Topic: Runtime Error! (Read 2898 times) previous topic - next topic
Runtime Error!
allways when i play music for more than about 30 minutes i get the same 3 messages about an runtime error when i close foobar2000
Warning
metadb_handle leaks: 1 objects
OK
Microsoft Visual C++ Runtime Library
Runtime Error!
Program: D:\Programme\foobar2000\foobar2000.exe
R6025
- pure virtual function call
OK
foobar2000.exe - Fehler in Anwendung
Die Ausnahme "unknown software exception" (0x40000015) ist in der Anwendung an der Stelle 0x011f77ad aufgetreten.
Klicken Sie auf "OK", um das Programm zu beenden.
OK
is there the posibility to check which dll-file could cause the error cause i dont want to remove one - play music for 30 minutes - check if it crashes - insert the dll-file and remove another...
it's no error of windows cause i have reinstalled windows today and the error was before and after.
is a listing of installed components interesting or the file failure.txt?
Runtime Error!
The listing of components please, but I think you should post failure.txt too. BTW older foo_infobox and/or unofficial foo_playcount (maybe only older version I'm not sure because I use the official one now) can cause this.
