Topic: compress with lpac using EAC? (Read 6448 times) previous topic - next topic
How do I set up EAC to compress with lpac?
I want to use the following commands:
-n -5  -c -v
Thanks,
Jan.
choose user defined encoder, set extension to pac and write in the additional commandline field %s %d <commands>. If this doesn't work change the order of the %s %d to %d %s. One of those both settings should work!
well it doesn't work... dumb me:D
[edit]
this does it:
-n -5 -c -v %d %s
Yes that seems to work.
I thought I did try that but apparently I didn't.
Thanks!!
Jan.
Actually theres a few problems with that in theory at least.
The proper command line would be: -5 -c -v %s %d
I'd go ahead and add the -r for random seeking too.  You don't need the -n because EAC implicitly gives it an ouput path.  Make sure you put .pac as the extension, and uncheck the Add ID3 Tag as well, since lpac does not support them.
I don't need -r bacause it is jist for storing untill I compress with mpc.
I knew that -n was probably not needed but I semed to get in trouble if I removed it with my first attempts.
Thanks,
Jan.
