Topic: FLAC 1.13 transcode bug? (Read 6277 times) previous topic - next topic
I'm not totally shore this is a bug.
But I think it is unwanted behavior when transcoding corrupted FLAC files.
After an error message the so far created temp file will be renamed to the original FLAC file.
In this case all the date after a corruption is lost.
To reproduce this, modify one or more byte(s) somewhere in the middle of a FLAC file with a hex editor.
Here are the screenshots with and without the –verify option:
flac.exe -5 --force test.flac
flac 1.1.3, Copyright © 2000,2001,2002,2003,2004,2005,2006  Josh Coalson
flac comes with ABSOLUTELY NO WARRANTY.  This is free software, and you are
welcome to redistribute it under certain conditions.  Type `flac' for details.
test.flac: 59% complete, ratio=0.991test.flac: ERROR got FLAC__STREAM_DECODER_ER
ROR_STATUS_FRAME_CRC_MISMATCH while decoding FLAC input
flac.exe -5 --force --verify test.flac
In both cases all the data after the corruption is lost.
Here is a workaround that I use to transcode:
for %%i in (*.flac) do (D:\Console\flac.exe --test "%%i" & if errorlevel 1 pause)
D:\Console\glob.exe -c D:\Console\flac.exe -5 --force *.flac
