services 0.3.2  (foo_run)
Music Browser 1.2.2c [Jul  6 2006 - 09:42:02]  (foo_browser)
Database Search 1.4 beta 4  (foo_dbsearch)
Dolby Headphone Wrapper 1.1  (foo_dsp_dolbyhp)
cwbowron's title format hooks 1.0.11b [Sep 27 2006 - 08:29:16]  (foo_cwb_hooks)
Winamp DSP Bridge 1.4.1  (foo_dsp_winamp)
Discogs Tagger 0.92  (foo_discogs)
Standard DSP array 1.0  (foo_dsp_std)
Audio CD Writer 2.0.1  (foo_burninate)
CD Audio Decoder 2.1.1  (foo_cdda)
Columns UI 0.1.3 beta 1v7  (foo_ui_columns)
Run Command 1.0 beta 2  (foo_runcmd)
Quick Search Toolbar 2.8k  (foo_uie_quicksearch)
Playlists Dropdown 0.5.7.5  (foo_uie_playlists_dropdown)
Dockable Panels 1.0.4 [Nov  8 2006 - 14:23:59]  (foo_dockable_panels)
foo_custominfo 0.1.2  (foo_custominfo)
Playlist tools 0.5.7  (foo_utils)
freedb Tagger 0.5.2a  (foo_freedb2)
ABX Comparator 1.3.1  (foo_abx)
Track info panel mod 0.7.1 beta [Nov 22 2006 - 03:51:45]  (foo_uie_trackinfo_mod)
Seek Remote Control 0.0.2  (foo_seek_remote)
Moderation: added codebox
foo_ui_panels
Reply #138
Stupid question maybe, but how do I change the background color on the trackinfo panel? Installing this made it black, and I can't get it to change back. Is there an undocumented variable or function that I'm missing somewhere? It's not on the wiki...
foo_ui_panels
Reply #139
$drawrect(0,0,0,0,brushcolor-rrrr-ggg-bbb pencolor-null)
elevatorladylevitateme
foo_ui_panels
Reply #140
Hey this is (almost) exactly what I requested for you to do with the track info mod ^__^!: My Post
I'm loving this component, and the way this is used is exactly one of the reasons I had brought it up (100% custom configs!).
AWESOME work . Good job once again man .
Song List: keikoniumboards.ke.funpic.org/files/songlist.html
foo_ui_panels
Reply #141
This is definitely the future of Foobar interface development!
Two requests/problems:
  • When anything, including playlist, has focus and I alt-tab away/back again, it has lost focus.  This also happens with internal pop-ups like preferences.
  • Would be nice to be able to right-click on Track Display/Album Art, etc., to configure them.  With multiple instances of each in the PanelUI control panel, it can be hard to pick the right one, especially since they seem to reorder randomly on start-up.
foobar2000 core 0.9.4.2
PanelsUI 0.4.2 beta [Feb 13 2007 - 10:11:21]
Album Art Panel 0.2.6
foo_ui_panels
Reply #142
hey guys, seems like i'm always behind, so i apologize if this sounds stupid.  is this all code based? i cant even figure out how to add another panel.  im in the settings under preferences, and i see the "available" panels, but can't add them.  thanks for any help
foo_ui_panels
Reply #145
just an FYI above or under the link u might want to make a note when u updated like (version x.xx.x date 2007) so when people have issues and u fix and upload a new version they know they have the latest
foo_ui_panels
Reply #146
i'm pretty new to tagz, could someone give me a basic code for the menu, buttons, and trackbar.  i can't figure out how to change background from black (including the background for menu, buttons etc).  basically so it looks like the default foobar.  thanks for putting up with me
foo_ui_panels
Reply #147
Hi.
Wiki
and 7 posts up.
Please read the available resource before asking questions. You'll actually get answers quicker!
If you really know very little about Title Formatting, the wiki has a nice intro.
foo_ui_panels
Reply #148
Is there a comprehensive guide to using PVARS anywhere?
I'd be kind of interested in this too.  I mean, is there any real difference between PVARS and regular variables except that PVARS can be accessed/changed in any part of PanelsUI (SCPL, Track Display, main config)?
the only difference is that the value of pvars are stored between different titleformatting runs, whereas regular variables aren't.
should be fixed with the new version.
no, track display should react to changes in pvars in any sections...
you should be able to use pvars for this.
