Topic: foobar 0.9 using far too much cpu (Read 8239 times) previous topic - next topic
foobar is using ~30-50% of my cpu when i'm listening to music.. i don't know what's causing it. here is a list of my loaded components (although i'm not experiencing crashes or anything, just high cpu consumption):
Core (2006-11-25 13:21:34)
    foobar2000 core 0.9.4.2
foo_albumlist.dll (2006-11-25 17:49:06)
    Album List 3.2.0
foo_audioscrobbler.dll (2006-09-14 00:20:40)
    Audioscrobbler 2.1
foo_cdda.dll (2006-11-25 13:19:46)
    CD Audio Decoder 2.1.1
foo_converter.dll (2006-11-25 13:20:00)
    Converter 1.0.1
foo_dsp_delta.dll (2006-03-21 18:16:22)
    LPCM <--> delta-PCM converter 0.1.1
foo_dsp_std.dll (2006-11-25 13:20:12)
    Standard DSP array 1.0
foo_freedb2.dll (2006-08-29 18:43:04)
    freedb Tagger 0.5.2a
foo_input_std.dll (2006-11-25 13:19:14)
    FLAC Decoder 1.1.0
    Standard Input Array 1.0
    WMA Decoder 1.1
foo_masstag.dll (2006-11-25 13:18:42)
    Masstagger 1.6
foo_playcount.dll (2006-09-16 17:55:54)
    Playback Statistics 1.3.2
foo_playlist_tree.dll (2006-11-17 16:34:38)
    Playlist Tree Panel 2.2.4 [Nov 17 2006 - 16:34:17]
foo_rating.dll (2006-12-10 04:22:22)
    foo_rating BETA 1.1
foo_rgscan.dll (2006-11-25 13:18:18)
    ReplayGain Scanner 2.0.2
foo_ui_columns.dll (2006-11-22 12:05:24)
    Columns UI 0.1.3 beta 1v7
foo_ui_std.dll (2006-11-25 13:18:12)
    Default User Interface 0.9acc
foo_uie_albumart.dll (2007-01-14 23:09:26)
    Album Art Panel 0.2.6
foo_uie_console.dll (2007-01-13 14:22:20)
    Console panel 0.2
foo_uie_example.dll (2007-01-13 14:22:16)
    Example Columns UI Panel 0.1
foo_uie_trackinfo.dll (2007-01-10 17:27:37)
    Track info panel 0.8
Any help would be greatly appreciated..
make sure your trackinfo is at 50000, 1, 50000 (default is 3000, 60, 3000)
try turning off album art display.
Thanks. The trackinfo thing fixed it.. Unfortunately I tried removing my album art panel first, and now I can't get it back -
for some reason, when I try to add an album art panel, foobar closes and an error message is displayed: "unhandled exception: dynamic_assert failure"
Any ideas on how to fix this?
That is a bug with the latest release of foo_uie_albumart.  I'm looking into it right now.
edit: okay, I think I've fixed the bug.  Please re-download the .dll from here.
Nice one. works perfectly. thanks!
I'm still having this problem.. Computer is, at times, running slower than it was with itunes in the background. My components:
http://pastebin.com/873175
It seems to occur whenever I do something like loading a large or complex page in firefox.. As if there's a memory leak occuring (like what happens with soulseek).
Anyone have any ideas?
Are you using Resampler ? Watch DSP plugin's menu, if SSRS or PPHS is Active, Disable it.
