Topic: sorting artists with 'the' at beginning (Read 28385 times) previous topic - next topic
can this be done in the filter view as well?
I had the same need, but I also wanted to have surnames in front of first names for sorting, e.g. "Dylan, Bob" instead of "Bob Dylan". My only solution so far is to use a ARTIST SORTNAME meta field (like proposed by musicbrainz, if I remember correctly). For "The" bands I can fill ARTIST SORTNAME easily with the swapprefix command.
That's impossible to achieve automatically, since FB2K doesn't see name and surname, but a series of words. It would be very simple if all your artists have one word for name and one word for surname, but that's not the totality of the possibilities.
But since this is the majority, you could set a script for this type of artists to fill ARTIST SORTNAME, and then manually fill the field for the remaining ones.
I'm new at this, but I believe you could also select all your tracks, go to Properties, select %artist% and right-click to Edit, CTRL-A to select all, and paste into Excel.  This will create a one column display of all your artists.  Then you can use Excel functions to create your LAST, FIRST protocol and when this is done for all artists and in one column, copy the column.  Back in foobar, go back to Properties, add a field called ARTIST SORTNAME or whatever, right-click it and choose Automatically Fill Values.  Select "Clipboard: Line Per Track" from "Source" and type in %ARTIST SORTNAME% in Pattern.  As long as your selection for Properties is exactly the same as it was when you copied out the %artist% field, everything should match up.  If something goes wrong, you could just remove or clear the field and try again.
I might give this a shot.
That's the same reason I found this post. Anyone? The playlist view in columns UI already organizes things fine, but anything that starts with "The" gets sorted into the T's in filter view, which seems like a huge oversight. I can't see a way to modify how the filters sort, I just started trying out foobar2000 today.
Re: sorting artists with 'the' at beginning
Any ideas how it is possible to expand this:
$if($stricmp($left(%album artist%,4),'The '),
$right(%artist%,$sub($len(%album artist%),4))', The'
[%album artist%]
so that "Die" or "Das", for german bands, also moved to the end of the name?
[%album artist%]
Use the $swapprefix function:
$swapprefix(%album artist%,The,Die,Das)
I'm late
Works nicely. Thank you very much!
I also would like see this sorting over UPnP.  ;)  Do you know how the Media Libery Tree must be edited for this?
"The" and "A" is no problem, because Foobar already has a swap option for this in artist names under the UPnP/Server/Contents section. But of course there is nothing for "Die" or "Das"
Reply #32
Yes, I'm using Foobar also as Media Server.
As I recall you can edit '<foobar2000 directory>\foo_upnp_ml_tree.xml' to dictate what is shown in the (upnp) library tree.
Reply #34
I'm not familiar with the structure of the libary tree xml.  The question is were and how to add the right lines.
I'm so disangeged to post my libary tree here ;) I hope someone could help me:
<MediaLibraryTree>
   <SubTree label="Albums">
      <spec type="object.container.album.musicAlbum">%album%[ '['%album artist%']']</spec>
   </SubTree>
   <SubTree label="Artists">
      <spec type="object.container.person.musicArtist">%artist%</spec>
      <spec type="object.container.album.musicAlbum">%album%</spec>
   </SubTree>
   <SubTree label="Album Artists">
      <spec type="object.container.album.musicAlbum">[%album artist% - ]['['%date%']' ]%album%</spec>
   </SubTree>
   <SubTree label="Genres">
      <spec type="object.container.genre.musicGenre">%&lt;genre&gt;%</spec>
      <spec type="object.container.album.musicAlbum">[%album artist% - ]%album%</spec>
   </SubTree>
   <SubTree label="Years">
      <spec>%date%</spec>
   </SubTree>
   <SubTree label="Compilations" query="compilation PRESENT">
   </SubTree>
   <SubTree label="Codecs">
      <spec>%codec%</spec>
   </SubTree>
   <SubTree label="Folders" type="filesystem"/>
   </SubTree>
   <SubTree label="Label">
      <spec>%publisher%</spec>
</MediaLibraryTree>
I also tried before to add the "Label" entry, but it isn't working :(
Reply #35
Ever listened to Therion?
Lepaca \m/
Reply #37
Thanks, marc2003!
I closed it with that line and I also changed %publisher% to %<publisher>%. But this whole entry still won't appear at my Pioneer.  :(
Any ideas how I could use this swapperprefix line from davideleo here too?