Glad you found the problem.
hehe, never say never
I will need to look into #1, but #2 should be fixed in the new version.
I've uploaded a new version. This uses a different storage format, so your old settings won't show up. It should be relative easy to migrate over, though.
1) Make a copy of the PanelsUI config.
2) Install new version.
3) Start foobar, default configuration will show up. Enter your old PanelsUI config, then hit apply.
4) In the panels list there should be a list of loaded panels. Hit each one, then "Import" and import your settings from the old version (the files will be in your PanelsUI subfolder named "ID - Name").
5) Restart.
The above should work, but make a backup of all of your settings, just in case.
foo_ui_panels
Reply #149
I get this instead:
Illegal operation:
Code: C06D007Eh, flags: 00000000h, address: 7C812A5Bh
Call path:
entry=>user_interface::init
Code bytes (7C812A5Bh):
7C812A1Bh:  8B 45 0C 56 8B 75 14 83 E0 01 85 F6 89 45 B4 C7
7C812A2Bh:  45 BC 09 2A 81 7C 0F 84 99 00 00 00 8B 4D 10 83
7C812A3Bh:  F9 0F 0F 87 4D 1D 03 00 85 C9 89 4D C0 74 07 57
7C812A4Bh:  8D 7D C4 F3 A5 5F 8D 45 B0 50 FF 15 08 15 80 7C
7C812A5Bh:  5E C9 C2 10 00 85 FF 0F 8E 36 93 FF FF 8B 55 FC
7C812A6Bh:  89 55 0C 0F B7 16 8B 7D F8 8A 14 3A 88 11 8B 78
7C812A7Bh:  0C 0F B6 D2 66 8B 14 57 66 3B 16 0F 85 A3 89 03
7C812A8Bh:  00 8B 50 08 66 8B 5A 04 38 19 0F 84 A1 89 03 00
Stack (0012F834h):
0012F814h:  00ECD9C8 7C9C93C0 77F643DD 7C9C93C0
0012F824h:  00000004 00000000 00ECCED4 00000000
0012F834h:  03AEDFE0 C06D007E 00000000 00000000
0012F844h:  7C812A5B 00000001 0012F8AC 7C80E0AF
0012F854h:  0012F944 7C839AA8 7C80E058 FFFFFFFF
0012F864h:  7C801BF6 7C801D6E 7FFDFC00 00000000
0012F874h:  00000000 0012F894 7C801DA4 03AD8600
0012F884h:  00000000 0012F8F0 03AB8BA9 C06D007E
0012F894h:  00000000 00000001 0012F8FC 03B225A8
0012F8A4h:  00000000 03B22138 00000024 03AEDFE0
0012F8B4h:  03AF4210 03AD8600 00000001 03AEE02A
0012F8C4h:  00000000 00000000 0000007E 7C9106EB
0012F8D4h:  03ABA8AB 03AF4220 00000000 00000010
0012F8E4h:  03AEE048 00000000 00000000 0012F954
0012F8F4h:  03A9B491 00000000 0012F8AC 00000000
0012F904h:  0012F930 03A43CEE 00000000 0012F930
0012F914h:  18FD51C9 00000000 0012FA6C 00000040
0012F924h:  00000180 004DF59C 03B225A8 00000000
0012F934h:  00000000 00000000 00000000 00008000
0012F944h:  0012F994 03AD5C66 00000001 FFFFFFFF
Registers:
EAX: 0012F838, EBX: 00000000, ECX: 00000000, EDX: 00000000
ESI: 0012F900, EDI: 00000000, EBP: 0012F888, ESP: 0012F834
Crash location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "RaiseException" (+00000052h)
Loaded modules:
ntdll                            loaded at 7C900000h - 7C9B0000h
kernel32                        loaded at 7C800000h - 7C8F4000h
COMCTL32                        loaded at 773D0000h - 774D3000h
msvcrt                          loaded at 77C10000h - 77C68000h
ADVAPI32                        loaded at 77DD0000h - 77E6B000h
RPCRT4                          loaded at 77E70000h - 77F01000h
GDI32                            loaded at 77F10000h - 77F57000h
USER32                          loaded at 77D40000h - 77DD0000h
SHLWAPI                          loaded at 77F60000h - 77FD6000h
SHELL32                          loaded at 7C9C0000h - 7D1D5000h
ole32                            loaded at 774E0000h - 7761D000h
comdlg32                        loaded at 763B0000h - 763F9000h
IMM32                            loaded at 76390000h - 763AD000h
MSCTF                            loaded at 74720000h - 7476B000h
msctfime                        loaded at 755C0000h - 755EE000h
foo_browser                      loaded at 00A20000h - 00A5B000h
foo_cdda                        loaded at 00A60000h - 00A96000h
foo_converter                    loaded at 00AC0000h - 00B29000h
foo_cwb_hooks                    loaded at 00B50000h - 00B85000h
foo_discogs                      loaded at 00BB0000h - 00C22000h
gdiplus                          loaded at 4EC50000h - 4EDF3000h
WS2_32                          loaded at 71AB0000h - 71AC7000h
WS2HELP                          loaded at 71AA0000h - 71AA8000h
WINMM                            loaded at 76B40000h - 76B6D000h
serwvdrv                        loaded at 5CD70000h - 5CD77000h
umdmxfrm                        loaded at 5B0A0000h - 5B0A7000h
foo_dsp_std                      loaded at 00D10000h - 00D51000h