Then try move all non standart plugins to other folder (backup foobar folder and configuration file before doing that). Maybe one of plugins is problem of cpu using
I was just closing foobar in order to do that (move all the plugins out), and it crashed:
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 7C918FEAh
Access violation, operation: write, address: 00000010h
Call path:
Code bytes (7C918FEAh):
7C918FAAh:  0B 64 A1 18 00 00 00 0F B6 4D 0B 89 88 84 0F 00
7C918FBAh:  00 38 1D 30 C0 97 7C 0F 85 CC 04 00 00 A0 48 C1
7C918FCAh:  97 7C F6 D8 57 1B C0 F7 D0 25 40 C1 97 7C 8B F8
7C918FDAh:  8B 46 10 3B C3 89 45 FC 0F 84 9E 00 00 00 8B 06
7C918FEAh:  FF 40 10 8B 45 FC 83 E0 01 89 45 E8 8B 06 FF 40
7C918FFAh:  14 F6 05 F0 02 FE 7F 01 0F 85 E6 92 02 00 39 5D
7C91900Ah:  E8 57 53 0F 85 AC DE 01 00 FF 75 FC E8 99 59 FF
7C91901Ah:  FF 3D 02 01 00 00 0F 84 53 93 02 00 3B C3 0F 8C
Stack (055BFE14h):
055BFDF4h:  7C919B3F 7C97C0D8 7C919AEB 00B6296C
055BFE04h:  00BC3AF8 0000FFFF 7FFDD000 00254888
055BFE14h:  00000010 00BC23C0 00000000 00000000
055BFE24h:  00000010 055BFE44 004DE4B8 00010003
055BFE34h:  7FFDE000 7FFDB000 055BFE64 00000000
055BFE44h:  055BFDF4 FFFFFFFF 00000002 055BFDE8
055BFE54h:  055BFF1C 055BFEE8 7C839AA8 7C8095D8
055BFE64h:  FFFFFFFF 7C809512 7C80A075 00000002
055BFE74h:  055BFEFC 00000000 FFFFFFFF 00000000
055BFE84h:  0000000C 055BFEF4 7C90104B 00BC2418
055BFE94h:  00B4C5AD 00BC2418 CB5DC53B 0012F544
055BFEA4h:  0012F7C0 00BC3AF8 BADB0D00 00004B4F
055BFEB4h:  81AFD5B0 F8A11C88 00000000 00000002
055BFEC4h:  0000000F F8A11CA0 00BC5800 00000000
055BFED4h:  00000220 00000000 00000000 0000000F
055BFEE4h:  055BFE9C 055BFF9C 00B60178 FFFFFFFF
055BFEF4h:  F87C6540 055BF9C0 0000008C 00000090
055BFF04h:  055BFE7C 00BC23C0 00000006 00000008
055BFF14h:  00000006 00000044 504F5453 663D6320
055BFF24h:  000A6F6F 7C90EE18 0000000B 0000000F
Registers:
EAX: 00000000, EBX: 00000000, ECX: 0000000C, EDX: 00BC2428
ESI: 00BC2418, EDI: 00000000, EBP: 055BFE88, ESP: 055BFE14
Crash location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlpWaitForCriticalSection" (+0000005Bh)
Loaded modules:
foobar2000   loaded at 00400000h - 004F3000h
ntdll loaded at 7C900000h - 7C9B0000h
kernel32 loaded at 7C800000h - 7C8F4000h
COMCTL32 loaded at 773D0000h - 774D3000h
msvcrt   loaded at 77C10000h - 77C68000h
ADVAPI32 loaded at 77DD0000h - 77E6B000h
RPCRT4   loaded at 77E70000h - 77F01000h
GDI32 loaded at 77F10000h - 77F57000h
USER32   loaded at 77D40000h - 77DD0000h
SHLWAPI   loaded at 77F60000h - 77FD6000h
SHELL32   loaded at 7C9C0000h - 7D1D5000h
ole32 loaded at 774E0000h - 7761D000h
shared   loaded at 10000000h - 10029000h
comdlg32 loaded at 763B0000h - 763F9000h
uxtheme   loaded at 5AD70000h - 5ADA8000h
foo_dbsearch loaded at 009E0000h - 00A55000h
OLEAUT32 loaded at 77120000h - 771AC000h
foo_dbsearch_api_demo loaded at 00A80000h - 00AA2000h
foo_albumlist loaded at 00AD0000h - 00B17000h
foo_audioscrobbler   loaded at 00B40000h - 00B70000h
WS2_32   loaded at 71AB0000h - 71AC7000h
WS2HELP   loaded at 71AA0000h - 71AA8000h
foo_autoplaylist loaded at 00BD0000h - 00C00000h
foo_cdda loaded at 00C20000h - 00C56000h
foo_converter loaded at 00C80000h - 00CE9000h
foo_dsp_delta loaded at 00D10000h - 00D2E000h
foo_dsp_std   loaded at 00D50000h - 00D91000h
foo_freedb2   loaded at 00DC0000h - 00E00000h
foo_input_std loaded at 00E20000h - 00F34000h
foo_masstag   loaded at 00F60000h - 00FB0000h
