Originally posted by M "--nogap" denotes gapless encoding for a set of contiguous files (that is, files sent sequentially through the encoder). How long has this been in LAME? I've been told Blade already had something like this, but I had not read anything about LAME implementing it. Yes, BladeEnc has it for sometime now, but in Lame it's only half-backed at the moment. Last time I tried (3.90 alpha6) the VBR-header, that most players rely on for bitrate indication and seeking, was only present in the last file of the gapless sequence.This means - if it works properly - that I no longer need to encode an album as a single stream and split it; also, in RazorLame I should be able to visually arrange the files in their proper encoding sequence and they will *automatically* be gapless! Apparently one also must include the "--nogapout" switch to redirect gapless output to the proper path. I tried using RazorLame's internal redirect, and the files still wound up in the source directory. Is this a bug, or simply a necessary part of the gapless encoding mechanism? Well, RazorLame doesn't support -nogap at all. It starts the lame process separately for each file to encode. -nogap (as it is in the current state) needs the files, that must gaplessly encoded, together on one command line (though wildcards can be used also, if I remember correctly). --nogapout is needed because of the different input syntax. Hope this clears something up a bit. -- Ge Someone
