Topic: Compiling (Read 5611 times) previous topic - next topic
Compiling
alright, i've been handed a code
#include "../SDK/foobar2000.h"
#include "../helpers/helpers.h"
Providing information about a component.
Viewed under Preferences > Components.
DECLARE_COMPONENT_VERSION(
// component name
"Playlist Context Menu Helpers",
// component version
"0.1.3",
// about text, use \n to separate multiple lines
// If you don't want any about text, set this parameter to NULL.
"Context menu playlist helpers\n"
"for foobar2000 v0.9\n"
"\n"
"contributors:\n"
"John Bell\n")
Component initialize and release
on_init is called after main window has been created,
on_quit is called before main window is destroyed
class initquit_foo_playlist_helpers : public initquit {
virtual void on_init()
// foobar2000 has a 'playing' playlist and an 'active' playlist
// force the playing playlist to "Now Playing"
static_api_ptr_t<playlist_manager> pm;
pfc::string8 playlist("Now Playing");
t_size play_ndx = pm->find_playlist(playlist, playlist.length());
pm->set_playing_playlist(play_ndx);
//pm->playback_order_set_active(0); //resets the order to start at the top
//virtual void on_quit() {}
static initquit_factory_t< initquit_foo_playlist_helpers > foo_initquit;
Context menu item implementations
class contextmenu_commands_foo_playlist_helpers : public contextmenu_item_simple
enum menu_index {
mnuSendToNowPlaying,
mnuAppendToNowPlaying
virtual unsigned get_num_items() {
return 2;
virtual GUID get_item_guid(unsigned p_index) {
static const GUID guid_context_send_to_now_playing = { 0xd3499f7c, 0xebf3, 0x4d98, { 0x94, 0xaf, 0x36, 0x5a, 0x95, 0x5d, 0x12, 0x2c } };
static const GUID guid_context_append_to_now_playing = { 0x6afbf8c0, 0x828f, 0x4d06, { 0xa4, 0x96, 0xa2, 0x39, 0x76, 0xe8, 0x6b, 0x8e } };
if( p_index == mnuSendToNowPlaying )
return guid_context_send_to_now_playing;
else if( p_index == mnuAppendToNowPlaying )
return guid_context_append_to_now_playing;
return pfc::guid_null;
virtual void get_item_name(unsigned p_index,pfc::string_base& p_out) {
p_out = "Send to Now Playing";
p_out = "Append to Now Playing";
virtual void get_item_default_path(unsigned p_index,pfc::string_base& p_out) {
p_out = "";
p_out = "";
virtual bool get_item_description(unsigned p_index,pfc::string_base& p_out) {
if( p_index == mnuSendToNowPlaying ) {
p_out = "Clears the Now Playing playlist and then sends the selected item(s) to the Now Playing playlist";
return true;
else if( p_index == mnuAppendToNowPlaying ) {
p_out = "Appends item(s) to the Now Playing playlist";
return true;
return false;
virtual void context_command(unsigned p_index,const pfc::list_base_const_t<metadb_handle_ptr>& p_data,const GUID& p_caller) {
if( core_api::assert_main_thread() )
if( p_index == mnuSendToNowPlaying || p_index == mnuAppendToNowPlaying )
pfc::string8 playlist("Browser");
t_size browser_ndx = pm->find_playlist(playlist, playlist.length());
playlist = "Now Playing";
metadb_handle_list list;
pm->playlist_get_selected_items(browser_ndx, list);
pm->playlist_clear(play_ndx);
pm->playlist_add_items(play_ndx, list, bit_array_false());
// We need to create a service factory for our menu item class,
// otherwise the menu commands won't be known to the system.
static contextmenu_item_factory_t< contextmenu_commands_foo_playlist_helpers > foo_menu;
how do i turn this into a .dll
Compiling
thanks
ive got microsoft visual basic... hopefully itll work.
Compiling
okay... i have no idea what im doing.
Compiling
Disappointingly, the code snippet you posted isn't written in Visual Basic, so the Visual Basic compiler may be slightly confused.  It's written in C++ using the foobar2000 SDK.  Maybe you should look at the step-by-steps in the forum sticky?
EDIT:  That was a good guess.
Compiling
yea, i looked at the wikis about BASIC and C++, and basic looked a little closer to the code i had because of the $s and things
but C++ had the brackets and visual layout that was more similar
eh, hopefully itll work now (its installing)
Compiling
alright, it cant find ...\my documents\visual studio 2005\projects\foo_nowplaying\foo_nowplaying\foo_nowplaying.h
what do i do from here?
Compiling
You know what, I have some free time on my hands, so I'll try it out (I haven't used the FB2K SDK before) and get back to you.
Compiling
thanks, man.
Compiling
It was pretty easy for me to figure out (using Visual Studio 2005 with the SDK) but it would be nigh-impossible if you have never used VS2005 before and have no programming experience, so if you are really dedicated to doing it I hope you have plenty of time to learn.
Anyway, here's a DLL of that source (credit due to this guy, I believe) which works on my machine, FB2K 0.9.4.1.  Let me know if you have problems with it.
Compiling
Sorry to step in.
FB 0.9.4.2
I can see the two context menu commands but it seems they don't work.
Compiling
Sorry to step in.
FB 0.9.4.2
(I didn't actually test it, so beats me whether it works right, I just saw that it shows up and the context menu items are added.  Better take it up with that guy in the other thread if it doesn't work : )
EDIT:  Reading the source code, I noticed that the source playlist is hard-coded to "Browser" - that is, the context menu items won't do anything unless you are on a playlist named "Browser", in which case they will send your selected tracks on "Browser" to a playlist called "Now Playing", if it exists.  Maybe that's what your problem is.
Compiling
i have a shitload of computer experience in just about everything except hard coding (from visual to audio to http)
i can get up to where it can't find the .h, but i guess i'd need the SDK from the main foosite?
whatever, i'll see if yours works.
yea, it seems to work