foo_playcount loaded at 00FD0000h - 00FF8000h
foo_rating   loaded at 01020000h - 0104B000h
foo_rgscan   loaded at 01070000h - 010B8000h
foo_uie_albumlist loaded at 010E0000h - 0111D000h
foo_uie_console   loaded at 01140000h - 0115B000h
foo_ui_columns   loaded at 01180000h - 01217000h
foo_ui_std   loaded at 01240000h - 01297000h
gdiplus   loaded at 4EC50000h - 4EDF3000h
netapi32 loaded at 5B860000h - 5B8B4000h
appHelp   loaded at 77B40000h - 77B62000h
CLBCATQ   loaded at 76FD0000h - 7704F000h
COMRes   loaded at 77050000h - 77115000h
VERSION   loaded at 77C00000h - 77C08000h
shdocvw   loaded at 77760000h - 778CF000h
CRYPT32   loaded at 77A80000h - 77B14000h
MSASN1   loaded at 77B20000h - 77B32000h
CRYPTUI   loaded at 754D0000h - 75550000h
WINTRUST loaded at 76C30000h - 76C5E000h
IMAGEHLP loaded at 76C90000h - 76CB8000h
WININET   loaded at 771B0000h - 77256000h
WLDAP32   loaded at 76F60000h - 76F8C000h
spywareguard loaded at 22200000h - 2221F000h
MSVBVM60 loaded at 66000000h - 66155000h
SXS   loaded at 75E90000h - 75F40000h
Secur32   loaded at 77FE0000h - 77FF1000h
SASSEH   loaded at 05280000h - 05294000h
SETUPAPI loaded at 77920000h - 77A13000h
urlmon   loaded at 7E1E0000h - 7E280000h
mswsock   loaded at 71A50000h - 71A8F000h
DNSAPI   loaded at 76F20000h - 76F47000h
DSOUND   loaded at 73F10000h - 73F6C000h
WINMM loaded at 76B40000h - 76B6D000h
rasadhlp loaded at 76FC0000h - 76FC6000h
wdmaud   loaded at 72D20000h - 72D29000h
msacm32   loaded at 72D10000h - 72D18000h
MSACM32   loaded at 77BE0000h - 77BF5000h
midimap   loaded at 77BD0000h - 77BD7000h
KsUser   loaded at 73EE0000h - 73EE4000h
DBGHELP   loaded at 59A60000h - 59B01000h
Stack dump analysis:
Address: 004DE4B8h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C839AA8h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "ValidateLocale" (+000002B0h)
Address: 7C8095D8h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "WaitForMultipleObjectsEx" (+000000AEh)
Address: 7C809512h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "CreateFileMappingA" (+000000B6h)
Address: 7C80A075h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "WaitForMultipleObjects" (+00000018h)
Address: 7C90104Bh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlEnterCriticalSection" (+00000046h)
Address: 00B4C5ADh, location: "foo_audioscrobbler", loaded at 00B40000h - 00B70000h
Address: 00B60178h, location: "foo_audioscrobbler", loaded at 00B40000h - 00B70000h
Address: 7C90EE18h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "strchr" (+00000117h)
Address: 7C91056Dh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlFreeHeap" (+00000130h)
Address: 00B4E3F3h, location: "foo_audioscrobbler", loaded at 00B40000h - 00B70000h
Address: 00B4C8C9h, location: "foo_audioscrobbler", loaded at 00B40000h - 00B70000h
Address: 00B4FE0Ah, location: "foo_audioscrobbler", loaded at 00B40000h - 00B70000h
Address: 00B549C0h, location: "foo_audioscrobbler", loaded at 00B40000h - 00B70000h
Address: 00B4FEAFh, location: "foo_audioscrobbler", loaded at 00B40000h - 00B70000h
Address: 7C80B683h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "GetModuleFileNameA" (+000001B4h)
Address: 7C80B690h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "GetModuleFileNameA" (+000001C1h)
Address: 00B4FE30h, location: "foo_audioscrobbler", loaded at 00B40000h - 00B70000h
Address: 00BF73E0h, location: "foo_autoplaylist", loaded at 00BD0000h - 00C00000h