foo_input_std                    loaded at 00D80000h - 00E94000h
foo_masstag                      loaded at 00EC0000h - 00F10000h
foo_out_ks                      loaded at 00F30000h - 00F5A000h
SETUPAPI                        loaded at 77920000h - 77A13000h
foo_playcount                    loaded at 00F80000h - 00FA8000h
foo_queuemanager                loaded at 00FD0000h - 00FF8000h
mscorlib.ni                      loaded at 790C0000h - 79BA8000h
foo_rgscan                      loaded at 03530000h - 03578000h
foo_uie_playlists_dropdown      loaded at 03580000h - 035B9000h
foo_uie_queuemanager            loaded at 035D0000h - 03609000h
foo_uie_quicksearch              loaded at 038D0000h - 03917000h
foo_uie_tabs                    loaded at 03930000h - 0395A000h
foo_ui_columns                  loaded at 03980000h - 03A17000h
foo_ui_panels                    loaded at 03A40000h - 03B02000h
Msimg32                          loaded at 76380000h - 76385000h
imagehlp                        loaded at 76C90000h - 76CB8000h
DBGHELP                          loaded at 59A60000h - 59B01000h
VERSION                          loaded at 77C00000h - 77C08000h
Address: 03AEDFE0h, location: "foo_ui_panels", loaded at 03A40000h - 03B02000h
Address: 7C812A5Bh, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Address: 7C80E0AFh, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "DuplicateHandle" (+000002B1h)
Address: 7C839AA8h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "ValidateLocale" (+000002B0h)
Address: 7C80E058h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "DuplicateHandle" (+0000025Ah)
Address: 7C801BF6h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "LoadLibraryExW" (+00000105h)
Address: 7C801D6Eh, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "LoadLibraryExA" (+0000001Fh)
Address: 7C801DA4h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "LoadLibraryA" (+0000002Dh)
Address: 03AD8600h, location: "foo_ui_panels", loaded at 03A40000h - 03B02000h
Address: 03AB8BA9h, location: "foo_ui_panels", loaded at 03A40000h - 03B02000h
Address: 03AF4210h, location: "foo_ui_panels", loaded at 03A40000h - 03B02000h
Address: 03AEE02Ah, location: "foo_ui_panels", loaded at 03A40000h - 03B02000h
Address: 7C9106EBh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 03ABA8ABh, location: "foo_ui_panels", loaded at 03A40000h - 03B02000h
Address: 03A9B491h, location: "foo_ui_panels", loaded at 03A40000h - 03B02000h
Symbol: "foobar2000_get_interface" (+00033AE1h)
Address: 03A43CEEh, location: "foo_ui_panels", loaded at 03A40000h - 03B02000h
Address: 004DF59Ch, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 03AD5C66h, location: "foo_ui_panels", loaded at 03A40000h - 03B02000h
Address: 03A43DD0h, location: "foo_ui_panels", loaded at 03A40000h - 03B02000h
Address: 03AF1B44h, location: "foo_ui_panels", loaded at 03A40000h - 03B02000h
Address: 03ADF710h, location: "foo_ui_panels", loaded at 03A40000h - 03B02000h
Address: 03AD6AB8h, location: "foo_ui_panels", loaded at 03A40000h - 03B02000h
Address: 7C910570h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlFreeHeap" (+00000133h)
Address: 7C91056Dh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 03ABAD5Ah, location: "foo_ui_panels", loaded at 03A40000h - 03B02000h
Address: 03ABAD79h, location: "foo_ui_panels", loaded at 03A40000h - 03B02000h
Address: 03AC2E90h, location: "foo_ui_panels", loaded at 03A40000h - 03B02000h
Address: 03A412EDh, location: "foo_ui_panels", loaded at 03A40000h - 03B02000h
Address: 03A4F80Eh, location: "foo_ui_panels", loaded at 03A40000h - 03B02000h
Address: 03AD4A40h, location: "foo_ui_panels", loaded at 03A40000h - 03B02000h
Address: 03A4D08Fh, location: "foo_ui_panels", loaded at 03A40000h - 03B02000h
Address: 03A5C7EBh, location: "foo_ui_panels", loaded at 03A40000h - 03B02000h
Address: 03A4A09Dh, location: "foo_ui_panels", loaded at 03A40000h - 03B02000h
Address: 03ADF8F0h, location: "foo_ui_panels", loaded at 03A40000h - 03B02000h
Address: 03ADF760h, location: "foo_ui_panels", loaded at 03A40000h - 03B02000h
Address: 03AD6853h, location: "foo_ui_panels", loaded at 03A40000h - 03B02000h
Address: 03A4A47Ch, location: "foo_ui_panels", loaded at 03A40000h - 03B02000h
Address: 004DF484h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 03A42E00h, location: "foo_ui_panels", loaded at 03A40000h - 03B02000h