Address: 00BF7810h, location: "foo_autoplaylist", loaded at 00BD0000h - 00C00000h
Address: 00BF7728h, location: "foo_autoplaylist", loaded at 00BD0000h - 00C00000h
Address: 7C913917h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlEncodePointer" (+00000000h)
Address: 7C91393Dh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlDecodePointer" (+00000000h)
Address: 00440041h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 01080128h, location: "foo_rgscan", loaded at 01070000h - 010B8000h
Address: 00410003h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00440044h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 010801C4h, location: "foo_rgscan", loaded at 01070000h - 010B8000h
Version info:
foobar2000 v0.9.4.2
UNICODE
Additional info:
Database Search Toolbar Demo 1.0  (foo_dbsearch_api_demo)
LPCM <--> delta-PCM converter 0.1.1  (foo_dsp_delta)
WMA Decoder 1.1  (foo_input_std)
Audioscrobbler 2.1  (foo_audioscrobbler)
Columns UI 0.1.3 beta 1v7  (foo_ui_columns)
Playback Statistics 1.3.2  (foo_playcount)
Album list panel 0.2.1  (foo_uie_albumlist)
freedb Tagger 0.5.2a  (foo_freedb2)
CD Audio Decoder 2.1.1  (foo_cdda)
Masstagger 1.6  (foo_masstag)
Database Search 1.4 beta 4  (foo_dbsearch)
FLAC Decoder 1.1.0  (foo_input_std)
foobar2000 core 0.9.4.2  (Core)
Converter 1.0.1  (foo_converter)
foo_rating BETA 1.1  (foo_rating)
Default User Interface 0.9acc  (foo_ui_std)
Autoplaylist Manager 1.0  (foo_autoplaylist)
Standard DSP array 1.0  (foo_dsp_std)
Console panel 0.2  (foo_uie_console)
ReplayGain Scanner 2.0.2  (foo_rgscan)
Album List 3.2.0  (foo_albumlist)
Does that shed any light on the situation?
[!--sizeo:1--][span style=\"font-size:8pt;line-height:100%\"][!--/sizeo--]Edited by moderation: Changed CODE to CODEBOX.[/size]
I don't know .. Put all plugins and backuped foobar2000.cfg back to their folders and update all plugins to their newest versions. If it doesn't help, try download new foobar2000 and install to other folder (not on old foobar) and load it. And what Windows are you using ?
Windows XP SP2
Running clean Foobar doesn't help ?
I just installed a test version of foobar to c:\footest and accidentally deleted the old configuration (told it to not keep the configuration for missing components - i figured, since foobar boasts of being able to be installed multiple times, that this wouldn't affect my main bloody install). gotten it back to the way it was before, visually, but all of my fucking play counts are gone
i'm too pissed off with this thing at the moment and am considering returning to itunes - it might take up 3 times as much RAM but at least it doesn't slow my computer down like foobar does (or rather, like foobar's components do).
i'll post back here if i feel like continuing with foobar and am in a better mood later.
I figured, since foobar boasts of being able to be installed multiple times...
...with user profiles disabled...
That sucks, dude.
elevatorladylevitateme
That sucks, dude.
Hi. So I used a clean copy of foobar2000 and tested with this page:
http://www.foon.co.uk/farcade/avoision2
The "memory leak" usually happens when Firefox does something intensive so this is a good test. Foobar started acting up again, even though it was a clean version. I'm running on a 3ghz, 512MB RAM PC so playing a game like this shouldn't be any problem, but it is (as is watching videos on youtube).
Since this happened with a clean version of foobar, i'm beginning to wonder whether it's a firefox problem and not a foobar problem - although foobar's CPU usage did shoot up when I started playing this game. I'm on Firefox 2.0.0.1.
I really don't have a clue what to do :<
I can only say maybe there's something wrong with your computer setup and/or foobar itself. Computer uses up to date WinXP SP2 with latest foobar and latest components I can find too. Playing music in foobar and going around open your page, youtube, complicated page like gamespot.com with firefox in multiple tabs does nothing like that. CPU usage is about 0.75% every 3 to 5 secs. Computer set up: Core 2 Duo, 945G (on board video), 512M RAM.
Core (2006-11-25 20:21:34)
foo_albumlist.dll (2006-11-26 00:49:06)
    Album List 3.2.0
foo_autoplaylist.dll (2006-08-04 21:56:56)
foo_cdda.dll (2006-11-25 20:19:46)
foo_channel_mixer.dll (2007-01-08 15:54:04)
    Channel Mixer 0.9.5
foo_converter.dll (2006-11-25 20:20:00)
    Converter 1.0.1
foo_cwb_hooks.dll (2006-12-01 13:47:46)
    cwbowron's title format hooks 1.1.0beta [Dec  1 2006 - 13:47:34]
foo_dbsearch.dll (2007-01-25 21:58:48)
    Database Search 1.4
foo_dsp_std.dll (2006-11-25 20:20:12)
foo_freedb2.dll (2007-01-22 13:07:44)
foo_input_awma.dll (2006-11-17 00:43:46)
    Acro WMA decoder 0.1.6.2
foo_input_monkey.dll (2006-08-04 21:57:18)
    Monkey's Audio decoder 2.1.1
foo_input_ofr.dll (2006-06-26 19:13:24)
    OptimFROG Lossless/DualStream Decoder 1.21b
foo_input_std.dll (2006-10-14 21:09:58)
    FLAC Decoder 1.1.0
    WMA Decoder 1.1
foo_input_tta.dll (2006-05-01 23:53:16)
    TTA Audio Decoder (unofficial) 2.4.2
foo_masstag.dll (2006-11-25 20:18:42)
    Masstagger 1.6
foo_masstag_addons.dll (2006-10-15 09:59:42)
    Masstagger Addons 0.3.2
foo_menu_addons.dll (2007-01-24 03:42:12)
    Menu Addons 0.3.7c
foo_navigator.dll (2006-11-05 02:56:28)
    Navigator 0.6
foo_playlist_manager.dll (2007-01-22 13:05:12)
    Playlist Manager 1.0.2
foo_psf.dll (2007-01-24 07:01:04)
    Highly Experimental 2.0.5
foo_rgscan.dll (2006-11-25 20:18:18)
foo_sic.dll (2007-01-08 11:52:52)
    foosic music database 1.0 beta 12
foo_ui_columns.dll (2006-11-22 19:05:24)
foo_utils.dll (2007-01-22 13:05:00)
    Playlist Tools 0.5.9
Try update your system driver like chipset driver, video card, sound card etc.
    Album List 3.2.0
    Channel Mixer 0.9.5
    Converter 1.0.1
    Database Search 1.4
    FLAC Decoder 1.1.0
    WMA Decoder 1.1
    Masstagger 1.6
    Menu Addons 0.3.7c
    Navigator 0.6
Good idea but i'm afraid it didn't help
Just to disclaim myself - i'm not running an overloaded version of firefox either. No skins, and the only add-ons are the bare essentials:
Adblock Plus
British English Dictionary
Download Statusbar
I'll bump this one up. I just switched to vista and noticed foobar using up 5-20% of the CPU. I was using Br3tt's iPhone skin and quite a load of components, so I decided to reinstall, but surprisingly the problem's still the same. I am using Opera (  ), and when Opera is loading some page e.g. foobar hangs and I get sound glitches.
This Vista (x64) version is freshly set up, so I might raise the suspicion that there's something wrong with the core component? Everything else is working fine here.
I tried out (clean) 0.9.4.5 and 0.95b6. Same problem.