Address: 03A40000h, location: "foo_ui_panels", loaded at 03A40000h - 03B02000h
Address: 03ADF628h, location: "foo_ui_panels", loaded at 03A40000h - 03B02000h
Address: 03AD773Bh, location: "foo_ui_panels", loaded at 03A40000h - 03B02000h
Address: 004C4DA4h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00466542h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0042FB99h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004BC422h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0042E186h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004303BFh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00466449h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004ABF45h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00430BA2h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C70FCh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C910732h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 7C9105D4h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 7C911538h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "wcsncpy" (+00000AA9h)
Address: 7C90EE18h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 7C910738h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 7C911596h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 004E41B0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004B49D0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C917BF5h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlReAllocateHeap" (+000001F8h)
Address: 0044005Ch, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0041005Ch, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00440020h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 10003251h, location: "shared", loaded at 10000000h - 10029000h
Symbol: "uGetCallStackPath" (+00000451h)
Address: 004E3E80h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C9106F0h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+0000011Ch)
Address: 00491D18h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E4230h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0040CA96h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004480F4h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004990ADh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00496FE0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C0570h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 10002D87h, location: "shared", loaded at 10000000h - 10029000h
Symbol: "uPrintCrashInfo_SetDumpPath" (+000000A7h)
Address: 004AF5D4h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00430EFAh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E0928h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0049729Ah, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004935BCh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004935B6h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004B49E4h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004B34A0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E4228h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004AF9C8h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00496154h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00ECCDA4h, location: "foo_masstag", loaded at 00EC0000h - 00F10000h
Address: 7C816FD7h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "RegisterWaitForInputIdle" (+00000049h)
Address: 7C816FE0h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "RegisterWaitForInputIdle" (+00000052h)
Address: 004961BDh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E0049h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004F0044h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004B0063h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00410072h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004D002Eh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0044002Eh, location: "foobar2000", loaded at 00400000h - 004F3000h
Version info:
foobar2000 v0.9.4.2
UNICODE
Additional info:
Playlists Dropdown 0.6 alpha 3  (foo_uie_playlists_dropdown)
Kernel Streaming Output 1.2.2  (foo_out_ks)
Quick Search Toolbar 2.8j  (foo_uie_quicksearch)
foobar2000 core 0.9.4.2  (Core)
FLAC Decoder 1.1.0  (foo_input_std)
Tabbed panel modified 0.2.5  (foo_uie_tabs)
PanelsUI 0.5.0 beta [Feb 14 2007 - 21:37:52]  (foo_ui_panels)
Queue manager 0.1.1  (foo_queuemanager)
cwbowron's title format hooks 1.1.0beta [Dec  1 2006 - 13:47:34]  (foo_cwb_hooks)
